Call of Duty: Warzone (F2P Battle Royale PC/PS4/XB1)
Viime yönä tai aamusta tuli patch, PC:llä koko reilu 20GB.
Spoilerissa oman näkymyksen mukaan Warzone/Plunder koskevat muutokset.
WHAT'S NEW:
  • New Coalition Operator, Talon!
  • Plunder: Blood Money - Guaranteed cash drops on all kills. Bounty Contracts and Finishing Moves pay extra cash!
GENERAL FIXES:
  • When using KBM, the navigation arrows used to change which Season you’re viewing go in the wrong direction. This has been fixed
  • Fixed a bug where the killcam showed the player they were killed by Thermite rather than underbarrel thermite
  • In some cases, Xbox players might experience in-game stuttering after the console has been in Rest Mode and the “Instant On” setting is enabled. This has been fixed
  • Fix for a bug where players could see Daily Challenges rewarding duplicate rewards instead of XP
  • We now show weapon and equipment counts in the killcam. If a player was using Stopping Power, then the ammo count will be orange to denote this. We also show whether a player was using Dead Silence in the killcam as well
  • Since the 3/10 update, some players could encounter white flashes of light/VFX when shooting/standing near a wall, object, or another player. This has been fixed
Weapons:
  • Increased the max travel time for Crossbow bolts from 3 seconds to 6 seconds for longer distance shots
  • Bolt action rechamber will no longer be retriggered if interrupted after the round has been ejected (this fixes an issue with redundant bolt action rechambers after weapon switches)
  • Removing inaccurate attachment description from Solozero NVG Enhanced Scope: “Optic glint visible to enemies”
Perks:
  • Amped: Increased Amped reload speeds for the Strela-P, PILA, and JOKR
  • E.O.D: Damage resistance fixes and tuning:
    • Fixed an issue where Thermite equipment was not showing the damage resistance icon even though damage resistance was being applied
    • Stuck Thermite and Thermite bolts no longer have their damage reduced
Field Upgrades:
  • Field Upgrade Pro: Stopped cases where failed Field Upgrade placements would cause equipment to be used
  • Tactical Insert: Added broken Tactical Insert icon that is shown when the Tac Insert is destroyed
  • Deployable Cover:
    • Shotguns now destroy Deployable Cover with 3 melee hits
    • Added damage stats for vehicle and thermite damage
    • Fixed a bug where placing Deployable Cover on a door two times would allow the door to be moved
  • EMP Drone: Allow the EMP Drone to be used at the start of a new round in multi-round game modes
  • Stopping Power: We’ve doubled the amount of Stopping Power ammo given to Akimbo weapons
PC:
  • Stun Grenades are now less intense
  • Several fixes to prevent crashes and improve stability
Warzone:
  • New weapons can be found on the ground and in Supply Boxes: 725 Shotgun, MK2 Carbine (Marksman Rifle), EBR-14 (Marksman Rifle) and the .50 GS (Handgun)
  • Players who disconnect in Last Stand will now drop their items when leaving the game
  • Fix for a bug where the animation for the player equipping a gas mask will interrupt and block players from deploying their parachute
  • Tuned close up shotgun damage to prevent a single shotgun blast from downing a fully armored player. Stopping power can still make this happen
  • Added Warzone specific controller button layouts. The Bumper Ping and Bumper Ping Flipped layouts will allow those playing Warzone with a controller to use the Ping feature more efficiently
Plunder:
  • Players can no longer stack self-revive kits
  • Players that are spectating still get plunder payouts from contracts but at only 40% of the value paid to living players
  • Fixes to help prevent hitching when interacting with Cash Deposit Helicopters and Recon Contracts
Battle Royale:
  • Fix for a rare bug that allowed players to equip two riot shields if they had two different camos, but only one would appear on the player
  • Made it easier to see which item is selected while using a Buy Station
  • Updated button layout for equipment while using gamepad
  • Fixed a bug for players are not receiving a banner on the top right of the screen for allies or enemies initiating kill streaks
  • Prevent bullets that hit the riot-shield from depleting player armor
  • If a player flies the Recon Drone out of bounds, the player will hear the out of bounds countdown timer but will not see the countdown splash on their screen. This has been fixed
  • Fix for various and potential exploits
  • Field Upgrades: Fixed a bug where some Field Upgrades were not ending at the end of the pre-match
  • Players will now get a kill when someone that you’ve downed, disconnects from the game
  • Reduced the amount of cash given for averting a bounty
  • Increased price of Loadout Drop within the Buy Station to $8,500
Pieni nosto tuossa loadout hintaan, +$2500.
