mobiilidata ja lan
PyleP
NOSTO
sen verran harvinainen kysymys että piti ihan goooglettaa;
Windows operating system has a metric value that is assign to an IP route to indicate the cost associated with using that route. When you have multiple active Internet connections on your computer, Windows automatically computes the cost of using them and assign a metric value to each of them. Then Windows set the most cost effective connection as default and keeps other active connections for backup (fail safe) purpose.
You can manually assign this metric value. If you set this value the same for all active connections you can force Windows to use all the connections.
  • Open Control Panel
  • Go to Network and Sharing Center > Change Adapter Settings
  • Double click on your active Internet connection
  • Select Internet Protocol TCP/IP Version 4
  • Click on Properties button.
  • A new box will open. Click on Advance button
  • Another box will come up. Uncheck Automatic Metric
  • Type value 15 in the box labelled Interface metric.
  • Repeat the above steps for all the active connections your have
  • Disconnect all your connections
  • Restart your computer and reconnect all the Internet connections
That’s it! You will have the combined the power of all your Internet connections!
tällä pitäisi toimia :smoke:
tollanen ruutu pitäisi kaivaa esiin ja sitten syöttää sama arvo KAIKKIEN yhteyksien arvoksi
sitten kun mikään ei toimi niin network reset pitäisi auttaa, en kylläkään ota vastuuta mistään:kahvi:
248 334
Kimix
