Battlefield 2042 (PC, PS5 & XBOX X)
Myös jotain infoa kuvien lisäksi.
Game Code name: KINGSTON
"Welcome to A World Transformed"
"U.S.A. and Russia stand at the brink of war. Proxy wars have waged for decades, generating experienced but displaced combat veterans. These Specialists use their skills to shape the future — a future worth fighting for."
"Battlefield 2042 introduces 7 vast maps for up to 128* players. From Seoul’s cities to Egypt’s deserts, every map offers a unique experience based on the natural environment."
"Customize weapons, gadgets and vehicles in-battle to tip the scales in your favor. Summon a robotic dog built for battle, employ a grappling hook or don your very own wingsuit."
"Choose your role on the battlefield and form hand-tailored squads through the new Specialist system. Based on Battlefield’s four Classes, Specialists have one unique Specialty and Trait – but the rest of the loadout is fully customizable."
three editions: Standart, Gold, Ultimate
"Members can deploy early with Access to the Open Beta, Full Ultimate Edition Game Access on October 15, Monthly Rewards and more"
Release date: October 15
Perks:
"Open Beta early access, Baku ACB-90 melee takedown knife, “Mr. Chompy” Epic Weapon Charm, \"Landfall\" Player Card Background, \"Old Guard\" Tag"
"4 New Specialists (1 per Season of the Year 1 Pass), 4 Battle Passes (1 per Season of the Year 1 Pass), 3 Epic Skin Bundles (”Blistered Earth”, ”Tempest”, and ”Cold Blood”)"
"\"Shadow Stalker\" Legendary Outfit, \"Obsidian\" Legendary Weapon Skin, \"Onyx\" Legendary Vehicle Skin"
"Official Digital Artbook and Exclusive Digital Soundtrack"
Eli class-systeemi on kuopattu? :eek: Hype kasvoi tähän asti, mutta nyt hirvittää että tämä menee liikaa hero shoottereiden puolle. Tässä aiempi leakki joka osoittautui näköjään todeksi:
E3cE3npUUAUEde4
Virallinen kansikuva spoilerin takana:
Edit: lisätty tekstiä alle
june 15th is a private testing session for big content creators & streamers.
open alpha/beta later this month
(june, not july like many thought to be announced at ea play)
you can hold/have two attachments on your character that you can swap out.
If you have a Kriss Vector and you want to add a vertical grip,
take of your red dot and add an acog you can do that on the fly if it's on your character.
you can swap out a small mag with a drum mag
you can grab a shotgun and take off the stock and barrel extension to make it easier in far & close ranges
(suppressor / compensator / choke)
squad & heroes mechanic from Battlefront 2 (called 'professionals' in 2042)
can have a specialist (professional) per class in your squad,
they are not over-powered but they have a gadget or two that will make it worth playing as one
makes then unique.
medic professional has a healing dart, she can heal people from range.
every squad has the ability to call down (Spawn down) vehicles
the leaked logo is 100% real
maps are the biggest in Battlefield history
- playable map when early access drops, sectors have points inside of them.
In order to capture a sector you need to capture the points inside of it.
every sector can range from 3 - 4 points. Once you capture a sector you own it, it can not be taken back.
one sector is the size of one Battlefield map (medium-sized battlefield 3 maps specifically)
- a map takes place in antarctica, called SHELF.
large cliff alike damavand peak from Battlefield 3 but much, much bigger.
Sectors on top of the map, if you own a sector you get down-time to do whatever you want for a while in-game.
You can capture a sector on the top of the cliff, when you have that downtime you can capture the sector at the bottom of the cliff.
main goal in bf2042 is to be squad based, you pre-plan and execute on those plans. not literally, but within a group of friends.
rush returns, heavy focus on teamwork & not lonewolving.
two trailers that have not been leaked & not teased yet are finished and ready to go.
- 20 years after Battlefield 4 (2024)
- 64v64 seen and tested, will be announced on the 9th alongside everything else.
- crossplay not at launch, old-gen (xbox one & ps4 can't handle it.)
