Counter-Strike 2
  • Keskustelun aloittaja Keskustelun aloittaja elmo
Famas ja Coltin hintaa säädettiin, Vertigo korvattiin Trainilla. Oliko niitä uudistuksia muitakin?
Kova toive olisi panostus jonkinlaiseen anti-cheattiin. Nythän tuo ykköskausi oli ihan totaalinen vitsi.
[ PREMIER ]
Premier Season Two is here, and Premier matchmaking has resumed
Every player who earned a CS Rating during Season One will receive a commemorative Premier Season One Medal which includes detailed Season Statistics
Every player will have their CS Rating recalibrated based on their Season One performance, and will need to re-establish their CS Rating by winning 10 matches
Train has been added to the Active Duty map pool
Vertigo has been removed from the Active Duty map pool
[ GAMEPLAY ]
M4A4 price reduced to $2,900
FAMAS accuracy improved and price reduced to $1,950
Reduced crouching accuracy for the MP9, MP5-SD, and MP7
Adjusted scope dot on AUG/SG to be more useable at range
[ UI ]
Added a new radar dynamic zoom option that will grow or shrink the radar to include your team mates, bomb and other detected elements
Adjusted grenade order in spectator UI to match weapon selection order
Increased brightness of carried C4 in UI
[ MAPS ]
Train
Removed a boost angle from Long Dog to Bombsite A
Fixed lighting artifacts on double-sided materials
[ MISC ]
Added fallback logic to allow playing incomplete demo files, either copied from an ongoing live match or recovered after a game server crash
Fixed an exploit where users could use secondary fire on R8 Revolver and then sell it back
Counter-strafe summaries are now available in game server log data distributed via log address in addition to console logs
Onkos muilla pelissä nykimistä? Täällä peli nykinyt jo useamman kuukauden ja koneelle on kaikki melkein tehty mitä voi ja mikään ei auta :/ muut pelit toimii ilman mitään onkelmia..
7800x3d ja näyttiksenä 7800xt
Oli helvetinmoista stutteria koneen spekseihin nähden (9800X3D ja 3070ti) ja lopulta syypääksi paljastui 2TB Kingston NV2. Vanha 512GB NVME-levy sisään niin kaikki nykiminen katosi.
Warppii pahasti välis, muillakin samaa ongelmaa.
Joskus alkaa pyöriä huonosti, mutta pelin uudelleen käynnistämien nostaa taas fps:t normaaliksi.
Joskus fps laskee johonkin satasen kantturoihin ja ihmeen tökkiväksi menee meno, ihan pelkkä matsista poistuminen ja liittyminen takaisin auttaa itselläni tuohon.
Premier on vieläkin ihan rikki. Ehkä joku 1/20:sta pelistä on semmosia, missä ei joku 10-15k ylempänä pelaava ole mukana. Toki voi olla, että kuvittelen liikoja ja porukka oikeasti huijaa softalla aina jolleivat myös osaa heitellä savuja jne ja pelit on vaan cheat vs cheat 95/100.
Ja sitten numero putoaa jonnekin 12-15k tienoille missä voi juosta yli. Ei mitään järkeä touhussa, kun pelit aina paskinta paskaa sitten paskasiemenistä kasvatetun paskapuun paskahedelmien.
Onko mitään vinkkejä miten cs2 saisi korjattua toimivaksi, kaikkea mahdollista yritetty youtubet selattu läpi ym. Eli ongelmana se että fps tippuu eikä mitenkään mene yli 165 fps. Tulee myös isoa pätkimistä/nykimistä ja fps droppeja, esim ensin fps on 150 ja sekunnin päästä 85 ja ei palaudu takaisin ennenkuin reconnectaa takaisin matsiin, aivan jumalattoman ärsyttävää. DM ei pysty edes pelaamaan kun lagaa ja fpssät usein paljon huonommat.
Resot ja kaikki mahdolliset asetukset koitettu eikä niillä ole oikein mitään vaikutusta, tällä hetkellä 16:9 ja kaikki asetukset alhaisimmilla. Koitettu kyllä kaikki mahdolliset yhdistelmät läpi eikä mikään auta tuohon fps droppailuun/nykimiseen.
