living_death
★ Still alive ™
- Liittynyt
- 15.11.2016
- Viestejä
- 7 900
Ostan serrikoneen M4A79XTD EVO lankkuun yhteensopivaa DD3 muistia.
Hakusessa olisi 2 x 8GB muistikammat, joko 1800- tai 1600MHz, mutta ei sen alle.
M4A79XTD EVO
M4A79XTD EVO
Dual-Channel DDR3 1800(O.C.) Support
The motherboard supports DDR3 memory that features data transfer rates of 1800(O.C.)/1600/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 25.6GB/s. Furthermore, the supply voltage for the memory is reduced from 1.8 V for DDR2 to just 1.5 V for DDR3. This voltage reduction limits the power consumption and heat generation of DDR3 which makes it an ideal memory solution.
