This is what solved my launching issues - Download the tool OpenXR API Layers off github and disable any VR layers that may be problematic. You'll see a warning message saying this layer may interfere with anti-cheat software) In my case, it was VR motion compensation, eye trackers, etc.
I have some good news for you!
After investigating the issue, our team has found a solution and pushed it live on EA app. I am thrilled that some of you are confirming you can play again!
Meanwhile, similar issues on Steam continue to be investigated.
In order to help our team, could you try to boot the game in another machine with the same Steam account and see if this keeps happening?
I am a steam user who can no longer play the game since July, since update 1.9. Today update 2.1 has not solved any problems.
The game turns on properly but crashes randomly and fairly quickly.
The error message "The anti-cheat did not find the original directory".
On steam we have the option to check the files and repair them and every time 3 corrupted files are repaired.
All workarounds have been tried, but none have worked.
Personally I have already tried on another machine with my Steam account and that of my friends but it is exactly the same problem.
So the game starts but concerning Poland and Latvia there is a big bug, where i find myself in a sidereal void.
Now i uninstalled ea app to download the new ea app and it works normally without bug.
kokeilitko sitä \steamapps\common\EA SPORTS WRC\Engine\Binaries\ThirdParty -> OpenXR kansion nimeämistä vaikka OpenXRbak ?Ilman vr:ää kaataa koko koneen eli boottaa sen. Tänään Dirty Dailies, noin puolessa välissä kaatui ja boottasi koneen.
Kaikki päivitetty eli myös EA app. Tiedostojen eheys tarkastettu. Peli ja steam C:llä.
Ei vissiin auta muu kuin päivityksen odottelu?
Klubien puolella on viralliset kuukausikisat erikseen WRC:lle ja vanhoille autoille, viikkokisat ja vissiin päivä ek:tkin.Tätä kaatuilu ongelmaa on ollut muillakin, mitä lueskelin EA WRC sivuilta valitettavasti. Itse en ole vielä uutta dlc hommannut, kun en oikein tiedä onko siitä itselle paljon hyötyä. Itse tykkään enemmän vanhemmista autoista ja aika vähän tullut ajettua noita WRC autoja.
No onhan tossa pari uutta maata kisattavaksi, joten varmaan dlc tulee hommattua jossain vaiheessa.
Itsellä olisi edelleen toive, että saataisiin tähän peliin päivä, viikko ja kuukausi kisat, mutta taitaa olla liikaa toivottu.
Nyt kun pienen tauon jälkeen taas on vähän ajanut WRCtä niin muutama juttu taas tökkii.
- Rengasrikkoja tulee liian usein ja liian helposti, menee maku kun jos jossain clubikisassa menee niin se on heti ralli siinä.
- Jos menee tieltä leveäksi, niin automaattinen reset ketuttaa kun väylä takas tielle olisi ihan ajettavissa. Samalla tulee max penaltit.
-paikallaan olon disqualify. Jos se on pakko olla, niin aikaraja saisi olla vaikka 5min. Grafiikan ja kuvakulmien kanssa kun säätää, niin olisi hyvä nähdä se tie ja pätkä.
-Oikealta ohjattavat autot. Ymmärrän että niitä on, mutta olisi helppoa tehdä myös vasemmalta ohjattavat versiot ja saisi itse valita kummalla ajaa. Varsinkin kun suurin osa pelin oikealta ohjattavista on oikeassa elämässä ollut enemmän rallikäytössä tai edes saatavilla vasemman puolen ohjauksella.
Vieläkö muilla peli jäätyy ja stutteroi VR:ssä? En haluaisi satsata rahaa uuteen korttiin, jos se ei auta.Kai se pitää vaihtaa tuo 2080 Super 7800 xt:hen. Pelistä kun pidän edelleen kun hullu puurosta.
