PSVR2 ennakkotilaukset on nyt auki suomessakin jälleenmyyjiltä, eli ainakin verkkokauppa, gigantti, elisa, vpd, proshop (hinta.fi mukaan)
Hinta 639e normipaketti, 699e horizon bundle, 49e lataustelakka
Tilasin kyllä omani jo kuukausi sitten kun ne tulivat tilattavaksi Elisalla, Gigantilla, Powerilla ja Verkkokaupalla, ainakin. Gigantti ja Power vaativat ennakkomaksun, Elisa ja Verkkis eivät.
John Carmack ilmeisesti lopettanut duunit Metalla. Aikaisemminhan se teki päivän viikossa metalle töitä konsultoivana cto:na. Mehukasta kamaa lähteen päässä
ninjaedit keskelle. Carmack kommentoi vuotanutta viestiä ja irtisanoutumistaan. Näemmä carmackin esimies myös kommentoinut carmack:in facebook postausta. Carmack:lla myös ketjullinen viestejä asiaan liittyen twitterissä
This is the end of my decade in VR. I have mixed feelings.
Quest 2 is almost exactly what I wanted to see from the beginning – mobile hardware, inside out tracking, optional PC streaming, 4k (ish) screen, cost effective. Despite all the complaints I have about our software, millions of people are still getting value out of it. We have a good product. It is successful, and successful products make the world a better place. It all could have happened a bit faster and been going better if different decisions had been made, but we built something pretty close to The Right Thing.
The issue is our efficiency.
Some will ask why I care how the progress is happening, as long as it is happening?
If I am trying to sway others, I would say that an org that has only known inefficiency is ill prepared for the inevitable competition and/or belt tightening, but really, it is the more personal pain of seeing a 5% GPU utilization number in production. I am offended by it.
[edit: I was being overly poetic here, as several people have missed the intention. As a systems optimization person, I care deeply about efficiency. When you work hard at optimization for most of your life, seeing something that is grossly inefficient hurts your soul. I was likening observing our organization's performance to seeing a tragically low number on a profiling tool.]
Earlier this year we announced Meta accounts: a new way to log into your Meta VR device(s). As we mentioned then, if you have been using your Oculus account to log into Meta VR devices, you will need to create a Meta account to continue to use those devices after January 1, 2023. Failure to create an account will result in losing access to your device and eventually your data.
Nyt eletään näköjään näitä aikoja. Maalaisjärjellä ajateltuna tässä olisi perusteet refundille, ainakin jos elettäisiin oikeusvaliossa. Joku selvittänyt asiaa tarkemmin? Turha koittaa, koijarit voittaa? Mitään vitun someja ei tähän taloon tule, se on ainakin varma.
Ehkä pääsyn rautaan saa takaisin sitten kun jaksaa tehdä ilmaisen tunnuksen. GDPR taitaa säädellä pitkäänkö dataa saa säilyttää. Ei meta vanhojen käytöstäpoistettujen tunnusten datoja saa maailmanloppuun asti säilyttää servereillä,...
Niin, sitähän tässä kysyttiin. Ja mitään muuta syytähän tässä ei ole kuin liiallinen laiskuus, jotta jaksaisi tunnuksia luoda. :rolleyes:
Picon käsien seuranta on aika makea:
Alla video jos kiinnostaa laita päälle :)
Terve,
Mitäs laseja suositellaan kun hakusessa olis lasit autosimuihin?
Ns. Hinta/laatu suhteelta parhaat olis hakusessa.
Terve,
Pico 4 taitaapi olla suht ylivoimainen. Heppu alla tekee VR simu videoita ja testailuja.
Joo Pico sai huippupäivyksen virtual desktopin osalta, mut nyt picolta on tulossa myös parantava streaming assistant päivitys. Mielenkiintoista nähdä oisko se tethering metodilla aito kilpailija vd:lle
Kyl kai simuhommiin edelleen piuhalla, laatu edellä ja piuha ei niin siinä haittaa.
Olen kyl sinänsä jäävi ku oo testannut langatonta, mut ihan datan (pienempi kaista) ja juttujen perusteella.
