Myydään Lenovo ThinkVision P32-20 32" 4k IPS monitor
Product : Lenovo ThinkVision P32-20 32" 4k IPS monitor
Price : 380
Product purchased (where and when) : Purchased in Verkkauppa for a year
You can find the receipt (warranty valid) : No
Other things to consider :
Condition:
In very good condition, no box included
No deadpixel, works perfectly
Comes with displayport, power cable
Specs:
Screen size: 31.5"
Panel: IPS WLED
Resolution: 3840 x 2160 UHD (aspect ratio 16:9)
Color reproduction: 100% sRGB, 95% DCI-P3, Delta E < 2
Refresh rate: 60 Hz
Screen surface: non-reflective
Brightness: 350 cd/m2
Contrast: 1000:1 native
Pixel size: 0.182 mm (140 dpi)
Viewing angles (horizontal/vertical): 178°/178°
Response time: 4/6 ms (extreme/normal)
Speakers:-
Connections: 1 x Thunderbolt 4 in; 1 x Thunderbolt 4 out; 1 x HDMI 2.0; 1 x DP 1.4; 1 x Ethernet; 1 x USB 3.2 Gen1 Type-B; 4 x USB 3.2 Gen1 Type-A with 1 x BC 1.2 (Downstream); 1 x Audio Out (3.5 mm)
Stand tilt: -5° to +23.5°
Stand rotation: +-45°
Height adjustment: 155 mm
Pivot adjustment: 90°
Flicker-free: yes
Low Blue Light: yes, hardware based
AMD FreeSync: no
NVIDIA G-Sync: no
VESA wall mounting: 100x100 mm
Kensington lock slot: Yes
Included cables: power cable, USB-A to USB-B cable, Thunderbolt cable
Physical dimensions with stand: 599.5 x 714.2 x 234.6 mm
Weight with stand: 10.1 kg
Location (also state in title and tag) : Pohjois Haaga, Helsinki
Delivery method : Pick up
Payment method : Mobilepay, cash
Janezky
