Diablo 4
Diablo IV Patch Notes
2.4.2 Build #69011 (All Platforms)—October 21, 2025
https://news.blizzard.com/en-us/article/24222917/diablo-iv-patch-notes
Bug Fixes
  • Fixed an issue where the Bartuc's Reign of Chaos quest could appear completed even though not enough Veneration had been acquired.
  • Fixed an issue where Bonestorm would occasionally be canceled prematurely.
  • Fixed an issue where Ramaladni's Magnum Opus still referenced "using this weapon" when it appeared as Chaos Armor.
  • Fixed an issue where Tuskhelm of Joritz the Mighty's Unique Power would last an insufficient duration while gaining Berserking.
  • Fixed an issue where Twisting Blades sometimes couldn't hit Hellwyrms when attacking from behind.
  • Fixed an issue where the Harbinger of Hatred Tormented Echo could jump through the fog wall.
  • Fixed an issue where some cosmetic items from previous seasons appeared locked.
Sanctuary Ignites with Itemization & Systems Changes
https://news.blizzard.com/en-us/article/24243142/sanctuary-ignites-with-itemization-systems-changes
Prepare yourself, wanderer. There are permanent changes coming to the way you play Diablo IV. Arriving with Season 11, we are overhauling the way Itemization, monster combat, player defense, all function. Additionally, this Season introduces The Tower, a multi-stage dungeon where completion can earn you a spot on The Leaderboard, which is making its triumphant return. These changes all affect both Seasonal and Eternal Realms.
To get your hands on any of these features coming with Season 11, check out the 2.5.0 PTR, available on October 21 for PC Battle.net users. For more details on the 2.5.0 PTR, read our blog here.
Vähän ihmettelin osaa näistä. Toivottavasti nyt ei käy niin et pitää alkaa jotain karkuun luikkivia mobeja jahtaamaan tai koko ruudun tappavat buildit entistä parempia.
Monster Combat Changes​
Improved Monster Behavior​
Monsters will better react and adapt to combat in their express desire to end your life. Each monster should now have its own clear role and own identity when fighting. Monster behavior was previously too predictable; they’ll now be more dynamic in how they respond to you in combat.
Deadlier Enemies Lurk​
Expect your defenses to be tested by your enemies; you’ll be more regularly dealt damage from these intelligent packs. Monster affixes will also be more powerful, making them more necessary to deal with before moving on to other less important enemies.
Monster packs will also group up less, making them harder to take out in one fell swoop. Their tactics have improved, and so yours should too. Additionally, Champion enemy rarity have been reworked to form champion packs.
Ongelma on ennemmin se ettei tuhnuenginellä saa mitään detailia niistä mosista kunnolla näkymäänkään ja monet mallit on lähellä toisiaan ulkoisesti. Sitten siitä tulee semmoista puuroa mitä hämmennetään paloiksi ja päreiksi. Ei ollut näin D1:ssä ja D2:ssa.
Aika paljon on tulossa muutoksia, muutama striimaaja pääsi haastattelemaan devaajia ja näistä on koosteista nyt esillä.
Lisäksi tapahtuma, jossa viimeksi julkaistiin uutta (Gamescom tms?) on tulossa aika tasan kuukauden päästä, tulisiko täällä tulevasta lisäristä tietoa, uutta classia tms?
2.4.3 Build #69378 (PC) and #69242 (Console)—November 12, 2025
Game Updates
  • Adjusted purchase confirmation inputs in Battle Pass Reliquaries to create a better player experience by making it faster and easier to claim rewards using Favor Tokens. The same button used to initiate claiming a reward is now used to confirm the claim using Favor Tokens.
  • The unlock criteria for the First Aid achievement has been changed. Note that if you’ve already unlocked this achievement, it will remain unlocked.
    • Previous: Upgrade your Healing Potion Fully.
    • Now: Use your Healing Potion 1000 times.
Bug Fixes
  • Fixed an issue where Battle Pass tokens weren’t consumed correctly if you had multiple unused Premium Battle Pass tokens from previous seasons.
  • Fixed an issue where Chaos Rifts sometimes did not properly open Chaos portals in Helltide.
  • Fixed an issue where enemies spawned for Chaos Rifts could spawn outside the expected range.
  • Fixed an issue where the Whisper bounty for sealing Chaos Rifts could appear for Eternal Players.
  • Fixed an issue where enemies could spawn inside the walls of Nightmare Dungeons.
  • Various performance, stability, and visual improvements.
Ei ne mosat ny ihan ykkösellä kuole enää noissa myöhemmissä piteissä. Jos ei sitten ole joku bugi lipsahtanut jakeluun ja niitähän on lipsahtanut useinkin. Iso pit ja nopehko kolaus vaatii ihan kunnon grindiä geariltakin. Pelkästään sopiva hahmo + build riittää johonkin perus lvl75 touhuun toki vähemmällä vaivalla.
