Corsair ML-sarjan tuulettimet (MagLev)
Ledeistä en vain tykkää, eli haluaisin tuularin pimeäksi.
Riittävästi vain värivaloja kehiin niin jospa ne äänet unohtuvat...
Ihmisaivothan ovat tunnetusti huonot moniajoon.
Onko kukaan verrannut näitä ML:iä elooppeihin?
SilentPCreview totesi eLoopit akustisesti keskitasoisiksi, niin eiköhän ML voittaisi.
The B12-2 unfortunately lacked the broadband quality of the M12 series. At 1,200 and 1,100 RPM the fan droned somewhat, while at 900 RPM, a slightly dull buzz was noticeable. At 700 RPM, some tonal elements centered at ~90 Hz crept in. This combination of characteristics is undesirable but in the B12-2's case, they were fairly muted. The overall sound was acceptable.
Visually, the B12-PS is identical to the B12-2 but we noticed an immediate difference the moment it was turned on. The B12-PS was easily the worst sounding fan of the roundup. It was a buffet of all the sounds you don't want to hear in a fan. At top speed, it whined, buzzed, and hummed, all simultaneously, and from there it just got worse. At 1,100 RPM the fan slowed to the point where a very strong, dirty tone revealed itself. As we slowed the fan further, this tone started to fluctuate, vacillating in frequency. We thought at first that there was something wrong with our motherboard's PWM controller so we tried it on another motherboard and a voltage controller but it sounded the same.
We also had a triple set of the B12-P, a second PWM version that spins at 2,000 RPM. It had a similar character but when dialed down to speeds equivalent to the B12-PS, it developed an odd rattle...
Fan Roundup #7: Antec, be quiet!, Corsair, GELID, Noiseblocker, SilverStone | silentpcreview.com
Heh heh. Olipas hauskaa.
Lähinnä se että tuollaista yksiväristä led mallia saisi huomattavasti halvemmalla kuin muita. Ledeistä en vain tykkää, eli haluaisin tuularin pimeäksi.
Jollain ikivanhalla zalmannin ledi tuulettimessa oli erikseen 2-pinninen liitin joka oli pienessä lenkissä tuulettimen johdon tyvessä. Oli kätevä kun sen vaan irrotti niin ei ollu ledit päällä.
Tuossa äskettäin omat dual packin "non prot" asensin ja ensituntumat.. no. Eipä oo kaksiset. Ainakin toinen tuulettimista mielestäni rallattelee täälläkin. Ja ellei satu tarvitsemaan noita yli 1000rpm nopeuksia (eli n. 40-100%), en näe syytä miksi näitä on niin julmetusti hehkutettu.
Noiden edellä oli Bitfenixin spectret, jotka maksimikierroksillaan 1200-1300rpm tietämillä pitivät vielä aivan miellyttävää ääntä. Hankin ML120 siinä toivossa, että pölyfilttereiden läpi liikkuisi ilma paremmin, mutta samalla melutasolla lopputulos aivan sama, ainakin kotelon lämpöjen osalta. Spectreistä ei sen sijaan kuulu mitään turhia sivuääniä.
Hyvät on ollut mainospuheet, mutta palautukseen lähtee heti kun seuraavaksi on Verkkokaupan suuntaan asiaa
Saako vialliset ML:t palauttaa takuuseen tuon rallatuksen takia vai meneekö omasta pussista? Jotain tuollaista ihmettelin @mRkukov keissistä jossa tupla pakkauksia ei ole enää voinnut palauttaa, mutta pitäähän noissa nyt prkl takuu olla? Voi sitten ainakin myydä uusina ja avaamattomina eteenpäin pienemmällä tappiolla jos joku haluaa riskiä ottaa..?
Mitä taas elooppeihin tulee, niin itselläni moiset ajelee freenassissa 2kpl ~700 rpm kieppeillä ja ovat erittäin hiljaisia. Kennolle eivät sovi pulliin ja käsittääkseni ei sovi (ainakaan hyvin vaakatasoon).
Koska laakerit ovat jotakuinkin samat, kiinnostaa eritoten miten maglevit toimivat pullissa esim UT60 kennolla jossa demiflexin filtteri edessä. Push menee hankalammaksi toteuttaa ja vaatisi eteen kuitenkin filtterin. Noh, tutkiskelen asiaa.