- Levolution returns, more akin to Battlefield Hardline,
looks gnarly but not as effective to the map as Siege of Shanghai tower.
- tornados & "Twisters" show up on the map, every map has a twister but not every map has a tornado.
twisters can pick up cars but can't throw them like the Tornado.
- floppy_ragdoll did not leak the images as people believe, they were posted in a private chat between insiders/game changers.
- a bunch of big name streamers and youtubers will be testing on the 15th privately
Toivottavasti edes US ja RU on jotenkuten pidetty militaryteemaisina vaatteiden suhteen, tuo kolmas häröpallojoukkio minun puolestani saakin olla hiukan randomimpi.
En pysty, jos tässäkin juoksee Vitosesta tuttuja sirkustarhalaisia. En vastusta customointia, mutta pitäisivät edes jotenkin "realistisena" nuo vaihtoehdot univormuissa.
Toisaalta kaikissa leakatuissa kuvissa on pelkästään military- tai asiaankuuluvissa asusteissa olevia.
Ja Origin-leakeissä 128 pelaajaa on kirjoitettu 128* pelaajaa... Parasta olla 128 pelaajaa ainakin conquestissa.
Reactions: mol
Onkos pc / series x / ps5 konsoli crossplaysta ollut mitään puhetta? Herot kuulostaa huonolta, kaikilla samat aseet sitten.
Battlefield 2042 is so called as it takes place 20 years after Battlefield 4.
Crossplay appears to be delayed due to the PS4 and Xbox One being unable to “handle it”.:D
Maps in Battlefield 2042 appear to be the largest in the series’ history and include controllable territories known as sectors with points assigned to parts of them.
One such map is apparently called ‘Shelf’ and takes place in Antarctica, it’s described as a large cliff akin to Damavand Peak from Battlefield 3.
64v64 matches
Three editions: Standard / Gold / Ultimate.
Levolution, and updated traversal mechanics including wingsuits, grapplehooks, and ziplines.
Jos betaan pääsy vaatii ennakkotilauksen, niin pakko se on kai taas sitten haksahtaa samaan ansaan ja laittaa ennakkotilaus sisään Ultimate-versiosta. :rolleyes: BF1 ennakkotilaus, BFV ennakkotilaus... mitään ei ole opittu.
Yllättävää. Eiköhän tuo korjata puukottamalla PC- ja uusimpia matolaatikkoversioita vähän kehnommiksi.
Toivottavasti pudottaisivat PS4- ja Xbox One-pelaajat omille karsituille servuille ja sitten PC/PS5/XSX omille servuilleen.
Pari sataa tuhatta näyttää jo tuijottavan countdownia.
Vähän alkaa jo jänskättää, itselle ainakin kolahtaa noi kuvat jos on aidot. Eiköhän ne ole, jos kerta kaivettu jostain Originin kautta.
Olis kyl jeba jos vois määrittää, että itselle kaikki viholliset näkyy normiunivormuisina, riippumatta millaisen pellepuvun tähtäimessä oleva on vinguttanut Visalla itselleen. Mutta sehän ei käy, koska sitten lumihiutaleet ei osta niitä pellepukuja kun ei pääse esitteleen "tyylitajuaan" muille.
Noh kuulaa kalloon ja teabagia perään kaikille pellepukulaisille. Kyllä ne siitä oppii.
Nuo grappling hookit ja lentopuvut on vähän siinä ja siinä. Toivottavasti liikkuminen on kuitenkin edelleen joten kuten maassa pysyvää, eikä mitään Apeximaista että puolet ajasta vedetään ilmassa.
Saapa nähdä. Ennakkotilaukseen en kyllä laita vaikka kuinka pääsisi betailemaan muita ennen. Se on vaan periaate, että digitaalisia pelejä ei ennakkotilata ja sillä sipuli.
Turha vielä innostua.
Melkonen rimanalitus. Sopulilaumat juoksee ja suolaantuu pitkin kenttää. Miljuuna räjähdystä joka puolella. Pelaajien tekemät kikat siirertty traileriin (jihad mönkkärit, heittoistuin/sinko jetteily). Sellanen häröpallo että ei jumalauta. Voitti kyllä huonoudessaan ja sekamelskassaan edellisten trailerit.
