Forza Horizon 3 (PC, Xbox One)
Avataampa tännekkin Horizon keskustelu.
http://www.xbox.com/fi-FI/games/forza-horizon-3
http://forums.forzamotorsport.net/turn10_topics89_Horizon-3-Discussion.aspx
Io-techille on nyt myös oma clubi Sukken perustamana. Löytyy nimellä IO-TECH (pelistä löytyy hakutoiminto clubien etsimiseen) ja tägi [IO-T],
Platforms:
Platform Resolution Frame Rate Xbox Live Gold Required?
Xbox One 1080p 30 FPS Yes, for Multiplayer
Windows 10 Up to 4K Unlocked (unless VSync is on, 60 FPS) No, not at all
PC Requirements:
Minimum Requirements
CPU i5 3570 @ 3.4 GHz
GPU NVIDIA GTX 750 Ti 2GB
AMD R7 250X 2GB
RAM 8GB
Hard Drive Type HDD
Available Space 60 GB
Resolution 1920 x 1080
Windows Version Windows Anniversary Edition 64-bit 14393.101
Supported Wheels:
  • Logitech G27 Racing Wheel
  • Logitech G25 Racing Wheel
  • Logitech G29 Racing Wheel
  • Logitech MOMO Force Feedback Racing Wheel
  • Thrustmaster T300RS
  • Thrustmaster T500 RS Gaming Wheel
  • Logitech G920 Xbox One Wheel
  • Thrustmaster T150
  • Thrustmaster TX Xbox One Wheel
  • Thrustmaster TMX Xbox One Wheel
  • Thrustmaster RGT Force Feedback Racing Wheel
  • Fanatec Wheels soon to be announced (sometime in September)
Ainakin aiemmin toiminut halvin tapa ostaa peli. Vaatii feikkiosoitteen Singaporesta.
    • Go on Singapore Microsoft Store
    • Search for "Gift Card"
You now have a cart with SG$70€ of gift cards, which is the price of FH3 on the Singapore store. It roughly equals to 51 USD.
    • Use paypal to pay for the gift cards
    • When asked to fill your adress, use a fake Singapore one (google map is your friend).
Now the cards are yours, you got 2 codes you have to redeem on your account.
    • In your computer's "Start" menu, search for "Region & language", and go to the relevant settings.
    • In the dropdown list, change your country to "Singapore". You don't have to change the language.
    • Open your microsoft store app, it should be the SG version now.
    • Redeem your gift card codes.
    • Look for FH3 and buy it with your Microsoft Store balance, now of SG$70.
    • Download.
    • Play.
    • Have fun!
You can change your region to your original afterwards and it will work.
https://whirlpool.net.au/wiki/xb1_non_aus_digital_purchases_faq
Tätä on tullut mätettyä pari päivää. Maistuu, vaikka olikin työn ja tuskan takana selvittää, miksi ei aluksi suostunut käynnistymään.
Hyvää viihdettä tämä peli tosiaan on ja ainakin itse olen odottanut "ikuisuuden", että tämän tyylinen autopeli tulisi PC:lle. Ensi vuonna pitäisi päästä sitten myös motorsport sarjaa pelamaan tietokoneella.
Laitetaampa muutama kuva vielä pelistä.
Heh, on tämä kyllä kova kärry :happy:
Jaksaiskohan joku perustaa oman Clubin IO-techin käyttäjille tähän peliin? Voisi lähteä pois tuosta muro-clubista.
Voe helvetti, mikähän tähänkin tuli päivityksen jälkeen, mikä tuli viime viikolla. Sen jälkeen valikoissa ja kaikkialla FPS vanhoilla asetuksilla 60+, mutta itse ajamaan ku menee niin fps tippuu 20-25 ja sen jälkeen pysyy siellä vaikka valikoissakin käy. Päivitystä ennen ei ollut tällaisia ongelmia. FPS:ään ei vaikuta vaikka laittaisi kaikki asetukset minimille. Käytössä i5-4970K ja GTX970, 16GB DDR3 1600MHz.
