Myyty Kingston A400 240GB SSD - Oulu
Myytävä tuote: Kingston A400 240GB SSD
Hinta: 25€ (+ kirjepostit)
Tuote ostettu (mistä ja milloin): Tullut käytetyn koneen mukana pari viikkoa sitten, power_on_hours perusteella ei kummosesti ole käytetty
Kuitti löytyy (takuu voimassa): Eipä ole
Muuta huomioitavaa: Vajaa viikon ollut käytössä
Koodi:
smartctl 7.0 2018-12-30 r4883 [x86_64-linux-5.3.0-pf2-tr] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Phison Driven SSDs
Device Model:     KINGSTON SA400S37240G
Serial Number:    50026B738044F936
LU WWN Device Id: 5 0026b7 38044f936
Firmware Version: SBFK61K1
User Capacity:    240 057 409 536 bytes [240 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Oct 15 16:27:39 2019 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)   Offline data collection activity
                   was never started.
                   Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)   The previous self-test routine completed
                   without error or no self-test has ever
                   been run.
Total time to complete Offline
data collection:        (65535) seconds.
capabilities:             (0x11) SMART execute Offline immediate.
                   No Auto Offline data collection support.
                   Suspend Offline collection upon new
                   command.
                   No Offline surface scan supported.
                   Self-test supported.
                   No Conveyance Self-test supported.
                   No Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
                   power-saving mode.
                   Supports SMART auto save timer.
Error logging capability:        (0x01)   Error logging supported.
                   General Purpose Logging supported.
Short self-test routine
recommended polling time:     (   2) minutes.
Extended self-test routine
recommended polling time:     (  30) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x0032   000   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       127
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       28
148 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       0
149 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       0
167 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       0
168 SATA_Phy_Error_Count    0x0012   100   100   000    Old_age   Always       -       0
169 Unknown_Attribute       0x0000   100   100   000    Old_age   Offline      -       31
170 Bad_Blk_Ct_Erl/Lat      0x0000   100   100   010    Old_age   Offline      -       0/146
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 MaxAvgErase_Ct          0x0000   100   100   000    Old_age   Offline      -       9 (Average 4)
181 Program_Fail_Cnt_Total  0x0032   100   100   000    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0000   100   100   000    Old_age   Offline      -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
192 Unsafe_Shutdown_Count   0x0012   100   100   000    Old_age   Always       -       12
194 Temperature_Celsius     0x0022   069   035   000    Old_age   Always       -       31 (Min/Max 19/35)
196 Not_In_Use              0x0032   100   100   000    Old_age   Always       -       0
199 CRC_Error_Count         0x0032   100   100   000    Old_age   Always       -       0
218 CRC_Error_Count         0x0032   100   100   000    Old_age   Always       -       0
231 SSD_Life_Left           0x0000   099   099   000    Old_age   Offline      -       99
233 Flash_Writes_GiB        0x0032   100   100   000    Old_age   Always       -       500
241 Lifetime_Writes_GiB     0x0032   100   100   000    Old_age   Always       -       2040
242 Lifetime_Reads_GiB      0x0032   100   100   000    Old_age   Always       -       74
244 Average_Erase_Count     0x0000   100   100   000    Old_age   Offline      -       4
245 Max_Erase_Count         0x0000   100   100   000    Old_age   Offline      -       9
246 Total_Erase_Count       0x0000   100   100   000    Old_age   Offline      -       101560
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
Sijainti: Oulu
Toimitustapa: Nouto, posti
Maksutapa: Käteinen, tilisiirto, MobilePay
Kuva: Jos ei tiedä miltä näyttää niin kai sen kuvan voi ottaa..
26€ sisältäen kirjepostin. Onko tuotteella takuu?
Ei ole kuittia sillä tuli käytetyn koneen matkassa kuten ilmoituksessa mainittu. Kingstonin takuukäytännöistä ei ole kokemusta eli toimivuustakuu on ainut minkä voin antaa.
Vastaile jos levyn otat.
missä päin oulua? jos ei kovin kaukana keskustasta niin voin käydä hakeen sen 20€ hintaan ovelta.
huntimanti oli YV:llä vastaillut ottavansa levyn ennen seuraavaa HP/nouto tarjoajaa joten menee hänelle.
246 002
Riksa82