Minun keissi jossa ei voitu palauttaa? Ainoa "case" oli siis CDON, jossa koko asiakaspalvelu on täyttä paskaa. Alkoi tapahtua vasta kun kuluttajaneuvona ehdotti riitauttamista. CDON.com -ketju
Nyt nämä uudet laitoin suoraan postin asiakaspalautukseen verkkokauppa.comiin täysin myyntikuntoisina. Yhdestä paketista puuttuu tarra, mutta sitäkään ei huomaa ellei tiedä sellaisen puutteesta. En edes miettinyt etteikö myyntikelpoista pakettia saisi palauttaa, tietysti saa.
Tilasin nyt myös 6x prot samasta paikasta. Katsotaan josko vihdoin saisi toimivat tuularit koneeseen.
Kävin kans palauttamassa tuulettimet. Odottelen innolla onko ne pro mallit sitten ilman rallatusta. Jos on niin lähtee tilaukseen kans täältä. Tosin 140e menee pelkkiin tuulettimiin. hyhhyh
Mulla meni ainakin Jimssiin takuuseen nuo tuulettimet ku hiljasella nopeudella rallatti. Tilasin Pro led mallit tilalle. Katsotaan rallattaako nuo uudet.
Itsekin palautin koko setin. Non-pro mallit rallattaa. Piste.
Nyt sain pro malleja 6 kpl ja arvatkaa mitä ensimmäinen tekee? No ei rallata, mutta visertää niin perkeleesti. :D
Heti toinen testattu pro malli olikin sitten ehjä. Ehjä ja hiljainen. Ei todellakaan sitä non-pro mallin rallatusta. Tuota pro mallia ei 30+cm päästä voi kuulla... nyt testaamaan loput 4 kpl, mutta hyvältä vaikuttaa tämä pro. :)
Edit:
Ehjiä ja äänettömiä testattu: 3
Visertää: 1 kovaa ja 1 hiljempaa.
mitä hemmettiä? Eikös noissa tuulettimissa pidä aina olla jännite? Otat tuulettimen irti?
Lienekkö kevät tulossa, kun noin iloisesti ja äänekkäästi Corsairin MannenLaatu tuuletin visertää :lol:
Pitäähän joka talossa nyt kotisirkka olla...
Näinköhän tuo olisi jotain yksilövaihtelusta riippuvaa käytöstä tuulettimen sisäisen PWM:n takia...
Eihän sen pitäisi sitä moottorin kannalta miksikään muuttaa tehdäänkö se pätkintä jo ennen tuuletinta vai tuulettimessa.
Laakeriäänen kun sen ei pitäisi olla, niin kovin outoa se rallattelukin.
Rallattelu oli tosiaan "moottoriääni" noissa non-pro malleissa. En usko että se olisi mitenkään laakerin syytä.
Tuo sirkuttelu taas vaikuttaa juurikin laakerivialta. Se ei nimittäin lopu johdon irroittamisessa, vaan jatkuu kunnes tuuletin pysähtyy.
Nyt olen testaillut noita kaikkia kuutta pro tuuletinta:
-Yksi menee suoraan takuuseen, tuo sirkuttelija.
-Kaksi näistä on lähes täysin äänettömiä.
-Kolme taas pitää hyvin heikkoa sirkutuksen tahtista sihinää. Sihinä varmaan paras termi kuvaamaan tuota ääntä. Tuntui että se vaihteli miten päin tuuletinta pehmusteella piti. Yksiä päin se saattoi olla selvä ja voimakas, mutta toisin päin hyvinkin pieni, lähes huomaamaton.
Testasin myös teoriaa siitä että nämä ottaisi itseensä kovista iskuista. En voi vahvistaa teoriaa, päin vastoin. Kunnon kolkuttelut polvea vasten (auts) tuntui jopa hiljentävän osan sihinöitä. Polvikäsittelyyn pääsi kaikki 6 tuuletinta ja tuo sirkka ei kyllä opiksi ottanut. Sirkutusta ei siis kolkuttelemalla paranneta, mutta muuten väittäisin että tilanne jopa parani.
