- Liittynyt
- 19.10.2016
- Viestejä
- 6 859
Reddit - Please wait for verification
www.reddit.com
I may have found the solution to this. Please try the following:
Click on Windows and type Task Scheduler.
Go to Task Scheduler Library and look for “ModifyLinkUpdate” under Authors you'll see Advanced Micro Devices.
Open it and go to the Triggers tab.
Select the trigger that says “On workstation unlock” and delete it.
Lock your computer, then unlock it to confirm that it no longer pops up.
Word to the wise. If you right-click it in the `ModifyLinkUpdate` task in the main `Task Scheduler Library` panel, select `Properties`, then go to `Triggers`, select `On workstation unlock`, hit `Edit...`, then uncheck `Enabled`, you can just disable it instead...
So if something else breaks, you can rollback the changes.
Itse jään odottamaan kuitenkin toistaiseksi vain uutta päivitystä.
Ei valitettavasti auttanut näytön heräämisen kanssa.
