Mozilla Firefox -keskustelu
Kiva että löytyi, mutta..
Moni kysyi jo miksi käytät vanhaa Firefox versiota, joka ei kovin turvallinen ole enää netin käytössä missään mielessä.
Ei se, miksi käytän, liity mitenkään siihen, mistä kyselemäni add onin voi löytää. Mutta muuten tiedoksi: eri koneissani on tarpeet erilaisille ohjelmistoille. Esimerkiksi yksi kone, jota käytän paljon, on sellainen, että siinä käyttöjärjestelmä on pysynyt muuttumattomana vuodesta 1997.
73.0
Firefox Release
February 11, 2020
Version 73.0, first offered to Release channel users on February 11, 2020
We'd like to extend a special thank you to all of the new Mozillians who contributed to this release of Firefox.
New
  • Today’s Firefox release includes two features that help users view and read website content more easily, quickly. Like all accessibility improvements, these features improve browsing for everyone.
    • Firefox has offered a page zoom feature for more than a decade that allows users to set the zoom level on a per-site basis. For users who need to zoom most websites, having to adjust zoom for each new site can be an annoyance. To address this, we have implemented a new global default zoom level setting. This option is available in about:preferences under "Language and Appearance" and can be scaled up or down from 100% as needed and sets the default zoom level for all sites. Per-site zoom is still available to make adjustments to individual sites as needed.
    • Many users with low vision rely on Windows' High Contrast Mode to make websites more readable. Traditionally, to increase the readability of text, Firefox has disabled background images when High Contrast Mode is enabled. With today’s release of Firefox 73, we introduce a “readability backplate” solution which places a block of background color between the text and background image. Now, websites in High Contrast Mode are more readable without disabling background images.
Fixed
  • Various security fixes.
  • Improved audio quality when playing back audio at a faster or slower speed.
  • Firefox will now only prompt you to save logins if a field in a login form was modified.
Changed
  • WebRender will roll out to laptops with Nvidia graphics cards with drivers newer than 432.00, and screen sizes smaller than 1920x1200.
Developer
  • Developer Information
  • WAMP-formatted WebSocket messages (JSON, MsgPack and CBOR) are now nicely decoded for inspection in the Network panel.
Web Platform
  • Improved auto-detection of legacy text encodings on old web pages which don’t explicitly declare the text encoding.
unresolved
  • Users with 0patch security software may encounter crashes at startup after updating to Firefox 73. This will be fixed in a future Firefox release. As a workaround, an exclusion for firefox.exe can be added within the 0patch settings.
Eilen tuli win 10 joku päivitys ja sen jälkeen rupesi Firefox selainpalkki näyttämään jotenkin erikoiselta. Kun hiiren vie siihen päälle ja painaa siitä hiirellä, tulee sellainen iso neliö, joka erillään ns muusta selaimesta. Miten saa vanhan mallisen nuolella olevan takaisin?
Kumulatiiviset päivitykset asennettu ja tuo uusin FF päivitys ja ei mitään ongelmia, kaikki näyttää samalta kuin ennenkin. Ettei olisi joku addon solmussa?
Missähän vika kun lakkasi YouTubessa kommentit ja Share-valikko latamaasta? Pyörittää vaan latausikonia ikuisesti. Käytössä 72.0.2, kokeiltu ajaa safe modessa ilman plugareita ja alustettua asetukset poistamalla prefs.js, ei vaikutusta asiaan.
Mulla teki samaan joskus pari? versiota sitten Windows 7:lla.. En tehnyt mitään ja alkoi taas toimia jonkin ajan kuluttua.
Saakos noita hakukone ehdotuksia poistettua mitenkään käytöstä? Alkanu jo ärsyttämään tuo vihreä plus merkki
Tämä korjaantui yksinkertaisesti kirjautumalla Google-tunnuksella sisään :confused:
Nyt toimivat ilmankin kirjautumatta.
