Myyty Kingston KC3000 2048 Gt M.2 SSD -kovalevy (Lahti)
XFi
Tuote: Kingston KC3000 2048 Gt M.2 SSD
Hinta: 120 €
Tuote ostettu (mistä ja milloin): 11/23 Verkkokauppa.com
Kuitti löytyy (takuu voimassa): Kyllä / takuuta jäljellä ~51 kk
Äskettäin puretusta koneesta irroitettu, äärettömän nopea kiintolevy moneen käyttöön. Alkuperäistä pakkausta ei tallella.
Koodi:
smartctl --all /dev/sdf
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.79-Unraid] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       KINGSTON SKC3000D2048G
Serial Number:                      50026B7686801581
Firmware Version:                   EIFK31.6
PCI Vendor/Subsystem ID:            0x2646
IEEE OUI Identifier:                0x0026b7
Total NVM Capacity:                 2,048,408,248,320 [2.04 TB]
Unallocated NVM Capacity:           0
Controller ID:                      1
NVMe Version:                       1.4
Number of Namespaces:               1
Namespace 1 Size/Capacity:          2,048,408,248,320 [2.04 TB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            0026b7 6868015815
Local Time is:                      Thu Jul 18 13:00:36 2024 EEST
Firmware Updates (0x12):            1 Slot, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x005d):     Comp DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x08):         Telmtry_Lg
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     84 Celsius
Critical Comp. Temp. Threshold:     89 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     8.80W       -        -    0  0  0  0        0       0
 1 +     7.10W       -        -    1  1  1  1        0       0
 2 +     5.20W       -        -    2  2  2  2        0       0
 3 -   0.0620W       -        -    3  3  3  3     2500    7500
 4 -   0.0620W       -        -    4  4  4  4     2500    7500
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         2
 1 -    4096       0         1
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        23 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    0%
Data Units Read:                    46,367,424 [23.7 TB]
Data Units Written:                 13,706,684 [7.01 TB]
Host Read Commands:                 438,329,881
Host Write Commands:                190,030,061
Controller Busy Time:               601
Power Cycles:                       6
Power On Hours:                     2,038
Unsafe Shutdowns:                   3
Media and Data Integrity Errors:    0
Error Information Log Entries:      34
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 2:               59 Celsius
Warning: NVMe Get Log truncated to 0x200 bytes, 0x200 bytes zero filled
Error Information (NVMe Log 0x01, 16 of 63 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS  Message
  0         34     0  0x000e  0x4004      -            0     0     -  Invalid Field in Command
  1         33     0  0x000d  0x4004      -            0     0     -  Invalid Field in Command
Warning: NVMe Get Log truncated to 0x200 bytes, 0x034 bytes zero filled
Self-test Log (NVMe Log 0x06)
Self-test status: No self-test in progress
No Self-tests Logged
Paikkakunta (ilmoita myös otsikossa ja tagissa): Lahti
Toimitustapa: Nouto / postitus
Maksutapa: MobilePay / Siirto-maksu / tilisiirto (OP)
Kuva:
Oranta