Kiitos vinkeistä. Vähän lueskelin tuosta picosta sen verran, että nähtävästi pitäs ajosimuja ajaa virtual desktopin kautta ja vaatii näytönohjaimelta paljon. Tällä hetkellä budjekti ei taivu vr lasien lisäksi näytiksen investointiin
Picoja voi ajaa ihan yhtä rumalla kuvalla kuin vaikkapa riftejä, jos kone ei parempaan pysty. Sen takia ei siis kannata huonoja laseja hankkia, ettei kone jaksaisi ajaa niitä täysillä. Paremmissa on vaan sitten varaa parantaa kuvalaatua kun kone paranee. Itse en tosin saanut pico 4:sta toimimaan pc:llä, mutta monilla muilla näyttäisi ne toimivan
Ei mennyt kuin stömsössä. Powerista hankitussa Quest 2 hihna hajosi ja koska ei ole virallinen kumppani Meta ei alkanut millekkään.
Power ei saa uutta laitetta kuulemma hankittua tilalle ja tarjoaa vain kaupan purkua.
Pura kauppa ja osta uusi? Lähinnä savet menettää, mutta softat on tilikohtaisia.
Kaiketi saa vielä uudet refealennuksetkin kaiken muun lisäksi.
Teitkö tiketin Oculucsen sivulle loggaantuneena ja kielenä Suomi? Huomasin itse että jos eglanninkielisenä tekee niin tiksu menee Jenkkilään ja ne ei tunnista suomalaisia jämyjä. Jos suomenkielisen kautta tekee tiksun niin menee Irlantiin ja niille kelpaa suomalainen jälleenmyyjä.
Minulla Elite Strap meni rikki ja laittoivat uuden Irlannista.
Mä suosittelen langallista yhteyttä, motonetistä vaan usb-c to ethernet adapteri ja sit riittävästi cat6 johtoa, että yltää reitittimeen jossa kiinni myös pc. On paljon sulavampi kuin wifillä.
Laitoin Pico 4:sen tilaukseen PCVR ja Sim Racing -käyttöön. Miten tämä langallinen viritys käytännössä siis toimii ja mitä oheishärpäkkeitä/softaa se tarvitsee?
USB-C to Ethernet -adapteri kiinni Picoon ja siitä Cat-kaapelilla reitittimeen. PC kiinni piuhalla oletettavasti samassa boksissa. Meneekö tämä myös Virtual Desktopin kautta Windowsin puolella, kuten ilmeisesti tuo Wifi-yhteystapakin? Tämä metodi ei tarvinne erillistä reititintä, vaan voin käyttää tuota nykyistä kaapelimodeemia?
Adapteri langattomalla latauksella ja seinään käytön aikana, niin kestää akku pidempään. Ilmeisesti Pico tukee ainoastaan 20W latausta?
Star Wars: Squadrons toimii VR:ssä todella hyvin muuten, mutta kaikki muu kuin itse lentely on hieman kankeaa kun pitää joystickillä (vai oliko se näppiksellä?) ohjailla dialogeja ja valikkoja. Tämä oli ensimmäinen peli missä Riftin reso alkoi haittaamaan pelaamista. Kohteiden ja tekstin tunnistaminen oli jo hieman hankalaa. Muissa peleissä se on lähinnä tuntunut liian epätarkalta mutta ei ole rajoittanut sen tarkemmin. Esimerkiksi Elite: Dangerouksessa ei reso missään kohti häirinnyt.
Tää on picolla upea kokemus. Xbox padilla valikot ja lentäminen maittaa.
Siis pimax 5k ja artisan malleilla tätä alunperin testasin mut nyt kyt picon linssit jne tekee tästä älyttömän hienon. Tuli pelattua akullinen putkeen.
Muista laittaa se verkko yksityiseksi winukassa. Ja wifi picosta pois päältä. Ei se mulla heti ekasta mennyt, jotain tein mutten muista mitä. Oisko pitänyt palomuurista portti aukaista...