Ei ole käsittääkseni mikään lisäosa, mikä liittyisi tuohon osoite riviin. Erittäin ärsyttävä vika, kun peittää osan osoitteista sen alla ja siitä tulee tuollainen ns erillinen iso neliö ruutu tuon osoite palkin kohdalle. Mikään muu ei muuttunut eilen, kun win 10 pro päivittyi.
Sama täppä on valittuna, ei auta.
Edit.
Nämä on myös pois käytöstä, mutta ei auta. (Asetukset -> Selaus)
Miksi ylipäätänsä pidät sitä hakupalkkia esillä, jos käytössä on ainoastaan Google haku? Poistat sen palkin, niin osoiterivi kyllä toimii suoraan Google hakuna.
Sitä on vaan tottunut siirtymään osoiteriviltä tuohon hakupalkkiin tabia painamalla ja siitä suoraan Googlen sivulle
Uutta taas tarjolla:
74.0
Firefox Release
March 10, 2020
Version 74.0, first offered to Release channel users on March 10, 2020
New
  • Your login management has improved with the ability to reverse alpha sort (Name Z-A) in Lockwise, which you can access under Logins and Passwords.
  • Firefox now makes importing your bookmarks and history from the new Microsoft Edge browser on Windows and Mac simple.
  • Add-ons installed by external applications can now be removed using the Add-ons Manager (about:addons). Going forward, only users can install add-ons; they cannot be installed by an application.
  • Facebook Container prevents Facebook from tracking you around the web - Facebook logins, likes, and comments are automatically blocked on non-Facebook sites. But when we need an exception, you can now create one by adding custom sites to the Facebook Container.
  • Firefox now provides better privacy for your web voice and video calls through support for mDNS ICE by cloaking your computer’s IP address with a random ID in certain WebRTC scenarios.
Fixed
  • We have fixed issues involving pinned tabs such as being lost. You should also no longer see them reorder themselves.
Changed
  • When a video is uploaded with a batch of photos on Instagram, the Picture-in-Picture toggle would sit atop of the “next” button. The toggle is now moved allowing you to flip through to the next image of the batch.
  • On Windows, Ctrl+I can now be used to open the Page Info window instead of opening the Bookmarks sidebar. Ctrl+B still opens the Bookmarks sidebar making keyboard shortcuts more useful for our users.
  • We have disabled TLS 1.0 and TLS 1.1 to improve your website connections. Sites that don't support TLS version 1.2 will now show an error page.
Developer
  • Firefox’s Debugger added support for debugging Nested Web Workers, so their execution can be paused and stepped through with breakpoints
Web Platform
Täytyy ilmeisesti kirjoitella Mozillan pojille bugirapsaa, kun ainakin macOS:n puolella tabien tekstit suttaantuvat/boldaantuvat puoliksi aina välillä ilman mitään sen kummempaa syytä. Pistää silmään. Kukaan huomannut samaa muilla käyttöjärjestelmillä?
Ei suttaannu tabien tekstit macOSllä. Tosin vaihtui jo 75 betaksi firefox.
Windowsilla on yksi tapaus, joissa moista sattuu, mutta yleisesti ottaen ei ole näkynyt moista.
No, Mozillan pojat saivat tapauksen tutkittavaksi.
Onko sulla käytössä minkään sortin userchrome.css muokkauksia?
Itsellä tuo käyttöliittymän musta "teema" sekä tabs not on top muokkaukset, jolla välilehdet siirtyy selaimen yläosasta kirjanmerkkipalkin alle. selvisi tästä edellisestä päivityksestä hyvin, joten suuria muutoksia käyttöliittymään tuskin tehtiin.
Mutta ainahan se on mahdollista että tämä bugi liittyy johonkin userchrome.css muokkaukseen.
Toki jos et ole moisia tehnyt, niin sitten voit unohtaa nämä minun horinat.
Mikäköhän on kun tänään Firefox alkanut käyttäytymään oudosti, menee noin 20 sekunttia että YouTube latautuu kun selaimen käynnistää?
