Myyty Kovoja [HML]
  • Keskustelun aloittaja Keskustelun aloittaja iisac
Tuote: 2 x 12TB WD, 1 x 8TB Seagate, 4 x 3TB WD
Hinta: 12TB 120€/kpl, 8TB 80€,6TB 65€, 3TB 35€/kpl
Tuote ostettu (mistä ja milloin): Täältä, Amazon.de
Kuitti löytyy (takuu voimassa): toisessa 12TB saattaa olla, muissa ei taida olla
Isommat kaupat etusijalla.
Ollut NAS-käytössä koko elämänsä.
Lisäilen tähän vielä muidenkin levyjen SMART-tiedot.
Koodi:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.108-1-pve] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Blue
Device Model:     WDC WD60EZRZ-00GZ5B1
Serial Number:    WD-WX41D883T44U
LU WWN Device Id: 5 0014ee 2bb203fbd
Firmware Version: 80.00A80
User Capacity:    6,001,175,126,016 bytes [6.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5700 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Nov 28 20:03:09 2023 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                ( 2984) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 684) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   227   197   021    Pre-fail  Always       -       7616
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1265
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   088   088   000    Old_age   Always       -       9093
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       591
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       60
193 Load_Cycle_Count        0x0032   183   183   000    Old_age   Always       -       51022
194 Temperature_Celsius     0x0022   125   100   000    Old_age   Always       -       27
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%      8963         -
# 2  Extended offline    Completed without error       00%      3538         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Koodi:
Model Family:     Seagate BarraCuda 3.5
Device Model:     ST8000DM004-2CX188
Serial Number:    WCT0PVLV
LU WWN Device Id: 5 000c50 0b9ea36c2
Firmware Version: 0001
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5425 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
Local Time is:    Tue Nov 28 18:07:08 2023 EET
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (  41) The self-test routine was interrupted
                                        by the host with a hard or soft reset.
data collection:                (    0) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        ( 978) minutes.
SCT capabilities:              (0x30a5) SCT Status supported.
SMART Attributes Data Structure revision number: 10
  1 Raw_Read_Error_Rate     0x000f   100   064   006    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0003   092   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       106
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   083   060   045    Pre-fail  Always       -       219719779
  9 Power_On_Hours          0x0032   054   054   000    Old_age   Always       -       41126 (223 161 0)
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       106
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   055   040    Old_age   Always       -       38 (Min/Max 33/38)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       163
193 Load_Cycle_Count        0x0032   085   085   000    Old_age   Always       -       30481
194 Temperature_Celsius     0x0022   038   045   000    Old_age   Always       -       38 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   100   064   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       33229h+47m+40.212s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       155148940523
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       344929137170
No Errors Logged
# 1  Extended offline    Interrupted (host reset)      00%     41076         -
# 2  Short offline       Completed without error       00%     40962         -
# 3  Short offline       Completed without error       00%     40794         -
# 4  Extended offline    Completed without error       00%     35357         -
# 5  Extended offline    Completed without error       00%     31636         -
# 6  Extended offline    Completed without error       00%     22547         -
# 7  Extended offline    Completed without error       00%     18060         -
# 8  Extended offline    Completed without error       00%     13316         -
# 9  Extended offline    Completed without error       00%     10358         -
#10  Extended offline    Completed without error       00%      8699         -
#11  Extended offline    Completed without error       00%      5647         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Koodi:
Model Family:     Western Digital Ultrastar He10/12
Device Model:     WDC WD120EMAZ-11BLFA0
Serial Number:    8CKA9VEE
LU WWN Device Id: 5 000cca 26feef735
Firmware Version: 81.00A81
User Capacity:    12,000,138,625,024 bytes [12.0 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Nov 26 03:07:19 2023 EET
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (   87) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        No Conveyance Self-test supported.
                                        power-saving mode.
recommended polling time:        (1316) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   127   127   054    Old_age   Offline      -       112
  3 Spin_Up_Time            0x0007   159   159   024    Pre-fail  Always       -       403 (Average 423)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       3280
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   140   140   020    Old_age   Offline      -       15
  9 Power_On_Hours          0x0012   097   097   000    Old_age   Always       -       26625
10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       53
22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   096   096   000    Old_age   Always       -       4990
193 Load_Cycle_Count        0x0012   096   096   000    Old_age   Always       -       4990
194 Temperature_Celsius     0x0002   224   224   000    Old_age   Always       -       29 (Min/Max 6/57)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
No Errors Logged
# 1  Short offline       Completed without error       00%     26463         -
# 2  Extended offline    Completed without error       00%     26463         -
# 3  Short offline       Completed without error       00%     26295         -
# 4  Short offline       Completed without error       00%     26127         -
# 5  Short offline       Completed without error       00%     25959         -
# 6  Extended offline    Completed without error       00%     22241         -
# 7  Short offline       Completed without error       00%     19686         -
# 8  Short offline       Completed without error       00%     19662         -
# 9  Short offline       Completed without error       00%     19638         -
#10  Short offline       Completed without error       00%     19614         -
#11  Short offline       Completed without error       00%     19590         -
#12  Short offline       Completed without error       00%     19566         -
#13  Short offline       Completed without error       00%     19542         -
#14  Short offline       Completed without error       00%     19518         -
#15  Short offline       Completed without error       00%     19494         -
#16  Short offline       Completed without error       00%     19470         -
#17  Short offline       Completed without error       00%     19446         -
#18  Short offline       Completed without error       00%     19422         -
#19  Short offline       Completed without error       00%     19398         -
#20  Short offline       Completed without error       00%     19374         -
#21  Short offline       Completed without error       00%     19350         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Koodi:
smartctl 7.3 2022-02-28 r5338 [x86_64-w64-mingw32-w10-21H2] (sf-7.3-1)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     WDC WD120EDAZ-11F3RA0
Serial Number:    5PJ3VZ1F
LU WWN Device Id: 5 000cca 291ddf15c
User Capacity:    12 000 138 625 024 bytes [12,0 TB]
Device is:        Not in smartctl database 7.3/5319
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Nov 28 17:47:15 2023 FLEST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1246) minutes.