Se picon oma 30w laturi käytössä itellä ja ostin 5m oculus kaapelin niin voi sitä virtaa pitää pelatessa, hitaasti menee muttei pidä 100%. Sitä varten pitäis olla 40w laturi että pitäis 100% pelatessa.
Joo vd kanssa toi on tarkoituskin käyttää. En tiedä toimiiko Streaming Assistant tuolla tavalla. Täytyy kokeilla heti kun tulee uusi päivitys julkiseksi.
Täytyypä kokeilla, ois kyllä joystick myös mut pädi myös.
Minulla on toistaiseksi jäänyt pelaamatta. Tosin ei VR:n takia vaan, koska se lentomalli oli käsittämätön näin wanhalle Freespace veteraanille. Ei auttanut vaikka kaivoi vanhat lentovermeet tai kokeili padilla.
Lentomalli on heikompi versio/ esitys vanhoista tie fighter jne peleistä.
Inertiaa jne ei ole about yhtään.
Mutta ihan semi sama kuite oli jo wanhoissa.
Freespace oli taas sit ihan omansa, siitä ku sais VR version.. :)
Kokeilin nopeasti tätä adapteria ja hienosti yhdisti Pico 4 nettiin piuhan kautta ja Speedtestin mukaan antoi maksimit mitä oma 400 netti antaa.
Otithan wifin pois päältä picosta?
Löytyyköhän jotain pelejä Quest 2:lle jossa toinen pelaaja voisi pelata tai muuten vaikuttaa pelimaailmaan puhelimella?
Näissä ilmeisesti pancake linssit? Kuva pakattuna PC:ltä myös piuhalla?
Silmien seuranta puuttuu. Jotenkin ei nyt vielä ainakaan herättänyt omistushaluja.
Lisäksi LCD näytöt ja Picoa huonompi resoluutio, mutta yli tuplasti kalliimpi.
En muutenkaan ymmärrä näitä standalone laitteita kun jollain mobiiliprossulla pitäisi pyörittää VR:ää. Kokemus on aivan kauhea noilla mopoprossuilla. Ehkä joillekin kasuaaleille sitten uppoaa jotka eivät ymmärrä paremmasta.
Edelleen odotellaan PC:lle laitetta jossa olisi OLED, displayport ja langattomuus samassa paketissa. Langattomuus on kyllä aivan ehdoton tietyissä peleissä.
On niillä nyt silti puolensa. Mediakäytössä toimii ja kyllähän ne pelitkin ihan hyvin pyörii mutta näyttää vaan graafisesti hirveän rumilta kun rimaa joudutaan laskeen suorituskyvyn takia.
Saisi joku Varjo ja kumppanit alkaa tota Nofiota lisensoimaan. XTAL3:n yrittää mutta sen hinta on jossain yli 10000€. Bradleyn mukaan Nofio kuitenkin toimii isoillakin resoilla ihan hyvin.
Miksi OLED kun se rajoittaa VR:lle tärkeää pixel persistenceä eli liikeblurria? Vai onko tämän suhteen tullut läpimurtoja VR puolella? LCD näytöillä liikeblurri on saatu jo alle puoleen pikseliin per 1000px/s liike mutta ainakin kun viimeksi tsekkasin niin OLED näytölliset VR kakkulat blurraa useita pikseleitä samalla nopeudella. OLEDissa kun ei saa taustavaloa erilleen pikseleistä niin minusta OLEDilla ei ole sijaa VR maailmassa blurreineen verrattuna LCD jossa taustavalo on erillään pikseleistä ja pitämällä strobe 0,33ms mittaisena ja kirkkaana kuin aurinko päästään käytännössä kokonaan eroon liikeblurrista.
LCD on tällä hetkellä ehdoton kuningas niin kauan kun OLEDin kirkkaus alle millisekunnin strobella on luokkaa 10nits (käytännössä pimeä ruutu). LCD:stä todennäköisesti siirrytään microLEDiin seuraavan 10v sisään.
