Call of Duty: Modern Warfare (2019)
^ Huomenna klo 9 toi patch, tosin on siinä muutakin.
Patchia pukkaa, PC:llä koko vähän vajaa 20GB.
Ainoat asemuutokset koski Warzonea, siellä Kar buff ja SP-R 208 nerf.
Uutena PC:llä se että voi poistaa osia pelistä. Osia mitä voi poistaa on:
  • Campaign
  • Multiplayer
  • Special Ops
Warzonea ei voi poistaa.
Muutokset koossa on (miinusmerkki edessä siis):
-35GB Campaign
-42GB Multiplayer
-38GB Special Ops
-72GB Special Ops + Campaign
-129GB poistaa kaikki, eli vain Warzone jää
Source reddit.
Aika paljon säästöä siis! Vähän jopa yllätyin.
PLAYLIST UPDATE, MODERN WARFARE:
  • Ground War
  • Gunfight
  • Deathmatch Domination + Drop Zone
  • Gun Game TDM
  • HQ Firefight - teams can add to their score by capturing the headquarters and also by getting kills
PLAYLIST UPDATE, WARZONE:
  • Removing Blood Money Quads
  • Adding Plunder Quads
GENERAL FIXES:
  • Fix for an issue where the “next unlocks” section was showing attachments out of order
  • Fixed an issue where teammates could spawn inside a closed off room on Broadcast
  • Fix for a bug where viewing the “Nevermore” execution in the menu could sometimes cause the animal model to get stuck
  • Fixed a bug where grenades could fall through the floor in the Foreman’s Office while on Mialstor Tank Factory
  • Fixed a lighting issue with the “Gilded Arm” variant from the Season Six Battle Pass
  • Fix for an issue where players could experience a crash after reaching wave 45 or higher in Survival mode
  • Improved stability for PC
WEAPONS:
  • Increased minimum damage at range on the Kar98 in Warzone
  • Reduced minimum damage at range on the SP-R 208 in Warzone
WARZONE:
  • Fixes to help improve volume levels with War Tracks slider
  • Fixes to help prevent players from dying while completing the Subway puzzle
  • Fix for a bug where players might not be able to access Bunker 11
  • Fixed a gas mask bug when players attempt to complete the Station puzzle
  • Fix for a bug where using a self-revive near the doors on the subway train, they will clip out of the train but still be transferred to the next station
  • Fix for a collision bug near the entrance of the underground road on the West side of the airport
  • If a player dies post doors closing of the subway car, they will be pulled out of gulag by the fast travel system and then pulled back into gulag for a match once it is their turn. This has been fixed
  • Fix for an issue where the player's view could be forcibly moved when exiting a vehicle or parachuting
  • Fixed a bug where players could experience a crash after engaging with a Bounty contract
Harmi tosiaan, ettei warzonesta pääse eroon. Noin iso määrä turhaa paskaa sitä pelaamattomalle tarkoittaa, että peli vie silti tajuttomasti tilaa.
No juu, sen pitäisi kyllä olla vaihtoehto.
Vähän tuntuu että tämä on ollut hyvin pikainen ratkaisu, kun tuossa äskettäin nousi se isompi hulabaloo kun peli ei mahtunut 250GB SSD:lle.
Eli josko jossain vaiheessa sekin vaihtoehto tulisi...
Nythän on toi aa 12 saatavilla kolmella hipfirella haulikolla seitsemässä eri matsissa. Patch noteihin ei kumminkaan tämä mahtunut.
PC puolella codin päivitys meni hyvin ja nopeasti. Mut pikku este codin pelaamiseen tällä hetkellä on launcheri joka päätti antaa tällasen kivan ilmoituksen, prkl ei sitte! :rage: Onko muilla samanlaisia "ongelmia"?
On muuten tällä hetkellä multiplayer melkosta sontaa kiitos uuden haulikon. Puolet pelaa sillä, tai muulla haulikolla kun tekevät uuden haulikon challengia. :poop:
Noh, ei kai tuo useampaa päivää kestä.
