NVIDIAlta firmware-päivitys GeForce RTX 5060:n ja RTX 5060 Ti:n mustaan ruutuun käynnistymiseen
Kaotik
Banhammer
Ylläpidon jäsen
NVIDIA on todennut GeForce RTX 5060- ja RTX 5060 Ti -näytönohjaimia koskevan ongelman, joka johtaa joidenkin vanhempien emolevyjen kanssa käynnistymiseen tyhjään ruutuun.
Käyttäjän pitää ladata NVIDIA GPU UEFI Firmware Update Tool v2.0, jolla BIOS päivitetään. Sovellus tunnistaa näytönohjaimen ja tarkistaa, tarvitseeko se firmware-päivitystä sekä lataa automaattisesti oikean päivityksen asennettavaksi.
Voit lukea tarkemmat NVIDIAn antamat ohjeet alta:
To ensure compatibility with certain motherboard SBIOSes, an update to the NVIDIA GPU firmware may be required. Without the update, GeForce RTX 5060 series cards in certain legacy motherboards could experience blank screens on reboot. This update should only be applied if blank screens are occurring on reboot.
Click here to download the NVIDIA GPU UEFI Firmware Update Tool v2.0.
The NVIDIA GPU Firmware Update Tool will detect whether the firmware update is needed, and if needed, will give the user the option to update it.
If you are currently experiencing a blank screen during reboot, please try one of the following workarounds in order to run the tool:
  • Completely power down your system before booting
  • Ensure you are using the latest SBIOS from your motherboard vendor
  • Ensure you are in UEFI boot mode and not Legacy/CSM
  • Boot using an alternate graphics source (secondary card or integrated graphics)
  • After powering on your system, wait for your operating system to load with the graphics driver installed
Once you have the tool downloaded, please run the tool and follow the on-screen instructions. Ensure all apps are closed before running the tool and make sure no OS updates are pending in the background.
If you are experiencing issues in Legacy/CSM boot mode, and your motherboard does not support UEFI boot mode, please contact customer service of your graphics card manufacturer for a legacy VBIOS update.
Applicable Products
GeForce RTX 5060 Ti, GeForce RTX 5060
Lähde: NVIDIA Support
Eipä ole "tavat jolla näytönohjaimen julkaisun voi tyriä" -bingokortissa enää kovin montaa tyhjää ruutua tämän sukupolven osalta, saavutus itsessään Nvidialta. Never stop the madness ja kohta vedetään taas.
Toivottavasti nyt saavat noi ajuripuolen ongelmat selätetty myös vaikka tuo viimeinen ajuri näytti nyt aika toimivalta eikä keskuteluita ole käyty enää samalla tavalla.
Onkohan isoin osa "Brainpoweria" siirretty ajat sitten AI-puolelle, vai mistähän notkahdus kertoilee...
huijarihuijari