Omistanut Vive, Vive Pro, Oculus Rift, Rift S, Quest 2 ja Valve Index. LCD paneeleileilla en saa oikein siellä olemisen tunnetta heikon kontrastin takia, jonka takia suosin ehdottomasti OLEDia sen heikkouksista huolimatta VR laseissa.
Tarvetta olisi uusille PC laseille, mutta eipä ole LCD lasit kiinnostaneet enään. Onneksi PSVR2 on tulossa niin saa korkeamman reson OLED paneeleita vihdoin ja viimein.
Täältä löytyy quest 2 stand alone käyttöön ja psvr 2 ennakkotilattu...niillä mennään loppuelämä koska ps5 jää kyllä mulle vikaksi pelikoneeksi ja ei ole tarkoitusta hypätä pcvr kelkkaan koska ei tarvetta ökykalliille pc lle.
Eiköhän noista nyt nauti monia vuosia jos silmät vaan näkee ;)
Kyllä toi quest 2 on ihan passeli määrätynlaisille peleille ja immersio on vakuuttava sillekin. Psvr 2 sit tuo silmäkarkkia nohin isomman tuotannon peleihin. Toivotaan että half life alyx tulisi pleikalle.
Edit... Ja kyllähän tuo psvr2 on jo nyt saanutkin ihan hyvää ennakkohehkutusta niiltä jotka sitä päässeet testaamaan. En usko että floppi tulee olemaan missään mielessä ja jos jo omistat ps5 niin onhan toi melkein pakkoostos.
Hinnat tuskin tulee tippumaan noissa laseissa mihinkään. Näkihän se jo ps5 jossa hinta jopa noussut. Itsellä pleikka ollut julkkarista saakka ja onneksi vaakatasossa kun nyt siitäkin ollut vääntöä netissä.
Täytyy kyllä kompata, että OLED näytöissä VR:ssä on olleet parhaat väritoistot (historia: Gear VR, Lenovo Explorer, Samsung Odyssey+, HP Reverb G1, HP Reverb G2). Itse en OLEDin pixel persistenceä huomannut kuin pimeissä kohtauksiss (black smearing). Oleding hyvät puolet voittavat huonot minun mielestäni.
Gran Turismo 7 ja Beat Saber tulossa PSVR2:lle. Kyllähän näiden avulla laitetta saadaan jo liikkumaan.
GT7 myi mulla psvr2:en. Joutui ennakkotilaamaan. Kalliiksi kävi gt7 kun piti ostaa ps5+rallipenkki+fanatecin gt7 ratti myös sitä varten. Tosin tuleehan tolla muutakin pelattua + rattihärdelli toimii myös pc:n kanssa.
Eihän tuo OLEDin MPRT (~3,5ms) mikään huono ole mutta harmittaahan se vähän kun sen on hoksannut tietää mitä katsoa. Pään liikkeessä kaikki pikselintarkat yksityiskohdat peittyy kevyeen blurriin. Black smearista tuli mieleen että onko OLED VR kakkuloissa edelleen niin että valintana perfect blacks ja black smear tai ei black smearia mutta pohjamusta on LCD:n harmaa? Saapa nähdä miten PSVR2 OLED, että onko ratkaistu mitään näitä ongelmia tai onko miten mitigoitu.
Tilasin jonkun kolmannen osapuolen comfort strapin + lisäakun ja säilytystelineen vajaa satasella, saa nähä tuleeko pelkkää skeidaa - ainakin videoesittely näytti kivalta.
Tuli hommattua tuossa Pico 4 lähinnä PCVR-käyttöön, osittain ihan testimielessä kun en ole koskaan näitä VR-laitteita ennen kokeillut. Seuraavat mietteet puhtaasti siis tällaisen noviisin näkökulmasta.
Käyttöönotto oli helppo ja nopeasti pääsi kokeilemaan joulubundlessa tulleita ilmaispelejä. Testiin valikoitui minigolf-peli, joka vaikutti ihan hauskalta, mutta grafiikat olivat kielmättä melkoista suttua. Tämä nyt oli ihan odotettavissa, joten eikun ostamaan 20€:n Virtual Desktop -lisenssiä, jotta pääsee simuilemaan Ethernetin yli.
