Kodin yleiskaapelointi ja RJ45 läpi talon - keskustelua ja vinkkejä
  • Keskustelun aloittaja Keskustelun aloittaja Lexy
(Sorry for writing in English)
It looks like I also have some related situation to the whole A/B standards and cable routing through the house.
We are getting optics fiber in a few months and I want to future proof the network; the house is from 2012 and it already has cat 6 cables connected from the electricity panel inside the house to all rooms. I tried to see if the cables work and connected a switch inside the electricity panel, but I get no connection to the pc / laptop if I hook it up to any of the outputs in the rooms. So I bought a cable tester, and the master lights up in the proper order, 1->8, but here is the surprise, all jacks at the other end (in the rooms) light up in the reverse order, 8->1 . Does this have anything to do with the standards, or are all keystone outputs in the rooms reversed wired?
Checking the cables, they look to be terminated to standard A at both ends, if I saw that correctly. So now I am lost and have no idea why they don't work. Is there something that I miss here, or is the wiring in the house done weirdly?
What would be the way to fix this, re-wire the jacks in the rooms, or replace the cables completely and terminate them in standard B?
To mention a bit about the plans, will get a Unifi Dream Machine SE, that will be connected to the switch in the electricity panel (10Gb ideally) and from there to the rooms. And a U6 access point will take care of the wireless, so the cables should also be PoE or PoE+ capable.
Hmm... Is there a possibility on the cabinet side connector to be put backwards? So that it is not 1 to 8, but to 8 to 1. Does the small white part come off? Maybe the top part have been put in the wrong way to the bottom part and that causes the numbering error. Strange that if every connector is the same?
I think that sticker is upside down on those connectors. I remember hearing there was 3M connector with upside down instruction sticker. Those worked fine if both ends were same mislabeled connector, but you have correct order in other end and mirrored in other.
Thanks for all the answers and ideas.
Indeed, did not even consider the stickers might be wrong. Though the order of the wires in the main cabinet is correct, according to standard A. But how can I check the order in the wall jacks?!
Cables that I used to check the connection are not the problem for sure, as I tried more than a couple, that are already in use between devices, and also the cable tester tool shows them as good.
The only thing left to do, again, as I remember I already did this some time ago, but just to double check, is to check the direct connection between router and pc, and then plug the same cable in the main cabinet and at the other end, in the room, the pc. I guess this should work and check for sure if the wiring is ok or not.
Hey,
probably just the markings on the ethernet outlets are wrong, and the cabling is ok and works. Put a switch in the distribution cabinet and small patch cables to every socket, that should work.
Finally I got to the bottom of it.
The keystones in the main cabinet were installed wrong. I opened them, turned the caps 180° and reinserted them, and now they work properly. So it was basically an installation problem, since with this type of keystone they can be mounted reversed, and no one bothered to check them properly after installing, and the previous owners had wifi, and never used the sockets in the rooms.
Great that you found the solution and also posted it here if someone else is ever having the same problem.
It's crazy how these things happen since every installation should be measured and the results included in the contracts, but no one seems to be making these and the payer doesn't care.
Well most of them do not know there should be a ”pöytäkirja” eg measurement results. Let alone what that slip of paper says. ;)
And some installers do not measure cables, they just create a bogus report "tarkastuspöytäkirja" and give it to the customer. I have at least twice seen that, report says all cables are ok but when I tested some cables there were swapped pairs and some other problems.
Onkos kaapeleiden höyrynsulkumuovin läpiviennin tiivistämiseen muita vaihtoehtoja kuin teippaus?
Yksittäisethän menee teipillä, mutta kun tulee +10 piuhaa samasta kohtaa ja sitten vielä kuitenkin tulee jossain vaiheessa tarve lisäillä kaapeleita...
