- Liittynyt
- 01.01.2017
- Viestejä
- 447
HPE Proliant ML330 G6 kyseessä.
Nyt paljastui, että toinen vekottimen niceistä ei oikein nouse, eikä ole koskaan näiden 6 vuoden aikana noussut gigaiseksi.
$ grep Mbps /var/log/messages*
/var/log/messages:Jun 8 22:54:40 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages:Jun 9 00:19:04 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages:Jun 9 00:19:19 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages:Jun 9 00:24:46 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages:Jun 9 00:30:09 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages:Jun 9 00:31:57 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages-20170521:May 17 15:20:17 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170521:May 17 15:20:54 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170521:May 17 15:22:16 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170521:May 17 15:25:48 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170521:May 17 15:26:25 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170521:May 17 15:27:55 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170528:May 25 16:25:46 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170528:May 25 16:25:56 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages-20170528:May 25 16:36:38 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170528:May 25 16:36:48 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
/var/log/messages-20170528:May 26 11:28:17 sunderland kernel: tg3 0000:03:04.1 enp3s4f1: Link is up at 1000 Mbps, full duplex
/var/log/messages-20170528:May 26 11:28:26 sunderland kernel: tg3 0000:03:04.0 enp3s4f0: Link is up at 100 Mbps, full duplex
Mulla oli ensin LAN tossa enp3s4f1-portissa ja enp3s4f0 oli käyttämättä, mutta jatkossa olisi tarkoitus laittaa toiseen niistä WAN ja käyttää tätä konetta routerina. Nythän on niin että ILO on tuossa 0-portissa eli mielellään siitä tekisin ja nyt teinkin LAN-portin. Ja huomasin tämän ettei se portti toimi![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Mikä tohon voisi olla syynä? Manuaalista en löytänyt yhtään mitään NICcehin liittyvää, enkä myöskään ILO:n kautta.
Portit on kiinni samassa HP:n hallittavassa kytkimessä, ja kaapelitkin vaihdoin tuossa samalla kun vaihdoin portit. Eli LAN on nyt samalla kaapelilla samassa kytkimen portissa kun ennenkin, mutta nyt se toimii vain satasella, ainoa mikä muuttui oli koneen NIC.