  2 Throughput_Performance  0x0004   128   128   054    Old_age   Offline      -       108
  3 Spin_Up_Time            0x0007   175   175   024    Pre-fail  Always       -       382 (Average 369)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       66
  9 Power_On_Hours          0x0012   097   097   000    Old_age   Always       -       23136
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       66
22 Unknown_Attribute       0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1015
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       1015
194 Temperature_Celsius     0x0002   232   232   000    Old_age   Always       -       28 (Min/Max 13/45)
No Errors Logged
# 1  Short offline       Completed without error       00%     23115         -
# 2  Extended offline    Completed without error       00%     23087         -
# 3  Extended offline    Completed without error       00%     22660         -
# 4  Short offline       Completed without error       00%     22491         -
# 5  Short offline       Completed without error       00%     22323         -
# 6  Short offline       Completed without error       00%     22155         -
# 7  Extended offline    Completed without error       00%     16752         -
# 8  Extended offline    Completed without error       00%     13001         -
# 9  Extended offline    Completed without error       00%      3911         -
#10  Extended offline    Interrupted (host reset)      30%       390         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Koodi:
Model Family:     Western Digital Purple
Device Model:     WDC WD30PURX-64P6ZY0
Serial Number:    WD-WCC4N6DN7031
LU WWN Device Id: 5 0014ee 2b78b400a
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Nov 28 18:14:24 2023 EET
                                        been run.
data collection:                (38580) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 387) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       10
  3 Spin_Up_Time            0x0027   195   185   021    Pre-fail  Always       -       5225
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       242
  9 Power_On_Hours          0x0032   019   019   000    Old_age   Always       -       59479
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       242
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       214
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1607
194 Temperature_Celsius     0x0022   112   110   000    Old_age   Always       -       38
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
No Errors Logged
# 1  Short offline       Completed without error       00%     59387         -
# 2  Extended offline    Completed without error       00%     53962         -
# 3  Extended offline    Completed without error       00%     50229         -
# 4  Extended offline    Completed without error       00%     41170         -
# 5  Extended offline    Completed without error       00%     36669         -
# 6  Extended offline    Completed without error       00%     29699         -
# 7  Short offline       Completed without error       00%     29672         -
# 8  Extended offline    Completed without error       00%     28935         -
# 9  Short offline       Completed without error       00%     28922         -
#10  Extended offline    Completed without error       00%     27319         -
#11  Extended offline    Completed without error       00%     24270         -
#12  Extended offline    Completed without error       00%     17044         -
#13  Extended offline    Completed without error       00%     12990         -
#14  Short offline       Completed without error       00%      6149         -
#15  Short offline       Completed without error       00%      6126         -
#16  Short offline       Completed without error       00%      6125         -
#17  Short offline       Completed without error       00%      6077         -
#18  Short offline       Completed without error       00%      6053         -
#19  Short offline       Completed without error       00%      6030         -
#20  Short offline       Completed without error       00%      6005         -
#21  Short offline       Completed without error       00%      5981         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Koodi:
Serial Number:    WD-WCC4N1AKPPRY
LU WWN Device Id: 5 0014ee 20cdf11e7
Local Time is:    Wed Nov 29 19:25:34 2023 EET
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (37140) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 373) minutes.
  3 Spin_Up_Time            0x0027   191   182   021    Pre-fail  Always       -       5441
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       237
  9 Power_On_Hours          0x0032   019   019   000    Old_age   Always       -       59496
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       237
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       209
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1635
194 Temperature_Celsius     0x0022   117   110   000    Old_age   Always       -       33
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
No Errors Logged
# 2  Extended offline    Completed without error       00%     53973         -
# 3  Extended offline    Completed without error       00%     50247         -
# 6  Extended offline    Completed without error       00%     28960         -
# 7  Extended offline    Completed without error       00%     27319         -
# 8  Extended offline    Completed without error       00%     24270         -
# 9  Extended offline    Completed without error       00%     17048         -
#10  Extended offline    Completed without error       00%     13021         -
#11  Short offline       Completed without error       00%      6742         -
#12  Short offline       Completed without error       00%      6720         -
#13  Short offline       Completed without error       00%      6696         -
#14  Short offline       Completed without error       00%      6672         -
#15  Short offline       Completed without error       00%      6648         -
#16  Short offline       Completed without error       00%      6624         -
#17  Short offline       Completed without error       00%      6600         -
#18  Short offline       Completed without error       00%      6576         -
#19  Short offline       Completed without error       00%      6553         -
#20  Short offline       Completed without error       00%      6529         -
#21  Short offline       Completed without error       00%      6504         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Paikkakunta (ilmoita myös otsikossa ja tagissa): Hämeenlinna, kulkeutuu myös arkena Martinlaaksoon Vantaalle
Toimitustapa: Nouto / Posti / MH
Maksutapa: Käteinen, Mobilepay
JsKK