Täytynee siis testata nämä 5kpl tuohon radiin kiinni. Ajelen ensin hetken aikaa tuossa pöydällä pehmusteen päällä, josko joku alkaisi vielä sirkuttaa. Periaatteessa tuollainen magneettilevitaatiolaakeri pitäisi varmaan "parantua" vain ajan kanssa eikä huonontua. Saas nähdä.
Edit:
Niin ja nyt 850rpm kanssa nämä ovat tosiaan erittäin hiljaiset. Voittaa helposti vanhat tuulettimet samoilla nopeuksilla. Ei kyllä tule ikävä non-pro malleja. :D
Magneettilaakeroinnin kun pitäisi poistaa esim laakerin löysän ja sellaisten aiheuttamat äänet, niin ei voi kuin ihmetellä tuota rallattelua.
Toisaalta päästäisikö tuo magneettilaakerointi tuulettimen jotenkin värähtelemään?
Servereissähän ääni ei ole pääasia, vaan luotettavuus/pitkäikäisyys, niin siellä tuollaiset pienet värähtelyt menisivät täysin.
Edit:
Asiallista. Mä kans pistin tilaukseen 5kpl noita pro malleja. Pidän valkoisesta valosta ja sitä ennestään löytyy komponenteista mutta toivottavasti tuulettimien ledit eivät tee överiä valaistuksen suhteen tietokoneessa. Toivottavasti ainaki osa ois ehjiä ettei tarvi alkaa tähä palautusrumbaan ku nytki tietokone on jo viikonlopun yli ollu passiivisella vesijäähyllä :D
Edit: lisään vielä että aloin itsekseni nauramaan tota että mun tuurilla varmaan kaikki 5 sirkuttaa tuollain ja voin vaan kuvitella että minkälainen viidakon ääni siitäki syntyis :rofl:
Kotisirkalla on ääni pätkivä, niin josko se onkin tuo heinätöpökatti mitä nuo Corsairit ovat syöneet:
Suomen heinäsirkat ja hepokatit (Orthoptera)
Vierailehan itäisessä Suomessa telttailemassa loppukesästä, niin pääset tunnelmaan.
Kannattaa vain ottaa korvatulpat/kuulosuojaimet mukaan.
Joop. Asensin nuo 5 radiin push/pulliin ja harmikseni useampikin noista alkoi hiljalleen ujeltelemaan. Sellaista ujoa ujeltelua joka loppuu heti kun vaihtaa kierroksia. Sitten taas hetken pyörittyä alkaa hiljalleen ilmetä uudestaan. Täytyy toivoa että pienellä sisäänajolla se loppuisi.
Mutta piru vie, on nuo kyllä hiljaiset! Kunhan tuo ujeltelu loppuisi niin todella äänettömät tuulettimet. Parasta myös se ettei kierrosten vaihtelu lämpöjen mukaan aiheuta mitään lisä-ääniä. Päinvastoin, tuo ujeltelu katoaa aina kun kierrokset vaihtaa tahtia.
Heti ku toi video alko niin näin vaan mun tietokoneen jossa oli 5kpl tuulettimia pitämässä tota sirkutusta noin 1200rpm kiekoilla :rofl:
On kyllä tähän threadiin hyvin aiheellinen video :rofl:
Mukava lukea, että muutkin kuulevat näiden paskojen rahinat, ujellukset ja sirkutukset.
Siitä sitten vastapainoksi 7x ML140 karvalakin kokoonpano ilman sirkutuksia, vihellyksiä tai ulinoita.
Videolla 500 -> 700 -> 1800 -> 700 RPM
Suurin melun lähde on radin takana oleva D5 pumppu.
Kait tässä pitää alkaa täyttelemään lottokuponkia, kun kaikki ML sarjalaiset ovat toistaiseksi olleet hiljaisia, vaikka ovat eri kaupoista ja eri aikoihin ostettu. :smoke:
Samaa rahinaa nuo kuulostaa pitävän alle 1000rpm ku mullaki. Mua ainakin häiritsi tuo ääni mitä ne pitää alle tuon 1000rpm ja tuulettimet meni takuuseen. Niinkuin jo ylempää ilmi kävi (mitä todennäköisimmin, tai ainakin uskon jo niin), nuo non-pro mallit kaikki pitää tuota pientä rahina ääntä pienillä kierroksilla.
