- Estetty
- #1
- Liittynyt
- 03.03.2019
- Viestejä
- 175
Myytävä tuote: Asus ROG Poseidon 1080TI
Hinta: 380
Tuote ostettu (mistä ja milloin): Tietokonekauppa 2017
Kuitti löytyy (takuu voimassa): receipt
In good condition, works as it should.
With the card I can send a 240mm Ek-phoenix 240mm radiator it has a built in pump so it's a little bigger than usual 240mm radiators and fittings+2x vardar fans. The radiator has some scars but does not leak
All in the pics + a GPU holder (since it's a heavy card sagging is common) for 380€
Sijainti: Turku
Toimitustapa: would like pick up, but shipping can be sorted aswell.
Maksutapa: mobilepay or banktransfer.
Hinta: 380
Sijainti: Turku