Aikani asetuksia ihmeteltyäni (ja Googlen ystävällisellä avustuksella) sain säädöt tehtyä niin VD:n streamer clientin, itse VD:n kuin SteamVR:n puolellekin. Peliksi valikoitui Automobilista 2, laatuasetuksista "Godlike" valittuna ja bitrate ns. maksimit kun on kerta parasta eli RTX 4090 alla.
Nordscleifea lähden kaahailemaan ja aika nopeasti päällimmäisenä fiiliksenä on pettymys. Makea gimmick VR itsessään, mutta immersiota syö kyllä pahasti tuo kuvanlaatu yleisesti. Auto on sisältä kohtuu yksityiskohtainen, mutta tie ja muu ympäristö melkoisen epätarkkaa. On kai mahdollista, että jotkut säädöt on pielessä, mutta aikani eri komboja kokeilin parannusten toivossa.
Jos tämä on "Godlike", niin en ymmärrä miten kukaan niillä viidellä tai kuudella alemmalla kuvanlaatuasetuksella kehtaa pelata yhtään mitään. Itselläni on silmälasit, en tiedä vaikuttaako jotenkin asiaan? Ilmankin kokeilin, mutta ei tullut mitään. Ilmeisesti kaukolaseista ei eroon pääse edes virtuaalitodellisuudessa.
Taitaa lähteä palautukseen. Sinänsä näillä voisi jotain jumppa/nyrkkeilypeliä ehkä pelatakin, mutta todennäköisesti tulee kuitenkin lähdettyä mieluummin punttisalille kuin heiluttua VR-lasit päässä olohuoneessa.
Se on langattomasti noilla xr2 standalone laseilla tuollaista compressiosuttua. Quest2:lla sama homma; itse piiri ei kykene suurempia määriä dataa langattomasti käsittelemään. Simupeleihin aina displaykaapelilla oleva headset :p
Toki osittain tämä oli tiedossakin. Aika paljon tuli foorumeita luettua kuinka Pico:lla streamataan ja miten hyvin se toimii. Itselläni oli Pico tosiaan kaapelilla reitittimessä kiinni, mutta toki samat piirin rajoitukset on siinä mukana kuin langattomassa toistossakin.
Aika paljon näitä on kuitenkin hehkutettu, myös PCVR ja simukäyttöön, niin siksi tuli otettua skeptisyydestä huolimatta kokeiluun. Harmi kun kaikki DP-lasit markkinoilla on jo ainakin pari vuotta vanhaa tekniikkaa.
Täytyy olla jotain sulla pielessä. Ite pelaan dcs jne simuja picolla.
Maalien ja koneiden näkyminen kauas tärkeää.
Ei kyl ole suttua, toki VR ei 4k monitorille pärjää mut silti VR kuvaksi terävä.
Mulla ex VR potat CV 1, Samsung odysey, pimax 5k,vive cosmos, pimax artisan ja reverb 2.
Reverb 2 oli hitusen terävämpi keskeltä mutta picon terävyys laidasta laitaan parempi.
Sulla ekat VR lasit niin odotit liikaa, ei näillä viel 4k näytölle pärjää. Varjo Aero ois sit toki eri asia mutta se kirpaisee sit enempi euroja.
Minusta Quest2 on ollut riittävän hyvä jopa langattomana. Reverb g1 oli terävämpi ja siten simuissa parempi mutta Quest on kokonaisuutena parempi.
Kokeileppa
1) ottaa ssw pois päältä
2) laittaa lasit 72hz mode
3) päivitä pico, oli eilen tullut päivitys jakoon, edellinen versio rikkoi yhteensopivuutta VD:n kanssa
4) steamVR:ssä pitää olla resolution 100%
5) steamvrssä adv. Supersampling päälle.
6) tai 5.kohdan sijaan toi 4.kohdan reso esim 125%
7) vd:n bitrate ei kannata ikinä olla 150, optimi god likella 120-135.
Kimpale