Koneen speksit Ryzen 3900x, rog strix x570, geforce rtx 3070Ti, 16gb ram, SSD, win10
Alkuun cs2 toimi ihan hyvin ennen ensimmäisiä päivityksiä ja csgo toimi moitteetta. Muut mielestäni raskaammatkin pelit toimineet ihan kohtuullisen hyvin ilman tällaista ongelmaa.
Tuo premiumin rank systeemi on muutenkin ihan outo, miten laskee pisteet. Vaikka oisit ihan paska ite, mutta muu tiimi kantaa, nousee sulla rankki vauhilla jonnekkin 15k tienoille. Sitten taas häviöistä ei saa juurikaan miinusta. Outdoitan on myös se että jos itse olet 15k ja vastapuolella suurin osa on alle tuon tason, niin silti saat voitosta ison potin ja häviöstä lähtisi todella vähän.
Sitten tällänen kannettu ja paskan rank systeemin tuotos päätyy joskus omaan tiimiin ja vastassa on sitten rankiaan vastaavat pelaajat niin voi moro kun viedään taas kuin pässiä narussa.
Onko anti-cheatiin tullu jotain päivitystä?
Tuskin koskaan tulee. Niin kauan kun case ja skin kauppa pyörii niin tuskin on mitään oikeata kiinnostusta valvella fiksata tuota kuntoon.
Paremman anti-cheatin ja ranking-systeemin perässä kannattaa pelata vain faceittiä. Niillä on myös huomattavasti paremmat palvelimet kuin valvella.
Jos et oo kokeillu niin ddu näyttiksen ajurit veks ja uudelleen asennus.
Onko peli mennyt kenelläkään muulla aivan tilttiin silloin tällöin? Itselläni on nyt käynyt kaksi kertaa lyhyen ajan sisään niin, että peli jämähtää yhtäkkiä paikalleen ja muutaman sekunnin kuluttua myös hiiren kursori häviää ja näppis lopettaa myöskin reagoimasta. Tämän jälkeen ainut vaihtoehto on koneen sulkeminen virtanappulasta. Jumittamisesta huolimatta Discord toimii normaalisti, eli tiimikavereille pystyy ilmoittamaan ongelmasta. Peli toimii muuten ihan normaalisti, pätkimistä tms. ei siis esiinny.
En oo pelannut CS:ää kuukausiin mutta mulla alkoi joskus nykiä, jos oli prossulla (Ryzen 7600 tais olla silloin) liikaa alivolttia (Curve Optimizer). Joku -20 tai -25 oli kyllä "vakaa" eli ei kaatunut peli tai kone CS:ää tai mitään muutakaan pelatessa mutta sekä CS:ssä että Diablo IV:ssä huomasin sellaista vitun ärsyttävää nykimistä, joka ei kuitenkaan ollut nettilagia tms. Curvea säätämällä jonnekin -15 tienoille loppui nykiminen. En tiedä onko tästä muille apuja mutta kannattanee ainakin koittaa jos kynäri nykii ja prossulla on kovaa miinuscurvea.
Täällä kans kaikki mahollinen tehty ja pätkii nii perkeleesti. Itellä heittää viivettä vaikka netti ok ja kaikki muut pelit toimii niinkuin pitää. Ollu pelaamatta kynäriä varmaa kohta jo 6kk 🥱
Ratkaisin tämän ongelman ostamalla koneen missä on 14900kf + 4090 näyttis niin loppu pätkimiset. Lompakossa kyllä kirpaisi mutta oli jo aikakin päivittää konetta.
Tuo on nykyisin aika tarkka prossustakin, CS2:sessa 3900X:llä sain itse 200fps 7900XTX:n kanssa, kun vaihdoin 5800x3d:n tilalle niin FPS nousi 400 lukemiin. Nyt 9800x3d kanssa pyörittää aika stable 500fps ja ei nyi.
Onko muille tullu nyt uuden seasonin myötä enemmän huijareita premieressä vastaan/omaan tiimin kuin aiemin? Tässä on lähes tulkoon joka toisessa pelissä ollut, yleensä vasta puolella huijari.
