AMD CPU-spekulaatio (Zen6/Zen7 ...)
Mulla taas jäänee odotteleen Tomahawk ja 5800x cooleria - D15S Chromax. Huomenna piti sen tulla myös, mutta Belgian posti tai Amazoni mokailee, toimitus viivästyny. Argh!
What’s new in AGESA 1.1.0.0 for Ryzen 5000 Series:
  • General performance improvements for many types of workloads
  • Improved support for loading and applying overclocked memory profiles
  • Improved BIOS overclocking robustness
  • Improved USB hotplug detection
  • Improved SATA device detection on select SATA ports
  • Adds support for Eco Mode for automatic TDP reduction (AMD Ryzen Master)
Overall, this AGESA is designed to bring the Ryzen 5000 Series to the full performance and experience intended by AMD. Performance optimization is really the hero of this release, so make sure you grab the update for your motherboard when you’re up and running on “Zen 3.”
But that’s not all! We have an exciting roadmap beyond AGESA 1.1.0.0 and wanted to give you a small preview of what’s coming in future BIOS updates.
Beyond AGESA 1.1.0.0 for Ryzen 5000 Series:
  • Returning support for negative core voltage offsets (“undervolting”) with all-new AMD functionality for better frequency, voltage, and performance tweaking
  • Additional AMD optimization for performance and stability at ~2000MHz fabric clock. While not all processors are innately capable of reaching this frequency, our tuning is intended to help stabilize the overclock on capable samples2 —good luck!
  • Additional functionality tuning for benchmarking under extreme OC conditions (e.g. LN2)
Jaa riittäisiköhän nykyinen be quiet! Shadow Rock 2 edelleen :hmm: ei ole aikeita kellotella.
Oma 5900X menee samoin D15S Chromaxin alle (UPS toi eilen Amazonista):
Olihan tuolla 20% lisää Zen2 nähden.
Hardware Unboxed testeissä myös, vaikka pienemmät mallit puuttuukin. Ovat kuitenkin tasoissa/lähellä 16-ydin mallia. Ja Zen1 kaukana takana kuten pitääkin.
Ei pöllömpi IPC suorituskyky 5950X:n osalta:
Toivottavasti threadripper 5000 sarjan odotus ei ole liian pitkä, quad challed muistilla tahtoo nähdä "5950x" version, niin ja enempi pcie väyliä. Hiukan pelottaa, kun "vasta" tuon pro malllin saivat liikenteeseen.
On tieten hyötyohjelmissa tuo kehitys selkeämmin näkyvillä lisäytimiä hyödyntämällä, mutta ei nyt voi sanoa että ois hypitty mitenkään isoin harppauksin eteenpäin muilta osin.
Milloin sit viimeksi on sinusta tullut 'iso harppaus'? Tämä on nähdäkseni yksi isoimmista loikista miesmuistiin myös yhden säikeen/ytimen suorituskyvyssä.
Tulossa setuppi joista näillä vaikutusta CPUn cooleriin:
Meshify C (saapunut)
5900X (tilattu)
X570 Unify (todennäköinen valinta)
G.Skill 32GB (2 x 16GB) Trident Z Neo 3600 C16 (todennäköinen valinta)
Tilauksessa NH-15D, mutta tuossa pari ropleemaa:
  • Etumainen tuuletin on niin iso / matalalla, että sitä pitää nostaa muistien vuoksi -> jos nostaa, ei mahdu enää Meshify C koteloon
  • Tuulettimet pitäisi siis laittaa "imemään", eli keskituuletin kiinni etummaiseen jäähyripaan ja etummainen siirtää kotelon perälle kiinni taaimmaiseen jäähyripaan -> X570 Unify emossa ei välttämättä tilaa takaosassa korkeuden suhteen -> pitää nostaa -> ei mahdu Meshify C koteloon
Ratkaisu voisi olla NH-D15S chromax.black + NF-A12x15 PWM chromax.black. Tätä setuppia olisi suoraa varastossa, käsiin ei jäisi turhaa NF-A15 puhallinta ja keulille saisi puhalluksen tuolla NF-A12x15:sta. Olisiko moinen fiksu setuppi? Tuo NH-15DS ei ilmeisesti eroa NH-15D mallsita muuten kuin että mukana tulee vain yksi NF-A15 ja se on hieman "vinossa" ja näin GPU:n suuntaan enemmän välystä.