Ehkä kokeilevat ensin tuon vaikutusta, ja tarvittaessa hilataan lisää. Sanoisin että kyllä tuokin määrä voi alkupelissä tehdä jo eroa entiseen.
Loput muutokset eli peruspeliä koskevat voi vaklata linkin takaa:
Eikä mitään mainintaa tuosta warzone ctd:stä. Liekö sitten ajureissa vika...
ctd?
EDIT: Jaa niin, crash to desktop. Heh.
Onhan siellä tämä, ei ne yleensä noita crasheja avaa sen enempää:
PC
Postaanpa ihan pyytämättä tämän, elikkäs pelaan itse PC:llä ja vaimo PS4:llä ja meillä on ollut aika paljon murheita pelin oman voice-chatin kanssa, varsinkin crossplay-peleissä. Pelatessa näkyy ikoni että toisen mikki aktivoituu, mutta puhe ei kuulu jompaan kumpaan suuntaan. Pienen kikkailun jälkeen löysin konstit joilla saatu voippi skulaamaan kaikilla noin kymmenellä tyypillä joilla ongelmia on ollut.
Elikkäs PC:llä oli sellainen ongelma, että en kuullut muiden puhetta, mutta oma mikki toimi normaalisti. Ratkaisu oli navigoida Windowsin ääniasetuksiin ja disabloida kaikki muut äänilaitteet paitsi käytössä olevat kuulokkeet ja mikrofoni ja laittaa ne vielä oletuslaitteeksi (set as default). Eilen näyttiksen ajuripäivitys oli muljauttanut näytön aktiiviseksi äänilaitteeksi ja voippi lahosi uudelleen sen myötä, mutta nappasin sen pois päältä ja homma lähti taas pelittämään.
Pleikkarilla puolestaan mikrofoni ei aluksi toiminut lainkaan, mutta tämä korjautui sillä, että kävi ruuvaamassa pelin ääniasetuksista Mic thresholdin nollaan ja mikrofonin äänenvoimakkuutta ylös.
Ongelma tuntuu olevan PC:llä MW/Warzone kanssa se, että se tahtoo käyttää pelin voippiin Windowsin communication device. Monella käy juuri niin, että se valitsee siihen tarkoituksen esim. näytön kaiuttimet tai erilliset kaiuttimet headsetin sijaan.
Tuon pitäisi ratketa pysyvästi sillä, että määrität sun kuulokkeet default communcations deviceksi.
En ole ihan varma miten tuo menee jos on erillinen mikki.
Joka tapauksessa sitten ei enää pitäisi vaikuttaa jos uudet ajurit palauttaa esim. näytön kaiuttimet käyttöön.
Monella PC kaverilla oli tuo sama ongelma, ja kaikilla tuo comm device default vaihto auttoi pysyvästi.
ctd?
PC
Kattos perkele! Käynti optikolla voisi auttaa. Kävin testaamassa yhden rundin plunderia 120 hertsillä ja hyvin näytti toimivan.
Reactions: TML
Itellä toiminu kaatumatta ja muutenki pyörii tosi sulavasti. ryzen 2600 ja rtx2070. Peli itsessään kyl kolmen kimpassa kavereiden kanssa on superhauskaa. Tämmönen kasuaalikin saattaa välillä jopa pari tappoa saada. Pubg oli jotenkin mulle ihan liian sekava, tässä on yksinkertaistettu monia juttuja just sopivasti meikän makuun. Crossplay myös boonusta koska jotkut kaverit pelaa pleikkarilla niin päästään silti yhdessä peliin.
Tähän lisätietona että tosiaan jostain syystä jengillä heittelee peli itsestään render resolutionia väärin.
Jos näin käy itsellä kantsii käytännössä joka käynnistyksellä tarkistaa tuo.
Tässä nuo kuvat jotka ei tosiaan täällä lataa, mutta uudessa ikkunassa kyllä. Olisiko blokattu hotlinkkaus. Toinen imgur, siinä syy että https ei voi linkata kun bbs blokattu eli muuttaa kuvan urlin http. Tuosta ekan kuvan imgshare.io ehkä ylipäätään blokaus emt.