Muut huomannut samaa?
Itsellä Youtube latautuu normaalisti, 5-6 senkuntia niin kaikki pikkukuvat ladattu kotisivulta.
Oletko asentanut uusia lisäosia tai kiristänyt mainosten estoa tms?
Täysin samat setit mitkä ollut kuukausia.
Onkohan tämä telian ongelma, vai mistä johtuu että telian sivuilla kirjautumisessa ehdottaa aivan täysin erikoisia nimiä mistä ei minulla ole yhtään mitään tietoa..? Käytän itse ainoastaan tätä konetta / nettiä..
Edit: näyttävästi joillakin muilla sivuilla myös tuota tekee... esim. Elisan sivuilla. Mistä johtuupi? googlesta ei tunnu apua olevan tähän..
Onko välimuistipalvelin (proxy) käytössä?
Näyttäähän tuo olevan, "Käytä järjestelmän välityspalvelinasetuksia". Pitäisikö se mieluiten ottaa pois, vai laittaa automaattiseksi?
Ymmärtäisin jos tuossa olisi jotain ehdotuksia, mitä olen itse jonnekin kirjoittanut. Mutta tuollaisia en ole ikinä mihinkään kirjoittanut, niin rupesi mietityttämään..
Selaimen asetuksista tuo on kiinni, että tallentaako se käyttäjätunnukset sivustoille tulevaisuutta varten, se että miksi sinne on tullut jotain outoa on mielenkiintoista. Onko tullut lisäiltyä addonei tai muuta? Jos ei muuta, niin profiili uusiksi, mutta joutuu näkee vaivaa ku kaikki tyhjenee...
Käytössä ollut pitemmän aikaa nämä samat addonit: (bttv twitchille, ublock, adblock), enkä niihin ole koskenut, ainoastaan päivittänyt.
Nuo oudot "ehdotukset / täydennykset" tässä juuri mietityttää, mistä ne on tullut. Joskus aikaisemmin oli tuollainen yksi nimi, mutta kun cccleanerilla puhdistin kaiken, niin hävisi. Nyt tullut sitten useampi..
Periaatteessahan nuo ei kai haittaa mitenkään, mutta rupeaa miettimään liikaa vaan asioita, mistä ne on voinut tulla.. Joku etäkäyttänyt konetta, sivustoilla vika, selaimessa vika vai mistä tulee..?
Eli tunnukset on täysin tuntemattomia? Et ole missään muuallakaan noita käyttänyt? Joskus noita tapahtuu, että ehdottelee väärään sivustoon, ku login sivuston tunnistaminen bugailee selaimella.
Käytätkö jotain kolmannen osapuolen password manageria (joka automaattisesti syöttää login tietoja halutuille sivuille)?
Juu, täysin tuntemattomia minulle. En ole ikinä kuullut / nähnyt missään noita tunnuksia.
Nyt kun vedin ccleanerilla jälleen kokonaan tyhjäksi, niin häipyivät taas. Katsotaan kuinkahan kauan menee kuin taas ilmestyypi..
Kävin huvikseni tuolla Telian kirjautumissivustolla ja kyllähän tuo ehdotteli tunnuksia joilla olen kirjautunut eri palveluihin, eli automatisaatio jyllää. Mutta eipä siellä ylimääräisiä näy ainakaan minulla, eli kyllä jokin sun koneellasi ne sinne lykkää menemään, jos ilmestyy itsekseen.
Kaikki nuo "siivousohjelmat" on turhia taas omasta mielestä, etenkin tuolla CCleanerillä on melkonen historia tietoturvan puolesta...
Voisitko selventää.
Eikös nuo korjattu ja uudet versiot taas turvallisia. Sinällään läppärille en tuota asentanut. Mutta taas pöytäkoneen win8:ssa tuota vielä käytän.
Jostan kummallisesta syystä Ruutu plussaa katsoessa ohjelmat eivät näy ilman että CCleanerilla tyhjää selaimen tiedot.