Täytyy olla kyllä täysin eri mieltä. Jos ei ole realistic damage päällä niin rengasta, eikä autoa muutenkaan, saa mitenkään rikki. Saisi olla kovempi damage-vaihtoehto vielä olemassa. No renkaan ei tarvitsisi siinä mennä enää helpommin rikki, mutta kyllä realisticillakin saa välillä melko mällin pistää ja ei mitään. Mikään pakkohan sitä rengasta ei ole sitten vaihtaa, eikä usein kannatakaan. Sitten jos on joku 10 km pätkä ja vetäsee heti alussa niin kannattaa, mutta riskiä on hyvä olla olemassa ja positiivista että virheistä rankaistaan
Harmittaa tämän epäsäännönmukaisuus. Välillä pääsee palamaaan kovinkin kaukaa, jossain kohden palauttaa ihan turhan helposti. Onko sulla yleisö pois päältä tai pienellä asetuksella? Niiden päälle ajamisesta tulee isoa penaltia ja matalilla asetuksilla joihinkin paikkoihin ei piirretä lainkaan yleisöä mutta pelin törmäyslogiikassa siinä kohtaa on edelleen katsoja ja sitten tulee outoja penalteja. Esim Kreikassa on yhdessä täysin leikattavissa olevassa neulansilmässä sisällä YKSI JÄRKKÄRI, jota ei piirretä jos yleisö on lowlla. Ja se ukko tönöttää ihan tien vieressä, siihen voi törmätä vaikka kaksi reangasta olisi yhä tiellä.
Joo miksi tämä on offlinessa ja clubeissa ylipäänsä päällä. Online lobbyssa ymmärrän ettei voi trollata
Valmistajien, ei niinkään pelintekijöiden vika. Noille pitää ostaa lisenssit erikseen. Ne oikeakätiset lisenssit ovat luultavasti halvempia, kun ei niitä juuri kukaan halua ostaa.
RS200, Escort, NR4 Lancer, Ascona 400 ainakin pitäisi saada vasenkätisenä. Jostain syystä tosin tässä pelissä ei ihan niin paha ole ajaa väärältä puolelta, mutta Dirt Rally 2:ssa mulla oli kokoajan sellainen tunne että maailma pyörisi vasemmalle päin kun ajoi vääränkätisellä autolla. Oli ihan mahdoton ajaa
Mulla stutterointi ja jäätyminen on loppunut, mutta onhan noita asetuksia ja engine.iniä muokattu kohta sen +20 tuntia.Vieläkö muilla peli jäätyy ja stutteroi VR:ssä? En haluaisi satsata rahaa uuteen korttiin, jos se ei auta.
Muistanko oikein, että sulla oli juurikin sama prossu kun mulla eli 5800x3d (edit: joo, niin. tuossahan tuo lukee)? Minkälaisella kypärän resolla ja in-game asetuksilla (medium/high/ultra) pystyy niillä ajamaan?Kyllä mulla edelleen aika-ajoin stutteroi, mutta ei niin pahasti että seinään olisin hetkeen ajanut sen tähden, eikä mitään sekunnin jäätymisiä. Mulla on nyt juurikin 7800XT johon siirryin 3060Ti:stä. Peli kyllä pyörii sillä paremmin, mutta rehellisyyden nimissä täytyy sanoa, että Nvidia piirsi jostain syystä tien tässä pelissä paremmin. RXllä tie on jotenkin rakeinen vähän kaikilla asetuksilla. Tykkään kyllä kortista ja hinta/teho suhde oli kohdallaan ja siksi ostinkin. Prossuna 5800x3d, muistia 32Gb alle 4000mhz nopeuksilla, Quest2 Steam Linkillä ja peli asennettuna ssd:lle. Graffa-asetuksia ja engine.ini säädelty.
Jos haluat ajaa ralli simulaatiota -> RBR (modeineen)Mitäs mieltä muut RBR-pelaajat, kannattaako tämä peli hommata näin jälkijunassa? Dirt Rally 2:sta kokeilin, mutten tykännyt ajotuntumasta. Onko tässä paremmat fysiikat kuin DR 2/miten ajotuntuma vertautuu RBR?
Kiitos vastauksesta, en tiedä meneekö jo liiaksi ohi kanavan tarkoituksen mutta kysytään kun en tiedä, nämä varoitukset nyt ilmeisesti liittyy tähän kaatumiseen, onko tietoa mitä tarkoittaa?Mikäs näytönohjain jos NVIDIA saattaa olla alkavaa muistivikaa gpun muistipiirissä. Tosin yleensä ruutuun tulee artifakteja mutta joskus menee vaan pimeäksi. Jos GPU pohjasta vikaa niin tapahtuman hallinnassa pitäs olla nvdkkrm tms kaatunut hetkellä jolloin kuva pimeni.
