Myydään HGST SAS 8TB levy
Paha.
Tukijäsen
Tuote: HGST SAS 8TB levy
Hinta: 70€ (posteilla 85€)
Tuote ostettu (mistä ja milloin): -
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.15.0-67-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: HGST
Product: HUH728080AL5200
Revision: A907
Compliance: SPC-4
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca2620d1448
Serial number: R5G75ZLV
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Sat Mar 28 16:21:21 2026 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
Read Cache is: Enabled
Writeback Cache is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 35 C
Drive Trip Temperature: 85 C
Manufactured in week 12 of year 2017
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 101
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 2437
Elements in grown defect list: 0
Vendor (Seagate Cache) information
Blocks sent to initiator = 860678395002880
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 54570845 2563187.273 0
write: 0 0 0 0 93245 25455.437 0
verify: 0 19 0 19 69790 252007.552 0
Non-medium error count: 0
No Self-tests have been logged
Background scan results log
Status: scan is active
Accumulated power on time, hours:minutes 58359:10 [3501550 minutes]
Number of background scans performed: 353, scan progress: 3.05%
Number of background medium scans performed: 353
Protocol Specific port log page for SAS SSP
relative target port id = 1
generation code = 15
number of phys = 1
phy identifier = 0
attached device type: SAS or SATA device
attached reason: unknown
reason: unknown
negotiated logical link rate: phy enabled; 12 Gbps
attached initiator port: ssp=1 stp=1 smp=1
attached target port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca2620d1449
attached SAS address = 0x51402ec016944974
attached phy identifier = 4
Invalid DWORD count = 24
Running disparity error count = 0
Loss of DWORD synchronization = 6
Phy reset problem = 0
Phy event descriptors:
Invalid word count: 24
Running disparity error count: 0
Loss of dword synchronization count: 6
Phy reset problem count: 0
relative target port id = 2
number of phys = 1
phy identifier = 1
attached device type: no device attached
reason: power on
negotiated logical link rate: phy enabled; unknown
attached initiator port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca2620d144a
attached SAS address = 0x0
attached phy identifier = 0
Invalid DWORD count = 0
Loss of DWORD synchronization = 0
Invalid word count: 0
Loss of dword synchronization count: 0
Paikkakunta (ilmoita myös otsikossa ja tagissa): Hyvinkää
Toimitustapa: Nouto / posti
Maksutapa: Käteinen / MobilePay / jne
visakte