Minkälaista muistia te ootte meinannu noiden uusien Ryzen 5000 kanssa? Moni on noita Triddent Z Neo käyttänyt. Mietin itse että saakohan tota FCKL oikeesti noilla uusilla 2000 mhz niin että sais kaveriksi 4000 mhz muistit? Toisekseen tarpeena olisi 32gb, onko se sitten 2 kammalla vai neljällä, ehkä näistäkin kannattaa odottaa testauksia ennenköä laitaa uusia kampoja tilaukseen? Itsellä meni tänään läpi tuo 5900X ja aiemmin jo tilannut kaappiin odottamaan Aorus X570 Master, ensi viikolla sitten pääsenee kasailemaan.
En onnistunut ostamaan 5900x mutta siinä kun pettyneenä katselin arvosteluita niin totesin että 5600x on aika tasoissa pelikäytössä joten kävin hakemassa strix b550, 5600x ja 32gb muistia.
Nyt on uusi kone kasassa ja kaikki pelaa hienosti mutta artic lf 240 ottaa muisteihin kiinni ja nyt kylki auki ja se lauhdutin koneen päällä, pitänee huomen käydä katsomassa jos olisi ripjawsseja matalampia muisteja tilalle.
Testailin viritellä tehoja ulos mutta en tajua noista amd kuvioista mitään, 4755 onnistuin saamaan cine r20 kun oli kerroin käsin 47.5.
Nyt on uusien Ryzeneiden myötä alkanut kutkuttamaan prossun (ja emon toki samalla) päivitys.
Tällä hetkellä on kiinni i5-8600K, ja siihen tulossa joskus 3080 Gaming X Trio kun vaan toimittajalle niitä saapuu lähetettäväksi. Ajatellut LG B9S:ssä pelata. Onko tuota prossua järkeä lähteä päivittämään uusiin Ryzeneihin ja jos on niin mihin niistä? 5800x silmäillyt mutta revikoita on heikonlaisesti. Mitä mieltä olette?
Anandtechin arvostelu kannattaa käydä lukemassa läpi jos on kiinnostunut teknisemmästä analyysistä. Rocket lakella pitää olla aika kovat kellot jotta menee ohi 1t SPEC2017 IPC:ssä, n. 13% kaula tarkoittaa että kellot pitäisi saada n. 5,6-5,7GHz asti jotta mentäisiin tasoihin. (Olettaen että rocket laken ja tiger laken IPC on jotakuinkin sama. Ennakkotiedot puoltavat tätä oletusta)
Toinen mielenkiintoinen graafi:
Applen omilla prossuilla olevat läppärit saattaa heittää aika kovat tulokset tiskiin, jos saavat kellontaajuudet kolmeen gigahertziin asti.
Tuosta puuttuu se "Equipped to win" kamppis, mikä tekee tuosta 5600X:stä ei niin hyvän diilin. Kattelin tubesta coreteksin videon missä oli kysellyt joiltain retailereilta noista launc määristä ja 5600X tullut jakooon yhtä paljon mitä noita muita malleja yhteensä.
