Myyty Wifi/Bluetooth sovitin Pci-Express väylään
Myytävä tuote: Wifi/Bluetooth sovitin Pci-Express väylään
Hinta:
30
Tuote ostettu (mistä ja milloin): -
Muuta huomioitavaa: Myynnissä muuallakin.
Tälläinen piiri RTL8821CE - Realtek | Wireless SoC ja tälläinen sovitin:
Product Description
100% brand new and high quality
Features:
Convert NGFF card to standard PCI-e card in order to work on desktop computer.
Works for motherboard with standard PCI-e slot.
Comes with 4 pin to 9 pin USB cable, connect from adapter card to 9 pin USB header on motherboard to activate bluetooth function.
6dbi dual antenna ensure pure and stable wireless signal.
Support DOS, Windows 7/8/10, Linux, Mac OS.
Not require driver, support Intel and AMD motherboard.
Converter Kit only, other accessories demo in the picture are not included!
Tips:
Please check your wirelelss card support AMD system or not.
If this card does not detected in Windows, or computer cannot boot up, Please change PCI-e speed from AUTO to GEN1 or GEN2 in BIOS.
Specification:
Interface Type: Desktop PCIE 1X, 4X, 8X, 16X
Module Interface: M.2 (NGFF)
Quantity: 1 Set
Note:
1.No retail package.
2.Please allow 0-1cm error due to manual measurement. pls make sure you do not mind before you bid.
3.Due to the difference between different monitors, the picture may not reflect the actual color of the item. Thank you!
Package includes:
1 Pc x Wireless Network Card
1 Pc x Board
1 Pc x Bluetooth
Sijainti: Helsinki
Toimitustapa: nouto, posti
Maksutapa: käteinen, tili, mobilepay, bitcoin
Kuva:
    1,8 MB · Luettu: 49
roosaevelin
