Intel Coffee Lake (LGA1151 Z370) kellotukset & kokemukset
Hiukan takapakkia nudecnc Ncore-v1:n kanssa.
We are really sorry that we did not get back to you sooner. We had some serious problems in the production. We posted some updates on our Kickstarter website, we are sorry you did not get that information, we will look into that. As you probably know all Ncores were/ are available only to pre-order at this stage, we were hoping to start shipping in December. However, We are sorry to say that we have found out that there have been some problems with the production ( mistake in one dimension of the Ncore). This, unfortunately, will result in a delay in shipping as We needed to send them back to the production unit for a remake. At this stage, it is very hard to say exactly when they will arrive. We are ever so sorry for that delay we are trying our best to sort it all out. Please understand we are still a startup at the very beginning of setting everything up... ( just me and my wife at the moment)
If you want more details please go to our Kickstarter website.
Ncore V1-naked die cooling waterblock, designed by NUDEcnc
We will understand if you would like a full refund. However just to let you know we definitely did not vanish or close the company. Everything is moving really fast and we are trying to solve out all problems to be able to deliver the Ncore.
Kind regards
Arek&Aleksandra
NUDEcnc
Saapahan nähdä kerkeääkö toimitukseen ennenkuin iskee päivitys/rakenteluhimo?
Tarjosi toki kaupan purkua mutta ... kivahan tuota olisi päästä testaamaan.
Ja lisää jobinpostia tähän aiheeseen:
Update 9: More News.. good and bad · Ncore V1-naked die cooling waterblock, designed by NUDEcnc
No näin se vain on. Ainoa mitä tehnyt niin ottanut Asuksen MCE:n pois että pyörii vakiona.
Katsoppa hwinfolla mitä vcore on pelatessa?
Edit: tarkasta myös, että cooleri on asennettu kunnolla ja että neste kiertää aiossa.
Tsekkaa mikä bios sulla on. Z370-H ainakin lykki aika jykeviä voltteja vakionakin prossulle ja XMP päällä sitten vielä enemmän. Ja sit noi coolerin kiinnitykset ja toimivuudet, onhan sekin nähty että jollakin on jääny se blokin kalvo sinne prossun ja jäähyn väliin.
Milläs tuon nesteen kiertämisen tarkastaa?
Noh tämä ei nyt kuitenkaan ole tässä tapauksessa sentään kyseessä :lol:
Kokeile radia, lämpeääkö se rasituksen mukana. Letkun jäykkyydestä huomaa myös onko kierrossa painetta. Ko. prossu ei ole käsittääkseni korkattu? Entäs se vcore?
En vielä ehtinyt sen enempiä katselemaan kun menin nukkumaan. Korkattu ei ole enkä korkkaa.
Ei noi kyllä siltikään vakiokelloilla kuulosta normaalilta. Mulla on vakiona ja korkkaamattomana Eisbaer 360 kanssa lämmöt huomattavasti alhasempana pelatessa (en nyt hatusta osaa heittää lukua, mutta veikkaisin että vähän reilu 60c, alle 70c kuitenkin). Tsekkaa se VCore, vakiona ei pitäis mennä 1.2v ylemmäs.
Itsellä 8700K ja 4.7ghz coret ja 1.26v niin huitelee 40-58c lämmöt pelatessa H110i kanssa ilman fps lockia. 80c kuulostaa järkyttävältä.
Edit. Push-pull
1,3V paikkeilla pyöri kun pelasin erän TDM:ää BF5:ssä.
Ai noinko alhaisillakin pitäisi toimia? Kuulostaa melko hurjalta.
Noissa on paljon heittoja. Sinun tilanteessasi katsoisin vaan jännitteen mukaan taajuuden, koska 100-200MHz heitto on vielä todella marginaalinen.
Väsymys painaa päälle tähän aikaan mutta meni hieman ohi mitä nyt tarkoitit tuolla :btooth:
4.7GHz on vielä helppo saavuttaa. Muistelisin ite että aikasemmalla 8700k pääs 4.7ghz suurinpiirtein vain kerrointa nostamalla, mutta 48 -> 49 ->50 hyppäykset alkoikin sit vaatimaan jo huomattavasti enemmän. Toki yksilöitä kaikki, mutta veikkaan et sun emossas on joko vanhentunu BIOS tai sitten sulla on vaan tosi paska kivi kun vakionakin vaatii ton verran jännitteitä.
Toi aikasemmin mainittu Z370-H tosiaan lykki vakiobiosilla järjettömiä jännitteitä vakiona. Biospäivitys sitten korjas.
Biosin päivittelin tänään ennen kuin tuon laittamani kuvan otin.
Manuaalilla 1,3V ja 4,7GHz all cores ei ihan hirveästi eroa. Hulluja määriä tuo haluaisi pyytää (eikös VID ollut se?).
