Vaihdettu Lian Li PC-O11 Air RGB kotelo-> ITX Koppa / Muuta
Vaihdetaan seuraavaa tavaraa :
- Lian-Li PC-O11 Air RGB kotelo sis. 5x120mm tuulettimet joista 3 on RGB.
Vaihdossa otetaan vastaan :
- NCase M1
- Streacom DA2
- Raijintek Ophion Evo
Muutakin saa tarjota esim. iPhonea jne..
Sijainti Kuopio.
Nouto tai Posti käy.
Mulla olis itx-mylly. titan x (pascal), 16 gb 3000mhz ram, r5 2600, b450i, nxt h200, yms.
Jonimoisio
BANNATTU
BANNED
Have an iPhone 8 64gb. For pump/res and gpu with block?
If it was iPhone XS maybe, not for iPhone 8 you would need to pay hell of a €€€ to get that trade.
Also watercooling loop + graphics card with backplate and block is reserved right now for someone else.
Jonimoisio
BANNATTU
BANNED
[QUOTE = "JATech, post: 5067998, member: 26390"] If it was iPhone XS maybe, not for the iPhone 8 you would need to pay for it.
Also watercooling loop + graphics card with backplate and block is reserved right now for someone else. [/ QUOTE]
Okey, was worth a shot ^^
Thank you anyways.
huov1
༼ʘ̚ل͜ʘ̚༽
Raijintek Ophion Evo löytyisi Lahdesta, jos on vielä ajankohtainen
247 618
tija