Mjaa a, mikähän se syy sitten lienee.. kun itse en niitä laita. Noh, jos ei se muuta haittaa tee niin tyhjentelee välillä vua sitte nämä..
tarkistukset yms kaikki olen tehnyt, joten haittaohjelmia jne ei pitäisi olla myöskään, ettei sellaisestakaan kyse ole.
Voisitko selventää.
Näistä on keskusteltu useasti aiemminkin ja mielipiteitä on monia (eikä aihe ny oikein kuulu tänne), mutta ainakin minusta noista on enemmän haittaa kuin hyötyä, monesti saanut lukea ku ongelmia ja ajellaan ties mitä siivousohjelmia säännöllisesti.
Mutta jokainen ajakoon mitä softaa haluaa, jos niin haluaa. Itse en ole noita käyttänyt, koska en ole nähnyt niiden tuovan mitään hyötyä ja hyvin koneet toimineet ilmankin turhia ylimääräisiä softia...
En minäkään mitään muita, mutta kun tuolla on saanut kätevästi selaimen tyhjättyä niin siksi ollut. Mut joo, ehkä tuosta voisi luopua, kun muuta käyttöä ei ole ollut. Selaimien itsessään vaihtoehdot vain ovat mitä ovat. Miksi ei näissä voisi olla että kun selaimen sulkee niin kaikki data poistetaan automaattisesti esim.
Ainakin Firefoxissa on asetuksissa "Delete cookies and site data when Firefox is closed", ei se sen vaikeampaa ole...
Itseasiassa Firefoxilla selaan yksityinen tilassa. Mutta esimerkiksi Vivaldissa moista ei ole.
Mistä saa asetuksen että jos välisivuja on auki ja painaa äksästä kiinni niin ei sulje jos tosiaan on auki useampi sivu?
Saa siihen ainakin varoituksen päälle, niin voi perua, jos ei haluakkaan sulkea.
Warn you when closing multiple tabs
Tänään päivittyi tuo firefox uusin versio pöytäkoneeseen. Ja sama vika tuli takaisin mikä oli aikaisemmin. Eli tuo osoite/hakukenttä suurenee kun siitä painaa hiirellä ja siellä ei ole enää sitä nuolta ollenkaan. Samalla se ns pullistuu isommaksi ja peittää alla olevia tekstejä ja menee myös tuohon yläpuolelle kanssa osaksi. Viimeksi pääsin tuosta eroon kun asensin normi version selaimesta, jonkun betan tilalle. Netistä en osannut ainakaan hakea oikealla sanalla, miten saisi muutettua.
Löytyhän se ratkaisu tuohon. Tässä linkki jos jollakin muulla samaa ongelmaa.
Minulla ei ole mitään valittamista uuteen osoitepalkkiin. Nuoli valikon avaamisen merkiksi olisi varmaan hyvä mutta toisaalta harhaanjohtava, sillä mihin tahansa klikkaaminen avaa alle osoitelistan. Erityisesti pidän siitä, ettei valikko aukea enää koko selaimen levyiseksi vaan ainoastaan osoitepalkin levyiseksi. Aiempi koko selaimen levyiseksi aukeaminen oli lievästi sanottuna ruman näköistä.
En ymmärrä mitä tarkoitat, noitahan voi muotoilla mieleisekseen..... :hmm:
Argh... Nyt ei sitten toimi tuplaklikkaamalla osoitetta sen kokonaan valinta, vaan toimii samalla tavalla ku Chromessa eli yksi klikkaus valitsee heti koko osoitteen, eikä sitä näytä enään pystyvän muuttamaan :tdown:...
@rane58 sulla ei oo kuvassa edes se valikko, josta @Xiyng puhuu, eli tää (itellä se näkyy nyt koko ruudun levyisenä varmaan omien säätöjen takia, sekä myös ohuempana samasta syystä)kettu_valikko.jpg:
Maukka_99