En jaksa uskoa, että Equip to Win kamppiksen puuttuminen olisi ollut deal braker. Mutta tosiaan kuten videosi havainnollisti, tuota 5600X mallia on tullut kiitettävästi jälleenmyyjien hyllyyn. Tänään lähti myös oma kappale tulemaan postissa. :)
Mahtaakohan näiden X-versioiden kanssa käydä sama kuin 3000-sarjassa, vai onko sieltä edes tulossa 5600 non-X? 3600 -> 5600x olisi melko mukava päivitys 1080p resolle. Sinänsä turha maksaa tuosta 5600x yli 300e jos sieltä tulee 5600 200-250€ hintaan. Ellei sitten kellot ole selkästi korkeammat X-mallissa tai IF-kulje paremmin.
se on silti 6 core / 12 thread CPU, uusissa konsoleissa on 8 core / 16 thread, joten....
Joten jos zen 3 on 20 % nopeampi samoilla kellloilla ja ytimiä on 33 % enemmän 3700x prossussa, jäljelle jää samoilla kelloilla 13 %-yksikköä enemmän tehoa 8+ytimisellä 3700x nähden 6-ytimiseen 5600x. Sitten otat huomioon että 5600x:ssä on 5-10 % korkeammat kellotaajuudet, jolloin täydellisesti 8:lle ytimelle skaalautuvassa kuormassa eroa on vain n. 5 % ja tämä tosiaan vaatii täydellisesti skaalautuvan kuorman. Ja pelit harvemmin skaalautuvat 8:lle ytimelle täydellisesti, jolloin 5600x vähintään on yhtä nopea peleissä, useimmiten nopeampi.
Ite laittaisin tuon säästetyn rahan ennemmin näytönohjaimeen, kuin 2 lisäytimeen. Näytönohjain pitää jokatapauksessa olla sieltä parhaasta päästä, jos 5000 sarjan prossuista haluaa jotain hyötyä.
Itellä ostoslistalla 6800xt, joten konsolit voi pitää 8 ytimensä, ohi ei ole menossa.
EDIT: Ja oli jo varmaan tiedossa, että ikivanhat ps4 ja xbox one x on 8 core vehkeitä?
99% varmuudella tulee "ei X" versiot. Milloin? Sitä ei vielä tiedä. Tosin 1080p pelaamiseen kyllä riittää edellisen sukupolven prossut, vaikkakin 5600X @1080p on varmasti parempi kun 3600.
Ehkä semmoselle, joka päivittää konettaan 5v+ välein, niin varmaan kannattaa laittaa se 8/16-prossu tai 12/24.
6/12 piisaa aivan hyvin seuraavaan sukupolveen asti.
Onko näistä 59xx prossuista tiedossa tässä vaiheessa onko tulossa jotain päivitettyjä malleja, niinkuin tuli 3900X jälkeen 3900XT ?
Heittäkääs nyt paremmin asiaa ymmärtävät miten mikä olisi järkevä ratkaisu omiin tarpeisiin. Hommatako 5600X vaiko nyt käytettynä sit 3900X. Tällä hetkellä kiinni 2700X ja näyttiksenä 5700XT (tarkoitus päivittää 6800XT) x470 lankulla. Käyttönä on satunnainen pelailu (pugb ja cs) sekä striimaus hommat. Kannattaako mun ajatella edes tuota 5-sarjaa, vai päivittäisikö vain 3900X prossuun? Pugbi toimii omiin tarpeisiin ihan hyvin nykyiselläkin, mutta jos isket striimin päälle niin alkaa fps:sät putoamaan useita kymmeniä.
Eipä ole silmiin osunut muita kuin se 5600 non-x huhu:
Mutta melko varmasti sieltä on tulossa vaikka mitä malleja ensi vuonna.
Eipä ole silmiin osunut kuin se 5600 non-x huhu:
Jos tuo pitää paikkansa ni tuo tulee oleen hintaansa nähden melkonen peliprossu mikäli kellottuu lähellekään samoihin lukuihin kun X-mallit.
5600x olisi tulossa, onko tuosta mukana tulevasta tuulettimesta mihinkään vai pitääkö laittaa joku aio jäähy tilaukseen? Käyttö hyvin casuaalia pelaamista, enkä ajatellut kellotella.
