Cyberpunk 2077
Peliä sai lähes uutena pari vuotta sitten kaupoista poistomyynnistä alle kympillä ja joku lisäri maksaa 3x tämän :rofl:
Jos joku ei nähnyt niin traileria:
Minäkin sen meinasin poimia poistoista, mutta en sit ehtinyt hakemaan postista ajoissa minusta riippumattomista syistä. Ei kovin monesta paikasta löytynyt, ja sittemmin järjestään ~30€ tarjouksessa.
Taisin 20e maksaa Ps5:lle. Tietty vähän koomista, että lisäri 30e, mutta 50e yhteensä ja pääpeli on minulle todella kovaa settiä niin ei ongelmaa.
Ilmeisesti siellä on joku suurempikin overhaul tulossa ihan perus peliinkin
“All the core, main systems of the game have been redone or updated in a major way,” he told VGC. “The biggest ones are the perks and skill trees, which have been rebuilt completely, and the next one is we’ve added vehicle combat which enables new car chases.
“We’ve also greatly expanded AI and completely redone the police system, which is rebuilt from the ground up and now has multiple levels with multiple archetypes of enemies who will chase you – it’s also different in Dog Town compared to Night City.
“We’ve also redone the loop and whole progression of the game; the difficulty curve is different, the tiers and drops of loot is different, the archetypes of enemies has been redone for more variety. Those are the core things that we’ve changed, and if you look into it there are very few systems that we didn’t change or update. Even the UI and UX have been greatly updated.
“We also looked at the criticism for example of the open world. When you play the base game versus Phantom Liberty, you will see the difference. For example, there are car chases that happen dynamically when factions fight. AI improvements mostly extends to enemies. Your followers, like you saw with Agent Reed in the demo, can also use it, but pedestrians are mostly bug fixes.”
Järjestelmävaatimuksissa tulossa iso hyppy. Jo 1080p 60 FPS vaatii aika tykin prosessorin. Varmaan liittyvät tuohon isoon päivitykseen, joka parantaa avoimen maailman immersiota ja tekoälyä. Vaativat enemmän laskentatehoa. Nytkin jo aika vaativa peli prossulle.
Saa nähdä, milloin tuo päivitys tulee. Seuraavaa läpipeluuta ei viitsi aloittaa ennen sen julkaisua. Suunnitelmana oli aloittaa uusi hahmo ja pelata päätarina loppuun ennen lisäriä. Jos päivitys julkaistaan DLC:n kanssa samoihin aikoihin, niin sitten on lykättävä.
Tuli katsottua eilen illalla tuo traileri ja ensimmäisenä tuli mieleen että juoni on kopioitu lähes suoraan "Escape from New York" :sta :D
Ai lisäosa pitäisi ennakkotilata? Eikö tämän pelin julkaisusta otettu mitään opiksi:lol:
Lupauksia, suuria puheita ja pettymyksiä. Toivottavasti jotain on opittu ja keskustelu ei palaa tuohon tämänkin ketjun ~70 sivun mielipahaan nyt syksyllä. Minä en markkaakaan laita CD Projektin pelkkiin lupauksiin ja suuriin puheisiin.
Rautavaatimuksia prossjen osalta katellessa herää vähän kysymys, että pärjääkö 6-ytimisellä 7600X:llä maksimit lasissa, kun 7900X:ää vilautellaan. Toisaalta useinhan nämä vaatimustaulukot on vähän mitä sattuu ja nytkin tuolla on prossu, jota ei edes ole olemassa (Ryzen 7 7800).
Mutta tuleeko muutokset jos et osta lisäosaa? Eiköhän mutta tulipa mieleen :rofl2:
Tässä ennakossa puhuttiin mm. paremman vihollisten tekoälyn, poliisien ja uusitun perkkijärjestelmän tulevan myös peruspeliin. Ilmeisesti tekijät hypenttävät nyt lisäosaa ja muutoksista peruspeliin kerrotaan lähempänä jukaisua.
Osa muutoksista tulee patch 1.7 muodossa, oletettavasti kaikille peruspelin omistaville. Sitten taas toinen osa muutoksista, varsinkin nuo laskentatehoa vaativat, tulee sitten oman käsityksen mukaan tuossa maksullisessa laajennuspaketissa, jota ei ole saatavissa last gen konsoleille. Saa nähdä miten linjajaon tekevät, koska laajennus vaikuttaa ymmärtääkseni aika paljon peruspeliin mekaniikkapuolella, kuten myös juonipuolella (uusi ending, jne).