Muilla samoja ongelmia? :tdown:
E: Tarkemmalla tsekkauksella, kun pelin asetukset on minimillä niin CPUn käyttö kaikilla coreilla jotai 20-30 prossaa, mutta GPU huutaa koko ajan 98% vaikka lämmötki idlellä eikä tuulettimen RPM ainakaan korvakuulolla nouse. GPUn muistit jossain 75% tietämillä. Mistähän tuo mahtaa johtua? Ennen patchia ei ollut ongelmia, kunhan malttoi vain ei grafiikka-asetuksia laittanut pelissä ihan tappiin. Muut pelit on toiminut mielestäni ihan normaalisti, tässä ainoastaan huomannut ongelmia.
E2: Lisätään vielä, että tuo Forzan versio on siis 1.0.17.2. NVidialta myös uusimmat 373.06 -ajurit.
Voisko GPU:n muisti kuitenkin hakata vastaan, tai siis GTX970 tapauksessa se 3,5GB raja ylittyä?
Itsellä on 144hz näyttö ja tänään aikasemmin tuntui että peli lagaa aivan törkeästi. Noh boottasin ja otin pienetkin kellot pois prossusta, muutin prioriteetin korkeaksi sekä vaihdoin 144hz->60hz. Sitten toimi kuin vettä vaan vaikka nosti asetuksia mediumille ja msaa sekä fxaa 2x niin fps +60 jatkuvasti. Joka päivä saa runkata asetuksia, alkaa vituttaa :rage:.
Uutta patchia pc:lle!!!
Päivityksen koko : 974.5MB
(Kopioin suoraan muroon kirjoittamastani viestistä)
Ois aika heikko päivitys jos ennestään jollain medium-asetuksilla sulavasti pyörinyt peli veisi patchin jälkeen kaiken muistin GPUlta minimiasetuksilla :think:
Jaa-a, mitähän sitä seuraavaksi keksisi kokeilla. Pitääköhän sitä vielä jumpata noita ajureita...
Jännästi itselläni toiminut alusta asti ihan kohtalaisen hyvin ja jokainen päivitys on vielä parantanut sulavuutta. Viimeisin päivitys poisti mielestäni kaikki pienetkin ja satunnaiset nykäykset. Kolme kertaa tainnut peli kaatua ja aika monta tuntia jo kertynyt peliaikaa. Uusimmat nvidian ajurit olen aina asennellut, kun niitä on ilmestynyt.
Näytönohjaimelta varaa ainakin itselläni 1080p kaikki ultralla ja 4xMSAA 5Gb muistia. Tuntuu tuo näyttismuistista tykkäävän, jos sitä on tarjolla. Olis tuossa silti vielä optimoitavaa, koska prosessori tuntuu olevan pullonkaulana (2500k 4,4 Ghz) ja näytönohjaimen käyttö ei ole kuin harvoin >90%.
No itse tässä odottelen GTX 1080 ja katon sitten että miten mahtaa pyöriä. Nykyinen on tuo 970 niin ei ole kuin 3,5GB "nopeaa" muistia joten epäilen että näyttis on pullonkaulana itellä. Prossu tosin hakkaa koko ajan melkeenpä ~100%.
Kannattaisi varmaan harkita prossun reippaampaa kellotusta, jos vaan jäähdytys ja emolevy antaa myöten. Voi muuten mennä 1080 tehot paljolti harakoille tässä pelissä, jos ei sitten pelaa 4k resoluutiolla.
Antaa kyllä mutta ei jaksaisi ruveta siihen hommaan kun ei kellottelusta pahemmin mitään kokemusta ole.. Nykyisetkin kellot taitaa tulla jostain biosin "Best performance" tyylisistä pienistä tweakeista.
Tein tosiaan IO-Techille oman Clubin, kaikki saa liittyä! :kippis:
Myös alotuspostaukseen saa laittaa tuon jos haluaa. Clubi siis IO-TECH ja clubin tagi [IO-T].
Tuli vihdoin ostettua amazon us:ta ja täytyypi joinaa tuohon clubiin jahka lataus valmistuu.