Harmi kun HWUB ei saanut alkuun 5600X:ää. GN:n testien perusteella se on tosi hyvä pelikäytössä(kin). 5900X toki loistava all rounder. Summa summarum pelikäyttöön näkisin järkevinä valintoina 3100/3300X/10400 --- 3600 ---- 10600K/5600X... Ja sitten kun 5600 ei-X julkaistaan niin se.
Kyllähän sillä vakiollakin pärjää, mutta ilmeisesti se on aika äänekäs. Suosittelen aftermarket jäähyä.
Hys hys. Eikai täällä vaan suositella pelikäyttöön alle 8 coren prossuja? Etkö ole kuullut uusinta totuutta, että koska konsoleissa on 8 corea niin alle 8 coren prossuilla ei tee enää PC:llä mitään? IPC:llä, kellotaajuudella, välimuistilla tai millään muulla ei ole merkitystä, kun 8 corea on se juttu. Jos ostat vuonna 2020 alle 8 coren prossun olet täysi idiootti. Näin on minulle kerrottu. :poop:
Jännä nähdä miten porukalla onnistuu 1:1:1 kellot 4000mhz muistin kanssa. PC gamerilla ei, mutta Tompalla ilmeisesti kyllä.
Nimim. 5900X ja 4000mhz muistit tulossa, X570 Dark Heroa odotellessa
AMD Ryzen 5000 isn't hitting its full memory potential at launch
Toivon todella että tuleva kivi (5600x) on sitä luokkaa että FCLK olisi ainakin se 1900 ja ennemmin tai myöhemmin enemmän.
Nykyisellä 3600 kivellä menee helposti 1900, niin olisi tuon suhteen takapakkia jos ei uusi kulje 1900.
Muistit speksattu 4133mhz b-diet, 4000mhz olis hyvä :)
Mulla ois aika sama tilanne. Löytyisiköhän meille joku joka ois halpa ja hiljainen? Mulle itse asiassa mahtuis koppaan aika korkea cooleri (185mm max).
Siinä ainakin kelpo vaihtoehtoja, tosin Jonsbosta en arvosteluja oikein löytänyt, mutta ei tuollaista jäähyä PITÄISI voida kusta totaallisesti :D
Paino sanalla tällä hetkellä. Ei siitä oo kuitenkaan kun kolme vuotta kun "neljä ydintä riitti pelaamiseen". Tilanne saattaa muuttua hyvinkin nopeesti, 7700K:ta tuskin kukaan suosittelee enää mihinkään muuhun kun esports-pelien, vanhempien pelien tai kevyitten indie-pelien pelaamiseen. Ja siitä ei tosiaan ole kun hieman päälle kolme vuotta kun tuo prossu oli nopein peliprossu markkinoilla.
Joka tapauksessa tällä hetkellä tilanne kuitenkin on se että tuo 6c12t prossu todella messevä peliprossu ja IPC-ero konsoleihin on melko huomattava, joten ero säikeissä ei pitäs ihan heti tulla vastaan. Vaihtoo ei siis tarvi miettiä ihan hetkeen aikaan mikäli nyt meinaa 5600X:n laittaa alle ja päivitys järeempään onnistuu todella helposti mikäli säikeitä alkaa tarviin lisää. Tämä taas ei ollu mahdollista 7700K:n kanssa samalla alustalla.
Oma suunnitelma on kuitenkin laittaa jollain aikataululla 5900X alle koska plääni on taas kerran skipata seuraava sukupolvi, joten tuolla prossulla olis tarkotus pärjätä vähintään yhtä pitkään kun nykysellä. Laittaa sitten kaiken vaihtoon kuhan DDR5 hinnat alkaa oleen jotain muuta kun neitsytverta JEDEC-spekan kapuloista.