Varovaisen positiivisesti suhtaudun tähän. Ovat saaneet tehdä tätä aika rauhassa, ja paistaa tietynlainen halu paikata peruspelin puutteita joita aikanaan tunnetuin seurauksin jäi pois paketista. Tuolla hinnalla jos julkaisevat katteettomia lupauksia tai paskaa niin se on taloudellisesti firmalle liian iso kolaus kestettäväksi kun ei ole seuraava Witcher ihan parin kuukauden päässä pelastamassa. Tajuavat varmasti itsekkin tuon...
Saa näköjään kuvan perusteella laittaa ostopöksyt jalkaan ja ainakin prosessorin käydä upgreidaamassa viimeistään syssymällä / loppuvuodesta.
Vielä kun viitsisi pelata tuon yksinpelin läpi. Enemmän aikaa on mennyt pelimaailman ihmettelyyn ja kaikenmaailman kuutamokeikan heittämiseen.
Sellainen korjaus, että viimevuotinen 1.6 jäi jo viimeiseksi sisältö&ominaisuuspäivitykseksi vanhoille konsoleille.
Lisäksi
So I got to play a lot of Phantom Liberty and my ultimate take away is that in the past three years CDPR has essentially remade the entire game. Every single fundamental and mechanic is improved. Like even the character models have been remodeled.
Leveling is now skill based so you’re unlocking new attacks and abilities not just getting small stat increases. Clothes no longer give you stats or armor, (unless it is literally armor) stats come from your cyberware which places greater emphasis on customization.
You do have a body limit so you can’t chrome out too much without taking an HP decrease which makes you actually think about how you customize yourself. The police system is everything you wanted, MAX TAC come in via drop ship. Police and Gangs now chase each other and you.
Leveling cyberware on a new skill tree unlocks special abilities like overdriving your gorilla arm punch smacking enemies into the stratosphere. Ai is vastly improved, they block and hide behind cover. I couldn’t just run up to a still target and kill it easily.
The melee combat feels a lot better and dodging is now it’s own button, you can anime zip to a point now instead doing that tiny hop. There are also stylish executions on its own button. And you can block bullets with your blade weapons.
And honestly there are too many other changes and improvements to recall right now. It’s like a brand new game. It’s fuckin great.
All of these changes are also coming in the base game, it’s not just in the expansion. The entire game has been redone with this stuff.
Ostin vihdoin tämän (peruspeli) ja mietin, että refundaanko samantien ihan periaatteesta kun ei vittu tämän kaliiperin pelistä löydy vittu TOGGLE AIM - optiota olleenkaan. Herranjumala mitä paskaa.
Itse odotellut mielenkiinnolla tällaista "oikeaa" versiota, tuo ensimmäinen peliversio oli vaikeimmallakin tasoilla niin naurettavan helppo, että koko peli oli vain interaktiivinen elokuva ja maailma ei ylläpitänyt immersiota pätkääkään ainakaan minulle... Ainakin kun johonkin levelille 20-30 pääsi, oli pelitavasta riippumatta jokaikinen quest yhtälailla tylsä taistelun haasteettomuuden takia. Musiikkia ja parhaiden NPC dialogia lähinnä tuli kuunneltua. Itse pidin peliä suorastaan huonona, siitä näki että kaikki mitä oli suunniteltu oli jätetty puolitiehen, mitä ollaan vihdoin korjaamassa, hienoa!
Tuollaista tylsien ja suhteellisen surkeiden DPS numero %-taikinan, sekä levelaamisen/perkien parannusta kohti interaktiivisempaa pelimekaniikkaa kyllä odottaa innolla, ehkä ei tule keskityttyä enää (toivon mukaan) DPS numeroihin vaan taistelutaktiikkaan ja eri tekniikoihin ja pelimaailmasta tulee taas mielenkiintoinen.
Prätkän fysiikat on muutenkin melko karseat. Mukava niillä on suoraan ajella mutta mutkat menevät melko erikoisesti :D Tuleekohan näiden fysiikoihin parannusta Phantom Libertyssä?
