Nothing aloitti Nothing OS 3.0 -päivitykset Nothing Phone (1):lle ja CMF Phone 1:lle (Android 15)
Kaotik
Banhammer
Ylläpidon jäsen
Nothing on aloittanut Android 15 -pohjaisen Nothing OS 3.0 -käyttöjärjestelmän vakaan version jakelun Nothing Phone (1) ja CMF Phone 1 -puhelimille.
Nothing Phone 2(a) Plus on saanut päivityksensä jo aiemmin tänä vuonna.
Shared Widgets
  • Use widgets to link up with friends and family. See another person’s widgets displayed on your home screen and interact with each other through reactions. A new way to stay connected.
Lock screen
  • Introduced new lock screen customisation page. Access by long-pressing the lock screen or via the Customisation page.
  • Choose from a range of new Clock face styles.
  • Expanded widget space, allowing you to place more widgets on your lock screen.
New app drawer style
  • Added AI-powered Smart Drawer to automatically categorise your apps into folders, keeping your app drawer organised and making apps easy to find.
  • Now you can pin your favourite apps to the top of the app drawer for quick access to your favourite apps.
Enhanced pop-up view
  • Drag the pop-up view to any position on the screen, for convenient multitasking.
  • Easily resize the pop-up view by dragging the bottom corners.
  • Pin the pop-up view on the screen edge, for speedy access.
  • Swipe down incoming notifications to enter the pop-up view. Allows you to quickly view information without leaving your current app. Enable via Settings > Special features > Pop-up view.
Elevated design
  • Redesigned Quick Settings, and an optimised editing experience. Allows you to effortlessly tailor your shortcuts to your preferences.
  • Redesigned widget library. Choose your favourite Nothing Widgets or swipe left to browse third-party widgets.
  • Enhanced Settings with updated UI visuals. Network & Internet and Bluetooth options now display current connection.
  • New Dot animation for fingerprint unlocking and charging.
Other improvements
  • Allow AI to learn your usage habits and prioritise your frequently used apps. Keeps them active for longer intelligently for a smoother and more efficient experience.
  • Added support for auto-archive function. Automatically frees up storage space without removing apps or data from your device.
  • New partial screen sharing, so you can record just an app window rather than the entire screen.
  • Updated setup wizard to version 3.0 for a smoother introduction.
  • Enabled predictive back animations for apps that have opted in.
  • Improved the lock screen charging status display to help you easily know the charging speed at a glance (only for CMF Phone 1).
Lähde: Two more Nothing smartphones receive Android 15-based Nothing OS 3.0 stable update
lennik