Ranen klipissähän työstetää jo kasoja ihan urakalla paikoin.
Juu mutta tuohan on vain samaa tylsää skaalausta kuin D3 riftit..
(Kuten Breezer_kin sen jo totesi)
Voihan mistä vaan hommasta tehdä haastavaa kun skaalausta vaan lisää. Muuten sisältö on ihan samaa.
Seasonit lähes kopioita toisistaan pieniä uusia vivahteita toki aina.
Mun mielestä hahmon powerit vois pudottaa alemmas ja vähentää vaikeustasoja.
Jokohan taas "tuhotaan" Eternalin itemit kolmannen kerran.
Oliko joku kiinalaisten Diablo juttukin 12. päivä? Et ehkä sitä pedataan enemmän.
Jotkut uhosi jo uuden classin shadow dropista game awardsissa ja että tulisi mukaan seasoniin, mutta sitä nyt en usko millään. Se nyt luulisi väkisin olevan maksullista lisäosamatskua, tai kai sitä seasonissakin voisi maksullisen pelillisen lisäkilkkeen julkaista. Tuskin kuitenkaan.
Näyttää jatkuvan sama teema kuin muissaki siisöneissä, uudet voimakuutiot ja pieni season tarina. Itse olisin hyvin yllättyny jos nuo uuden classin toho tähä hätää olisivat taikoneet, ei oo noita uusvanhoja towereitakaa saanu valmiiks season alotuksee. Totesivat kanssa etteivät osaa matikkaa niin annetaa kaikki vaihtoehdot itemin parannuksee. Epäilen että riittäs se niiden matikka uusien puolustusjuttujen laskuunkaan ja korjataan sitte ku faneista joku tekee kaavat julkasun jälkee.
Huhumylly yltyy vaan, eikös toi oikean laidan ase nyt ole flail:
Näkyy täällä kohdassa "Additional Bonus Rewards":
Lisäksi...
Linkki: https://x.com/ThatsLeviathan/status/1996312363939901708
Kuka tyyppi on:
Stephen Stewart | Leviathan
@ThatsLeviathan
Class Designer on @Diablo IV @Blizzard_Ent
En mä ehkä vieläkään usko, mutta aina voi toivoa. :D
Niin, olihan D3 kumpikin classi maksun takana. Toinen erikseen ja toinen lisärissä.
Ihan hyvin voisin paladinista jonkun 15€ heittää, mitä luokkaa necro tais olla D3:ssa.
Noh asia selvinnee sitten ensi viikon perjantaina aamusta, mielenkiinnolla odotellaan.
Tosta paladinista on huudeltu niin kauan D4 kohdalla, eikä sitä ollut edellisessäkään dipessä, että semisti petyn jos joku muu classi tulee. Tuli se nyt sitten yllättäen pian tai joskus ensi vuonna lisärin kanssa.
ostin black friday alesta pelin enkä varmaan kerkeä kiireiltä tuota tarina puolta ihan loppuun ennen kuin seasoni loppuu. oletettavasti tehtävä progressio säilyy hahmolla kun se palautuu seasonista standarddiin? hölmönä menin tekemään seasonal ukkelin koska en tiennyt hahmon tekohetkellä milloin season päättyy.
Säilyy kyllä. Ellet tarkoita season-tarinaa, jota ei pysty kai jatkamaan.
Paladin shadow drop :hmm:
Sieltä se tuli! Paladin!
Paladinia pääsee pelaamaan tänään ennakkotilaamalla lisäosan.
Linkki: https://x.com/Diablo/status/1999309406823961020
Itse lisäosan mukana tulee myös toinen uusi class.
Two New Classes: Paladin Available Today with Lord of Hatred pre-purchase (the Other is a Secret, Playable at Launch!)
Huhtikuussa 2026 tulee jatkoa, taisi olla paladin classi videossa? Hammerdin.
28.4.2026
Lord of Hatred
Tulihan se sieltä, mahtia.
Paladin, ai että.
Arvelinkin vielä eilen että lisäriin tulee ehkä toinen, niin on siinäkin enemmän mieltä.
Ilmeisesti amazoni olisi tuo toinen classi. Ei kyllä ehkä jaksa 40e maksaa, että pääsisi paladinia pelaamaan, mutta nyt näkee onko tuo suunnittelufilosofia se, että uudesta luokasta tehdään aivan järkyttävän OP alkuun, aivan kuten SB oli tullessaan.