PS4 vertailu:
Kyllähän tuo eka kuva näyttää siltä että olisi render resolution alhainen.
Allekirjoittaneella tekee tätä samaa vaikka on uusimmat nVidian ajurit + Render resolution 100. Mistähän muusta tuo voisi johtua?
Asetuksista oon rassannut vähän kaikkea mahdollista, mutta nuo staattiset objektit näkyvät tuollaisen pikseliverhon takaa...
Prossuna 3600 + näyttiksenä GTX1080.
Hyvin huomaa serveissä että ympäri eurooppaa istutaan kotona kun baarit on kiinni
Naurattaa kyllä hulluna kun on jo 20 sakissa, ja joku tyyppi tulee täysin varomattomasti taloon sisään. Kuulee jo kaukaa tassutuksen ja ovien kolinan, sitten vaan mahalleen johonkin kulmaan ja odottelemaan. :coffee:
Jotain tyydytystä saa noista ulinoista vielä chätissä, kun kerää kaverin legendaryja maasta.
Ite oon enemmän sitä tyyppiä että kuljen seiniä pitkin, vaikka usemmiten siellä ei oliskaan ketään.
Uusimman patchin jälkeen pc:llä tuntuu jäävän ne hyppysyöksyn näkökentänkavennusefektit (ruudun reunoilta tulevia vaaleita säteitä tms.) päälle enemmän tai vähemmän pysyvästi.
Harvinaisen rasittavaa.
Editti: Kuvaselitys spoileriin
Tai sitten en vaan tajua
Onko tässä isoin kartta ja pelaajamäärä kaikista Battle Royale peleistä?
Parhaat asetukset äänien puolesta? Mä en kuule vihujen juoksuaskelia tässä pelissä ollenkaa, Ihan sama kuin lähellä vihu juoksee niin ei vaan kuulu. Vaikka ihan selän takana muutamien metrien päässä niin ei kuulu mitään. Alkaa vituttamaan.
Ei niitä kyllä monesti kuule. Ja saattahan vihulla olla useastikkin dead silence perkki päällä. Mutta joo ei tätä peliä oikein äänien perusteella useastikkaan voi pelata. Vieläkään osaa hahmottaa kuinka kaukana joku ammuskelee ja juurikin välillä ilmestyy vihuja selkään ja minne millonki aivan tyhjästä :D. Hyvä peli silti.
Itse kokeilen tällä hetkellä boost asetusta audiossa, tuntuu olevan vähän parempi. Aiemmin oli siis se studio tjsp.
Jotkut käyttää jopa boost high.
Toki onhan tässä pelissä äänet hyvin sekaisin, mutta silloin kun askeleet kuuluu oikein toi boost vaikuttaa ihan hyvältä.
Account ban ilmaispelissä... :facepalm:
Account bannit käyttöön ja joku tsydeeni ettei pelaamaan pääse ilman tiliä jossa puhelinnumero ja 2 vaiheen autentikaatio tms. niin kyllä sillä aika paljon vähenee jo.
Bannaamatta jättäminen nyt ainakin on typerin mahdollinen vaihtoehto.
Samantien voisivat vuotaa kyseisen käyttäjän tiedot niin, että kotiosoite on selvitettävissä. Sitten paikallisille laitapuolenkulkijoille työkeikka murtamaan kyseisen huijarin sormia. Huijaaminen loppuu tai ainakin katkeaa (heh) joksikin aikaa, työttömyys laskee ja rehelliset pelaajat saavat pelirauhan. Kaikki voittaa!
Onhan siellä näköjään porukkaa hyvin bännätty.
Olisi mielenkiintoista joskus kuulla millaisia onnistumisen tunteita tuo huijaaminen tarjoaa sillähetkellä kun olet listalla ykkönen ja tiedät ettet olisi siihen omin avuin pystynyt vai ajaako näitä se muiden pelin pilaamisen ilo eteenpäin että ovat valmiita jopa maksamaan siitä.
En tiedä tuosta. En ole kuullut. Pitääkin etsiä jos tuohon löytyisi joku korjaus kun näillä yhteyksillä menee melko kauan tuohon lataukseen.
itse löysiin tuollaisen mutta olen huono enkus sano jos löydät jonkun ohjeen joo tosiaan menee todella kauan kun ton hakee:(
Ei Blizzardin foorumeilla ainakaan ole mitään ratkaisua ongelmaan. Ovat kyllä tietoisia ongelmasta ja yrittävät ratkaista sitä.
