Pi-Hole - mainosblokkeri raspberry pi:stä
Pi Hole ei enää estä Youtuben mainoksia Samsung Smart-TV:n Youtube:ssa. Muilla sama ongelma? Mainoksia tulee nyt 5 minuutin välein! En edes muistanut kuinka kauheaa on käyttää tuota ilman mainos blockkeria.
Täällä: How do I block ads on YouTube? lisää aiheesta.
Ei varmaankaan onnistu piholella enää, kun guugle luo uusia osotteita mainoksille koko ajan.
Tuolla pari scriptiä taisi olla, jolla sai hetkeksi mainokset pois.
Ei auta varmaan kun mainokset tulevat www.youtube.com/ads polusta videoihin. Siihen jos tekee jonkun SSL Proxy joka suodattaa on mahdollista blokata jotenkin mainokset. Toinen vaihtoehto on selaimeen tai sovelluksen lisättävä suodatin (adblock-laajennukset).
Laitetaan nyt vaikka tähän ketjuun, koska voi asentaa raspiin.
Introducing AdGuard Home
Currently, you can install AdGuard Home on MacOS, Linux (x32 or x64), and Raspberry Pi
The first question will be about pi-hole so let me please copy/paste my answer from product hunt.
First of all, pi-hole is an awesome product and kudos to its devs for doing a lot. Before AdGuard Home launch it was the only viable option in this field. Second, we named this version "0.9" for a reason. A lot of new features are planned for the nearest future.
Notable features/differences of the current version:
  • AdGuard Home has the same software under the hood as we use for our public AdGuard DNS servers (which are quite popular) so it is ready for the heavy load.
  • Simple UI, configure malware/phishing blocking, blocking adult websites or enforcing safe search, all in a couple of clicks.
  • It understands adblock rules syntax so you don't need 10k lines hosts files to block doubleclick subdomains.
  • It shows you some metadata about domains, and it's quite interesting to see who really tracks you.
From the developer's point of view: AdGuard is built on modern tech and written entirely in golang, which makes the further development easier. It is not a set of different tools (like pi-hole), but a single binary - easy to deploy and manage, and it can be compiled for whatever platform you want.
Meet AdGuard Home — a way to protect the entire home network without client apps! • r/Adguard
Tuli vähän rankemmin lisättyä filttereitä tälläsestä jättimäisestä collectionists : firebog
Ainakin ensimmäisen vuorokauden perusteella AdGuard taitaa jäädä taloon.
Minkä käyttiksen päällä pyörität tuota? Vois viikonloppuna kanssa testata...
Tuli vähän rankemmin lisättyä filttereitä tälläsestä jättimäisestä collectionista: firebog
nuo samat listathan menee myös piholeen. Mikä piholessa ja adguardissa on se suurin ero?
- adguard suljettua koodia, siinä missä Piholesta saa kaikki lähdekoodit. Ajellaanko tässä sitten mitä lienee nsa boksia kotona;)
Tuo rajaa itsellä kyllä adguardin täysin pois.
Hyvä silti tuokin olla olemassa, ehkä siitä saa jotain hyviä ideoita Pi-holen hemmot siirrettyä omaan projektiinsa.
Ei jaksanu odottaa viikonloppuun, koska asennus helppo. Pistin pyörimään macOS High Sierra virtuaaliin.
Siirsin tuon AdGuardin pyörimään rautaan kun vaikuttaa ihan hyvältä. Koneena Mac Mini late 2014 (MacOS Mojave) ja tuon on aina päällä. Pitää tehdä skripti, että tuo AdGuard Home käynnistyisi samalla kuin kone.
Pihole pyörii tuossa samassa koneessa virtuaalissa (Ubuntu Server 18.04).
Täytyy nyt seurata, mihin tuo AdGuard Home kehittyy...
Tein macOS Automator softalla tuollaisen hätäratkaisun. Eli adguard_start.app joka käynnistyy automaattisesti ja nostaa AdGuardHomen ylös. Ei jää mitään terminal ikkunaa pyörimään työpöydälle.
Mulla siis kirjautuu tuo kone automaattisesti sisään bootin jälkeen. Täytyy jossain vaiheessa tehdä tuo paremmin.
Nätisti on pihole toiminut. Ei ongelmia. Itsellä pyörii tuo siis HP:n Microserver gen7:ssä Ubuntu 18.04:sen päällä.