Nyt en ulkoa muista enkä ole hetkeen taas pelannutkaan WRCtä, mutta jos kypärän resolla tarkoitat SteamVR resolution scalea, niin se on n. 135% tjsp ja in-game asetukset on moni high/ultra, mutta ne kaikki aiemmin todetut tehosyöpöt sitten ihan low tai off.Muistanko oikein, että sulla oli juurikin sama prossu kun mulla eli 5800x3d (edit: joo, niin. tuossahan tuo lukee)? Minkälaisella kypärän resolla ja in-game asetuksilla (medium/high/ultra) pystyy niillä ajamaan?
Siis olenko tosiaan ainoa jolla tuo Muddy Business vastustaa pahasti? Siellä EP Lappi vetää aivan uskomatonta vauhtia ja voittaa joka pätkän.
20 sekuntia jään väkisinkin. Onko kellään mitään säätösettiä millä tuo ei puske niin paljoa märällä ja hitaissa?
Millä rengastaktiikalla vedätte?
Löysin jostain asetuksia, jolla sain pelin pyörimään AirLinkillä ilman nykimistä 2080 Superillani, et ehkä mun ei nyt sit tarvikaan ostaa uutta näytönohjainta. Low näyttä ihan tarpeeks hyvältä näin vaatimattomalle miehelle.Tänään vähän testailin lisää ja Totesin että ainakin itsellä Se on Steam linkin Network latency piikkejä Mikä Itsellä on sitä pientä nykimistä tehnyt. Virtual Desktop toimii nyt itsellä paljon smoothimmin langattomasti ja mitä aikaisemmin luulin suorituskyky eroksi onkin lähinnä asetuksista kiinni. Riippuen VD stream quality asetuksesta se rasittaa näytönohjainta enemmän tai vähemmän ja High asetuksella joutuu pelistä pudottaa asetukset low että pyörii tasainen 72 fps ja medium asetuksella saa pelistä kin pitää medium. Tasan ajella jatkossa VD kautta ja pitää pelin asetukset low, niin pyörii smoothisti. Upscalerilla saa nostettua grafiikka asetuksia selkeästi fps pysyessä hyvänä, mutta omaa silmää se ei miellytä, niin itse jatkan terävillä palikka-asetuksilla.
Joo, mä ajelen AI:ta vastaan Quick Playssä ja ikinä en oo ollu 15 sakissa Keniassa. Yleensä ihan siellä vikojen joukossa 32 auton rutistuksissa. Sitten taas Monte Carlot ja Estoniat tulee voitettua aika usein.Onko tuo ura vieläkin rikki. Tavallaan 80 prodsentilla laskettelin ruotsissa ja tulin toiseksi, isoja virheitä ja ruostetta ranteissa. Lähin sitten keniaan ja ei oo mittään jakoja, otin vielä uudestaan ja tulin limitissä niin 10sec turpaan ja koko rallissa joku 12 ja kunnolla turpaan. Ei se ajaminen mitään huippua ollut mutta jos sieltä ruotsista pystyi laskettlemaan ja yhtäkkiä ihan kunnolla turpaan.
Joo kävi itsekkin eilen ajelee kisan ja onhan se aika haastavaa näillä tehokkailla takavetoisilla. Itsellä ainakin näin liukkaalla on haastavaa, ettei aina kurvissa survo kaasua pohjaan. Itse kisa muutamiin pyörähdyksiin aikaa kyllä paloi, mutta ihan ok lopputulos. Pikkasen rohkeammin olisi pitänyt painaa, että olisi itse tyytyväinen.Ruotsi ja takaveto ei kyllä tässä pelissä lähde meikäläiseltä. Tai lähtee lapasesta ja useintekkirallissa ekalla pätkällä 5 eri kertaa katon kautta ympäri. Muita en päässyt edes maaliin
Samaa tässä tehnyt, ilman palautusta vielä.Ostin kun oli hyvässä alennuksessa Steamissa. Testasin, tappelin vr-toteutuksen kanssa ja palautin. Dirt Rally 2 on selkeästi parempi VR:nä pelattuna.
Löysin siihen jonkin ohjeen, mutta en jaksanut.Samaa tässä tehnyt, ilman palautusta vielä.
Oon saanut sen muuten jo aika pelattavaan kuntoon, mutta hieman paremmin pitää saada pyörimään (90fps+) ja se kaamee kimalle pois maisemasta.
Koititko engine.ini puukotuksia?
Ne teki suuren eron (AA).
Mistä ne tekkirallit löytyy ja pääseekö sinne vielä mukaan? En ole palkintosijoja hätyyttelemässä.![]()
