Valvontakamera kotiin
Haussa kamera, jolla voisi ikkunan läpi katsoa, kuka soittaa ovikelloa.
Akkukäyttöinen
Mielellään toimisi lokaalisti ja olisi helppo yhdistää HA:han
Tuo ovikellon liipaisu tapahtuisi zigbeen kautta eli tuohon kameraan riittäisi vain jos sillä saisi wifin kautta kuvan HA:han.
Pitääpä kurkata noi kuhan kotia pääsee.
Olihan siellä erroria vaikka kuinka.
Koodi:
[2023-03-15 18:53:08] frigate.video                  ERROR   : Kuisti: Unable to read frames from ffmpeg process.
[2023-03-15 18:53:08] frigate.video                  ERROR   : Kuisti: ffmpeg process is not running. exiting capture thread...
[2023-03-15 18:53:18] watchdog.Kuisti                ERROR   : Ffmpeg process crashed unexpectedly for Kuisti.
[2023-03-15 18:53:18] watchdog.Kuisti                ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : Guessed Channel Layout for Input Stream #0.1 : mono
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : [segment @ 0x55c5f7804d80] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : [segment @ 0x55c5f7804d80] Non-monotonous DTS in output stream 0:0; previous: 0, current: 0; changing to 1. This may result in incorrect timestamps in the output file.
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : [swscaler @ 0x55c5f7eb4400] deprecated pixel format used, make sure you did set range correctly
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : [h264 @ 0x55c5f7455e40] error while decoding MB 72 43, bytestream -6
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : [NULL @ 0x55c5f7384c80] missing picture in access unit with size 88704
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : "KAMERAN TIEDOT": corrupt decoded frame in stream 0
[2023-03-15 18:53:18] ffmpeg.Kuisti.detect           ERROR   : [segment @ 0x55c5f7804d80] Non-monotonous DTS in output stream 0:0; previous: 2538296083, current: -830103483316929823; changing to 2538296084. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:27] frigate.video                  ERROR   : Etupiha: Unable to read frames from ffmpeg process.
[2023-03-27 18:16:27] frigate.video                  ERROR   : Etupiha: ffmpeg process is not running. exiting capture thread...
[2023-03-27 18:16:34] watchdog.Etupiha               ERROR   : Ffmpeg process crashed unexpectedly for Etupiha.
[2023-03-27 18:16:34] watchdog.Etupiha               ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3059799, current: 3059799; changing to 3059800. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3059800, current: 3059800; changing to 3059801. This may result in incorrect timestamps in the output file.
[2023-03-27 12:27:11] frigate.record                 ERROR   : Unable to store recording segment /tmp/cache/Kuisti-20230327122659.mp4
[2023-03-27 12:27:11] frigate.record                 ERROR   : [Errno 28] No space left on device: '/tmp/cache/Kuisti-20230327122659.mp4' -> '/media/frigate/recordings/2023-03/27/12/Kuisti/26.59.mp4'
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3072055, current: 3072055; changing to 3072056. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3072056, current: 3072056; changing to 3072057. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3072057, current: 3072057; changing to 3072058. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3072058, current: 3072058; changing to 3072059. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3072583, current: 3072583; changing to 3072584. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3075938, current: 3075938; changing to 3075939. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3075939, current: 3075939; changing to 3075940. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3075940, current: 3075940; changing to 3075941. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3075941, current: 3075941; changing to 3075942. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3077423, current: 3077423; changing to 3077424. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3077424, current: 3077424; changing to 3077425. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3077425, current: 3077425; changing to 3077426. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3077426, current: 3077426; changing to 3077427. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3077965, current: 3077965; changing to 3077966. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3077966, current: 3077966; changing to 3077967. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 3638828, current: 3638828; changing to 3638829. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 7327753, current: 7327753; changing to 7327754. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Non-monotonous DTS in output stream 0:0; previous: 8149935, current: 8149935; changing to 8149936. This may result in incorrect timestamps in the output file.