Tänään tullut seurailtua, mielenkiinnosta, paljonko Lumia 1020 haluaa soitella kotiin. Kiihkeästi 20 sekunnin välein yrittää tavoitella sqm.telemetry.microsoft.comia.
Tännekin varoitusta, kyseessä siis juvanderin suomilista. Lähti aika nopeasti pois kaikista omista laitteista.
Käytätkö suomalaista mainoksenestoa? Voit alistua tietämättäsi poliittiseen sensuuriin
Käytkö useinkin ay-liikkeiden nettisivuilla?
Mulla taitaa olla muistikortti taas vaihtokunnossa. Pihole vastailee dns-kyselyihin kyllä, mutta webui ei toimi eikä ssh:lla pääse sisään. Pakko laittaa tää pyörimään jonkun kunnon raudan päälle. Ei jaksa säätää muutaman kuukauden välein koko roskaa uudestaan.
Hieno olkiukko. Siinä vaiheessa kun Ublockin mukana tulevan adblock listan ylläpitäjä rupeaa sotkemaan oman nuppinsa politiikkaa mainosteneston alle ja sensuroimaan käyttäjien tietämättä netinselailua, niin ei voi muuta kuin toivottaa pikaista visiittiä kallonkutistajalle.
Varsinkin kun tuon "selkeän" AY-liikkeiden sensurointikohdan ulkopuolella on riveillä 362-363 nämä hienoudet:
  • jhl.fi/jasenyys/
  • jhl.fi/toiminta/
Kyseinen lista oli vakiona Ublockin vakio suomilista, näytti jo lisärin kehittäjien toimesta olevan poistettu tuon spedeilyn ansiosta.
/OT
Muistikortin kestävyys huollettaa täälläkin. Olen tuumaillut, että jos nuo lokit ottaisi pois päältä niin paranisiko kestävyys. Kuitenkin kun 40k kyselyä vuorokaudessa tulee täällä.
Osta Samsung Pro+ kortti niin ei tarvitse huolehtia (itse en ole tosin saanut vielä edes yhtään Samsungin Evoa rikki, Samsungilla on flash-muistitekniikka aika hyvin hallussa).
Onko Pihole pyörimässä ja kuinka kauan?
Piti kaivaa kaapin perukoilta vanha miniläppäri, että sai piholen pyörimään kun taas muistikortti teki tenät raspberryssä. Muistaakseni ostin kyllä viimeksikin "kunnollisen" kortin siihen. Tarkoitus olisi kuitenkin laittaa myös muuta kevyttä raspberryn pyöritettäväksi, mutta ei kyllä tule mitään jos menee pari muistikorttia vuoteen.
Itsellä ei ole ollut koskaan mitään ongelmaa muistikortin kanssa.
Olen käyttänyt useamman vuoden samoja kortteja. Tarviiko tässä huolestua, että kohta hajoaa.
Kortit Samsung pro 32gb ja SanDisk Ultra Plus 32gb
Täällä samsungin evo muistikortti, en nyt muista oliko 32 vai 64 gigaa. Reilun vuoden pörissy pihole ilman ongelmia ja toistaiseksi ei edes merkkejä lahoamisesta.
Ei ole, kaikenlaisessa muussa käytössä.
Nuo Samsung Pro+ kortit on MLC tekniikalla, ei niitä saa rikki ehjällä raudalla/normaaleilla jännitteillä. Muistikorteissa ei ole muita kunnollisia kuin Samsung.
Reilu viikko ollu nyt AdGuard Home käytössä. Ihan hyvin pelaa. On tuo UI vähän onneton verrattuna piholeen, mutta onnistuu tarpeelliset jutut.
Onko näiden kahden erolla nyt jotain suurta minkä takia kannattaisi vaihtaa tuohon AdGuardiin?
Pitänee siis hommata tuollainen samsungi testiin. Samalla varmaan tilata uusi poweri, jos vika löytyykin siitä.
Onko jotain valmista suomilistaa piholeen, tuntuu puskevan kaiken maailman kasino androidohjelmiin
Elisan boksi Zyxel VMG3925-B10B home networking valikosta ei äkkiseltään ULA juttuja löydy..hmm.
Mulla tämä sama boksi, mutta oon sen verran vielä kujalla näistä asioista niin ei aukea, että mitä asetuksia muutetaan ja mistä.
