    • Ei ref-linkkejä
Tekniikka MSI MAG X870 TOMAHAWK WIFI ATX - emolevy (AM5 kantaan) 219,99€
Taneli-
☤ Virallinen ⚔ testaaja ☣
Tuote: MSI MAG X870 TOMAHAWK WIFI ATX - emolevy (AM5 kantaan)
Tarjoushinta: 219,99€
Normaalihinta: 319,99€
Kauppa: Verkkokauppa
Voimassa: Kampanjahinta 219,99 on voimassa 24.6.2026 klo 23.59 asti.
Linkki: MSI MAG X870 TOMAHAWK WIFI ATX -emolevy 219,99
Kommentti tarjouksesta:
Koskaan ei hinta.fi mukaan ole näin halvalla emoa tarjottu, halvin tainnut olla 286,90€ 5.2025..
Yksi parhaista AM5 emoista varsinkin kun katsoo hinta / laatusuhdetta (ei heti tule mieleen toista alle 220€ emoa joka olisi yhtä laadukas)
Itse pystyn vielä laittamaan ostoskoriin ja olisi noudettavissa?
Eli vielä näkyy löytyvän...
eli se siitä laadusta sitten...
Ettei mene pelkäksi vänkäämiseksi niin tässä arvosteluja:
Pros:
  • Impressive value for money.
  • Good DIY features for installing PCIe and M.2 hardware.
  • 5Gbit Ethernet and WiFi 7.
  • VRM is plenty strong enough for your Zen 4 or Zen 5 CPU.
Cons:
  • Fourth M.2 slot is effectively only for show.
  • A Power micro button would be nice.
KitGuru says: The MSI MAG X870 Tomahawk is relatively basic but does a good job and has no obvious problems.
Only if you would rather die than have a motherboard without a light-show built in, or demand 3 Gen5 M.2 slots could you complain. We don’t, so won’t. The Tomahawk has always been a good choice for users on a budget, but the MSI MAG X870 Tomahawk is a good motherboard by any measure at all and wins our OC3D Performance Award.
Value and Conclusion​
  • The MSI MAG X870E Tomahawk Wi-Fi s currently listed online for $299
  • X870E for $300
  • Good VRM and M.2 cooling
  • PCIe Gen 5 SSD and GPU support
  • Minimal PCIe lane sharing
  • Decent number of USB ports
  • USB4 and Wi-Fi 7
  • Only one M.2 port with decent-enough cooling for PCIe Gen 5 SSDs
  • Rear case fans will need long cables to reach nearest fan headers
  • Middle M.2 heatsink is tricky to install
  • Struggles to stand out from the crowd
  • Software could do with some polish
  • USB4 ports share bandwidth with second M.2 port
Mutta no, jos oikeasti pitää paikkansa että 10% kaikista kyseisen mallin emolevyistä hajoaa / palautuu korjattavaksi tms. seison korjattuna. En ole kuitenkaan miltään isommalta sivustolta moisesta kuullut enkä samanlaisia ongelmia kuten Asrockin (tuhoaa 3D prosessoreita ennen ja jälkeen bios päivitysten) mutta jos sinulla on laittaa linkkiä niin kerro ihmeessä.
Vielä näkyy olevan ostettavissa...
Kerrotko millä prosentilla Asrock tuhoaa prosessoreita? Onko se 10? Onko se 1? Onko se 0.1? Tämä kiinnostaa, mikäli tietoa on.
Tässä on uutinen aiheesta:
Sen (uutisen, suora lainaus) mukaan "on raportoitu jopa 183 tapausta, jossa palanut prosessori on ollut Ryzen 7 9800X3D. Ongelmat eivät kuitenkaan rajoitu siihen, vaan uhreja on tullut toiseksi eniten Ryzen 7 9700X –malleista ja kolmanneksi eniten Ryzen 5 9600X –malleista. Seuraavia sijoja pitävät hallussaan Ryzen 9 9950X3D, Ryzen 7 7800X3D ja Ryzen 9 9900X. Prosessorin suorituskyvyllä ei siis vaikuta olevan suoraa vaikutusta kuolleiden prosessorien määriin eikä ongelmat rajoitu Ryzen 9000 –sarjaan. Myöskään emolevyllä ei vaikuta olevan merkitystä, vaan palaneita prosessoreita on tullut läpi ASRockin emolevymalliston, joskin keskittyen eniten 800-sarjan piirisarjoihin."
Voitko laittaa dataa siitä miten monta emolevyä on ostettu & palautettu juuri tätä MSI MAG X870 TOMAHAWK WIFI versiota? Kun en sitä tietoa löytänyt.. ..mutta sen jälkeen tämä keskustelu taitaa omalta osaltani olla tässä, jos sinä et tätä emoa halua ostaa ei siinä mitään... Kun tuntuu että tässä ketjussa tulee vain ns. one linereita vastaukseksi, ei mitään linkkejä ei mitään faktaa. Lähinnä vaan kysymyksiä...
Tuosta samasta uutisen ketjusta bongattu:
Verkkokaupan sivuilta kun painaa tämän emolevyn kohdalla lopussa olevaa "Näytä kaikki lisätiedot" nappia tulee näkyviin Huolto ja palautukset kohta. Sen mukaan Huoltoon on mennyt yli 10% ja palautuksia ei ole yhtään. Myyntimäärää ei näe mutta viimeksi saapuneiden listassa on 30 kappaletta viime vuoden syyskuun jälkeen joten on niitä varmaankin ainakin useita kymmeniä myyty.
Mulla on tästä X870E versio. Olisko E:ssä vähän rouheampi PCI-E puoli, en muista. Ei tässä rautapuolella ole mitään valittamista, mutta MSI:llä on vähän reipas ote BIOS-julkaisuissa. Tuppaa tulemaan välillä sellaisia oho hupsis versioita, joita sitten vetävät vähin äänin pois. Kolikon toisella puolella kaikenmaailman agesa-versioita ei tarvitse venailla ensi jouluun. Tuki myös kestää. 2018 julkaistuun B450 Tomahawkiin tulee edelleen bioseja.
UwU_LoL