Toivottavasti. Tuntuu siltä, että ovat ottaneet CDPR:lla aika paljon vaikutteita ja parannusehdotuksia laajennusta tehdessä noista peruspeliin tehdyistä modeista. Kenties jopa maksaneet modaajille heidän luomansa sisällön lisäämiseksi laajennukseen (tekivät saman Witcherin kohdalla). Autojen ja pyörien käyttäytymistä parantavia modeja on monta ja ne on suosittuja, eli tarvetta pienelle parannukselle on ollut pelaajien keskuudessa havaittavissa. Laajennuksessa on mahdollista ilmeisesti pultata autoihin kiinteitä aseistuksia, tai siellä on autoja joissa aseistusta on asennettuna, ja alkuperäsen ajotuntuman mukaan siitä ei varmaan tulis kuin sanomista, joten jotain ovat varmasti jo tuon puoleen tehneet.
Processor Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz 3.40 GHz
Installed RAM 16.0 GB
GTX 980 4gb
Onkohan mitään jakoja saada pyörimään edes ihan minimeillä ?
GTX 980 4gb
Jos se toimii nykyisellä 1.6 versiolla juuri ja juuri pelattavasti ihan minimeillä ni sanoisin että ei se hauskaa ainakaan tule olemaan. Riippuu vähän mihin on tyytyväinen, näkeekö 20fps pelattavana vai 40fps...
jep sitä vähän pelkäsinkin, ps5 on hankinnassa sitten joskus.
Välillä on ollut pelejä jotka on pyörineet ihan sujuvasti , vaikka on menty reilusti alle minimivaatimusten.
Tuli tämä nyt ostettua alesta, mutta toisaalta mietin onko mitään järkeä aloittaa ensimmäistä läpipeluuta nyt. Siihen tulokseen tulin, että vaikka pelin aloittaisinkin ilman modeja ihan vain kokemuksen takia, niin en varmasti kestä koko peliä ilman modeja. Niin paljon perusasioita on mahdollista korjata vain modeilla, että hermothan tuohon menisi.
Lisäksi lukemani & yllä mainitun perusteella tuo 26.9. tuleva Phantom Liberty päivitys korjaa peruspelistä niin monta asiaa, että ehkä pitäisi suosiolla aloittaa peli vasta silloin. Ja kaiken lisäksi tuo päivitys varmaan rikkoo useimmat modit saapuessaan, eli menisi koko läpipeluu muutenkin sekaisin..
Itse en enää ennen lisäriä kyllä aloittaisi.
Korkeintaan testailisin mekaniikoita, ja tutkisin pelimaailmaa etenemättä tarinassa alkua pidemmälle. Samalla pystyy opettelemaan sen modien asentamisen ja käyttöön oton, että on sitten nopea päättää PL julkaisun jälkeen mitä modeja haluaa edelleen siihen lisätä, ja ne osaa helposti ottaa käyttöön.
Uusi päivitys 1.63, pieniä bugikorjauksia taitaa olla lähinnä
(Viimein myös Ryzen 7000 ja DLSS Frame generation toiminee oikein...)
EDIT: toimii frame generation, eikä stutteroi
Jep peli poistukoon Steam-kirjastosta odottamaan parempia aikoja. Starfield julkaistaan ennen lisäriä, joten saas nähdä siirtyykö Cyberpunk jälleen seuraavaan kalenterivuoteen :)
Kova luotto toki siihen että Bethestan muinaisella enginellä kyhätty peli olisi julkaisun aikaan bugiton ja olisi siedettävä ilman modaajien tekemiä korjauksia. :smoke:
En kyllä tiedä mitä modeja tämä nykyisellään erityisesti kaipaa, ainakin Nexus sivun eniten ladattujen listalla ei hirveästi tullut mitään maata mullistavaa vastaan. Toki nuo moottoripyörät tietyssä mielin käyttäytyy kuin kiskoilla ajaisi. Omat kokemukset konsolilla ja olikohan 1.3 vai 1.4 versiosta eteenpäin aina silloin tällöin pelaillut eteenpäin.
Yhtä motskarimodia kokeilin (en muista nimeä) niin ei se ainakaan parantanut ohjausta. Palasin heti takaisin oletukseen. Onko heittää hyvää modia siihen?