Itse ainakin olen toteuttanut pienien putkien sijasta yhdellä isolla 50mm putkella läpiviennin varastosta välikatolla, jonka kautta siis verkkokaapelit menee. Tiivistys sitten jollain massalla mikä irtoaa järkevästi mutta on myös tiivistä (eli ei millään liimamassalla).
Mä suunnittelin vastaavaa niin että teippaan pätkän 100mm solukumiputkea höyrynsulkuun, sitten litistän sen pään niin että kaapelit tulee rivissä läpi ja kahdella päistä yhteen pultatulla lattaraudalla nipistän sen pään tiiviiksi. Tai "vajan oven saranalla" jos löydän riittävän ison. Ideana siis että voi helposti lisäillä sinne kaapeleita.
Tekee sinne jonkinlaisen ”alueen” vaikka jostain makuualustasta/solumuovista/mistävainkumimatosta tai vastaavasta, johon voi tehdä aina uuden alkureiän, jonka läpi lyö sen uuden piuhan, kun vain tulee tarve.
Tai sitten vaan teippaa, tai on teippaamatta..
Nimim. Reikiä se on todennäköisesti muutenkin täynnä.
Joo. Reikiä varmasti on, mutta eipähän olisi ainakaan enempää, jos saisi tiiviiksi.
Jotain kumi/bitumilevyä vähän mietinkin. Siihen saisi reikiä sitten lisättyä, jos tulee tarve ja sen saisi teippaamalla reunoilta tiiviiksi.
Mulla on talossa Ethernet kaapelointi jotka päätetty keystone päihin. Jos jatkan tätä kaapelia uudella joka päättyy myös keystone päähän pitääkö sen olla samaa T568A tai B luokkaa? Vai voiko se olla eri? Lähinnä kun en tiedä kummalla standardilla sähkäri on kaapelit päättänyt.
Selvyydeksi en siis en ota vanhaa keystone päätä pois vaan väliin tulee patch kaapeli ja siitä jatkuu uudella.
Ei tarvi olla samaa. Riittää kunhan saman kaapelin molemmissa päissä on järjestys sama.
Talossa puhelinkaapeli 16mm putkessa, jota voisi myös käyttää kaapeloinnissa. Saako tuosta siam/tupla kaapelin miten läpi?
Eikai tuohon uskalla muuta sanoa, kuin että kokeile. Voi olla Rrutussa tai paljon mutkia matkalla.
Kun se 6 piuha on kuitenkin sen noin 6mm, niin ei siellä liikaa tilaa ole.
Oma kokemus on että siiamilainen tahtoo olla vähän haastava. Erillisissä taas kannattaa suosia halkaisijaltaan ohuempia kaapeleita. Kuinka helppo rasti tuo on riippuu sitten vedon pituudesta, mutkien määrästä ja putkituksen laadusta ja kunnosta.
Siamilainen pistää vastaan vaikka putki olisi reilumpikin, koska se ei oikein voi kääntyä "sivulle" pitää kaapelin kääntyä aina "kyljelleen" ennen mutkaa. Hyllyllä ja kanavissa tuo sieamileinen on paikallaan, mutta ei sitä kannata putkiin pakottaa.
Verkkolaitteet päivittynyt järeämpään rautaan kuidun saapumisen jälkeen.
Jostain 2010 vuodelta tuli vastaan puoli-ilmaiseksi sen aikaista "kalleinta Cat6e" kaapelia. Mikähän RJ45 liitin tuohon voisi käydä? Joka pari on suojattu foliolla erikseen + koko kaapeli lisäksi. Yksittäinen johdin eristeineen on sen verran paksu, että perus-RJ45 liittimeen ei mene työntämällä kuin millin. Eli mahtaako tuohon olla mitään standardi-vaihtoehtoa. Vai erikoisliitintä sitten jotain.
jos liittimien kanssa ei ole kiire niin kannattaa tilata AliExpress niin saat paljon halvemmalla noita.
On noi f/ftp kaapelit melkoista jöötiä vieläkin. Yleensähän ne päätetään siihen naaras liitinyksikköön.
