- Liittynyt
- 29.03.2017
- Viestejä
- 2 841
Tässä lokitietoja:
2025-01-05 02:10:33.261 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-05 02:10:33.262 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nordpool which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-05 02:10:36.723 CRITICAL (MainThread) [custom_components.hacs] <HacsData restore> [The repo id for music-assistant/hass-music-assistant is already set to 911125621] Restore Failed!
Traceback (most recent call last):
File "/config/custom_components/hacs/utils/data.py", line 222, in restore
self.async_restore_repository(entry, repo_data)
File "/config/custom_components/hacs/utils/data.py", line 270, in async_restore_repository
self.hacs.repositories.set_repository_id(repository, entry)
File "/config/custom_components/hacs/base.py", line 290, in set_repository_id
raise ValueError(
...<2 lines>...
Liekko palauttaminen ainoa keino?
Edit: tässä on ilmeisesti kyse samasta ongelmasta: After HA update to Version 2025.1.0 HACS is not starting: "custom integration 'hacs' sets option flow config_entry explicitly, which is deprecated at custom_components/hacs/config_flow.py" · Issue #4314 · hacs/integration
Tuolla laittamasi linkin lopussa oli jo muutamia purkkafiksejä mitä voi kokeilla riippuen virheilmoituksista.
Ja kuten vanha viisaus HA osalta on ollut et jos purkkisi toimii niin älä päivitä ellet tarvitse jotain uutta ominaisuutta tms.