Hyvin ainakin vaikuttaisi pyörivän sigun setillä. Eipä ole vielä tullu havaittua stutterointia tai muuta lagia. Ainut asia harmittaa on se että DFGT ei ole tuettujen rattien joukossa.
Onko kukaan enää pelannut tätä sen jälkeen, kun astetta kovempi simu eli MSC tuli markkinoille? :D
Eilen kävin vähän pitkästä aikaa ajelemassa, ja nyt kun ajattelin että nopeasti pari skabaa käyn ottamassa niin PC:lle tullut joku kahden gigan päivitys :btooth:
E: Foorumin omaan Clubiin ainakin mahtuu vielä :D Tervetuloa vaan kaikille
Juu kiitos, tulikin vaihdettua 'siitä toisesta' tähän oikeaan. :)
Ja kyllä, tämäkin Forza maistuu edelleen. Motorsport 6 jäänyt vähemmälle.
Uus autopäkki sieltä tuli eilen. Vieläkin käyttää aika paljon ensimmäistä corea. Kyllähän tätä silti tulee pelattua päivittäin ja jo keretty hakkaamaan 390 levuseks:hammer: Tulipahan ajettua goliathissa 9.07.983 ajaksi joka olisi maailman 67. nopein aika mutta perässä joku keltanen kolmio joka vissii johtuu siitä kun käytin rewindiä kerran...
Tullu taas parina iltana nyt pelattua, tekemistä nyt tuossa ainakin riittää. Ei edes viitsi aina festareita päivitellä kun mapissa muutenkin jo niin paljon tavaraa mitä ei ole mennyt läpi :lol:
Holden Monaro GTS tuli päiviteltyä tykimmäksi, mahtava peli kyllä. Kulkee yli kolmeasataa ja kutosellakin lähtee renkaat sutimaan vauhdissa kuin vauhdissa. Mukava leikkiä tuommoisella pitkin katuja :tup:
Ja nyt ois saanu 8.58.533 golathissa kaverin co-op campaign ja se perhana ei tallentanu sitä hemmetin aikaa... :rage:
PC-demokin näytti tulleen niin pääsi kokeilemaan. Näytti kyllä ihan hyvältä ja vaikutti hauskalta, mutta eipä tuosta silti vielä kehtaa maksaa täyttä hintaa. Katsellaan tilannetta uusiksi kun alkaa saamaan alle 40e:lla.
Pelasin xbox 360 -padilla ja hieman jäi häiritsemään, että vakionäppäimiä oli hirveä liuta erilaisia asetteluita, mutta ei tietenkään juuri itseäni miellyttävää. No itsehän toki voi säätää, mutta tarvitsee asettaa kaikki näppäimet alusta alkaen eikä vain voi vaihtaa muutaman paikkaa päittäin mitä itse kaipaisi valmiisiin asetuksiin. Toinen mikä jäi hieman kummastuttamaan oli, ettei voinut tai sitten en osannut asettaa samaan näppäimeen useampaa toimintoa kuten vakioasetteluissa on. Eli esimerkiksi normaalisti radio säätyy padin nuolista, mutta se avustaja Anna päällä nuolilla ohjataankin sitä. Nyt lopputuloksena omassa asettelussa ei voinut padilla käyttää Annaa laisinkaan. Samoin hieman kummastutti, että radion kanavanvaihto tai photomode on pakko pitää asetettuna johonkin padin näppäimeen muttei sitä Annaa...
Enko osannut vai eikö oikeasti ole mahdollista :D ?
Joitain toiminnalisuuksia on sieltä advanced controllerista mahdollista vaihtaa päittäin mutta tuo schemen luominen tyhjästä on kyllä huonosti tehty ja myös se ettei valmiita setuppeja voi muokata.
- Eikö tässä voi vieläkään tehdä kunnollisia custom pad asetuksia? On melkein pakko käyttää jotain valmista vaihtoehtoa.