Viimeisin matsi oli kyllä huvittava kun oli kaksi wallhackaaja meidän tiimissä, niin ite kerran ammuin vihuin savuihin, niin toinen näistä wh janttereista tokasi, että "älä pliis ammu savuihin jooko?" :lol: Sitä kommenttia vähän aikaa siinä mutusteltiin kunnes selvis että tää kaveri myös näkee seinien läpi.
Itsellä on tapana aina seuraavana päivänä katsella pelien demot läpi. En ole huomannut että, tuoreimmalla kaudella olisi mitenkään erikoisen paljon huijareita. Ihan yhtä paljon kuin ennenkin. Eli helvatisti.
Tuo premier on käytännössä pelaamiskelvotonta ainakin n. 25k ränkissä mitä olen muutaman kymmentä peliä pelannut season 1:n aikana. Vähintään joka toisessa pelissä joku silver-tasoinen pelaa peittelemättä selvällä wh:lla ja/tai aimbotilla.
Muutenkin cs2 niin surkeassa kunnossa pelillisesti, että itsellä jäänyt tosi vähälle pelaamiset. Ikävä on kova cs:gota.
Jos on paska trustfactor tulee vain ja ainoastaan koodareita vastaan ja omaan tiimiin :D
Mitä tämä tarkoittaa?
Luotettava käyttäjätunnus?
Oma pitäisi olla ihan ok(kuva), silti pelkkää sontaa prem
Tää trustfactor hapatus on ihan höpöä vaan.
Omakin steam lvl jtn yli 55 ilman mitään banneja tai muita, ja silti tulee häkkereitä, yleensä just sattuu tulemaan vihuille. Siitäpä syystä nyt s3 rankki on reilusti alle puolet s2 parhaimmasta rankista.
Ei se höpöä ole, jos on saanut tarpeeksi reportteja niin tulee enemmän koodareita vastaan ja omaan tiimiin. Siihen pääasiassa vaikuttaa nuo reportit.
Trustfactorin alhuuden huomaa siinä jos queue ajat ovat pitkät tai että peli kertoo että quessa on joku 30-45 pelaajaa eikä satoja pelaajia.
Oma Trustfactor on yhdellä smurffilla absoluuttisen huono, 300h on record, 2006 luotu tili ja joka matsissa on vähintään 3-4 koodaria täysin uusilla tileillä. Joko on cope tai sitten ei, tiedä siitä. Samaa ongelmaa ei niin paljolti ole pääasiallisella tilillä jolla on enemmän tunteja, pelejä yms. (Sekä varmaan vähemmän reportteja)
Yleensä tuolla +25k ratingissa tulee vastaan pelureita jotka ovat ostaneet tilinsä jostain, tasan 2000 rating Faceitissä 20-25 matsia pelattuna, steam level 40 ja pelissä tasan 500-600 tuntia, ja 99.5% nämä pelailee ilman seiniä :P
Nämä skinit kun ei hirveen tuttu maailma ole niin mikälainen arvo mahtaisi olla M4A1-S Vaporwavella kun float on 0.00099 eli aika pieni. En löytänyt mistään skinisivustoilta referenssiä tuollaiselle -en ainakaan sellaisilta jotka eivät olisi vaatineet Steam-kirjautumista...
CSFloat - Buy & Sell CS2 Skins on the Most Advanced Marketplace on aika suosittu ja turvallinen sivusto josta varmaan löytyy jotain referenssiä ja kaikkihan riippuu kuka sen tahtoo sitten lopulta ostaa.
Onko muilla faceit clientti aiheuttanut ongelmia? Monen vuoden tauon jälkeen tuli asennettua se ja siirryttyä premieristä pelaamaan sitä mutta aiheuttaa hieman harmaita hiuksia. Tuon asennuksen jälkeen kone alkoi välillä käynnistyä uudelleen aika pian bootin jälkeen. Ei koskaan pelatessa vaan kaatuminen tapahtui heti jo ennen pelin käynnistystä. Nyt ongelma on muuttunut sellaiseksi, että VSCodella työskennellessä kone käynnistyy melko nopeasti uudelleen. Kone voi olla käynnissä tuntikausia ongelmitta mutta kun yrittää VSCodella alkaa työstämään jotain, niin 5-15min niin boottaa yhtäkkiä.
