Nightingale
  • Keskustelun aloittaja Keskustelun aloittaja Charun
Charun
Tukijäsen
Nightingale is a PVE open-world survival crafting game played solo or cooperatively with friends. Build, craft, fight and explore as you venture through mystical portals into a variety of amazing and fantastical realms.
You are stranded beyond our world, cut off by the collapse of the arcane portal
network. This catastrophe has left you fighting to survive in a labyrinth of beautiful and dangerous Fae realms.
Your goal: become a skilled Realmwalker, and navigate the web of transdimensional portals. Only then can you discover your way to the magical city of Nightingale, the last known bastion of humanity.
Prepare to make your way through Faewild forests, harrowing swamps, and shimmering deserts as you unlock the portals leading deeper into the lands of Fae. Cook meals, build shelter and muster the spirit to persevere in the face of adversity.
Craft tools to harvest trees, ore, and plants, along with rarer resources found deep in the realms. Discover new schematics and assemble the equipment and weapons you need to survive. Using specialized ingredients and arcane technologies, you can enhance your gear with magical properties.
Design and construct an impressive estate from a variety of styles and tilesets. Upgrade and customize your structures, and form communities to safely live off the land. You can even recruit NPC workers to help harvest resources as you work to expand your property.
Freely roam expansive realms, where stunning visuals will transport you into a mystical Gaslamp Fantasy world. Find the abandoned remnants of past Realmwalker expeditions, investigate mysterious Fae architecture, search shadowy subterranean caves, and scout derelict ruins. Through every new portal, beauty and danger await you in equal measure.
Adventure solo, or play cooperatively with your friends in an online shared-world realmscape. Combine your strengths, skills, and resources to survive and thrive together. Work together to build communal estates, join up in uncovering the mysteries of the realms, and unite in facing the challenges of the Fae.
Craft and wield a variety of melee weapons and firearms to confront the fearsome creatures that lurk in the portal network, including twisted Fae mimicries of humanity known only as the Bound. Gather your strength and join other players against colossal apex creatures found in the deepest reaches of the realms.
Assemble a miscellany of Realm Cards to reshape the landscape of your next destination. While each realm will feature new dangers, discoveries, and surprises, you have the power to influence its design, including prevalence of hostiles, abundance of resources, and even the environment itself.
Tämä ollut itsellä pitkään seurannassa, mutta jossain kohtaa kehitystä lopahti mielenkiinto, muistaakseni "always online" vaatimukseen, mutta eilen EA-julkaisun jälkeen eräs kaverini streamasi tätä Twitchissä ja päädyin sen hankkimaan. Pelkästään hahmon luominen on varmasti monipuolisin jonka olen peleissä nähnyt, joskin suurin osa liittyy pelkkään ulkonäköön. Myös ulottuvuuksien (realm) välinen matkustaminen korteilla ja niiden vaikutus proseduraaliseen generointiin vaikuttaa varsin mielenkiintoiselta. Joistain paikoista tulee mieleen Starsand, Fountain of Youth, Green Hell tai jopa Bioshock.
Ainoa, mikä hieman edelleen mietityttää on pakotettu serveriyhteys, eli offlinena tätä ei voi pelata ja kun kuitenkin pelitalon ensimmäinen julkaisu kyseessä, eikä mitään takeita servereiden ylläpidolle ole, niin voi hyvinkin jäädä ns. kakkaa kintaaseen, mutta eiköhän tuosta 26€ edestä ajanvietettä irtoa.
Tätä kirjoitellessa peli juuri asentui, niin lähdenpä ulottuvuuksia hyppimään!
Kehittäjinä näemmä vanhoja Biowaren partoja.
Muutama tunti takana ja kyllä maistuu.
Tunnelma on upea ja tuo paikoittain mieleen Outcast ja Myst pelit.
UI on vähän kömpelö ja taistelu voisi olla mielenkiintoisempaa, mutta muuten ei valitettavaa toistaiseksi löydy.
Ilmeisesti myöhemmin mahdollisesti tulossa optio yksityisille palvelimille.
Joo, hyvin tuo maistu serverin huoltoon asti kun peli potkas pihalle. Jotenkin älytöntä yksinpelistä lentää ulos sen takia, kun servereitä päivitetään.. Toivottavasti tulee jossain kohtaa ihan oikea SP optio ja vaikka local host co-op moodi tuohon, mutta peli itsessään kyllä vaikuttaa hyvältä. :thumbsup:
Osui melko ilkeä bugi kohdalle.
Hyppäsin kalliolta kuolemaan ja itemiloota päätyi vuoren sisään tavoittamattomiin.
Muuten jees, mutta sinne meni kartan kaikki (5?) Synchronous Lotukset ja nyt pähkäilen miten saan kyseiseen tavaraan liittyvän questin tehtyä :btooth:
Syksyllä kun Intelin tarjouksesta tutkin, niin painotettiin enemmän yksinpelimahdollisuutta ja ulottuvuuksien välillä hyppimistä. Mutta vertauskuvallisesti kyseessä taisikin olla enemmän Fallout 76 kuin Fallout 4. Onko tässä mitään selvästi etenevää tarinakampanjaa, vai onko jatkuva rakentelu ja keräily se pääpontti?
Kaikki tuo realm- ja korttipuoli kiinnostaisi, mutta mihinkään rakenteluun ja grindaukseen ei viitsisi nyt aikaa tuhlata. Hätäpäissään menin jo pelin lunastamaan.
Kyllä tuossa tarinaa seurataan, mutta tietysti parempia varusteita ym. varten joutuu myös keräilemään ja craftailemaan. Kovaa grindaustarvetta ei itselle vielä omalla mittapuulla ole vastaan tullut.
Offline mode tulossa! :kippis: Nightingale - Nightingale - A Message on Offline Play - Steam News
[UPDATE: To address questions we've received, development on other updates (QoL, new content, fixes, bugs and other work) continues uninterrupted and we'll have more news on those to share in the coming days]
Hey Realmwalkers,
We’ve seen a lot of discussion in recent days around our decision to make Nightingale online-only at our Early Access release. We understand that this can be frustrating for a number of reasons.
Our vision for the game since inception was to create an interconnected series of Realms, with the idea of allowing for co-operative exploration in mind - a universe bigger than a single Realm or server. That meant we made a choice early in development between supporting co-op from day one or focusing development on an offline mode.
Co-operative gameplay associated with having party members across multiple Realms was the more technically challenging problem and therefore the one we chose to tackle first. Looking back on that decision, we misjudged what some of you were looking for in your experience.
We are now prioritizing and developing an offline mode that we plan to release as soon as feasible. Keep an eye on our social channels and Discord for updates in the coming weeks alongside other things we're working on. Thank you to everyone who has stepped into the Realms with us so far - the journey has just begun and we look forward to sharing it with you all.
- The Inflexion Team
Luopari