Itse tilasin Arctic Freezer 34 DUO E-sports. Pärjännyt hyvin testeissä. Muuten kait noista sun vaihtoehdoista mikä vaan, mutta Jonsbon unohtaisin.
Mulla on suunnitelmissa ollut hankkia 5950X + Asus Crosshair VIII Hero emo. Emo tukee mun olemassa olevia 4000MHz muisteja speksien mukaan, mutta onko nyt niin, että tuon prossun kanssa, johtuen FCLK:sta, en saa ajettua muisteja vielä tolla nopeudella? Ja mahdollisesti jossain kohtaa BIOS-päivitys korjaisi asian?
Se on valitettavasti tuurista kiinni kuinka hyvin prossun FCLK kellottuu. 3600-3733 on aikalailla taattu, 3800 yleinen. Toistaiseksi ei tunnu olevan mitään varmaa tietoa kuinka yleistä 4000 tulee olemaan. AMD:n community forumilla oli virallinen viesti jonka mukaan tosiaan tulevat AGESA-versiot tulevat parantamaan tilannetta jonkin verran
ps. suosittelen vilkaisemaan myös tulevan VIII Dark Hero emolevyn jos budjetti antaa myöten
Ensinnäkin kannattaa harkita Dark Hero emolevyä. Se osaa vaihtaa lennosta OC ja tavallista modea. Saa vakioboostikellojen ja kellotuksen hyödyt samassa paketissa. Mitään tietoa ei ole tuleeko feature vanhempiin asuksiin.
Toisekeen kukaan ei voi luvata sinulle FCLK 2000MHz:tä. CPU-yksilöissäkkin on eroja. Mutta AMD:n ilmoituksen mukaan he pyrkivät vakauttamaan 2000MHz kelloja. Tod. näk. tämä koskee niitä yksilöitä jotka ovat jo jotenkin tuolla toimineet.
Kun AMD:n monipiirirakenteen takia siellä on pari-kolme pientä piiriä ison lämmönlevittimen alla, niin tuollaisessa suorakontakti-lämpöputkiratkaisussa olisi suotavaa, että CCD-piirin yläpuolelle sattuisi ainakin kaksi lämpöputkea, lämpö kun ei sivusuunnassa kovin hyvin leviä vielä parin millin matkalla.
Fortis olisi kai tässä suhteessa optimaalisin niin lämpöputkien määrän (5) kuin sijoittelun (aivan vieri vieressä) suhteen. Tähän on kuitenkin vaikea löytää mitään käytännön testejä, ne kun on usein tehty Intelillä.
Kiitos molemmille vastauksista! En oo huomannutkaan tuota dark heroa ja ilman muuta se on sitten se mihin tähtään. Tuntuu vaan vähän tyhmältä alkaa ajaa 4000MHz muisteja matalammilla kelloilla kun Intelin kanssa on toiminut ok. No ehkä korjaavat tuon + jos tilaan 5950X:n, se on mulla sitten joskus...
@SeppoSokeri
Mikäli Alpenföhnin coolereihin päädyt, niin Jimm's marraskuun tarjouksissa: Alpenföhn Ben Nevis Advanced Black RGB -prosessorijäähdytin (Tarjous! norm. 36,90€) - 29,90€
Saat sinä matalammista kelloista sen hyödyn että todennäköisesti saa viilattua latenssit pienemmiksi. Penkeissä 3200cl14 vs 3600cl16 ei merkittävästi näkynyt eroa, 3600cl14 kun kellotti niin huomasi kyllä heti. Vähän mietinnässä että onko edes 3800cl16 järkevä vaihdos, nykyisellä 3800xllä ei fclk jaksanut 1900. Katsotaan uusiksi 5800xllä, 3800cl14 olisi muisteilla erittäin todennäköisesti saavutettavissa mutta voltit alkaa mennä mukavuusalueen ulkopuolelle. Eli ehkä rehellisesti vaihtoehdot ois 4000cl16 tai tuo nykyinen 3600cl14.
