Myydään DIY tricopter osina
Kleimo
Töysäläinen
Tukijäsen
Myytävä tuote: Käytännössä kokonainen tricopter + satunnaisia osia
1x #QUAD-CON16K/19534 HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA) = $14.99
3x #DT750/6247 hexTronik DT750 Brushless Outrunner 750kv = $34.80
3x #TR_P18A/4312 TURNIGY Plush 18amp Speed Controller = $35.70
1x #BMS-385DMAX/8761 BMS-385DMAX Digital Servo (Metal Gear) 4.2kg / .15sec / 16.5g = $20.48
1x #GWS-RD-1047/10055 GWS EP Propeller (RD-1047 254x119mm) (6pcs/set) = $4.82
1x #07-01002x5/8432 Front Wheel Steering Arm & Mount Set 40mm (5sets) = $2.59
1x #258000011/21758 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) = $4.75
1x #XT60/9572 Nylon XT60 Connectors Male/Female (5 pairs) GENUINE = $3.19
1x #S110331-46/17410 Scorpion Lipoly Lock Strap 205mm (Small) x 3 = $4.90
1x #OR021-01006A/10412 Servo Extention Lead 420mm (5pcs/bag) = $2.88
1x #AM1001A/68 PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) = $1.59
1x #TR_PC/2169 TURNIGY BESC Programming Card = $6.95
1x #9171000003/21321 USBasp AVR Programming Device for ATMEL proccessors = $4.95
1x #T2200.3S.25/8934 Turnigy 2200mAh 3S 25C Lipo Pack = $7.99
1x #ACC6/7028 Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories = $22.99
1x #LPGUARD18x22/4134 Lithium Polymer Charge Pack 18x22cm Sack = $1.99
1x #RX-9X8Cv2/12339 Turnigy 9X 2.4GHz 8Ch Receiver (V2) = $8.99
1x #9114000004/20976 Turnigy 9X 9Ch Transmitter without Module (Mode 2) (v2 Firmware) = $49.99
1x #9X-LCD-WH/17129 Turnigy 9X LCD Backlight Kit - White (DIY) = $4.99
1x #9171000157/28496 Hobbyking X900 Tricopter Glass Fiber Multi-Rotor Frame = $29.99
1x #9171000183/31315 Turnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack = $12.99
1x #9171000073/24723 Hobbyking KK2.0 Multi-rotor LCD Flight Control Board = $27.95
2x #LPGUARD18x22/4134 Lithium Polymer Charge Pack 18x22cm Sack = $3.98
1x #T-Neckstrap/11982 TURNIGY Transmitter Strap = $0.99
1x #189000034/20982 CNC Alloy Prop Balancer for Propeller, EDF & Heli Shaft/Blade = $13.56
1x #T2650.3S.30/9267 Turnigy 2650mAh 3S 30C Lipo Pack = $16.51
Hinta: 200e
Tuote ostettu (mistä ja milloin): Hobbyking + ebay
Kuitti löytyy (takuu voimassa): ?
Muuta huomioitavaa: Tälläinen projekti joutaisi pois kaapista. Ollut kasassa ja muutaman kerran lennätetty. Nyt kuitenkin osina ja myydään ainoastaan yhtenä pakettina.
Sijainti: Tampere
Toimitustapa: Nouto (sis. akut), Posti (ei sis akkuja).
Maksutapa: Tilisiirto, käteinen.
Kuva: IMG_20171101_155257.jpg
246 171
Anomalia
