Myyty HP Proliant MicroServer Gen7 N54L + 5TB levyä [Vantaa]
  • Keskustelun aloittaja Keskustelun aloittaja Irrah
Tuote: HP Proliant MicroServer Gen7 N54L + 5TB levyä
Hinta: 90€ 80€ 70€
Tuote ostettu (mistä ja milloin): HP täältä ja levyt kaupasta
Kuitti löytyy (takuu voimassa): Ei ja ei
AMD Turion II Neo N54L
8Gb (2x4GB)
WD 1.0TB Blue
32MB Cache
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-91-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Blue
Device Model: WDC WD10EALX-008EA0
Serial Number: WD-WCATRA615544
LU WWN Device Id: 5 0014ee 25cc1490f
Firmware Version: 05.01D05
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Dec 11 18:46:40 2023 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (15780) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 183) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0xb037) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 179 178 021 Pre-fail Always - 4025
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 115
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 080 080 000 Old_age Always - 14801
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 110
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 89
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 25
194 Temperature_Celsius 0x0022 114 101 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
WD 2.0TB Red
64MB Cache
Model Family: Western Digital Red
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M2UU04CT
LU WWN Device Id: 5 0014ee 0aec2dfc5
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
Local Time is: Mon Dec 11 18:47:36 2023 UTC
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
been run.
data collection: (27360) seconds.
command.
power-saving mode.
recommended polling time: ( 276) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
3 Spin_Up_Time 0x0027 175 174 021 Pre-fail Always - 4250
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 12
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8404
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 12
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 46
194 Temperature_Celsius 0x0022 119 110 000 Old_age Always - 28
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
WD 2.0TB Red
64MB Cache
Serial Number: WD-WCC4M7JT9K2R
LU WWN Device Id: 5 0014ee 004181c5f
Local Time is: Mon Dec 11 18:48:33 2023 UTC
was never started.
been run.
data collection: (26580) seconds.
command.
power-saving mode.
recommended polling time: ( 268) minutes.
3 Spin_Up_Time 0x0027 174 174 021 Pre-fail Always - 4283
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 13
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8475
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 13
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 48
194 Temperature_Celsius 0x0022 120 110 000 Old_age Always - 27
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Etuoven lukko puuttuu, ei vaikuta toimintaan mitenkään. Kovalevykehikkoja olen 3D printterillä tehnyt tuohon, kun edellinen omistaja oli ne jostain syystä hävittänyt, toimivat tosi hyvin.
Paikkakunta (ilmoita myös otsikossa ja tagissa): Vantaa, Hämeenkylä
Toimitustapa: Nouto tai postitus +10€ hintaan
Maksutapa: MobilePay, käteinen, ...
Kuva:
Jiiaer