Joo, ok kiitos tiedoista. Ei nyt juuri ole tarvetta 10 Gbps kotiverkolle, mutta onpahan nyt sitten piuhaa valmiiksi. Giga tuntuu menevän aikamoista paukkulankaa pitkin. Kait nykyään ilmassakin.
Siis tuo f/ftp kaapeli on tarkoitettu häiriöiseen ympäristöön, esim tehdassaliin tms, 10G ethernet toimii ihan tavallisessa cat6 verkossa johonkin 50 metriin asti. Pidemmät vedot vaatii cat6a, mutta suojaamaton käy kyllä.
Sopiva pala Finfoam levyä. Finfoam toimii myös höyrynsulkuna. Helppo vetää uusia kaapeleita kun lyö sopivan ohkaisella ruuvimeisselillä läpi ja vetää kaapelin reiän läpi. Finfoam antaa sen verran periksi, että kaapeli istuu varsin tiiviisti paikoilleen.
Tämä muuten otetaan käyttöön.
Kiitos vinkistä.
Olen pari päivää lueskellut ketjun alusta loppuun. Monia hyviä vinkkejä tuli aikaisemmissa viesteissä vastaan, kiitokset niistä.
Olisi aika tyypillinen projekti edessä. Valokuitu on tuloillaan talon tekniseen tilaan ja pitäisi 2000-luvun alkupuolen kaksikerroksiseen taloon vetää verkkokaapeloinnit vanhojen puhelinkaapelien tilalle.
Puhelinkaapelit kulkee omissa 16mm (ulkohalkaisija) putkissaan ja lähtevät talon teknisestä tilasta.
Onko suositeltavin kaapeli tämä jo ketjussa aikaisemmin mainittu Gigamedia Cat6 Tietoverkkokaapeli-CAT6 - GGM CAT6UHR4WTU3 CAT6 1XU/UTP LSOH VA Dca - 0218550 - Gigamedia vai onko joku muu suositeltavampi?
Ainakin kaksi kaapelia olisi tarkoitus yrittää saada vedettyä samaan putkeen, mutta voisiko tuohon ulkohalkaisijaltaan 16mm putkeen mennä 3kpl per putki? Tätä mietin, että montako erillistä kelaa tuota verkkokaapelia kannattaisi tilata, jotta asennus olisi sujuvaa.
Alakerrassa on puhelinrasiat kahdessa eri huoneessa ja yläkerrassa 7 eri paikassa. Antennikaapeliakin on vedetty useampaan paikkaan, joten niitäkin putkia voisi hyödyntää. Mutta ajattelin nyt aloittaa noista puhelinkaapelien ja rasioiden vaihdoista, kun nillä ei jatkossa tee mitään.
Tekniseen tilaan hankin jo räkkikaapin, jonne kuitupääte on käyty asentamassa. Mitkä olisivat hyviä liittimiä ja mikä mahtaisi olla niille yhteensopiva ristiinkytkentäpaneeli. Sopiiko samat liittimet ristiinkytkentäpaneeliin ja ABB Jussi telerasiaan?
Valmiina olisi myös Zyxel USG60W palomuuri, josta on ne "lisenssit" vanhentuneet, tekeekö tuolla enää mitään?
Kaksi per putki on ainakin ihan hyvä määrä koska sitten saa sen 3.nap. puhelinpistokkeen vaihdettua helposti tupla rj45 rasiaan. Vai mihin meinasit sen kolmannen kaapelin päättää?
Useampaa kelaa en alkaisi kotikäytössä hankkimaan. Ei ole iso vaiva mitata, leikata ja vetää pitkäksi kahta erillistä johtoa yhtä vetoa varten. Urakka hommissa sitten useampi kela niin on nopeampaa.