Eipä ne taida osata yhtään patchia tehdä paskomatta aina jotain uutta. Sellainen kiva kierre. Aina puraisevat liian ison palan ja joku menee pieleen.
Minkäsmoinen kampanja tässä on, paljonkin pelattavaa tunteina? Search & Destroy pelimuoto myös kiinnostelee. Onko se voimissaan vielä?
Kampanjasta ei mitään käryä, mutta kyllähän S&D on erittäin suosittu pelimoodi. Vähintään voimissaan siis.
Onhan se kyllä hyvää hupia.
Olihan se kampanja ihan viihdyttävä, mutta jos vain sen takia on ostamassa, niin odottaisin, että pelin saa tyyliin 20 eurolla. Moninpeli tässä on kuitenkin se juttu. Myös tuota cooppia on tullut pelattua. Se on ihan hauskaa, jos ei perus tiimi vs. tiimi mättö jaksa innostaa.
Joo moninpelissä tuo S&D kiinnostaa myös. Kattelin, että 59,99 maksaa vieläkin. Mahtaakohan koskaan tulla alaspäin. :)
Itse ostin reilu pari kuukautta sitten ja silloin perusversio oli noin 40€ ja battlepass-versio 60€. Tuosta 40€:sta alemmas tuskin kovin äkkiä menee. Yleensä kun on avoin MP niin silloin tuo on tarjouksessa.
Vaikea nähdä tätä "vahinkona", esim. VAL ja R700. Nyt on viimeinen hetki rahastaa ennen kuin cold war tulee, joten alussa season passin aseista tehdään "vahingossa" ylitehokkaita, että jengi ostaisi sen paremman season passin jolla skippaa 20 ekaa tieriä, tai sitten rahalla suoraan tierille 30. Sitten viikon päästä kun massia on kerätty tapeeksi, niin patchataan aseet salonkikelpoiseksi.
Alla olevassa linkistä aiheesta lisää, sekä miten Activisionin patentoitu SBMM toimii ansaintamallina.
Itellä jää ainakin seuraava ostamatta kun katsellut yhden pelin verran tätä sontaa. :tup:
Joo, tilausta olisi kyllä hyvälle vaihtoehdolle. BO4 oli loistava, mutta ne loottiarpa aseet oli hanurista. Nyt taas SBMM tapaa peli-ilon. Melkein mielummin ne loottiarpa aseet takaisin, kun kerran jotain mikromaksuja Activi$sionin on pakko kerätä, kuin tiukka SBMM.
SBMM on taas mukava ettei tarvii helppoja lobbyi pelata. Pääsee jotain järkeviä vastaanki pelaamaan ja tuo taitotaso on niin alhanen muutenkin MP:s et mun mielest tuo ei ollut edes paha betassa :P Voi toki olla et tulevat alentamaan tai muuta
Seasoni alkaa olla taas sen verran pitkällä että pro pelaajat on levuttaneet tappiin ja lähteneet muualle, tilalle tulleet huijarit. Jee. Joka toisessa pelissä sai taas tänään kuolla aivan selvään aimbottiin.
No ilmankos oli eilen tahmeeta pelailla jos tuollaista liikenteessä.
Viimeisessä pelissä tein zombina sen superhypyn täydellä teholla vuoren huipulla puiden keskellä niin "HAXBOT" tms niminen kaveri veti täyden laserbeamin n. 300 metrin päästä, taisi olla Kilolla. Ei yhtään kutia ohi, tähtäin seurasi aivan liimattuna, ja lensin siis koko matkan kuin raketti, ja vielä suurimman osan puiden takana. Ja luonnollisesti minuahan siinä ei edes oikeasti ammuttu vaan kaveria joka oli siinä alapuolella puun juurella, välittömästi vaan kun tämä kuoli niin tähtäin liimasi aivan välittömästi suoraan meikäläiseen.