Eli katsot järkevän jännite/taajuus suhteen. Esim 4500MHz voi mennä 1.1V ja 4700 vaatiikin jo lähemmäs 1.2V. Toisakseen harkitsisin myös korkkaamista jollain aikataululla.
8700Kt kyllä kulkee tuon 4.7ghz järestään. Nuo vid curvet voi heittää noille jännitteiksi ihan mitä vaan, joten käsin vaan jännitteitä hakemaan.
VID = prosessorin pyytämä jänjännite
Vcore = "todellinen jännite"
Eli katsot vain Vcorea jännitettä ruuvaillessasi.
Tykkään pitää takuun tuotteissa joten korkkaamaan en lähde. 4,7ghz on se mitä haluan ihan siksikin että se lukee kiven paketissakin. Mitään isoja kelloja ikinä muutenkaan ole hakenut. E6400 oli 2,6ghz, Q6600 3ghz ja 3570K 4,3ghz.
Juu eli muistin oikein :)
Joku kyllä throttlaa kun IBT ajossa pudottaa 3,3ghz. Overkilliä tuo IBT toki on normikäyttöön verrattuna mutta silti.
4.7GHz on vaan yhden ytimen boost kellotaajuus. Ei sillä muuta funktiota ole vaikka paketissa olisikin maininta. Mitä ei kyllä edes ole, omassa lukee 3.7GHz.
Mut sulla on joku nyt pahasti pielessä jos vakionakin throttlaa. HWInfo lataukseen ja kato ottaako lämmöt vastaan.
Kuten raxama totesi, jotain siellä on vikana. Kyllä näiden pitää kestää nämä testit. IBT on lisäksi jo vanha softa, joten käytä vaikka uusinta linxiä tai primeä small fftllä.
Eihän tuo nyt vakiona ole vaan sen 4,7ghz kaikille ytimille kiinteellä 1,3V. Vakiona tuo menee kyllä ihan nätisti sen 4,3ghz mikä on kaikkien ytimien rasituksessa kellot silloin.
Ihme jankutusta täällä, jos sulla on lämmöt 80c° stockina pelatessa, nii se on ihan sama mitä siinä paketissa lukee kellotaajuuksista. Menet sinne biossii ja syötät vcoreen haluamasi lukeman, painat F10 ja yes. Sitten Windowsiin kattoo miten kävi ja toistat suorituksen mikäli tarvetta.
Eihän tässä nyt ole stockina ajamisesta puhuttu enää toviin yhtään mitään vaan tuo 4,7ghz kaikille ytimille.
Joo luin. Laitas nyt vielä kerran selkeesti mikä on ongelma ja mitä oot koittanut?
4,7ghz kaikille ytimille tavoite. Nyt rasitustesteissä pudottaa 3,2-3,3ghz tietämille vaikka pelatessa pitääkin kiltisti 4,7. Manuaalinen 1,3V ja LLC5 asetettu. Viimeksi kellotellut ivy bridgejen tullessa myyntiin niin ihan outoa näiden uusien viritykset. Silloin riitti vielä pelkkä volttien laitto :)
Powerlimitit pois ekana.
Eipä tuon coolerin asennusta pysty sössimään joten kaippa sitä kävi sitten silikonilotossa erittäin huono tuuri.
En ihan purematta niele väitettä että ei voi sössiä.
Liikaa tahnaa, paskaa tahnaa vaikka ja mitä voi mennä pieleen.
En nyt varma täysin varma omista luvuista ole, mutta sulla olisi n. 20 astetta enemmän 4.7 kuin minulla corsairin h100v2 aiolla.
Reactions: MrM
Fractalin Celsius S24:ssä on tahnat valmiina joten asennus on yhtä plug&play kuin boxed jäähyllä (jos niitä nykyään siis vielä olisi).
En nyt erityisesti tiedä fractalista mitään, mutta noin yleisesti ottaen user error numero 1 käyttää valmistahnoja. Sitä on aivan liikaa ja ne on vielä paskaakin monesti.
Tuo liika tahna on nykypäivän coolereilla ihan kukkua. Ylimääräinen tavara tursuaa vaan yli ja luonnollisesti socketin ympäristö tuhriutuu. Tuota linus tech tips testaili joskus ja lopputulos oli em.
Edit: tuossapa taitaa olla ko. video
Minä luotan tässä omiin testeihin. Aina parhaat tulokset ohuimmilla sipaisuilla. Kaveri taisi testailla samaa viimeksi ku nämä 8700k:t tuli myyntiin. Mulla on aivat toiselta ajalta testit.
Mutta joo. Tursuaahan se. Eikä esim grizzlyn siveltimellä saa mitenkään erityisen vähän.
Liikaa tahnaa ei voi olla koska viskositeetit jne, paitti jos nestemetalli käytössä. Silloin kyllä hajonnee muutakin. :P
LeoN0998
