Xbox Series X + Series S -keskusteluketju
Better cross-device connectivity
These controllers now support Bluetooth Low Energy, which delivers better compatibility across devices and allows for better pairing experiences. You will be able to play wirelessly on Windows 10 PCs, iOS 15+, and Android devices with Bluetooth Low Energy for remote play from your console or cloud gaming with Xbox Game Pass Ultimate on the go. After installing the firmware update, these controllers will remember one Bluetooth host (e.g., smartphone) and one Xbox Wireless host (e.g., Xbox console), so you can quickly and seamlessly switch between previously connected devices with a simple double tap of the pair button.
This level of compatibility and connectivity has become the norm for modern devices and accessories. Increasingly, the controller will be your common touch point to your Xbox games across devices. We are invested in expanding Xbox gaming beyond the console, so Xbox controllers need to work equally well on both Xbox consoles and Bluetooth devices and moving between all these devices needs to be easy.
Reduced Latency
With this firmware update, we are bringing to these controllers the innovation of Dynamic Latency Input (DLI). Dynamic Latency Input delivers controller inputs more efficiently to your Xbox Series X|S console for a more responsive gaming experience and seemingly instantaneous action.
We are excited to bring new software features to Xbox One controllers, Xbox Elite Wireless Controller Series 2, and Xbox Adaptive Controllers that were previously available only on next gen Xbox Series X|S controllers. The firmware update is available to Alpha Skip-Ahead and Alpha users today, and will be available to additional flight rings in the weeks to come.
Ohjaimiin tulossa isoa firmware-päivitystä. Päivitys on jo jaossa insidereille.
Viimeinkin tuo luvattu DLI vanhoille ohjaimille. Itsellä edelleen käytössä.
Nyt on saatu kehitettyä adapteri, jota jo alusta alkaen saatoi odottaakin.
XBox X/S -sarjan laitteille modattu CFE-adapteri jolla saa käytännössä minkä tahansa m.2 NVMe SSD:n toimimaan.
(CFE = Compact Flash Express tukee max. 4x PCIe 3 -kanavaa, tämä adapteri 2xPCIe 3-kanavaa).
Eiköhän näitä saa kohta joka liikkeestä...
edit. Täältä löytyy. Toistaiseksi aika arvokas, mutta hinnat varmaan laskevat pian.
edit. hiukan korjattu ja täydennetty
Nyt on satu kehitettyä adapteri, jota jo alusta alkaen saatoi odottaakin.
XBox X/S -sarjan laitteille modattu CFE-adapteri jolla saa käytännössä minkä tahansa SSD:n toimimaan.
Tämä on loistava juttu. :tup: Samalla lyö myös painetta MS:n suuntaan hinnoittelun osalta ja että mahdollistavat muidenkin kuin Seagaten valmistamat SSD-kortit mahdollisimman pian.
Sitä ohjaimen auringon kaltaista lediä ei vissiin saa mitenkään himmennettyä tai pois päältä.
Tähän asti ollut vain Elite ohjaimen ominaisuus, mutta tulossa pian Night Moden mukana
Hyppäämällä tuonne beta-ringille sen saanee heti käyttöönsä.
Mitä ihmettä. Jos se ei ole teknisesti mahdotonta himmentää miten se ei ole ollut natiivisti asetuksissa julkaisussa? Oliko se jokin segmentointi juttu elite ohjainten myynnin kannustamiseen?
Luojan kiitos, että se on tulossa niin ei tarvi jotain teippiä alkaa laittamaan siihen eteen.
Onko tuossa xbox series X -ohjaimessa mitään oleellista uutta verrattuna vanhaan xbox 360 ohjaimeen? 360 ohjain alkaa tuntua aika kuluneelta. PS5 ohjain on aivan loistava, mutta kun nuo uudet tärinä ja liipaisinominaisuudet ei toimi PC peleissä, vaikka ohjain itsessään kyllä toimiikin PC:llä. Sen takia mietin olisiko tuo series X ohjain paras valinta uudeksi PC:n kapulaksi.
Microsoftin omissa peleissä kuten Forzat ja Gearsit on Xbox Onen padista lähtien ollut liipasimien tärinät PC:lläkin.
Movies Anywhere -sovellus julkaistu Xbox Series X|S:lle ja Xbox Onelle. Sovelluksen avulla voit koota yhteen elokuvia, jotka olet ostanut useista palveluista. Palveluista kuten Amazon Prime Video, Vudu, Google Play, Microsoft Movies & TV ja useista muista suosituista palveluista. Sovellus tukee 4K, HDR 10, Dolby Vision ja Dolby Atmos.