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [h264 @ 0x55afb178eec0] error while decoding MB 110 10, bytestream -5
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [segment @ 0x55afb15f87c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : [h264 @ 0x55afb1780ac0] error while decoding MB 88 59, bytestream -5
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   : rtsp://192.168.101.101:554/11: corrupt decoded frame in stream 0
[2023-03-27 18:16:34] ffmpeg.Etupiha.detect          ERROR   :     Last message repeated 1 times
[2023-03-27 18:19:33] frigate.video                  ERROR   : Kuisti: Unable to read frames from ffmpeg process.
[2023-03-27 18:19:33] frigate.video                  ERROR   : Kuisti: ffmpeg process is not running. exiting capture thread...
[2023-03-27 18:19:39] watchdog.Kuisti                ERROR   : Ffmpeg process crashed unexpectedly for Kuisti.
[2023-03-27 18:19:39] watchdog.Kuisti                ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
[2023-03-27 18:19:39] ffmpeg.Kuisti.detect           ERROR   : Guessed Channel Layout for Input Stream #0.1 : mono
[2023-03-27 18:19:39] ffmpeg.Kuisti.detect           ERROR   : [segment @ 0x557d9c519280] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[2023-03-27 18:19:39] ffmpeg.Kuisti.detect           ERROR   : [segment @ 0x557d9c519280] Non-monotonous DTS in output stream 0:0; previous: 0, current: 0; changing to 1. This may result in incorrect timestamps in the output file.
[2023-03-27 18:19:39] ffmpeg.Kuisti.detect           ERROR   : [swscaler @ 0x557d9d031b80] deprecated pixel format used, make sure you did set range correctly
[2023-03-27 18:19:39] ffmpeg.Kuisti.detect           ERROR   : [segment @ 0x557d9c519280] Non-monotonous DTS in output stream 0:0; previous: 3081207524, current: -830103483316929823;
Eli tuolla nyt ainakin tuo tmp errori minkä nyt sain ainakin kuntoon. Katsotaan nyt tämä ilta tekeekö se vielä noita muitakin erroreita.
Edit. Frigatesta on vissiin jo vähän uudempaa versiota tullut kuin mitä mulla on käytössä. En nyt pikaisella googlauksella keksinyt miten tuon päivittäisi uusimpaan versioon?
Koodi:
Näytti tosiaan olevan ainakin levytila, se saattaa kyllä aiheuttaa muutakin.
Tosin näyttää siltä että kamera ei lähetä ihan kunnollista videota, voi johtua kamerasta tai ehkä yhteydestä.
Itsellä pari vanhaa hikvisionia päätyi vastaaviin stream- virheisiin muutaman päivän päällä olon jälkeen. En jaksanut kaivaa tarkemmin vaan vaihdoin uudempiin.
Päivityksestä virtuaalissa en osaa sanoa, ehkä vaan config talteen ja uuden asennus+config palautus.
Dockerilla helppoa kun config ja mediat on kontin ulkopuolella niin kontin voi aina tehdä uusiksi.
Jossain versiossa config muuttui, kannattaa varmistaa
No toinen noista mun kameroista ois aika vanha, en osaa sille edes ikää sanoa, mutta veikkaisin vähintään 6 vuotta.
Dockerissa mulla tuo pyörii. Pitää ettiä tuohon päivitykseen liittyen materiaalia kun ei noita ole tarvinnut tehdä.
Kysymykseni ei koske varsinaisia valvontakameroita, vaan, mistä saisi suht edullisesti linnunpönttökameran? voiko tuollaisen jotenkin värkätä itse?
Dockerilla asetukset ja media pitäisi olla kontin ulkopuolella.
Riittää että poistaa kontin ja tekee uuden samalla komennolla kuin alkuperäisen (olettaen että image ei osoita tiettyyn versioon). Jos olet seurannut frigaten ohjetta niin sitten toimii.
