Myyty 1TB SATA HDD jne.. (JNS)
Tuote:
- 1TB M.2 NVME PCIE 4.0, SK Hynix HFS001TEJ9X125N
- 1TB Western Digital 2.5" HDD
- 1TB Seagate Mobile 2.5" HDD
Hinta:
- SK Hynix 1TB SSD - 85€
- WD 1TB HDD - 20€
- Seagate 1TB HDD -20€
Tuote ostettu (mistä ja milloin): Tullut kannettavan mukana
Kuitti löytyy (takuu voimassa): Ei, Ei.
Smart statistiikka levyistä alla eli ovat täysin kunnossa.
=== START OF INFORMATION SECTION ===
Model Number: HFS001TEJ9X125N
Serial Number: AYCCN02101020CH1O
Firmware Version: 51022A20
PCI Vendor/Subsystem ID: 0x1c5c
IEEE OUI Identifier: 0xace42e
Controller ID: 0
NVMe Version: 1.4
Number of Namespaces: 1
Namespace 1 Size/Capacity: 1 024 209 543 168 [1,02 TB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: ace42e 003b185753
Local Time is: Wed Jan 21 15:53:12 2026 EET
Firmware Updates (0x16): 3 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x00df): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp Verify
Log Page Attributes (0x1e): Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Pers_Ev_Lg
Maximum Data Transfer Size: 64 Pages
Warning Comp. Temp. Threshold: 86 Celsius
Critical Comp. Temp. Threshold: 87 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 7.50W - - 0 0 0 0 5 305
1 + 3.9000W - - 1 1 1 1 30 330
2 + 1.5000W - - 2 2 2 2 100 400
3 - 0.0500W - - 3 3 3 3 500 1500
4 - 0.0050W - - 4 4 4 4 1000 9000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02, NSID 0xffffffff)
Critical Warning: 0x00
Temperature: 48 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 1%
Data Units Read: 75 661 741 [38,7 TB]
Data Units Written: 37 134 215 [19,0 TB]
Host Read Commands: 647 495 960
Host Write Commands: 426 179 276
Controller Busy Time: 39 908
Power Cycles: 745
Power On Hours: 4 037
Unsafe Shutdowns: 164
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 42 Celsius
Temperature Sensor 2: 42 Celsius
Thermal Temp. 1 Transition Count: 800
Thermal Temp. 2 Transition Count: 6
Thermal Temp. 1 Total Time: 2770354
Thermal Temp. 2 Total Time: 577
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
Self-test Log (NVMe Log 0x06, NSID 0xffffffff)
Self-test status: No self-test in progress
Num Test_Description Status Power_on_Hours Failing_LBA NSID Seg SCT Code
0 Short Completed without error 3108 - - - - -
=== START OF READ SMART DATA SECTION ===
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (16560) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 190) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 194 184 021 Pre-fail Always - 1300
4 Start_Stop_Count 0x0032 034 034 000 Old_age Always - 66431
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
9 Power_On_Hours 0x0032 076 076 000 Old_age Always - 17824
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1131
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 232
193 Load_Cycle_Count 0x0032 171 171 000 Old_age Always - 87707
194 Temperature_Celsius 0x0022 123 094 000 Old_age Always - 24
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 5
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0032 095 095 000 Old_age Always - 4175
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
power-saving mode.
recommended polling time: ( 1) minutes.
recommended polling time: ( 165) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SMART Attributes Data Structure revision number: 10
1 Raw_Read_Error_Rate 0x000f 100 064 034 Pre-fail Always - 650348
3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 087 087 020 Old_age Always - 13468
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 064 060 045 Pre-fail Always - 2802922
9 Power_On_Hours 0x0032 083 083 000 Old_age Always - 15385 (248 205 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 096 096 020 Old_age Always - 4746
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 074 053 040 Old_age Always - 26 (Min/Max 24/26)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 10
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 060 060 000 Old_age Always - 80740
194 Temperature_Celsius 0x0022 026 047 000 Old_age Always - 26
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x000f 093 093 030 Pre-fail Always - 6563 (200 154 0)
254 Free_Fall_Sensor 0x0032 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Paikkakunta (ilmoita myös otsikossa ja tagissa): Joensuu
Toimitustapa: Nouto/Posti
Maksutapa: Käteinen, MobilePay, Siirto, Tilisiirto
Tarjotaan 75 posteineen.
Teska