Mainitaan tässäkin keskustelussa, että Halo Limited Edition konsoli + Halo Infinite (digitaalisena) on ennakkotilattavissa Gigantista. Toimitus marraskuussa.
Koska niitä Dolby Vision pelejä alkaa tulla? Tietääkö joku?
Jotta tuosta täysi hyöty saataisiin, niin pelit pitäisi masteroida Dolby Visionille, joita ei taida olla vielä yhtäkään.
Insider ringissä DV for Gaming voi testailla, joka siis pakottaa HDR sisällön DV:lle, mutta ainakin tuoreimpien Known Issues tietojen mukaan siellä on vielä paljon hiottavaa tuon osalta:
Tilaukseen lähti, kiitokset vinkistä! Eiköhän vanhalle Series X:lle jokin käyttökohde löydy.
Sama täällä, piti tilata ja laitetaan ”wanha” Series X kiertoon :thumbsup:
Kiitos Nikolle vinkistä!
Osta ihmeessä. Itsekin ostin ja laitan vanhan Series X:n myyntiin. Saat varmasti omasi vielä vanhasta, kun saatavuus on mitä on.
Näin tein. Tällä hetkellä One X vielä kakkoskonsolina ja One S 3D Blu-ray-soittimena joten tämä Halo versio pääsee ykköseksi, nykyinen Series X korvaa One X:n toisena pelilaitteena ja One X korvaa One S:n soittimena. Sitten jääkin One S jonnekin pölyä keräämään.
Konsoli tilattu, klarnalla näytti ainakin tulevan lasku heti 30 päivän eräpäivällä vaikka konsolia ei saisikaan vielä.
Itsellä One X, One, X360, PS4 Pro, PS3, jne jne plus jotain muuta elektroniikkaa kaappien pohjilla. Ainakin, En ihan varma mitä kaikkea.
Piti nyt tilata kun on sen verta hieno ja Halokin lähellä sydäntä. Nykyinen Series X menee sitten pojalle.
Tuli heitettyä ennakkotilaus tuonne. Katsotaan tuleeko sitä konsolia ikinä perille asti tosin.
Ainakin Gigsun sivuilla lukee vieläkin et on rajattu erä ja yksi per tilaus tuon konsolin osalta. Tässähän toivoo, että tuon oikeasti saa omakseen.
Kyllä se sieltä tulee. Kyllä niillä on tiedossa montako konsolia ovat saamassa ja just sen verran saa tilauksia sisään.
Vieläkin epätoivoisesti haeskelen sitä Halo Infinite Elite Series 2 -ohjainta. Toi konsoli ei niin päräyttänyt, mutta perhana kun se ohjain meni niin nopeaan joka paikasta.
En edes tiennyt, että uutta Halo Elite ohjainta oli rajoitettu erä. Nyt alkoi kaduttaa, että jäi kallis ohjain ostamatta. :lonely:
Onko Seagatella ajallinen yksinoikeus noille laajennus(massa)muistipalikoille, vai miten homma menee? 1TB on hieman liian vähän omaan käyttöön, mutta onko tulossa vaihtoehtoja jollain aikataululla?
Virallisesti ei ole muuta tietoa kuin että muiden valmistajien mukaantulo ei ole poissuljettua. Silti ei taida olla merkkejä siitä, että mitään olisi tapahtumassa.
Ok, pitääpä seurailla tilannetta. Toisaalta 1TB riittänee, jos/kun ulkoisen USB-mötikän kautta pelejä tallettelee/siirtelee..
Takuulla on ajallinen yksinoikeus.
Ei Microsoftin lausuntojen perusteella.
"Xbox is continuing to invest in the Expandable Storage category on Xbox Series X|S with goal of offering choice for Xbox fans, including additional capacities and implementations in the future. "
"Microsoft tells me more suppliers and additional sizes will be available in the future "
Tuota tallennustilaa voi näköjään laajentaa käyttämällä NVME to CFexpress korttia ja lyömällä siihen perään Western Digital SN530 m.2 2230. Jotkut onnistunu tällein halvemmalla kuin ostamalla tuon virallisen palikan.
Vissii toi sama ku tämä, josta mainittiin viikko sitten?
Xbox-ohjaimen käyttö eri laitteiden välillä helpottuu ja nopeutuu entisestään.
Toivon mukaan tuo pätee myös siihen että usb:llä pc:ssä kiinni olleen ohjaimen paritus Xboxiin ei katoa joka kerta.
Juu sama homma. Oli näemmä menny ohi
Onkos mitenkä muuten mahdollista saada Xboxille ESPN+ toimimaan? Eli saako boksille VPN jotain kautta jne.
Kiinnostaisi ostaa se omanvärinen padi mutta perkele en pääse itseni kanssa sopuun mitkä värit siihen valitsen.
KNIKO
