Myydään vga-hdmi -muunnin (Lahti)
Myytävä tuote: vga-hdmi -muunnin
Hinta: 35
Kuitti löytyy (takuu voimassa):
Paikkakunta (ilmoita myös otsikossa): Lahti
Toimitustapa: nouto, posti
Maksutapa: käteinen, tili
vga-hdmi -muunnin vga-lähdön muuntamiseen ja skaalaamiseen hdmi-liittimellä varustettuun näyttöön tai televisioon. Tukee laajasti eri resoluutiota lähdölle.
Features
1. No need to install drivers, portable, flexible, plug and play.
2. Provide advanced signal processing with great precision, colors, resolutions, and details.
3. Support multi-VESA Standard VGA formats input.
4. Support HDMI 4Kx2K@60Hz, 4Kx2K@30Hz,1080p@60Hz or 720p@60Hz output.
Package
1. VGA to HDMI 4Kx2K Scaler Converter
2. 5V1A DC Power Supply Adaptor
3. Operation Manual
Specification
Input ports: 1xVGA, 1xEarphone, 1 x Min- USB
Output ports: 1xHDMI
Dimensions(mm): 93(D)x84(W)x28(H)
Wight (g): 160g
VGA input resolution:
640 x 480P@60Hz, 800 x 600@60Hz, 1024 x 768P@60Hz, 1280 x 720P@60Hz,
1280 x 768P@60Hz, 1280 x 1024P@60Hz, 1360 x 768P@60Hz 1920x 1080P@60Hz.
HDMI output resolution:
4Kx2K@60Hz,4Kx2K@30Hz,1080P@60Hz,720P@60Hz
Operation Controls and Functions
1. AUDIO input: These slot is where you connect to the audio PC or other audio signal source with 3.5mm earphone cable
2. VGA input: These slot is where you connect the VGA source output from PC or Laptop.
3. DC 5V IN: Connect the 5V DC power supply into the Converter.
4. HDMI OUT: The HDMI OUT connect to HDMI equipped TVs or monitors.
5. UPDATE: System software update.
6. Power LED: This red LED illuminate when the device is connected with power supply.
7. Resolution Button: Press this button to select the output resolution.
8. ZOOM Button: Press this button the scaling of the output picture.
9. AUTO Button: Press this button to automatically adjust the output picture.
Connection and Installation
1. Connect a source such as a PC to the Converter VGA input.
2. Connect the audio signal via the 3.5mm earphone cable.
3. Connect a display such as a monitor, TV or Projector to the HDMI output on the Converter.
4. Power on the device and display.
247 426
Muropakolainen