Ilmeisesti ei... Itsekin kovasti olisin tuota toivonut, mutta kun ei niin ei. Kaikkein eniten ärsyttää, että noissa valmiissa asetuksissa joita iso pino on, on sen avustajan ohjauskohdan tiedot tyhjänä, mutta jos luot oman asetuksen ja jätät tyhjäksi niin sitten sitten se avustaja ei toimi... Löysin valmiista melko hyvän, mitä nyt oikea tatti ja valintanäppäimet on väärin päin... Olisi huomattavasti helpompaa valita A:lla kuin tönäämällä tattia eteenpäin ja samoin katsella ympärille tatilla kuin kirjaimilla...
Muuten peli on kyllä ollut sangen mukavaa päristelyä ja erityisesti olen pitänyt mahdollisuudesta kustomoida kisoja itselle sopiviksi. Mää en niin välitä paahtaa pelin kaikkein uusimmilla ja nopeimmilla autoilla vaan vanhemmilla ja hitaammilla, niin on ollut mahdollista. Samoin ollaan kahden kaverin kanssa väännetty co-oppia, toimii pirun hyvin kaikilla on ollut mielipiteenä, että hauskempi sitä on ajella kuin yksinänsä. Co-oppina piti ajella sen vuoksi, että kisoihin sai botit/drivataret.
Peli on toiminut suhteelisen ongelmatta, mitä nyt piti asentaa Windows uusiksi jotta lähti päälle... Jämähti siihen aloitus-pop-up-ikkunaan, eikä liikkunut millään. Ei auttanut Windowsin päivitykset, näytönohjainajureiden päivittämiset vanhempiin eikä muutkaan tunnetut poppakonstit. Sen jälkeen lähti toiminaan ja ihan hyvin on pyörinyt pelin itsensä tarjoamilla asetuksilla, 60 fps on käytännössä koko ajan. Latolöytöjen välivideoissa jostain syystä tippuu alle kymmeneen hetkeksi, mutta eipä nuo niin pelaamiseen vaikuta.
Edit: Löytyi muuten syy tuolle alun toimimattomuudelle. Windows-storen pelit täytyy asentaa NTFS-formatoidulle asemalle, mun varastolevy oli ennen päivitystä ExFat...
Jos joku ei muroa enää seuraa niin tässä on kuvani sieltä. Koitetaas saada samalla eloa tähänkin ketjuun :).
Driftingin ystäville vähän kuvia mitä olen räpsinyt :comp:.
GetPhoto.ashx
GetPhoto.ashx
GetPhoto.ashx
GetPhoto.ashx
Ihan mukava peli on ollut. Tämän pelin pariin on hyvä rentoutua jos ei kaatuilisi usein:facepalm:.
Ajattelin tämän pelin hommata pc:lle. Toimiikos tässä g27 ihan normaalisti? kiinnostais päästä driftailemaan avoimeen maailmaan.
Ja mistä tämän sais halvimmalla?
Kiva tässä on ainakin kuvailla, meikäläiseltä muutama otos:
No en epäile kun näyttää noin hyviltä nuo kuvat. melkein kuin olis otettu ihan oikealla järkkärillä.
EDIT:
Tuli nyt ostettua elämäni kallein peli(ei edes lisäosilla varustetut ole olleet näin kalliita), mutta toivotaan että tämä kannatti. Voi mennä jokunen tovi kyllä kun tuota 52Gt pakettia latailee:D
Vaikuttaa toistaiseksi siltä että heitin 70€ kankkulan kaivoon. Ei nimittäin lataa peliä loppuun saakka, vaan tulee teksti "virhe katso lisätietoja"
Oli latautumassa yön yli, eikä äsken latautunut loppuun vaikka kokeilin. mitäs nyt?
^ Onko uusimmat päivitykset Windows 10:ssä? Varsinkin Anniversary Update? Tuolta ohjeet tarkistukseen: http://tunecomp.net/how-to-check-if-the-windows-10-anniversary-update-is-installed-or-not/
Sittenhän joillain on ollut sellaisia ongelmia ettei peli suostu asentumaan muualle kuin C-asemalle. Tästä toki ei taida olla kyse kun ei edes lataa loppuun asti. Vai mahtoiko se kysyä asennuspolkua ennen lautausta? En muista enää, kun itsellä kävi tuuri ja lataus ja asennus (E:lle) meni ongelmitta eikä pelikään ole kaatuillut (paitsi boxilla kerran :D).