No nytpä on uusin versio sisällä. Piti vaihtaa tuo image tuohon, niin sai uudemman version.
Marraskuussa latasin kamerat ja etupihan kamerassa 48% ja takapihan 42% akkua jäljellä eli todella hyvin pärjää yhdellä latauksella talven yli.
Mä joudun lataa 2krt/v. Eli koht puoliin lataan ja ennen lumien tuloa uudestaan, koska pitää tikapuilla ottaa kamerat alas.
Määrittelin Reolinkin RLC-410W-kameran lähettämään tallenteen FTP-palvelimelle. Lähettäminen on toiminut hyvin, mutta ongelma on se, että FTP-videoista karsiutuu varsinainen tallennuksen aiheuttanu liike pois. Esimerkiksi nyt viikonloppuna oli tippunut katolta lumet kello 16:43:26. Muistikortille tallentuneessa videossa näkyy koko tapahtuma, mutta FTP-palvelimelle lähetetyssä videossa ei näy mitään liikettä.
SD-kortilla oleva tallennus alkaa 16:43:11 ja FTP:llä 16:43:27.
Edit:
Juuri, kun kehiun, että videoiden lähettäminen FTP-palvelimelle on toiminut hyvin, niin huomasin, että kaikkia videoita ei FTP-palvelimenta löydykään. Logien mukaan kameran on kirjautunut palvelimelle, mutta ei ole lähettänyt mitään.
Edit 2:
FTP-tallennus on aivan erillinen toiminto. Ei vaadi muistikorttia lainkaan. Nettiyhteyden pitää olla siis hyvä. Muistikortille tallennettaessa toimi Pre-record, joka tallentaa videota myös ennen varsinaista liikkeen havaitsemista. Tätä ominaisuutta ei FTP-tallennuksessa ole.
Mulla etupihan pari kameraa latasin 4 kk kohdalla. Toisessa oli 20 % (kauimmaisin ja heikoin signaali) ja toisessa kolkytjotain 4 kk käytön jälkeen. Lapset leikkii etupihalla ja paljo suhaamista... Takapihan kamera 4 kk 10 d jälkeen 83 % (keskusyksikkö about ikkunan takana). Se on selkeesti lähimpänä kestävin :D
Valvontakamera haussa takapihalle, lähinnä valvomaan aina mitä koira puuhaa.
Vaatimukset:
-Wifi
-Hinta alle 150 euroa
-Ilmainen android softa, jolla seurata livenä kuvaa
-PTZ-kamerasta plussaa
Reolink E1 miettinyt. Onko muita hyviä?
Vaatimukset:
-Wifi
Odota, että tätä saa taas 199 € niin saat 2 kpl EZVIZ BC1 WIFI VALVONTAKAMERA 2 KPL - Power.fi ja välillä myös Telialla alessa mut sinne et voi palauttaa huvikseen jos ei miellytä - miksei miellyttäisi.
Vaatimukset:
-Wifi
Olisko täs vaihtoehto?
Miten hyvin noissa akkumalleissa tuo akku käytännössä kestää, jos toisinaan haluaa sitä livekuvaa seurata puhelimesta?
Kyllä eri virranhallintatiloja on. Mulla on BC1 virransäästötila päällä eli minuutin liveä ja sit kysyy et haluaako jatkaa. Uskon et tossa olis sama. Parhaalla asetuksella varmaan voi kokoajan.
Edit: Screenshot_20230411-183306.png
Täällä eufyn 2C kamerat, jotka lupaavat puolen vuoden kestoa, mutta omassa käytössä kaikki ovat kestäneet melkein vuoden tai yli. Aktiivisin piti ladata 9kk jälkeen. Ajoittain liveseuraaminen kuulunut myös omaan käyttöön.
