Myyty Gigabyte gtx 970 windforce.
rapukala
Official Ässrock advocate R♿T #46
Tukijäsen
Nanosta 180€ posteineen:hammer:
Samassa viestiketussa joku kertoo myös:
The g1 goes through a process gigabyte calls The Gauntlet. They take the gpus that are allocated to them, put them through special tests and pick the best of the best in terms of power delivery, efficiency, etc and use those in the g1. This can translate to better overclocking, thermals, and energy efficiency. Might be something to consider..things like, the windforce led light and back plate are added bells and whistles.
Minimaalisia eroja joo, mutta kun tuli tuota tutkittua niin sen takia olisi kiinnostanut :)
Tarjoan GTX:stä 155e+postit
246 171
Anomalia