Jussi datarasioissa taitaa tulla aina liittimet mukana? Taitaa olla Keystone standardia. Paneeli ja liitin esim:
Kaksi Onnisen CAT6 kaapelia menee 16mm putkeen vaivattomasti, kolme sai tungettua muutaman metrin matkan mutta tuskin pidempiä vetoja. Kaksi kelaa kaapelia on hyvä lähtökohta. Kannattaa huomioida, että puhelinvedot on yleensä ketjutettu rasiasta toiseen. Kolmella piuhalla pystyy siis vetämään yhden kaapelin kolmeen peräkkäin kytkettyyn rasiaan.
Liittimet ovat pitkälti Keystone-mallisia, samat Onnisen liittimet käyvät Jussi-kehykseen sekä ristikytkentäpaneeliin.
Zyxxelin palomuureja (ja kytkimiä) vihattiin verkkomiesten keskuudessa kaikista eniten. Ko. mallille luvataan gigainen läpäisy, mutta ilmeisesti lupaus ei vastaa todellisuutta: Tuotteen ZyXEL ZyWALL USG 60W -palomuuri arvostelut
Hyvä pointti tuo päättäminen. Oikeastaan olen tuota kolmen vetämistä miettinyt lähinnä yhteen paikkaan alakerran aulaan, kun siinä on seinässä 2xpistorasia, peitelevy,1xpistorasia, antenniliittimet ja puhelinpistoke. Jos tuon peitelevyn tilalle olisi laittanyt datarasian. Pitänee nyt kyllä avata tuo ensin ja katsoa mitä siellä peitelevyn alla on. Jossain kohtaa joku oli mielestäni linkannut tuon Jussi datarasian ilman liittimiäkin, saattaisi olla edullisempi ostaa liittimet erikseen siihen.
Totta juu, että ei varmaan aikanakaan kolmea erillistä 300m kelaa kannata ostaa, kun vedot minne kolme tulisi niin rajoittunee tuohon yhtene, kun muuten niitä ei saa päätettyä oikein mihinkään.
Alakerrassa on huone johon tulee antennikaapeli, mutta ei puhelinpistoketta. Olikohan tuohon ABB jussi sarjaan olemassa sopivaa kalustetta jossa olisi rj45 ja antenniliitin. Mietin jo, että vedän listan alla tuonne johdon, mutta helpompaa se olisi tuohon antennikaapelin putkeen laittaa.
Ok, hyvä tietää eli kahdella varmaankin mennään pääosin sitten. Onneksi nuo puhelijohdot on tähtikytkennällä ja teknisestä tilasta lähtee niille erilliset putket, jotka on jopa merkitty selkeästi. Ilmesesti pari kelaa tuota gigamedian kaapelia https://sahkonumerot.fi/0218550/ olisi hyvä alku ja mittaa siitä sitten yhden erillisen kaapelin, jos yrittää tuonne ala-aulaan kolmea samaan putkeen. Voi olla kyllä tuhoon tuomittu yritys.
Ok, hyvä tietää eli kahdella varmaankin mennään pääosin sitten. Onneksi nuo puhelijohdot on tähtikytkennällä ja teknisestä tilasta lähtee niille erilliset putket, jotka on jopa merkitty selkeästi. Ilmesesti pari kelaa tuota gigamedian kaapelia Tietoverkkokaapeli-CAT6 - GGM CAT6UHR4WTU3 CAT6 1XU/UTP LSOH VA Dca - 0218550 - Gigamedia olisi hyvä alku ja mittaa siitä sitten yhden erillisen kaapelin, jos yrittää tuonne ala-aulaan kolmea samaan putkeen. Voi olla kyllä tuhoon tuomittu yritys.
Hyvät lähtökohdat siinä tapauksessa. Itse jouduin vetelemään piuhoja autotallin kautta ja seinän läpi ulkokautta yläkertaan, kun valmiita reittejä ei ollut. Onnisen kaapelit on 100m keloissa, näppärä käsitellä ja riittää yllättävän pitkälle.