Kato pari viestiä ylemmäs mun postaus. Kattelen joka päivä kerran-pari. Mulla täyslaatu päällä ja ei mitään säästöjä.
itsellä myös kyseiset kamerat ja muuten kyllä loistavat kamerat mutta lähettimen ja kameran välinen kantomatka on todella onneton vrt vaikka xioamin edullisiin outdoor kameroihin
Kyllä nuo 164 m2 omakotitalossa just ja just riittää, mutta ei se kantama mikään superjuhlava ole. Itsellä olis laatikossa toinen keskusyksikkö jos haluais parantaa kantamaa (vaikka sähköverkon range extenderillä ja toisen yksikön perään puolet kameroista), mutta hyvin nuo on toimineet yhdenkin perässä vaikka 2/4 kamerasta "heikko signaali". Tosiaan kauimmainen kamera on naapuritalossa asuvilla vanhemmillani etuovella joten mahtuu siihen metrejä ja seiniä väliin.
Onko kokemusta mikä ohjelma olisi kätevä tallennettujen videotiedostojen analysointiin? Videot tulevat kameroilta FTP-palvelimelle omiin kansioihin ja noiden kansioiden videotiedostoja olisi kiva analysoida. Esim. etsiä henkilöitä, autoja, eläimiä...
Testailin YOLOv5:sta tallenteiden analysointiin. Vaikutti toimivalle, mutta pitäisi kirjoittaa skriptit, jotka käyvät FTP:lle tallennetut videot läpi, kirjoittaa tagit esim. tiedostoon ja poistaa videot. joissa ei esim. ajoneuvoja, ihmisiä tai eläimiä löydy.
Tämän päivän paras tallennus ohjelmisto, windows ympäristö ja 4-5 Boschin IP-kameraa?
Lokaali tallennus, mutta meilihälyt pitää löytyä, samoten hälyt kuvasta vain määrätyltä alueelta tapahtuvasta liikkeestä... osaa edes tarkempaa vaatimuslistaa laittaa kun on aikasta tuntematon aihe itselle :)
Jos open source/muu ilmainen löytyy, aina parempi. Jos maksullinen, one time fee parempi kuin kk maksullinen.
Googlella ihan liikaa vaihtoehtoja edes speksien vertaamiseksi...
Blue Iris ja CodeProject.AI saa tehtyä kohtalaisen helposti melkein mitä vaan:
Itse käytän agentDVR:ää: klik
Yksityiskäytössä ilmainen. Toimii ok, mutta linuxilla ei valitettavasti saa nassi tallennusta.
Tätä itseasiassa hyvin pikaisesti testasin, asennus ja kameran kuvan sain ruudulle. Mutta sen enempää en ole ehtinyt perehtymään.
Missään ei oikein tunnu selkeästi lukevan, että onko tuossa ilmaisversiossa jotain rajoituksia vs. maksullinen?
Ja tähän ei taida olla Android äppiä, jos jotain push-ilmoja haluaisi saada kameran aktivoitumisesta..
Kyllä se tuolla sivuilla on mainittu, mutta ei mitenkään selkeästi:
SSL secured web access, SMS, Twitter, email alerts, mobile device access, cloud uploads, Virtual Reality and other services that use our online platform require a subscription or an annual payment.
En sitten tiedä mitä noilla email alertseilla tarkoitetaan tuossa, koska kyllä ne minulla toimii normaalisti.
Ja tuolla mobile device accessilla varmaan tarkoitetaan jotain mobile appia. Tähän en ole perehtynyt sen enempää kun en itse sitä tarvitse. Riittää että heitän puhelimesta L2VPN päälle ja avaan nettisivun mistä voin noita omia kameroita vilkuilla vaikka maailman toiselta puolelta.
Edit:
Löytyhän sieltä tällainen:
Connect to your iSpyConnect account for
  • Secured Remote Access
  • HD Playback
  • Cloud Uploads
  • Rich Push Notifications
  • Email Services
  • Permissions
  • Software Updates
  • Virtual Reality
  • RTMP Streaming
  • Alexa, IFTTT and Home Assistant integrations
... and more!