Tuo on kyllä sen luokan ääni ettei kuulu 5cm tuulettimesta kauempana. Avoimessa kokoonpanossa ilman kotelon kylkiä tai etupaneelia voi kyllä olla häiritsevä.
Pientä rallatusta tosiaan itsekkin olin kuulevinani. Vaikea sitten sanoa :D Just tuli taloon viinikaappi ja saa lähteä pois. Kuulostaa samanlaiselta kompuran pärinältä :D
Voi hyvin olla että ne alkupään non-prot olivat todellisuudessa samoja moottoreita kuin pro malleissa. Nyt kuitenkin isoista kaupoista (cdon.com ja verkkokauppa.com) löytyvät ovat kaikki noita rallattelevia malleja.
Pro malleissa tosiaan on sama "rallatus" ääni, mutta sitä ei oikeasti kuule yli 10cm päähän. Se on niin hiljainen etten edes laske sitä ääneksi. Non-pro mallien rallatus kuului puolestaan yli 5m päähän, eli todella voimakas. Ja testasin tosiaan 13kpl non-pro malleja ja kaikissa identtinen rallatus.
Näin. Turhapa siitä on vääntää kun sulla on noista useammalla videolla ja useammissa non-pro malleissa selvästi kuultavana.
Tuohon pohjautuen en itse enää suosittelisi noita dual-packeja vaikka itselläni onkin hiljaisia malleja. Pelkästään Pro malleja tai noita uusia sikahintaisia RGB malleja jos haluaa lisää väriä.
Mitens nämä noctuan chromax.black.swap mallit verrattuna ML? Kokemuksia?
Jep. Tämän päätelmän itsekin tekisin. Vanhat ML120 non-pro mallit voi olla äänettömiä, mutta nykyiset kaupasta ostettavat (ainakin dual packit) ovat todennäköisemmin jo noita kovaäänisiä. Niissä se kovaäänisyys ei ole tuurista kiinni, vaan kaikki meluavat.
5kpl Pro malleja pyöri yön yli ja vaikuttaa siltä etteivät ne sirkuttele/ujeltele kunhan ei päästä kierroksia alle 700rpm. 700rpm on kuitenkin jo niin hiljainen/äänetön ettei sitä kuule edes metrin päähän, eli 700rpm kelpaa hyvin miniminopeudeksi.
Parasta noissa on silti tuo täysin häiriötön nopeuden vaihtelu. Eli vihdoin ja viimein saan push/pull setupin säätymään lineaarisesti lämpötilan mukaan ilman sivuääniä. Niin ja push/pull konffista aiheutuvat häiriöäänet tuolla 60mm paksulla radilla alkaa vasta 1500rpm tai yli. Eli soveltuu hyvin push/pulliin. :tup:
6kpl tilauksesta vain yksi lähtee huoltoon. Syy löytyy tuosta ylempää. Sirkutus kuului helposti yli 10m päähän. :D
Tiputtakohan voltteja tai virran määrä jos menee alle 700rpm? Mietityttää kun monella on erilaiset nuo hubit.
Ymmärrätkö mitä eroa on volteilla ja virralla? :D
Virta toki laskee kun kuorma pienenee. Voltteja taas ei saa laskea, koska magneettilevitaatio. Jos hiusta halotaan niin laskemalla virrankulutusta nousee voltit hieman kun tehohäviö johtimissa pienenee.
Mutta joo, älkää missään nimessä volttiohjatko näitä tuulareita. Tasan 12v ja PWM hoitaa nopeussäädön. Muuten menee rikki.
No oletko mittarilla erikseen tarkistanu? Kyllä ymmärän...
Pari sivua taaksepäin löytyy jännitteet ja ampeerit. ;)
Edit:
Mitattu viimeisen tuulettimen pinneistä (5 tuuletinta kiinni):
700 - 2400 rpm
12.24 - 12.17 Volttia
0.09 - 0.99 Ampeeria
Eli täydellä (2400rpm) teholla 5 tuuletinta kuluttavat 12 Wattia. Eli 2.4W per tuuletin.
Eiks juuri totavarten nestettä suositella kivien päälle? Ohjaus nesteen lämpötilan mukaan, niin loppuu sahaaminen.
