- Liittynyt
- 21.12.2016
- Viestejä
- 229
Myytävä tuote: Brocade VDX 6740T-1G premuim kytkin
Hinta: 300€
Tuote ostettu (mistä ja milloin): EBAYYY
Kuitti löytyy (takuu voimassa): takkua jäljellä ~10kk
Muuta huomioitavaa: upea
Toimitustapa: Nouto
Maksutapa: Käteinen tai pankki
Kuva:
Hinta: 300€
Toimitustapa: Nouto
Kuva:
Koodi:
sw0# show dpod
rbridge-id: 1
48 10G ports are available in this switch
4 40G ports are available in this switch
10G Port Upgrade license is installed
40G Port Upgrade license is installed
Dynamic POD method is in use
48 10G port assignments are provisioned for use in this switch:
0 10G port assignments are provisioned by the base switch license
48 10G port assignments are provisioned by the 10G Port Upgrade license
48 10G ports are assigned to installed licenses:
0 10G ports are assigned to the base switch license
48 10G ports are assigned to the 10G Port Upgrade license
10G ports assigned to the base switch license:
None
10G ports assigned to the 10G Port Upgrade license:
1/0/1, 1/0/2, 1/0/3, 1/0/4, 1/0/5, 1/0/6, 1/0/7, 1/0/8, 1/0/9, 1/0/10
1/0/11, 1/0/12, 1/0/13, 1/0/14, 1/0/15, 1/0/16, 1/0/17, 1/0/18, 1/0/19, 1/0/20
1/0/21, 1/0/22, 1/0/23, 1/0/24, 1/0/25, 1/0/26, 1/0/27, 1/0/28, 1/0/29, 1/0/30
1/0/31, 1/0/32, 1/0/33, 1/0/34, 1/0/35, 1/0/36, 1/0/37, 1/0/38, 1/0/39, 1/0/40
1/0/41, 1/0/42, 1/0/43, 1/0/44, 1/0/45, 1/0/46, 1/0/47, 1/0/48
10G ports not assigned to a license:
None
0 license reservations are still available for use by unassigned ports
4 40G port assignments are provisioned for use in this switch:
2 40G port assignments are provisioned by the base switch license
2 40G port assignments are provisioned by the 40G Port Upgrade license
4 40G ports are assigned to installed licenses:
2 40G ports are assigned to the base switch license
2 40G ports are assigned to the 40G Port Upgrade license
40G ports assigned to the base switch license:
1/0/49, 1/0/50
40G ports assigned to the 40G Port Upgrade license:
1/0/51, 1/0/52
40G ports not assigned to a license:
None
sw0# show version
Network Operating System Software
Network Operating System Version: 7.4.1b
Copyright (c) 2017-2018 Extreme Networks, Inc.
Firmware name: 7.4.1b
Build Time: 07:20:36 Dec 18, 2020
Install Time: 15:54:17 May 3, 2021
Kernel: 2.6.34.6
BootProm: 1.0.1
Control Processor: e500mc with 4096 MB of memory
Slot Name Primary/Secondary Versions Status
SW/0 NOS 7.4.1b ACTIVE*
6.0.2h
SW/1 NOS 7.4.1b STANDBY
6.0.2h
sw0# show chassis
Chassis Name: VDX6740T-1G
switchType: 151
FAN Unit: 1
Time Awake: 0 days
FAN Unit: 2
Time Awake: 0 days
FAN Unit: 3
Time Awake: 0 days
FAN Unit: 4
Time Awake: 0 days
FAN Unit: 5
Time Awake: 0 days
POWER SUPPLY Unit: 1
Factory Part Num: 23-1000064-02
Factory Serial Num: CUB2V23P001
Time Awake: 0 days
POWER SUPPLY Unit: 2
Factory Serial Num: CUB2V12P0A2
Time Awake: 0 days
CHASSIS/WWN Unit: 1
Power Consume Factor: 0
Factory Part Num: 40-1001216-03
Factory Serial Num: CQG3834P009
Manufacture: Day: 27 Month: 7 Year: 18
Update: Day: 9 Month: 12 Year: 2019
Time Alive: 292 days
Time Awake: 0 days
Airflow direction : Port side INTAKE
sw0#
