Myyty Macally USB-C to USB-A with Ethernet -adapteri - Ylivieska
Myytävä tuote:Macally USB-C to USB-A with Ethernet -adapteri
Hinta:15
Tuote ostettu (mistä ja milloin):Verkkokauppa outlet vajaa viikko sitten
Kuitti löytyy (takuu voimassa):9kk takuuta ja kuitti mukaan
USB-C to USB-A Hub with Ethernet Adapter
The Macally UCHUB3GB is a 2-in-1 device that adds 3 USB A ports and one Gigabit Ethernet port to your MacBook, MacBook Pro or Chromebook Pixel. The Macally UCHUB3GB is an USB-C to 3 port USB-A hub that allows you to continue to use your existing USB devices, like your keyboard, mouse, HDD, flash drive, printer, scanner, iPhone, with your new MacBook, MacBook Pro or Chromebook Pixel with USB-C/Thunderbolt 3 port. The UCHUB3GB also allows you to connect your computer to a wired Gigabit Ethernet network with stable and fast connection speeds at 10/100/1000Mbps. The Macally UCHUB3GB is compact in size and has a built-in cable for maximum portability.
Features
  • 3 USB A ports to connect your existing USB devices, like your keyboard, mouse, HDD, Flashdrive, iPhone, to your Apple MacBook, MacBook Pro or Google Chromebook Pixel
  • Supports USB 3.1/3.0 (5Gbps), USB 2.0 (480 Mbps) and USB 1.0 (12 Mbps)
  • 1 Gigabit Ethernet port to connect your USB-C computer to a Gigabit Ethernet network
  • Ethernet connection speeds at 10/100/1000Mbps
  • USB bus-powered (No AC adapter needed)
  • Compact design and built-in cable for maximum portability
  • Plug and Play (No driver or software required)
  • Includes UCHUB3GB and user guide
Paikkakunta (ilmoita myös otsikossa):Ylivieska
Toimitustapa:Nouto, posti
Maksutapa:Mobilepay, käteinen
Kuva:
    2,4 MB · Luettu: 11
JooJooJoo