Saiskos joltain vähän selvennystä?
Eli tästä otetaan DHCP serveri pois päältä ja annetaan pi holen DHCP servun hoitaa loput?
Pitääkö seuraavista muuttaa mitään?
En viittis suinpäin lähtee mitään muuttelemaan etten sekota koko pakettia...
Riittää että otat DHCP pois. Sen jälkeen tuo pihole jakaa dhcpltä osoitteet. Ei tarvitse muuta.
Pihole dhcplle kerrot, että jakaa haluamaltasi alueelta osoitteet ja gateway on tuo modeemisi osoite.
Noniin kiitos tästä.
Tossa qettyz aikaisemmin tuumas, että joutui jotain iptableseja tämän purkin kanssa. Noh kait se täytyy vaan löydä pi hole tulille ja kokeilla mitä tästä tulee :) .
EDIT: Hidas (sieltä tulikin jo vinkkejä)
Ei ole tuota reititintä, mutta jaetaan nyt omat kokemukset...
Täällä reititin hoitaa DHCP:n ja PiHole pelkästään DNS-liikenteen (eli mainosten blokkaamisen).
1. PiHolelle annetaan muuttumaton (staattinen) IP, jotta reititin osaa ohjata DNS-liikenteen aina PiHolen kautta.
2. Kerrotaan reitittimelle, mihin osoitteeseen DNS-liikenne ohjataan (eli PiHolen osoite).
Ota nyt ihan ensteks reitittimen asetuksista back-upit.
(jos asetukset menee pieleen, niin saat helposti palautettua nämä vanhat)
EDIT: mulla näköjään eri lähestymistapa, mutta toimii se näinkin
Kuva nro 1: anna olla ympyröity kuten se on kuvassa.
Kuvat 2 ja 3 tuonne ei tarvi tässä mitään tehdä.
Kuva 4 tuolla juuri annetaan PiHolelle staattinen IP. (eli kiinteä IP)
a) Etsi PiHole reitittimen clientti-listalta.
b) Ota ylös PiHolen Mac-osoite.
c) Annat PiHole:lle kiinteän IP:n kiinteäksi esim. 192.168.10.30. ja tänne tosiaan tarvitaan tuo Mac-osoite (kuvan 4 valikko).
d) Kuvan 1 kohtaan "DNS Values" klikkaat "Static" ja laitat tuon PiHolen IP:n (192.168.10.30).
Noilla uskoisin, että alkaa toimii.
Juu toimii. Sillä ei ole väliä mikä sen DHCP jakaa kunhan siinä yhteydessä myös annetaan pihole ensisijaiseksi DNS palvelimeksi.
Vielä parempi on ehkä antaa itse käsin staattinen IP suoraa piholelle DHCP alueen ulkopuolelta.
No nyt aukes! Sain piille staattisen IP:n ja vedetään viel apt-get päivitykset ja varmaan piin päivitykset ni pääsee testaamaan.
Noniin nyt on pi hole pyöriny vajaan päivän ja olisi seuraavia kysymyksiä ja huomiota:
- Samsungin älytöllössä ei toimi Ruutu ja Yle Areena vaikka disabloi pi holen. Palautin modeemiin alkuperäiset asetukset niin taas toimii. Onko tässä nyt joku IPv6 ongelma tms? Vai pitäisikö kokeille niin, että pi hoitaa tuon DHCP serverin?
Tämä vähän hämää kun tuohon ei pysty laittamaan pelkkää DNS server 1:stä vaan vaatii myös tuon toisen. Jossain olin näkevinäni, että piin IP oli ilmoitettu 192.168.10.100/24 niin laitoin tuohon DNS server 2 sen 24 loppusen. En tosin tiedä onko tuo oikein...
Pitäisikö tuolla olla myös piin IP??
- SSH yhteyttä en saa toimimaan millään. Oon koittanu sudo systemctl enable ssh ja sudo systemctl start ssh, mutta putty herjaa vaan Network error: Permission denied. Kokeilin myös shellinaboxia, mutta ei sekään toiminut.
- Muistakaa ostaa laadukas poweri piille. Mulla on joku ebaysta ostettu missä lukee kyllä 2,5A ja piti olla ihan piille tarkotettu, mutta saan melkein kokoajan Undervoltage herjaa. Tilasin jo toisen powerin Amazonista.
sorvail