Mulla kans yrittää ladata koko pasketta uudelleen, sama homma muutama päivä sitten kun oli patchi.
Hienosti on tehty, kun aina pitää päivityksessä ladata koko peli uudestaan. Taidan vaan odotella jos saisivat korjattua.
Tuskaa kyllä nämä päivitykset. Ensin latailin 170 GB heti kun tuo edellinen jättipäivitys tuli. Sekin piti hitaasti Ameriikan servuilta ladata, koska ilta-aikaan Euroopasta ei tullut ollenkaan. Tämän jälkeen Crash To Desktop (CTD) aina heti käynnistäessä. Googlettelun jälkeen poistelin jotain filejä ja ajoin repairin, joka päätyi latailemaan 150 GB paketin uusiksi. Nyt on pari iltaa pelailtu taas ilman ongelmia, mitä nyt eilinen 200 MB pikkupäivitys piti taas Ameriikasta ottaa, koska Euroopasta ei lähde tulemaan ilta-aikaan.
F2P versio vie mulla ~79.2Gb että ongelma ei ihan noin paha ole :srofl:
En ole kyllä muutenkaan huomannu että missään vaiheessa olis ladannu koko peliä uudelleen, en kyllä niin kyttäile noita aina kun jätän monesti koneen päälle jos tiedän että johonkin on tulossa patchi.
Huomenna pääsee f2p pelaajat pelaamaan myös normi multiplayeria viikonlopun ajaksi.
Ehkä tosin vain kuvan playlistiä missä pari karttaa.
EDIT: No täällähän ne tarkennukset.
Mitäs pelimoodia kannattaa pelata että saa aseita parhaiten/nopeiten kehitettyä warzonea ajatellen?
Jos tuon nyt oikein ymmärsin niin siinä on vain yksi playlist, playlist on siis yhdistelmä eri moodeja ja karttoja.
Siinä ei voi valita mitä pelaa.
Tuossa on kartat Shoot House ja Atlas Superstore.
Moodit on ilmeisesti Team Deathmatch, Domination, Hardpoint, Kill Confirmed ja Headquarters.
Noista tulee sitten joka rundi randomilla mappi+moodi yhdistelmä.
Joka tapauksessa tekee loadoutin missä ase jota haluaa nostaa ja tykittää menemään. Aika nopeasti noissa kaikissa tulee aseleveliä Warzone verrattuna, ja varmaan myös Plunderiin verrattuna.
Weapon tupla xp vielä päälle jos sellaisia löytyy.
Reactions: |le
Tämän viikonlopun kannattaa kyllä f2p Warzone porukan pelailla tuota normi MP:tä kun kerran pääsee. Ihan vaan siksi että on koko viikonlopun myös weapon tupla-xp, joten aika hätäisesti saa aseita nostettua ja kilkkeitä niihin avattua.
Olettaen tietenkin että tarvitsee aseita ja/tai niiden kilkkeitä avata, ja olettaen että jaksaa katsella cod mp:tä. :)
Weapon tupla-xp:llä saa käytännössä 2-3 tunnissa aseen nollasta lähes tappiin, eli jos on jo jossain suosikissa leveleitä niin ei sitä kauaa tarvitse tuolla mp:n puolella jauhaa.
Tämäpä juuri. Pitäis Warzonea ajatellen hommata ainakin Aug/FAL leveleitä :)
Ei ole kyllä missään muussa pelissä ollut näin verenhimoista porukkaa, osa tekee kaikkensa että edes sen yhden downed tyypin tapettua.
Johtunee siitä, että pelissä oli aiemmin bugi, joka laskin sen downedin "lopetuksen" sille pelaajalle tapoksi, joka teki "viimeistelyn".
Kai se kannattaa aina downed lopettaa jos niillä onkin self-revive?
Plus lisäksi toki onhan ylipäätään se lähes aina iso menetys sille tiimille. Harvemmin sitä ehtii Gulagin voittamalla, olettaen että Gulag vielä on, hakemaan ne kamat jotka menetti.
Kyllä itsekin pyrin aina järjen rajoissa myös heti lopettamaan downedin. Hyötyähän siitä vain on.
Terpsi
