- Liittynyt
- 14.10.2016
- Viestejä
- 21 839
MSI on ilmoittanut vahvistaneensa käyttäjien raportoimat ongelmat MAG CoreLiquid 240R- ja 360R -AIO-nestekiertojen suorituskyvyssä.
Suljetut nestekierrot ovat menettäneet nopeasti suorituskykyään coolerin kylmälevyyn kertyvän moskan vuoksi. Ongelma ei koske ilmeisesti kaikkia eriä, sillä MSI julkaisi verkkosivuillaan työkalun, jolla voi tarkistaa kuuluuko oma yksilö ongelmaeriin. Yhtiö on jo julkaissut V2-version samoista coolereista, joissa ongelma on korjattu. Ongelmista kärsivien coolerit vaihdetaan V2-versioon ilmaiseksi.
Lähde: MSI MAG CORELIQUID 240R / 360R Product AnnouncementDear MSI users,
Recently, we have received feedback from some of our users that they have experienced a drop in heat dissipation efficiency when using the MAG CORELIQUID 240R / MAG CORELIQUID 360R liquid coolers.
Our preliminary investigation has identified that a small portion of the liquid coolers produce sediment that can cause a blockage. This, however, will not cause any damage to your system since the processors are equipped with a protection mechanism against overheating.
MSI cares deeply about our users’ overall experience and we simplified our processes to provide faster product replacement services.
Users can identify whether they have an affected products by looking up the product serial number here. We will provide a comprehensive product replacement (MAG CORELIQUID 240R V2 / 360R V2) service to all affected products that have abnormal heat dissipation ( Example: CPU temperature is higher than 60°C while idle and the cooler is properly seated with thermal paste applied between the CPU and cooler ).
Moving forward, we will continue to work with our suppliers to thoroughly inspect all MAG CORELIQUID 240R / 360R liquid coolers that may potentially be affected. If you have any questions, please feel free to contact your local MSI Customer Service Center.
Please make sure your liquid cooler is MAG CORELIQUID 240R or MAG CORELIQUID 360R, and submit the product serial number to verify whether your product qualifies to apply. Next select your purchase region once the product serial number has been successfully submitted, we will provide you with a suitable swap suggestion. Please feel free to submit a web ticket via MSI Support if you have any questions.