Tuohon en kyllä koske vaikka lähtisi lentoon koko SER-jäte. :D
Täytynee vaan siis säätää biosista lisää..
Speedfan on ihan paras softa tohon hommaan joten mikä mättää :confused:
Vai onko se vaan perinteinen laiskuus taas kyseessä kun ei viitsi opetella tuota softaa...
Jos käytettävyys on samaa luokkaa kuin joskus viime vuosikymmenellä, niin ei kiitos. Toki prossu vielä korkkaamaton joten ei ihmekään että hieman mölisee :vihellys:
On se vähän hankala mutta Youtubesta löytyy videoita millä saat sen säädettyä 5 minuutissa minkä jälkeen voit antaa sen hoitaa hommansa taustalla ja unohtaa koko softan.
Omassa emolevyssä Speedfan ei toiminut lainkaan, tunnisti puolet fan controllereista ja nekin väärin.
Kuten kettu sanoi, tuulettimien ohjaus nesteen lämmön mukaan niin hyvä tulee. Aquaero tai Commander Pro kehiin.
Noniin elikkäs
3x ml120 pro white led
2x ml140 pro white led
Yksikään ei viserrä tai raksuta. Vain pieni tuhina kuuluu, joka on ihan oletettavaa. Mutta ei yhtikäs mitään sivuääniä. Jokasen testasin yksitellen eri kierrosnopeuksia kokeillen. Pysykää ihmiset kaukana noista non-pro malleista :D
edit: Yksi tuuletin alkaa visertää joskus kun laittaa 850rpm. Sitten kun nostaa kierroksia se häviää ja kun laskee niin se ääni tulee joskus takaisin. Jännä juttu.
Kysymys: Onko kukaan poistanut noita tuulettimen tarroja? Ahdistaa kun tarrat ei oo täysin keskellä tuulettimen pyöriessään se heittelehtii se tarra. Yhdessä tuulettimessa on tarra lähes täydellisesti keskellä :D
Laitanpa tännekin:
Vaihdoinpa vihdoin kaikki tuulettimet BIOS säätöön pois tuosta bugaavasta AiSuite:sta. Pari kertaa kävi niin ettei AISuite enää ohjaillutkaan mitään, eikä ilmoitellut mistään ongelmista. Huono softa, mutta sillä voi hyvin hakea arvot mitä sitten syöttelee BIOSiin. Biosiin sain arvot syötettyä vasta sen jälkeen kun vaihdoin nopeussäädöt "auto" asetuksesta PWM modeen. "auto" ei todellakaan toimi, vaan kun yritin tehdä säätöä niin pakotti PWM ohjatut tuulettimet 100% nopeudelle, tai toisinaan minimissään 60%. Asettamalla PWM moden manuaalisesti sai tiputettua alle 30% (kunhan ensin ajaa fan tuningin).
ML120 Pro tuulettimien (400-2400rpm) säätö veden lämmön mukaan:
min 32% lämpötilaan 34°C asti
mid 50% lämpötilaan 42°C
max 100% lämpötilassa 43°C
x-akseli mittausaika 20min. CPU + GPU mining rasitus, molemmat OC+OV.
1. Suljin Fractal R5 etuoven, jonka takana radi on puhaltamassa sisään. Tuulettimien nopeus nousi oven sulkemisen takia noin 10rpm.
2. Avasin R5 etuoven, lämpötila oli juuri kohoamassa (piikki heti jälkeen). Ovi kiinni olisi 1100rpm.
3. Irroitin 2/3 peittävän pölysuodattimen
Sanoisin että noista ML120 Pro malleista kannattaa valita niitä 1600rpm malleja niin saa tasaisemman säädön. Näillä 2400rpm malleilla saa toki pölyt putsattua kun heittää vain täysille. :D
ASUSin UEFI myös ihan susipaska säätämään noita. Itsellä ei tunnista yhden maglevin duty cycleä ollenkaan vaan minimiksi laittaa aina 60%. Hystereesi myös toimii aivan päin persettä ja tuulettimet keulittaa miten sattuu.
