Myyty Jamo C 805 Hi-Fi kaiuttimet
  • Keskustelun aloittaja Keskustelun aloittaja Nagol
Myytävä tuote: Jamo C 805 kaiutinpari
Hinta: 350€
Kuitti löytyy (takuu voimassa): Täysi toimintatakuu!
Muuta huomioitavaa: Hyvin pieniä virheitä, näkyvät kuvissa.
Toimitustapa
: Nouto, Posti (30€) hyvin pakattuna
Maksutapa: MobilePay/Pivo/OP/S-Pankki
Myydään Jamo C 805 kaiuttimet. Hyvässä kunnossa, ei ole luukutettu. Nämä ovat olleet uutena 1500e/pari, eivätkä ole mistään citymarketista. Lisäkuvia saa halutessaan.
Mikäli hinta hirvittää niin esitä järkevä tarjous. Paino n.18kg/kpl
System 2œ-way bassreflex
Woofer (inch/mm) 6 / 155
Midrange (inch/mm) 6 / 155
Tweeter (inch/mm) 1 DTT / 25
Sensitivity (dB - 2,8V / 1m) 88
Impedance (Ohm) 6
Weight (kg/lb) 18.5 / 40.8
Dimensions (HxWxD/mm/in) 877 x 201 x 347 / 34.5 x 7.9 x 13.7
Frequency Range 40 - 24,000
PowerLongTerm 160
PowerShortTerm 320
https://www.bhphotovideo.com//Jamo_C805_C_805_Concert
C 80 is a series of top of the range stereo and surround speakers from Jamo. The aim of this series has been to recreate the perfect concert experience nothing more and nothing less. Regardless of size, every speaker in the series is represented by the capital C as in Concert. The sculptural C 80 speakers, with their high level of finish and perfectly balanced sound, are a tribute to the great music and film experiences that we all love and take such remarkable pleasure from.
Technically speaking the C 805 has exactly the same state-of-the-art technology armoury as its bigger brothers, although the woofer units have been adjusted in size to fit the smaller cabinet. This makes C 805 a real best buy if you want to reproduce genuine concert and cinema sound in a smaller room preferably backed up by the C 80 SUB.
The speakers in the C 80 series share a number of attributes. They all feature tweeters with DTT and WaveGuide, and woofers and midrange units using Hard Conical Cone and Centre-Plug technology. Furthermore they all come with an Active Impedance Correction system, which neutralises the magnetic field around the pole piece, reducing distortion by up to 50%. All front speakers in the C 80 series feature bi-wiring allowing you to fine tune the sound in perfect harmony with your room.
As all of the speakers in the series are developed using the same uncompromising philosophy, its possible to combine them in a number of different ways. Sound-wise the C 80 family is characterised by its genuinely authentic acoustics. The series always conveys highly detailed and beautifully resonant sound across the entire frequency spectrum.
Whether you are looking for the ideal cinematic or the perfect musical experience, the C 80 series is guaranteed to blow your acoustic window wide open.
    1,1 MB · Luettu: 7
    1,5 MB · Luettu: 10
    1 MB · Luettu: 11
    2,8 MB · Luettu: 10
Almedin