Eipä ainakaan itselläni ole ollut mikään kiire tämän pelin pariin. Julkaisun aikoihin koneeni oli RTX OFF ja aloitusta oli helppo lykätä. Nyt sitten kun on rautaa rajalla, jatkuvasti on henkisesti kiinnostavampaa pelattavaa ja tämä on saanut odottaa ”pari päivityskierrosta vielä”. Ehkä tosiaan ensi talvena voisi tämän aloittaa Starfieldin ja AC Miragen toki kilpaillessa piikkipaikasta (ja kyllähän ne voittaakin :D)
Tuli ostettua Steamin kesäalesta. Pätevältä vaikuttaa. DSLL päällä RTX3070 mobilella pyörii mukavasti melkein kaikki grafiikka-asetukset tapissa. 5 tuntia pelattu. :)
Ei millään pahalla, mutta huono aika aloittaa läpipeluu. Kun se laajennus tulee, niin käytännössä peli muuttuu niin paljon, että on pakko aloittaa alusta (kykyjärjestelmä muuttuu täydellisesti)
Sittenhän sen voi suoraan pelata uudestaan, kun kerran muuttuu kokonaan. Ja eihän peli muutu ellei osta sitä laajennusta (itse kyllä ostan).
Kyllä muuttuu. Se uusittu kykysysteemi ja muut parannukset tulevat kuulema myös peruspeliin vaikka et ostaisi sitä laajennusta.
Jokohan tämänkin pelin voisi laittaa ostoon, kerta viimeaikaiset arvostelut ovat olleet jo muutenkin hyviä ja jos nyt peli vielä paranee entisestään.
Nyt saisi -50% alennuksessa Steamin kesäalesta, joten ostaminen voi olla kohdallaan (uskoisin ettei peli ole hetkeen alennuksessa DLC:n julkaisun jälkeen?). Pelaamaan en alkaisi ennen kuin tuo 26.9. julkaistava päivitys tulee (lukemani perusteella, en itsekään ole vielä aloittanut vaikka alesta ostinkin).
kuullostaa vähän siltä että tässä DLC:ssä luovutaan statseista aseissa ja vaatteissa. Skill tree on poistettu ja korvataan erilaisilla liikkeillä ja hyokkäyksillä. Cyberwarea on nerfattu rajoittamalla parannuksien määrää ja lisätty relic osio mitä pystyy parantamaan pelaamalla tuota DLC:tä. Pärrällä voi käyttää melee aseita ja joihinkin ajoneuvoihin on lisätty aseistusta. DLC:ssä eri jengit taistelevat toisiaan vastaan satunnaisesti esim jahtaamalla toisiaan autoilla ja kadulla liikkuvien NPC hahmojen käytöstä on korjattu
Sanoisin että kannattaa pelata vielä läpi kun kerkeää jos haluaa hahmon mikä on hyvä kaikessa. DLC's kun ostaa ja päivittää pelin niin sitten täytyy alusta asti valita millaisen hahmon haluaa kehittää esim räiskintä, melee vai hakkerointiin perustuvan.
Minusta kuulostaa, että pelistä tehdään juuri sellainen millainen sen olisi alun perin pitänyt ollakin. Tylsää on, jos hahmo on hyvä kaikessa eikä tarvitse edes yrittää erikoistua siihen omaan pelityyliin.
vielä pystyy erikoistua kaikkiin tyyleihin ja pelata tehtävät läpi kaikilla eri tyyleillä. Jotkut räiskimällä etu ovesta sisään tai hiipimällä muuta kautta, joko teräaseilla tai melee aseilla, hakkeroimalla. Päivityksen jälkeen kun vaate statsit on poistettu ja siirrety cyberware statseihin ja skill tree korvattu cyberware liikkeillä tuo ei ole mahdollista. Mainittiinhan tuossa että lootti on kans vaihdettu ja vaikeustasoa muutettu eli luultavasti olet jumissa siinä yhdessä peli tyylissä koko loppu pelin. Tietysti tuo lisää uudelleen peluu arvoa, mutta itse tykkäsin siitä kun jokaisen eri paikan pystyi läpäisemään eri tyyleillä tilanteesta riippuen
Antlous