Pari peliä ennen sitä olin yksi kolmesta onnekkaasta joita joku toinen aimbottaaja veteli SPR:llä vuorotellen päähän. Hauska oli katsoa kill cam miten se tähtäin vaan hyppää koko ajan seuraavan päähän aivan välittömästi ilman minkäänlaista kädenliikettä ja seuraa myös mukana koko ajan liikkuvia vihollisia.
Kiva että lisäävät näitä helvetin mikromakruleluja jatkuvalla syötöllä kun itse peli on vieläkin aivan yhtä rikki kuin julkaisussa, eikä minkäänlaista anticheattia.
No toisaalta taas, tännäänki tuli 7h pelattua eikä yhtään koodiepäilystä tullu vastaan. Juuriko on tosi että tuossa ei mittään anticheattia ole? Aika harvassa ainaki mulla on ollu psiitterit, toki en paljon ole pelannukkaan, olisko joku 200h ehkä mittarissa.
edit, jaa zombina, elikkä pelannu warzonea
Zombie warzonessa tosiaan kolme peräkkäistä peliä eilen ja kaikissa kuolin eri häckeriin... Perus multiplayerissä ei juurikaan ole tullut vastaan.
Joo, Warzonen puolella. Levelin 40-50 accountteja aika tasaiseen tahtiin tulee selvillä cheateilla että ei toi anticheat ainakaan kovin nopeasti niitä nappaa. Normi MP:ssa ei varmastikaan ole yhtä paljoa kun kyseessä on maksullinen peli. Oikeastaan voisivat tehdä tosta Warzonesta seuraavaan COD:iin jonkun maksullisen kilkkeen ihan vaan cheattereiden vähentämisen takia. Koko 60e peliä en kyllä sen takia halua ostaa, niin täyttä sontaa tuossa pelissä kaikki muu on.
Täs ei o kyl enää hitonka järkee, JOKA PÄIVÄ tulee joka toisessa tai joka kolmannessa pelissä huijareita vastaa ketkä ei edes peittele.. alkaa olee aika ettiä toinen peli mitä pelaa. :(
No niin pitkään kuin warzone on ilmainen niin ei paljoa bottereita paina tuo kiinnijäämisen pelote. Normipelin puolella tulee hyvin harvoin vastaan epäilyttäviä tapauksia mutta noita on selkeästi enemmän Warzonessa.
Nyt pääsee grindaa, Shoot the Ship.
Jee, pitkästä aikaa viikonlopun aikana ollut taas kiva pelata. Tuo on yksinkertaisesti paras pelilista, jonka pitäisi olla aina käytettävissä. Välistä tulee toki pelattua muitakin, mutta jos tuota pelilistaa ei ole saatavilla, niin jää koko peli käynnistämättä.
Poitsulle pitäisi muuten ostaa tästä PC-versio, onko missään näkynyt hyviä tarjouksia? Ei viitsisi ostaa ihan täydellä hinnalla, kun on ostettu jo yksi PC-versio ja yksi PS4-versio ja uusi cod vie tältä pelaajia, vaikka tämä vaikuttaisi olevan laadukkaampi julkaisu kuin tuo uusi kyhäelmä.
Eipä tuota taideta muualla myydä kuin Battle.net:in kaupassa. En tiedä pystyisikö kikkailemaan jotenkin VPN:llä tms. hintaa alemmas. 60€ normisti ja 45€ on välillä saanut tarjouksesta, luulisi tuon uuden codin tulemisen aikoihin saavan siihen hintaan tai hyvällä tuurilla hieman halvemmalla.
Jos nyt heti on pakko päästä pelaamaan, niin sitten on 60€ pulitettava. Jos jaksaa odottaa x määrän viikkoja, niin sitten voi saada noin 40€ Battle.netin tarjouksesta. Mielestäni ei ole vähän aikaan mitään tarjouksia ollut, joten voi olla, että piankin on alennuksessa. Yleensä MP on kaikille avoin sen viikonlopun, kun peli on tarjouksessa.