Siinä asemalla tarvitsee vissii olla myös aika paljon ylimäärästä tilaa että suostuu asentamaan.
Ja levyn tarvitsee olla formatoitu Ntfs:ksi eikä exfatiksi. Tosin se suostui sen silloin kyllä asentamaan muttei käynnistymään...
Ostin pelin storesta. painoin nappia "anna koodi" ja se rupesi lataamaan peliä. Ei kysynyt yhtään mitään minne asennetaan. pitää kattoo onko tuota anniversarya kunhan kotiin pääsen(luulis olevan kun vähän väliä tulee päivityksiä. Eilen sekä toissapäivänä). Levynä on seagate barracuda 1Tb joka on jaettu kahteen osaan. eli c-asema on 100Gt ja D asema on loput. En siis tiedä miten on formatoitu, kun en noista mitään ymmärrä. forza 6 asentui ihan normaalisti vähän aikaa sitten.
Juu voi olla että se yrittää asentaa C: osiolle jossa ei ole sitten tarpeeksi tilaa. Jostain sain kyllä itse valittua suoraan E: aseman itse. Oisko ollu jotku windows storen asetukset, en nyt muista.
Minun muistaakseni forza 6 asentui deelle ihan kysymättä. niin luulis tämänkin sinne asentuvan. No kunhan taas kotiin pääsen niin ruvetaan selvittämään mikä mättää
Tätähän se oli sinne ceelle änkemässä, nyt sanoi ettei ole tarpeeksi tilaa ja kysyi minne asennetaan. Deelle se sitä nyt pitäis asentaa. Nyt on sitten C-asema ihan täys:rage:, kiitos windowsapps
Asetuksista kävin tekemässä vaihdon että kaikki menee nyt D-asemalle. Ihme juttu että kysyi mulla vasta sitten kun toiselle asemalle ei mahtunut. Ja aseman vaihto asetuksen kävin tekemässä ennenkuin rupesin uudestaan peliä lataamaan. Mites saan nyt nuo "ylimääräiset romut pois tuolta C-asemalta kun siellä ei näy mitään ylimääräistä, ilmeisesti taas piilotettuja tiedostoja.
Ne joilla tuo Blizzard Mountain -lisäri jo on, onko se erillinen alueensa jonne pääsee jostain luokkaa lentokentän ja latausruudun kautta vai onko sinne ihan tie perille muualta pelialueelta?
Aika oikein arvailtu. Sinne pääsee lentokentältä erilliselle alueelle jossa on välissä latausta hieman.
No tuota hieman arvelinkin, kun lentokentälle oli kuvake ilmestynyt ja samoten pelin valikkoon oma välilehtensä. Kaippa tuo ostaa tarttee jahka tulee alennukseen.
Kai sitä itsekin voisi screenshotin jakaa:
Sormet syyhyäis jo päästä pelaa, harmi vaan kun lataus on valmis joskus 4 aikaa aamuyöstä. On tää vaa niin hyvännäköinen peli.
Voisin melkein muistin lisäystä suositella Forza pelejä varten sigusi perusteella. Erityisesti motorsport 6 Apexissa huomas hyvin 8 -> 16 Gb muistin lisäyksen ja Horizonia en tainnukkaan 8 Gb edes kokeilla.
Lisäystä on jossain vaiheessa kyllä tulossa. Nyt kun vaan sais tuon ratin asetukset kuntoon. Profilerista yleisistä asetuksista asetettu 900 astetta, mutta pelissä se ei sitä ole, vaan sen 180. Mikä on aivan liian vähän.
Se ratti ei käänny sisäkänäkymässä sen enempää mutta kyllä ne renkaat kääntyy enemmän kun katsoo ulkonäkymästä
Kaaleppi1