Tuskin on valmista kalustetta, joutuu askartelemaan tai laittamaan viereen pintarasian RJ45:sta varten. Kaapelin vetäminen vanhan seuraksi voi olla hankalaa, käytännössä olemassa olevaa kaapelia joutunee käyttämään vetolankana. Tai vetää sen avulla oikean vetolangan, jonka avulla vetää RJ45 ja coax-kaapelin samaan putkeen.
Laita tällainen toisen RJ45 pistokkeen tilalle, sama Keystone koko:
Deltacolla olisi myös ihan 4mm Cat6A-kelaa olemassa. Pitää yrittää sillä saada putkiin vedettyä coaxin tilalle coax+ethernet, mutta tuplana verkkojohtoa tuskin saa tuollakaan mahtumaan.
Mitäs eroa noilla Cat6A ja Cat6 esim. tämä Gigamedia on, luulin että ero on siinä suojauksessa ja noissa (Cat6A) olisi se folio. Mutta ilmeisesti tuota Cat6A kaapelia saisi myös ilman sitä foliota ja yhtä slimminä, kun Cat6 kaapeliakin? Onkohan Rexelillä tarjolla jotain tuollaista yhtä slimmiä Cat6A kaapelia. Kannattaisiko ottaa Cat6A, jos hinta on suunnilleen sama mitä tuolla Cat6 kaapelilla vai onko tuo Cat6 helpompi vetää pieniin putkiin.
U/utp on suojaamaton, f/utp ulkovaippa suojattu jne... Tuo cat luokka ei liity siihen ulkoisen häiriön suojafolioon mitenkään.
Cat6a on tarpeen jotta nykystanun 10G ethernet toimii yli 50m matkalla. Alle tuon riittää cat6.
Ero on se, että cat6a menee 100m 10 Gbp/s ja cat6 vain 55m. Molempia kaapeleita saa erilaisilla suojauksilla. Nuo matkat ovat siis standardin määrittämiä. Lisäksi cat6a kaapelin kanssa tulee käyttää cat6a liittimiä, että nuo lupaukset täyttyvät tuon 100m osalta.
Jaa, tuo olikin minulle ihan uutta että nykyään saa keystoneen vaikka millaisia liittimiä. Tuohan helpottaa pirusti sekä kotona että töissä, itsellä siis on kotona räkissä keystone-paneeli ja sitten erillinen paneeli jossa on muita liittimiä "xlr d-aukolla". Tuskin meillä duunissakaan tietävät tuota niin helpottaa tiettyjä kaapelointi/liitinongelmia kun löytyy standardikalusteita.
Juu, tuo ero niissä tosiaan. Onkohan tuo Cat6a mahdollisesti tulevaisuudessa parempi, kun tuo Cat6. Onko hyvää ohkaista Cat6a kaapelia 305m kelassa jostain saatavilla vai onko tuo jollakin tapaa harvinaista. Äkkiseltään en kovin ohkaista Cat6a kaapelia löytänyt, paitsi tuo aikaisemmin mainittu Deltaco. Vai onko tuolla loppujen lopuksi mitään merkitystä kumpaa noista (Cat6 tai Cat6a) laittaa.
Ei ole väliä, ellei sulla ole niitä pitkiä vetoja.
Jos ei harrastamisen ilosta halua kaikkia piuhoja uusia, niin joka huoneeseen / nurkkaan ei välttämättä tarvitse gigabit-kaapelia vetää. Meillä on rakennusvaiheessa vedetty verkkokaapelit joka huoneeseen, mutta en ole niitä laiskana miehenä kytkenyt "talojakamossa" kuin ne, joita käytetään. Rasioihin johdot kyllä on kytketty. Sama tv-kaapelien kanssa.
