Myyty Äänisuoja mikrofonille
Eräilves
Turrien turri
Tukijäsen
Myytävä tuote: Alctron PF8 mikrofonin äänisuoja
Hinta: 20€
Tuote ostettu (mistä ja milloin): Kiinasta olisikohan n. kuukausi sitten
Kuitti löytyy (takuu voimassa): Ei ole kuittia, eikä näille kummallisempia takuita ole kun kiinasta tilaa.. Mutta täysin virheetön, Pahvipakkaus oli ainoastaan kokenut vähän kovia kiinasta tullessaan.
"PF8 uses high quality noise reduction foam machining into cylinder microphone wind screen.
Through noise reduction foam to absorb the noise around recording room, but some of noise will be run away.
PF8 helps your microphone isolating in a quiet environment, under this environment microphone will record your voice exclusively.
PF8 windproof screen not only reduce the reflection of recording sound but also reduce the external wind and noise to disturb recording.
The PF8 is able to capture the complete spectrum of your voice and reduce much of the external environment,all the while giving you clear and concise vocals free of any coloration.
Function:
Optimize Your Voice
Capture your pure voice, reduce external noise, and interfere with recording sound.
Reduce Late Sound Trimming
Reduce excess balance and post production requirements.
Integrated Blowout Preventer
Removable BOP cover,In the recording process, which can prevent the plosive,can prevent erosion on the microphone sound head from slobber splashing.
Reduce Environmental Noise And Sound Reflection
Isolate your microphone in a quiet recording environment while reducing the sound reflection.
Specifications:
Color: Black
Material: Noise Reducing Sponge
Inserting Hole Diameter: 47mm
Compatible Mic Diameter: 48-58mm
Item Size: Approx.17 * 20 * 18cm / 6.7 * 7.9 * 7.1in
Item Weight: 130g / 4.6oz
Package Size: 21 * 19 * 17.5cm / 8.3 * 7.5 * 6.9in
Package Weight: 305g / 10.8oz"
Myyn sen takia, koska itselläni liian pieni mikki ja sen takia ei ole siinä kunnolla kiinni.
Sijainti: Inari
Toimitustapa: Nouto / postitus
Maksutapa: Ennakkoon tilille taikka postiennakko.
Kuva:
Uppia, eikö ole kellään tarvetta äänieriste suojalle? Voi myös tarjotakin.
Eemeli77