SpeedFanin kun laittaa ottamaan säädön pois UEFI:lta niin vallitsee täydellinen hiljaisuus. Hystereesi toimii ja kaikki tuulettimet säätyvät sekä CPU- että GPU-lämpöjen mukaan. Ei voi kuin suositella. Toki vaatii sen 20 minuutin paneutumisen siihen miten tuota sovellusta ajetaan se kun on vähän 90-luvun paradigmalla rakennettu ja selvästi suunnattu edistyneelle käyttäjälle.
Mulla ei ainakaan asusin uefi sekoile säätöjen kanssa. Tosin eipä nuo koskaan kovin lujaa pyörikkään, varmaan 500-800 välillä. AiSuite kyllä saattoi välillä sammutella ja sahailla itsekseen niin se piti sitten poistaa. Ajattelin laittaa yhden ml:n lisää taakse kattoon kopassa. Mulla on nuo muut ml 120 pro, niin voiko sille 140:n laittaa sit samaan käyrään? Ajan nyt nuita kaikkia kolmea cpu_fanin kautta lisävirrallisella jakajalla ja tolle cpu_opt ei kait saa laitteua omaa käyrää?
Ajaa sen "auto fan tuning" niin se tunnistaa minimit. Sitten pakottaa portille PWM säädön niin johan saa säädettyä. Hystereesi tosiaan paskaa, mutta toisaalta veden lämmöt ei kauheasti seilaa nekään. Vieläkö speedfan tukee uusia emolevyjä? Viimeksi kun testasin niin ei tukenut.
Update:
"Last modified on 30 oct 2015. "
Ei ainakaan asusilla. Se vaan peilaa CPU_FAN liitintä.
Update:
Juu ei tunnista vaikka miten päin ajaisi fan tuningia UEFI:sta tai sitten sillä ASUSin paskasoftalla Windowsista käsin. :) Varmaan miljardi kertaa koetin.
SpeedFan tukee ainakin omaa z370 Strixiä. Ei varmaan ole tuo ohjainpiiri vaihtunut muutamaan generaatioon Intelin alustalla ainakaan.
Sanooko se aina että xx -> 60 vai jotain muuta? Itsellä oli myös lukossa 60% kunnes pakotti PWM moden päälle.
Tietysti jos speedfan toimii niin en uefi säätöön koskisi itsekään. Pakko vain sitä kautta säätää kun vaihtoehto (ei ole) tuo aisuite.
Speedfan ei tue vielä mitään AM4 emolevyä, enkä usko että vähään aikaan tulee tukemaan. Se on kyllä omasta kokemuksesta aivan loistava softa mutta koska on yhden henkilön kehityksen varassa niin tuki ja kehitys omalle raudalle on vähän arpapeliä.
Tosiaan ostin tossa aikaisemmin 5kpl ml PRO sarjan tuulettimia. Yksi sirkutteli vähän. Tätä tapahtui satunnaisesti kun tuuletin oli hetken pyörinyt tietyssä rpm:ssä hetken. Sirkuttelu loppui kun tuuletin vaihtoi nopeutta. Ja taas alkoi hetken päästä kunnes oli ollut samassa rpm:ssä hetken. Mutta ihan parin päivän jälkeen sitä ei ole enää ollenkaan kuulunut. Eli jonkunnäköisen sisäänajon nuo vaatii :D Pelkäsin jo että joudun sen palauttamaan takuuseen. Nyt oon kyllä ollu todella tyytyväinen näihin tuulettimiin ja ei voi kun suositella jos lompakko antaa myöden. Jouduin irrottamaan mekaanisen kiintolevyn sen ollessa suurin äänilähde. Seuraavaks ongelmana virtalähteen tuulettimen äänekkyys...
Ihan koko ketjua en jaksaisi lukea läpi ja vähään aikaan ei ketjua muutenkaan ole tullut seurattua joten;
Mikä/mitkä fan-hubit nyt antaa tarpeeksi jännitettä ja ovat näitä aitoja pwm-hubeja joilla vältyn vahingoittamasta näitä ML:iä?
Emon PWM-liitännät kun loppuvat ikävästi kesken.
Hubissa saa olla RGB-säätöjä, mutta ei pakko, kunhan olisi optimaali näille ML:lle.
https://www.corsair.com/eu/en/Categ...ngType:Magnetic+Levitation&text=#rotatingText onko noissa kolmessa keskenään tiettävästi mitään laatueroja?
JJVH