IO ei ole kovin pistemäinen lämpö, vaan se on iso piiri ja se on keskellä ja se ei kuluta kuin max 20W käsittääkseni, joten sille kylllä osuu ihan minimissään kaksi putkea, vaikka se ei sinänsä niitä vaatisi.
Ja sen IHS:n tarkoitus on nimensä mukaan nimenomaan levittää sitä lämpöä. Mutta joo, joku tuollainen VOI olla epäoptimaalinen Ryzenille, mutta 5600X:n tapauksessa kuitenkin varmaan riittävä. Mutta joo ihan vieri vieressä olevat lämöpöputket olisi paras tai sitten vielä siinä jäähyssä oma lämmönlevittäjä
Tuossa videolla De8auer demonstroi tuon kyvyn kellottaa 5950x prossua multicoressa manuaalisesti ilman, että menettää tuon single core boost -ominaisuuden. Emona siis asus dark hero. Ajaa myös muisteja 4000mhz kelloilla. Toki saattaa olla, että tälle herralle lähetetty vähän hyllytavaraa paremmin kulkeva yksilö.
DOCP päällä ja FCLK näkyy olevan suurimmillaan 1800mhz ja myöhemmin 1400mhz.
Ei näytä että muistit ja fclk olis 1:1 synkassa.
Mä oon hiukan ulkona noista muistikellotuksista, mutta mulla on 4000MHz CL18 - muistit, jotka eivät nyt loppujen lopuksi niin nopeita olekaan ja jos ajaisin niitä 3600MHz CL16, ois ne teoriassa ainakin nopeammat? (Jos siis niitä saisi ajettua CL16)
Jos tuota kommenttia purkaa vähän auki, niin käytännössä siinä sanotaan myös että esim. 3700X ei ole tarpeeksi hyvä prosessori pelaamiseen :D
Jo kerran tässä triidissä taisin vastata tähän sun käyttämään hokemaan ydinten määrästä. Kuusiytiminen 5600X pääse 90%:iin kahdeksanytimisen 3700X:n suorituskyvystä monisäikeistyvässä koodissa. Melkein tasoissa siis. Nykyisissä peleissä 5600X taas on +~15-20% suorituskykyisempi kuin 3700X. Eli 5600X vastaa lähestulkoon edellisen sukupolven 8 ytimistä prosessoria ja sen yhden ytimen suorituskyky on ylivertainen esim. pelikäytössä.
Varsinkin jos parin vuoden välein päivittelee konetta, niin suosittelisin kyllä pelikäyttöön 5600X:ää. Tietysti AM4 kannasta luopuminen tämän (?) sukupolven jälkeen vaikeuttaa päätöstä.
Tähän kannattaa kysyä neuvoa kokeneemmilta muistiguruilta, toki jos saat fclk kulkemaan 2000 mhz niin kannattanee käyttää docp-asetuksilla muisteja, mutta jos jää esim 1900 niin kokeilisin ainakin pudottaa latensseja samalla kun pudottaa taajuutta. 3800cl16 taitaa olla vaikeampi saavutettava kuin 4000cl18 teoriassa tosin, joten voi vaatia volttien nostoa.
En osaa sanoa tukeeko docp useampia profiileita, xmp:ssä ilmeisesti löytyy osalle 4000mhz muisteista suoraan asetukset myös 3600mhz:lle.
Hemmetti menin tilaamaan 5800X eilen ja nyt tajusin että 5900X vaan satasen kalliimpi.. Ei vaan kiinnostais odotella sitä niin kauaa ku 5800x sain verkkiksestä kuulemma ekojen joukossa tilattua.
Kannattaisko silti vaihtaa tuo? Tulee vaan mieleen ku viimeksi päivitti prossua ja valitsin 6600K 6700K sijasta ja kaduin sitä tänä vuonna kun ne lisä threadit ois tulleet tarpeeseen.
Pointter