Windowsin palauttaminen clientin asennusta edeltävään tilaan ei ongelmaa poistanut ja Windows repairia ei pysty tekemään vaan aikansa yritettyään lopulta herjaa, että korjaus ei onnistunu tms.
Olisiko voinut käydä niin, että tuon asennuksen myötä on jotkin Windowsin tiedostot korruptoituneet ja temppuilee siitä syystä. Korjaus ei onnistunut Windowsin kautta eikä asennusmedialla tikultakaan.
Noh täytyy asennella Windows uudelleen jossain vaiheessa vielä ja katsoa mitä tykkää.
Tuota.. viestistä ei käy ilmi, mutta poistitko clientin, poistuiko se normaalisti? Löytyykö Event Vieweristä mitään aiheeseen liittyvää?
Poistin clientin, ei vaikutusta. Event viewer näyttää vaan että kone käynnistyi yllättäen uudelleen tms
Eli sieltä ei löydy mitään boottia edeltävää tapahtumaa Criticalina, Errorina tms.? Kokeile asentaa tuo client vielä uudelleen. Kyllähän tuo aika solmulta vaikuttaa kieltämättä..
Criticalina muistaakseni näkyy se bootti mutta ei kerro mitään muuta kun että on bootannu. Asensin clientin uudelleen muttei vaikutusta.
Koska tuo Windows asennuksen repairkin on jollain tapaa nyt solmussa kun ei anna sitäkään tehdä niin veikkaan, että tämä solmu ei aukea kuin puhtaalla Windows asennuksella. Täytyy siitä lähteä kun saan toisen koneen kasaan niin voi paremmin testailla tuota.
Jatkan vielä, onko sulla Core Isolation - Memory integrity (tai muita vipuja sen alla) käytössä? Kokeile niiden poistoa, jos on.
Sieltä asetuksista oli molemmat pois päältä ja niitä ei saanut edes laitettua päälle. En tiedä pitäisikö saada laitettua mutta jos pitäisi niin viittaisi vain lisää siihen, että koko käyttöjärjestelmä on solmussa.
Jos oli jo valmiiksi disabloituna, niin sitten ei mitään. Ei anna kytkeä päälle, jos on Windowsin mielestä epäkelpoja ajureita (99% tapauksista false positive).
Aika hyviä hyppyjä taas markkinoilla. Parin euron punaisia skinejä säästäneillä äkkiä muutamat sataset kasassa kiitokseksi siitä ettei katsonut myyntiin klikkailua ajankäytön arvoiseksi. Vaikea toki sanoa milloin kannattaa myydä, kun noita poistuu aina 5kpl per upgrade markkinoilta ja punaiseen päivittäminen on edelleen 10kpl. Ja varmaan Kiinalaiset jatkaa pumppaamalla rahanpesuaan joten aika arvaamatonta kaikin puolin.
Jep. Itse kattelinkin pitkään milloin sais jotkut hanskat halvalla niin nyt tulikin hyvä alennusmyynti :)
Valve alkaa puuhastelemaan laatikoiden poistoa jotta ei tule ongelmia EU:n yms kanssa ;P
Tai sitten Valve julkaisee kohta Steam Framen/Index 2 ja haluaa että porukka tuo ulkopuolista rahaa systeemiin eikä ostele niitä vaan steamrahalla.
Meinaa mennä moti cs ku ei vaan pyöri smuutisti... fps 1% lowi kokoajan jossain 80-140 välillä, vaikka peli pyöris unlockattuna 400. Oon käyny läpi aiiivan kaikki maholliset fixit ja ei auta. Eikä pitäs johtuu raudasta... huoh
Millaset palikat sulla on? Aika normaalia että se FPS laskee ja nousee, pahin on jos alt tabailee kesken pelin niin silloin 1% lowit ovat entistä alemmat :D
5700x, gtx 1080 ti ja 2x8 3600mhz 18cl, setuppi muutenkin optimoitu minttiin (omasta mielestä:D).
Testasin viimesenä olenkortena gsynciä ja täytyy todeta, että ajaa kyllä tosi hyvin asiansa.
Kaikella rakkaudella, ei tuo nyt mikään timanttinen tykki enää CS2:n aikakaudella ole - CS:GOssa vielä meni. Pitäisin ihan normaalina, että tuolla setupilla niitä dippejä vaan tulee..
portimo