Tuollahan noita avainkoodeja on vaikka muille jakaa: Buy COD Black Ops Cold War CD Key Compare Prices
Itse ostin tuolta Gamesplanetilta eikä ollut mitään ongelmaa
Modern warfaresta oli siis kyse, ei tuosta uudesta. Sen koodeja tuolla ei näytä olevan juurikaan battle.nettiä edullisemmin. Tai sitten en vain onnistunut löytämään.
48e on halvin ja sekin jossakin ihmeen Enebassa, jonne en ihan ensimmäisenä ole rahaa laittamassa.
En kyllä tässä vaiheessa enää tuollaista summaa kolmatta kertaa tästä maksa, eli ei sitten osteta. :D
Eiköhän se ole pian alessa joko Singles Daynä tai viimeistään Black Fridayn aikana.
aaa....pahoittelen erehdystäni...en vain ajatellut että kukaan enää ostaa tuota MW:tä kun uusikin on juuri tuloillaan :)
Siksi arvelinkin, että sen olisi saanut jo tässä vaiheessa halvemmalla. Tuo uusi taas vaikutti betan perusteella kaiken puolin huonommalta, joten se ei kiinnosta tässä vaiheessa. Tässä voi käydä niin, että MW:n pelaajamäärä romahtaa uuden version myötä, vaikka se uusi olisi millainen kötöstys.
En usko että pelaajamäärät romahtaa, vähenee juu varmasti, mutta väitän että lähes samaan tapaan löytää vielä BOCW julkaisunkin jälkeen pelejä MW puolella. Viimeistään joitain viikkoja julkaisun jälkeen, kun varmaan melko moni lopulta jättää BOCW vähemmälle ja palaa MW puolelle.
Eikä tämä tarkoita etteikö moni tykkäisi enemmän BOCW:stä, mutta ihan selvästi on nähtävissä että MW on hyvin monen mielestä selvästi parempi peli. Kuten myös mun mielestä.
Silti tuun kyllä myös tuota BOCW:tä pelaamaan, ihan jo vaihtelun vuoksi. Tässä ei nyt vuoteen ole tullut pelattua käytännössä yhtään mitään muuta kuin MW:tä....
Oliko jossain uutista, että jatketaanko tähä season passeja kuinka, kun toi cold war julkastaan.
Tästä artikkelista saa kuvan että varsinaista MW sisältöä ei enää tule Battle Passissa, mutta pelaamalla MW:tä etenee Battle Pass jonka sisältö on sitten käytännössä BOCW ja Warzone kamaa.
Tämä kohta tarkemmin:
While Season One Battle Pass content is accessible in Black Ops Cold War and Warzone, players will still be able to progress the Battle Pass by playing Modern Warfare.
Tuosta artikkelista tosin ymmärtäisi että myös MW:ssä rankit jotenkin muuttuisi jotta ovat linjassa BOCW/Warzone kanssa.
For the first time in Call of Duty history, Season One brings universal and synchronized player progression that works between Black Ops Cold War, Modern Warfare, and Warzone! Black Ops Cold War progression builds on a familiar and similar path to Modern Warfare while incorporating an innovative Prestige system, giving you more challenges and earnable content.
At the launch of Season One in December, the path to gaining XP and leveling up will be shared across all three Call of Duty titles: Black Ops Cold War, Modern Warfare and Warzone. This Progression system is both familiar and innovative, allowing you to level up in all three titles no matter which game you play.
Kertokaas mikä homma: päivitin koneen huomattavasti parempaan kuin entinen, ja fps multiplayer lobbyssa 20. Myös kun menen peliin (ground war) niin sama fps. Asetukset vaikka laittaa aivan samalle kun edellinen paska kone niin fps 20. Ennen sentään 60.
Ainakin uusimmat Nvidian ajurit korjasivat RTX 30-sarjan näytönohjaimilla tuon tyyppisen ongelman, jos sulla on siis 30-sarjainen koneessa.
edit. 457.30 ajurit
Jos päivitit 5600x prossuun, niin kannattaa tarkastaa kuinka monta ydintä codi yrittää käyttää.
Tuossa ei pitäisi olla arvona suurempaa kuin prosessorissasi on ytimiä.
martte123