Tämä siis android apin kohdalla. Löytyy myös ios appi.
Ulkomaanmatkaa pukkaa ja kamera olisi mietinnässä.. Löytyykö kameraa:
  • Tukee pilvipalvelua, tai vähintään etäkatselua
  • USB-virralla
  • 1080p
  • IR-valot pimeään
  • Hintaluokka: 30€
  • Amazon.de / Aliexpress käy myös hyvin
  • Itsenäinen systeemi, ei mitään tarvetta "valvomolle" tai pidempiaikaiseen tallentamiseen
Ja minulla on jo 720p Yi-kamerat, jotka tukevat kaikkea näistä, mutta yksi niistä jumittaa päivitysloopissa ja ne on kuitenkin vaan 720p..
Tarkoitus kuvata asuntoa, kun olen poissa ja antaa sitten mielenrauhaa, kun kukaan ei nyysi minun tietokonetta.. Nämä kamerat olisi päällä vaan, kun olen poissa pidempiä aikoja.
Mikä on edullisin ns. järkevä poe kamera ulkokäyttöön. Saisi olla mielellään n. 90 asteen kuvakulmalla.
Tulee NAS purkin kanssa toimimaan.
Reolink RLC-510A :han olen ollut todella tyytyväinen. Näistä saa jatkuvaa RTSP striimiä ulos h.264 codecilla jos sillä on merkitystä NAS:n suhteen.
Tuollainen 520A, eli dome mallinen voisi olla ihan näppärä. Hintakaan ei ole ihan mahdoton. Jotenkin tuo dome mallinen olisi ehkä enemmän omaan silmään sopivampi.
^ Kannattaa siinä kameran kotelointimallissa miettiä muutakin kuin estetiikkaa, domessa saattaa tulla heijastuksia kuvusta riippuen sijainnin valaistuksesta/auringon suunnasta.
Tästä ollut aiemmin jo ketjussa keskustelua.
Ezvizin BC1 kameroihin tullut päivitys. Ajan nyt takapihan kameraan sisään.
Ei oikein pikainen googlaus auttanut, joten kysytään.
Tosiaan pari Boschin Flexidome IP Indoor 4000 HD kameraa tässä käyttöönottovaiheessa.
Tällä hetkellä firmiksen versio 5.90.0112 (12510590) ja kamera itsessään kertoo että CPP4_H.264_7.10.0096.fw (0.00.0007) olisi tarjolla.
File ladattu, ja kun lähtee päivittämään niin 100% asti menee, ja webhallinta palaa ns. päävalikkoon ilman mitään herjoja.
Tämän jälkeen kun tsekkaan nykyisen firmiksen, on se tuo sama 5.90.0112 ja päivityslogi sanoo näin;
05.05.2023 09:15:50 0.00.0000 Error 0xd
05.05.2023 09:16:49 5.90.0112 OK
Eli olisiko kellään hajua, että mikä tässä nyt kusee? Liekkö olisi tuo nykyinen 5.90... sitten liian vanha päivitettäväksi suoraan versioon 7.10...?
Ja tätä kirjoittaessa sain kaivettua firmiksen versiota 6.22... mutta sama homma kuin tuon 7.10... kanssa logeja myöten.
Hyvinhän tuo kamera sinänsä toimii vanhallakin firmiksellä, mutta on tosiaan ainakin versionumero jo niiiin vanha että varmaan uusia ominaisuuksia tjsp. uudessakin olisi tarjolla.
Onko tuossa jotain PDF mukana missä näkyy päivityssykli?
Äh, tuo 6.22 minkä löysin, niin tarkemmin kun tavasin pdf:ää niin siellähän tosiaan sanotaan;
Note:
Due to an internal file system being introduced since firmware 6.1x and architectural changes thereof,
an upgrade to firmware 6.20 and higher is only possible from firmware 6.1x versions or higher.
