Myyty Näyttö/monitoriteline ErGear 13-35"/12 kg - HKI
Myytävä tuote: Näyttöteline ErGear 13-35"/12 kg - HKI
Hinta: 45€
Tuote ostettu (mistä ja milloin): Amazon.de, 6/21
Kuitti löytyy (takuu voimassa): Kyllä, takuu Amazonin käytännön mukaan.
Järeämmän kaliiperin monitori/näyttöteline (tuotelinkki) ohjeineen alkuperäisessä laatikossaan. Uudenveroisessa kunnossa. Toimi loistavasti ainakin LG:n 32" näytön kanssa, mutta jäi tarpeettomaksi kotikonttorin uudelleenjärjestelyn takia.
"Very suitable for ultra-wide monitors: the ErGear professional monitor arm is made of high-quality aviation die-cast aluminium, which has been specially developed for the perfect hold of 13 - 35 inch ultra-wide monitors, curved LED monitors, gaming monitors, etc., and can hold up to 12 kg
Flexible adjustment: the monitor arm allows free monitor adjustment and smooth movement in any direction, including adjusting the height by moving it up and down (max. 61.5 cm; extendable max. 51 cm, moves forward and back, tilt of the monitor +85° / -30°, swivel 180°, rotation 360° for ideal ergonomic alignment, easy to reach a comfortable viewing angle and healthy posture
Smooth full range movement: Lift, lower, pull, slide and adjust your monitor effortlessly with the help of the gas spring for the perfect working position and the most comfortable viewing angle, so it fits perfectly into any home or office
Required accessories: We provide our customers with all tools and accessories needed for installation, no additional purchase, the parts have been packaged separately and are clearly numbered in the instructions (English language not guaranteed), removable VESA plate, very easy to set up, even if you have never installed a monitor holder
Cable management: Single monitor holder with built-in cable control that helps hide cables to organise everything. The arm frees up desk space while at the same time creating a more comfortable working environment. More desk space, better efficiency."
Sijainti: Helsinki, Itäkeskus/Marjaniemi
Toimitustapa: Nouto, Posti, Matkahuolto
Maksutapa: Käteinen, tilisiirto (lähetys heti kun maksu näkyy tilillä)
Jos vielä kaupan, niin maksan pyyntihinnan (noudolla). Hieman oli hämminkiä sopiiko tuo mun näytön kanssa yhteen ja tuli jo tarjous kertaalleen peruttua, mutta viimeisimmän tiedon perustella pitäisi olla yhteensopiva...
Jos mun tarjous oli voittaja, niin laitatko mulle viestiä osoitteeseen tuumas at saunalahti.fi ku mulla tuo uuden käyttäjän 14 päivän karenssi päällä ni en voi yv:jä vielä lähettää
zaltah