Noissa joita käytetään, on kiinni Wifi Mesh tötteröt ja niissä tarvittaessa sitten sen kytkimessä piuhalla esim. TV tai konsoli tai NAS. Tai mikä nyt hyötyisi max. verkkonopeudesta. Muuten kaikki laitteet langattomassa Mesh:ssä jossa on 2 eri verkkoa. Toinen SSID on puhelimille ja kaikenmaailman leivänpaahtimille ja muille vakoilulaitteille ja toinen erillinen verkkonsa työläppäreille jne.
Parin NATin takana koko höskä, kun ei ole tarvetta yhteyksille tännepäin.
Ei liity ketjun mukaisesti kaapelointiin mutta jos sulla on kaksi NAT:ia peräkkäin samassa verkossa niin siitä ei ole mitään hyötyä, korkeintaan haittaa. Toki jos tarkoitit esim. verkkoja eri VLANeissa niin asia erikseen.
Joo, kirjoittelin vähän sinnepäin. Nettiliittymän reititin on NAT-moodissa ja sitten tuo meshi-verkko vielä omansa. Joo, langallisella puolella vain yksi.
Harrastamisen ilosta en tiedä, mutta jos tuon kerralla yrittäisi tehdä kunnolla.:) Kuidun kautta tulee jatkossa myös TV, niin yläpohjaan menevällä putkella saisi myös Cat kaapelin vietyä sinne. Siihen saisi sitten vaikka kameran tms. Aloitan nyt ensin noilla puhelinkaapeleiden korvaamisella.
Tällä hetkellä on VDSL ja mesh purkit. Tuon kuitupäätteen asennuksen yhteydessä annettiin myös 2kpl jotain huawein mesh purkkeja. Pitää miettiä minne nekin sijoitaa, jos ne ottaa käyttöön.
On tosiaan halvempi ostaa Jussirasia ja liittimet erikseen.
Jos on kyseessä levyseinä, niin saat remonttirasialla (levyseinärasia) helposti lisää rasioita, itse tein näin yhteen kohtaan. Eli 2xRJ45 tuli vanhaan rasiaan ja porasin 70mm reiän lähelle viereen ja siihen remonttirasian ja yhden RJ45 peitelevyn lisää. Välissä ei ollut juoksua, joten vanhasta rasiasta oli helppo rikkoa seinä ja pujottaa kolmas johto remonttirasialle.
Reactions: 10R
Voisi olla aika vetää tähänkin taloon rj45 teknisestä tilasta välikaton kautta 2-3 huoneeseen. Aikaisemmin jo kahteen huoneeseen onkin kaapelit tuotu, mutta nyt nettiyhteyden nopeuden nousun myötä, kiinnostaisi viimeinenkin wifi mesh laittaa kaapelin kanssa kiinni, kuten myös pleikkari.
Aikaisemmat eivät ole tehty puhelin lankojen putkeen, mutta olisiko se järkevää? En ole koskaan sellaista tehnyt, ja kuulostaa hieman haasteellisemmalta, kun en 100 varmaksi tiedä miten täällä vanhat langat menee...
Onko muuten nyt tullut vastaan hyviä BF tarjouksia tähän liittyen? Pisimmät vedot olisi siinä 20 metrin luokkaa, niin ei tarvetta kovin paksulle kaapelille.
Jos sähkökuvia ei löydy niin rasiat auki ja katselemaan miten puhelinpiuhat menee. Kylllä valmis putkitus välikatolla konyämisen voittaa, toki kannattaa varautua siihen että puheluinrasiat on ketjutettu. Ei kannata vetää vanhaa kaapelia ulos ilman että mukana on vetolanka tai uusi kaapeli tai kaksi.
Cat6 kaapeli ei kuulosta artikkelilta mitä olisi BF tarjouksena, ainakaan ei ole tullut vastaan. Mutta käypää kaapelia saa esim. Biltemasta. Kannattaa ostaa samalla kaksi 100m kerää jos meinaa pari-kaapelit vetää per putki. 100m kerä riittää omakotitalossa ihmeen pitälle, kun vedot on melko lyhyitä.
LeoN0998