Vähän kyllä hinta taas riipaisee, mutta kai se on ostettava, kun aikaisempikin on ostettuna. PoE2 julkaisu kuitenkin myöhästyy pitkälle vuoteen 2026(ehkä 2027), joten onhan sitten taas vähäksi aikaa välipelattavaa.
Siihe tasoon mitä saatii spiritbornissa ja jos tämä yhtää samanlaista kuraa niin taitaa jäädä tuo 40euron tuki pois. No kerraki ennustajat oli kumminki oikeessa, ei ne uskaltanu vetästä mobiilipeli korttis tällä kertaa :)
Hinta kyllä paljon parempi niille kellä ei ole edellistä lisäriä, koska tämän ostamalla saa senkin.
Melkoinen yllätys ja kyllä kelpaa! Lisäri ostettu jo viikonloppu tiukkaa tykitystä. :coffee:
Kalastus? :D
Eipä siinä, tota on monessa pelissä tullut tehtyä.
Jaaha, pitäisiköhän tälle pelille antaa taas mahdollisuus. En ainakaan osta mitään ennen kuin basegame alkaa tuntumaan valmiilta.
Pakko tämä on ostella että pääsee vloppuna Paladinilla mättämään. Viime season jäi välistä joten nyt maistuu taas uudella innolla.
Sama homma.
Tässä mennyt jo useampi season pelaamatta, mutta kyllä classista saa lisäpuhtia.
Se että lisärin julkaisussa tulee toinen classi on ihan jeppis, ei tuu julkaisussa sitten fiilistä ettei oikein mitään saa.
Toi Vessel of Hatred kampanja oli niin tynkä roska, että pitkälti classi oli ainoa pointti.
Joskus alussa tätä jaksoi tovin hakata. Myöhemmillä seasoneilla pari kertaa koittanut mutta melko nopeasti loppui innostus. Vessel of Hatredia en koskaan ostanut. Vieläköhän tähän pitäisi se 40e pistää (jolla kai käsittääkseni saisi molemmat lisärit?) ja vielä kerran pettyä..
Siellä heiluu nyt pelkkiä Paladineja sitten tässä seasonissa
EDIT. No mutta hyvä että tulee lisää Classeja, alkoi mennä vaikeaksi jo päättää millä alkaa seuraavaksi tahkoamaan.
Peli ei ole juurikaan muuttunut, jos ei tykännyt vuosi sitten niin tuskin nytkään.
Eniten aina tökkii tää seasonin alku. Päätöksillä kun ei alussa ole mitään merkitystä, niin ei meinaa pysyä mielenkiinto. Level 12 vasta ja johonkin päin ruutua pitäisi jaksaa klikkailla että pääsee joskus kunnolla pelaamaan. :beye:
On tuossa kuitenkin jotain ihan positiivisia muutoksia jo näkynyt.
e: Huu... Tämähän alkaa sittenkin jo vähän kiinnostamaan, sanctify on hyvä :think:
Ihan mielenkiintoisia muutoksia alkupelin progressioon noi challenget ja väli dungeonit. Mukavaahan tuota paukuttaa muutaman seasonin tauon jälkeen.
Ite aloitin penitentillä, menin jonkin porukan kanssa helltideen ja olin 10min päästä lvl 25.
Uus hahmo ja pitkän kaavan kautta tarinan alusta paladin (zealot) tulille. Kyllhä tää ihan soiva hahmoluokka on. D2 viboja vähäse kun katteli skillipuuta. Zeal ei ehkä ihan vastaava pensasleikkuri animaation osalta kuin D2:ssa mut ei aivan mahdotonkaan. Pitäähä se ny tarkistaa onko uudelle classille tehty jotain tarinaspesifisiä hahmon teemaan liittyviä pieniä easter eggejä. Nekromankeli oli vähän pettymys Act1-loppua kohti kun odotin enempi teemaan liittyen.
Itse lähdin piitkästä aikaa barbaralla liikkeelle. En laittanut neljää kymppiä sen takia että saisi classin joka tulee joka tapauksessa myöhemmin. Ja tod. näköisesti halvemmalla.
Miltäs se kuulostaa tai tuntuu? (barbi siis)
Kerrohan mietteitä jos ehdit jo pelailla. Tässä pohdin palaisiko D4 pariin taas pitkän tauon jälkeen vai ei..
Paladin vaikuttaa ihan hyvältä hahmolta. Tällä hetkellä T2 menossa.
Muutokset season journeyhyn on aika mukavat, kerrankin noiden tekemiseen on jotain motivaatiota resplendent sparkin lisäksi.
Edelliset kolme seasonia on tainneet jäädä kesken syystä tai toisesta mutta nyt tuntuu että saattaisi olla innostusta pelata T4:lle ja season journey loppuun.
m4tsu