Tuota se porukka ilmeisesti haluaa plus peukku countteri vaan nousee...
+ 129 000
- 601
Tuleepa mukavan pian gameplay reveal, sunnuntaina kuten Eldmor ehtikin jo sanoa.
Oletan että tuo "Hazard Zone" on BR?
Mutta mikähän tämä on:
Voisiko olla hyvät vuokraserverin systeemit... ?
Tuolloin 13. päivä on MS + Bethesda E3-esitys, niin olisiko gameplay sitten siellä? Ja samalla ilmoitus, että tulee Game Passiin day 1. :drool:
Ei hemmetti, siis ihan oikeesti :facepalm: En tiiä mitä ootin mut oli kyllä niin hajuton ja mauton reveal trailer et oksat pois. Ja jotain naurettavia hävittäjäsinkohyppyjä. Ja mitä se mönkijä teki pilvenpiirtäjän katolla? Tuk tukin kohalla jo repesin.
Hillitympi BF2142 reboottihan sieltä tuli, mutta enemmän jalat maassa meiningillä.
Siis... oletko pelannut yhtään uudempaa Battlefieldia? Tuo hävittäjäsinkohyppyhän oli todellinen fan service:
Jos jotain milsim-kokemusta haet, niin Battlefield-pelisarja ei ole sellainen.
Hävittäjäsinko oli nimenomaan asia, josta innostuin. Kertoo, että mobiliteetti ja liikkuminen on samalla tasolla BF 3/4:n kanssa, eikä ykkösen tai vitosen tasoa. Tää oli ehkä isoin toive itsellä, että ei ole niin kankeaa ja 10 sekunnin animaatioita ajoneuvoissa.
Kiitosta vaan mutta ainakaan nähdyn perusteella ei jatkoon. Kun ei iske niin ei iske.
Originista löytyy eri editionit tästä:
We’ll be evolving our world and expanding on the fiction through Seasons, each one lasting for about three months. Every Season will come with a new free and paid-for Battle Pass, delivering new content to chase after.
Ei ihan aukea mikä on ilmaisen ja maksullisen Battle Passin ero.
Sivun alareunasta vielä tarkennus pelaajamääriin:
*Xbox One and PlayStation®4 supports 64 players. 128 players and massive-scale maps are available on Xbox Series X|S, PC, and PlayStation®5.
Todennäköisesti vastaavanlainen kuin Warzonessa, saat ilmaiseksi auki vähintään kaiken mikä vaikuttaa itse pelaamiseen. Eli käytännössä uudet aseet.
Maksullisella saa sitten ehkä jotain skinejä ja xp tokeneita.
Hyvältä kieli poskessa pumpum peliltä näyttää. Vitonen jäi väliin, mutta ykköseen paloi satoja tunteja. Eiköhän tämä tilaukseen mene.
Joo oli itseasiassa Battlefield V:ssä myös noin. Pelaamalla sai kaiken helposti. Toivottavasti eivät rahastele tällä kertaa ahnaammin. Enpä haaskaa rahojani ihme-editioniin tälläkään kertaa.
Näemmä voi ostaa myös Steam ja Epic kautta, toki varmasti kun alkaa pelaamaan se käynnistää myös Originin.
Aika meemi traileri. Ei oikein noussut odotusten tasolle. Katsotaan nyt gameplay traileri ennen lyttäämistä
Katsoimmeko me saman trailerin?
Oli kuin katsoisi The Sims: Army DLC:n julkkaria. Sen verran veikeää oli.
Juurikin tuo suihkarista sinkohyppy on tosi ihgu ja kaikkea mutta ihanko se nyt piti laittaa kalliilla rendauksella mukaan traileriin komeilemaan.
Vaikuttaa kovasti hiukan uudemmalta Bäfä neloselta. Mikä on minusta erittäin mahtava juttu.
En tiedä miten tuo ufotornado tulee toimimaan käytännössä, mutta se todennäköisesti pilaa pelit, niin kuin nelosessakin nuo map-wide levololutionit teki. Minusta Levolution olisi saanut olla suunnilleen kaiken tuhoutuvuutta ja dynaaminen vuorokausi- ja sääsykli.
