Tuote: Zeal Transparent Gold Plated Screw-in Stabilizers V2
Hinta: 12
Tuote ostettu (mistä ja milloin): Zeal, 09 / 21
Kuitti löytyy (takuu voimassa): Kyllä, Ei
Toimitustapa: Nouto, Post
Maksutapa: MobilePay, Käteinen
Zeal stabilizer (4x 2u, 1x 6.25u) setti mekaaniselle näppäimistölle. Mukana kaikki osat mukaanlukien ruuvit.
Hinta: 12
Zeal® Transparent Gold Plated Screw-in Stabilizers V2
The Original and best transparent screw-in stabilizers on the market that have zero rattle. For 1.6mm Standard thickness PCBs only. Custom made PCB mount screw-in stabilizers designed by Zeal®. The insert is vintage "pre-clipped" style, so no need to clip the feet. The outer casing features a...
zealpc.net
299,6 KB Katsottu: 40
