Myyty MB Pro 13 2016 Retina (i5 2.9/16GB/512GB/Iris 550/Touchbar) HKI (See details)
Myytävä tuote: Macbook Pro 13 2016 Retina (i5 2.9/16GB/512GB/Iris 550/Touchbar)
Hinta: 250
Paikkakunta (ilmoita myös otsikossa): Hki
Toimitustapa: Nouto, Post
Maksutapa: Cash, Mobilepay
The device is in excellent condition. Everything works and no usage marks on the display or body. The battery cycle count is only 199
The issue is, sometimes the display flickers. The display does not go black or flips or anything like that. Just some elements or the backlight of the display act a bit weird. It does not have any effect on the usage of the computer. This issue is not present if the device is in Safe Mode. So I guess some driver issue or such. But as mentioned, the device works perfectly and the above-mentioned issue does not happen always. There is also a damaged screw and a slightly damaged bottom plate (See picture)
I will be providing the original 60W charger, a USB C hub, an Apple Magic Mouse 2, one HDMI cable, and one lightning cable with this package. The idea is if you want, you can then also use the device with an external screen.
Ask me for more details or pictures.
You can see some pictures here 7 new items by S M Mahbub Al Nahiyan
247 616
tija