Cameras with previous firmware versions below 6.1x first need to upgrade to firmware 6.1x.
Eli pitääpä jatkaa vanhempien firmisten etsimistä ja niistä katsella mihin 5.9 voi päivittää.
Valvontakameran tallentimeksi NAS vai NVR, esim tämä?
Tuossa olisi 2TB:n kovalevy mukana, eli saman hintainen noin kuin esim Qnap TS-130 + kovalevy, jota aluksi ajattelin, mutta olisikohan tuollainen tuohon tarkoitettu NVR kaikkein helpoin ja järkevin?
Kellään käytössä tuota Reolink NVR:ää?
Tulossa alkuun kaksi kameraa, todennäköisesti Reolink RLC-820A kameroita. Tällä hetkellä ei tarvetta useamalle kameralle, mutta tämä optio on hyvä olla olemassa. Lähinnä mietin noita NAS:ien kameralisenssejä. Monessa on kaksi ilmaista lisenssiä ja siitä eteenpäin joku 50€/kpl.
Hankin muutama viikko sitten Powerista Eufycam 3 setin Forever Power Security Camera with BionicMind™️.
Aikaisemmin olin ajetellut POE kameroita ja NVR tallenninta, mutta täytyy kyllä sanoa, että on kyllä ylivoimaisen helpot nuo akulliset kamerat kun ei tarvitse verkko- tai sähköjohtoja vedellä.
Kamera vain seinään ja se on siinä. Toki eivät nauhoita 24/7 toisin kuin POE&NVR vaan liikeestä ja ovat riippuvaiset WLAN toiminnasta.
Noille luvataan vuoden akunkesto ja lisäksi kameroissa on integroidut aurinkokennot, jotka ainakin aurinkoisilla paikoilla pitävät kamerat ladattuna käytännössä ikuisesti.
Muutaman viikon käytön jälkeen kaikissa kameroissa on edelleen 100% akkua.
4K kuvanlaatu on tarkka.
Tietoturvahaavahan noissa Eufyn kameroissa oli viime vuonna ja sen takia tulikin pitkään harkittua hankinko nuo.
Valmistajan mukaan haavoittuvuus on korjattu.
Joo, tätäkin miettinyt, mutta itse mielelläni rakentelen ja sen takia vedän ethernetillä kameroille piuhat, koska nuo akulliset tuskin ihan hirveän kauan kestää suomen -30c - +30c lämpötiloja, näin ainakin uskon. Lisäksi wlan riippuvuudesta en pidä. Noiden helppoudesta kylläkin, mutta kuten sanottu, mielellään näitä itselle rakentelee. Sähkön kanssa tulee työelämässä touhuttua myös ja kaapelinveto ja reittien tekeminen on normipäivää.
Itselläni on tuo reolinkin nvr ollut yli vuojen käytössä, mukana tuli 4 kpl kameroita. Nyt hankkinut lisää niitä.. Yksinkertainen ja toimiva. Pystyy päivittämään (itse ajattelin päivittää) kovon 6tb kokoo, ja esata liitännällä toiset 6tb pystyisi käyttämään.
On käytössä myös reolinkin wifi kameroita, joita en ole tuohon nvr:rään yhdistänyt. Kaikki kuitenki näkyy samassa puhelin softassa, ja toimii hyvin :tup: Ja ei mitään helvetin kk maksuja..
NVR. Toki merkistä(/malista riippuen, mutta pääsääntöisesti NVR tarjoaa selkeästi monipuolisemmat ominaisuudet valvontakamerakäyttöön, esim. itsellä oleva Hikvision mahdollistaa 24/h tallennuksista tapahtumahaun vain halutulta alueilta (vaikkei se ole alunperin kyseiseltä alueelta säädetty liikettä havaitsemaan). Samoin tapahtumia voi kameroiden kanssa yhteensopivan NVR purkin kanssa määritellä monipuolisemmin.
NikoLip
