Starting Nmap 7.01 ( Nmap: the Network Mapper - Free Security Scanner ) at 2017-07-12 21:22 EEST
NSE: Loaded 132 scripts for scanning.
NSE: Script Pre-scanning.
Initiating NSE at 21:22
Completed NSE at 21:22, 0.00s elapsed
Initiating Parallel DNS resolution of 1 host. at 21:22
Completed Parallel DNS resolution of 1 host. at 21:22, 0.08s elapsed
Initiating SYN Stealth Scan at 21:22
Scanning br01-asc-wsol-pfs01.websolute.net.br (200.150.205.1) [1000 ports]
Discovered open port 80/tcp on 200.150.205.1
Discovered open port 22/tcp on 200.150.205.1
Discovered open port 443/tcp on 200.150.205.1
Completed SYN Stealth Scan at 21:23, 24.10s elapsed (1000 total ports)
Initiating Service scan at 21:23
Scanning 3 services on br01-asc-wsol-pfs01.websolute.net.br (200.150.205.1)
Completed Service scan at 21:23, 14.32s elapsed (3 services on 1 host)
Initiating OS detection (try #1) against br01-asc-wsol-pfs01.websolute.net.br (200.150.205.1)
Retrying OS detection (try #2) against br01-asc-wsol-pfs01.websolute.net.br (200.150.205.1)
Initiating Traceroute at 21:23
Completed Traceroute at 21:23, 3.09s elapsed
Initiating Parallel DNS resolution of 11 hosts. at 21:23
Completed Parallel DNS resolution of 11 hosts. at 21:23, 0.66s elapsed
NSE: Script scanning 200.150.205.1.
Initiating NSE at 21:23
Completed NSE at 21:23, 16.61s elapsed
Completed NSE at 21:23, 0.00s elapsed
Nmap scan report for br01-asc-wsol-pfs01.websolute.net.br (200.150.205.1)
Host is up (0.33s latency).
Not shown: 997 filtered ports
PORT STATE SERVICE VERSION
22/tcp open ssh OpenSSH 5.4p1_hpn13v11 (FreeBSD 20100308; protocol 2.0)
| ssh-hostkey:
| 1024 bb:59:d2:da:d2:ff:47:75:c3:3d:c0:16:84:d5:01:3e (DSA)
|_ 2048 42:9e:8b:b6:f2:dc:59:a0:bd:dd:83:2f:b7:ba:64:de (RSA)
80/tcp open http lighttpd 1.4.32
| http-methods:
|_ Supported Methods: GET HEAD POST OPTIONS
|_http-server-header: lighttpd/1.4.32
|_http-title: Did not follow redirect to https://br01-asc-wsol-pfs01.websolute.net.br/
443/tcp open ssl/http lighttpd 1.4.32
| http-methods:
|_http-title: 501
| ssl-cert: Subject: commonName=Common Name (eg, YOUR name)/organizationName=CompanyName/stateOrProvinceName=Somewhere/countryName=US
| Issuer: commonName=Common Name (eg, YOUR name)/organizationName=CompanyName/stateOrProvinceName=Somewhere/countryName=US
| Public Key type: rsa
| Public Key bits: 1024
| Signature Algorithm: sha256WithRSAEncryption
| Not valid before: 2014-01-16T18:33:54
| Not valid after: 2019-07-09T18:33:54
| MD5: 5dfa 6a44 ad93 feea a273 3d52 e6f7 9ce4
|_SHA-1: e11f 36e3 656a 8ca4 c3b9 775e 82ab 8b7d f71b eecd
|_ssl-date: 2017-07-12T18:23:20+00:00; -8s from scanner time.
Warning: OSScan results may be unreliable because we could not find at least 1 open and 1 closed port
Device type: general purpose|firewall
Running (JUST GUESSING): OpenBSD 4.X (94%), IronPort AsyncOS 7.X (85%)
OS CPE: cpe:/o:eek:penbsd:eek:penbsd:4.0 cpe:/o:ironport:asyncos:7.5.1
Aggressive OS guesses: OpenBSD 4.0 (94%), OpenBSD 4.3 (85%), IronPort AsyncOS 7.5.1 (85%)
No exact OS matches for host (test conditions non-ideal).
Uptime guess: 0.000 days (since Wed Jul 12 21:23:19 2017)
Network Distance: 13 hops
TCP Sequence Prediction: Difficulty=251 (Good luck!)
IP ID Sequence Generation: Randomized
Service Info: OS: FreeBSD; CPE: cpe:/o:freebsd:freebsd
TRACEROUTE (using port 80/tcp)
HOP RTT ADDRESS
1 68.07 ms 10.80.10.1
2 68.09 ms 5.157.7.49
3 68.09 ms 5.153.234.253
4 65.27 ms 5.157.4.25
5 68.06 ms xe1-1-0.stoccolma1.sto.seabone.net (185.70.202.136)
6 415.42 ms et4-1-0.sanpaolo8.spa.seabone.net (195.22.219.75)
7 414.81 ms highwinds.sanpaolo8.spa.seabone.net (149.3.181.103)
8 415.42 ms 209.197.25.214
9 415.39 ms ae1-rc-06bbone-tmk.ascentynet.com.br (177.185.15.2)
10 ...
11 334.46 ms ae3-rt01bbone-cas.ascentynet.com.br (177.185.15.7)
12 ...
13 334.38 ms br01-asc-wsol-pfs01.websolute.net.br (200.150.205.1)