Trailerissa oli juurikin myös pidetty factionit ulkonäöllisesti asiallisina, varmaankin Vitosesta pelästyneinä. RU ja US näyttivät suunnilleen normaalilta ja Häröjoukko juurikin hiukan sekalaisemmalta.
Sanottiin ihan suoraan että 13.6. on gameplay reveal.
Joo, ymmärsin kyllä. Mietin sitä että kun EA:lla ei tuona päivänä ole tietääkseni omaa E3-esitystä, niin päivämäärä mätsää MS + Bethesda -shown kanssa. Ja siihenkin tuli nyt vahvistus:
Juu olen pelannut kaikkia muita Battlefieldejä paitsi nelosta ja myönnän olevani enemmän kallellaan realistisempiin ammuskelupeleihin kuten Hell Let Loose, Squad, Post Scriptum ja Enlisted. Pidän kuitenkin myös esimerkiksi Apexista ja Titanfallista. Traileri vain yllätti stunttivideomaisuudellaan. Ehkä kyse on siitä, kun pelin kuvauksessa kerrotaan Venäjän ja USA:n välisestä sodankäynnistä, ja sitten ruudulle lävähtää temppuvideo, niin meni aivot solmuun. Toisaalta hyvä näyttää jo heti alkuunsa, millaista itse pelaaminen tulee olemaan.
Steamissä on näköjään eri tavalla noi eri editioneiden edut. Köyhäin versiolla ei pääse pelaamaan viikkoa etukäteen kuten Originissa.
Jackfrags videolla vähän lisäinfo gameplaystä.
-Isoin kartta suunnilleen Pubgista tutun vikendin kokoinen.
Karttojen esittely
Jaa, kappas. Ymmärsin väärin mitä meinasit.
Mutta kiva että tulee pian, gameplay pätkästä näkee paljonkin millaista odottaa.
Katsoimme, jos tuota menoa vertaa 2142 robottiminigun tankkeihin ja miehistöllä on avaruuspuku päällä kyseisessä tekeleessä niin kyllä tuo on _siihen_ verrattuna.
Mötley Crüeta BF trailerissa... yllättävä valinta. Itse traileri ei herätä oikein mitään tunteita.
Pääasia, että loppuu se loputon raunioissa juoksentelu (BF1 ja BF5).
Näyttää olevan aika perinteiset classit, hyvä.
mahtaa olla se ja sama ostaako epicistä tai steamista ku originin vaatii kuitenki taustalle kuten aiemmatki battlefieldit
Tuo classi-systeemi ei sytytä yhtään. Kaikilla tulee olemaan aina se yksi paras ase käytössä ja muita aseita ei käytetä. Sitten tuo korjataan nerffaamalla aina sitä parasta asetta ja samalla vähän muutetaan TTK:ta.
Ymmärrän sinänsä idean tuo classisysteemin takana, eli koska muuttunut maailma ja muuttunut sodankäynti, mutta se silti tuskin tekee siitä järkevää. Normaalimpi classisysteemi tuntuisi järkevämmältä.
Täytyy silti muistaa että ollaan vielä kohtalaisen kaukana julkkarista, joten ei tästäkään voi vielä arvosanaa antaa.
Vanillan 7 karttaa vaikutti ihan kelvollisilta.
Vaikka olisi perinteiset classit, niin pelissä tuskin on mitään rajoituksia monta mitäkin saa olla pelissä. Eli silti jos jokin yksi ase olisi paras, niin kaikki vaan valitsee sen classin?
Mutta joka classi ei saisi sitten esim. sinkoa tai medipakkia, niin jotkut ottaa ennemmin noita kamoja, vaikka se tarkoittaisi parhaasta aseesta luopumista.
Ainoa iso pettymys tässä, että BR puuttuu. Toivottavasti joku näistä uusista pelimodeista tarjoaa jotain hyvää korviketta sille. Tiimipeli ihan eri tasolla kuitenkin BR:ssa.
Tohina
