Myydään Kingston a400 480GB - Espoo
Tuote: Kingston A400 480GB 2.5" SATA SSD
Hinta: 20 euros
Tuote ostettu (mistä ja milloin):datatronic, 10.6.2024
Kuitti löytyy (takuu voimassa):yes/yes (3years warranty).
The drive was replaced before under warranty.
Used as part of zfs pool but suddenly stopped working. It passes smart tests so cannot make a warranty claim. It should still work for normal PC usage though. (I will overwrite all data with zeroes before handing over the drive).
Paikkakunta (ilmoita myös otsikossa ja tagissa):Espoo
Toimitustapa: Pick up
Maksutapa
:cash, bank, mobilepay
Koodi:
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.13-amd64] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Phison Driven SSDs
Device Model:     KINGSTON SA400S37480G
Serial Number:    50026B7382D9ACB8
LU WWN Device Id: 5 0026b7 382d9acb8
Firmware Version: SHFK60.1
User Capacity:    480,103,981,056 bytes [480 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
TRIM Command:     Available
Device is:        In smartctl database 7.3/5610
ATA Version is:   ACS-3 T13/2161-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Aug 14 20:09:30 2025 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x02)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (    0) seconds.
capabilities:              (0x11) SMART execute Offline immediate.
                    No Auto Offline data collection support.
                    Suspend Offline collection upon new
                    command.
                    No Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    No Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x00)    Error logging NOT supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      (   3) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     -O--CK   100   100   000    -    0
  9 Power_On_Hours          -O--CK   100   100   000    -    9109
 12 Power_Cycle_Count       -O--CK   100   100   000    -    34
148 Unknown_Attribute       ------   100   100   000    -    0
149 Unknown_Attribute       ------   100   100   000    -    0
167 Write_Protect_Mode      ------   100   100   000    -    0
168 SATA_Phy_Error_Count    -O--C-   100   100   000    -    0
169 Bad_Block_Rate          ------   100   100   000    -    5
170 Bad_Blk_Ct_Lat/Erl      ------   100   100   010    -    0/7
172 Erase_Fail_Count        -O--CK   100   100   000    -    0
173 MaxAvgErase_Ct          ------   100   100   000    -    112 (Average 73)
181 Program_Fail_Count      -O--CK   100   100   000    -    0
182 Erase_Fail_Count        ------   100   100   000    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
192 Unsafe_Shutdown_Count   -O--C-   100   100   000    -    16
194 Temperature_Celsius     -O---K   036   045   000    -    36 (Min/Max 25/45)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
199 SATA_CRC_Error_Count    -O--CK   100   100   000    -    131202
218 CRC_Error_Count         -O--CK   100   100   000    -    5
231 SSD_Life_Left           ------   092   092   000    -    92
233 Flash_Writes_GiB        -O--CK   100   100   000    -    75388
241 Lifetime_Writes_GiB     -O--CK   100   100   000    -    9262
242 Lifetime_Reads_GiB      -O--CK   100   100   000    -    6714
244 Average_Erase_Count     ------   100   100   000    -    73
245 Max_Erase_Count         ------   100   100   000    -    112
246 Total_Erase_Count       ------   100   100   000    -    57558
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
ATA_READ_LOG_EXT (addr=0x00:0x00, page=0, n=1) failed: 48-bit ATA commands require SAT ATA PASS-THROUGH (16)
Read GP Log Directory failed
SMART Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00           SL  R/O      1  Log Directory
0x04           SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x30           SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f      SL  R/W     16  Host vendor specific log
SMART Extended Comprehensive Error Log (GP Log 0x03) not supported
SMART Error Log not supported
SMART Extended Self-test Log (GP Log 0x07) not supported
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%      9108         -
# 2  Short offline       Completed without error       00%      9108         -
# 3  Short offline       Completed without error       00%      9108         -
# 4  Short offline       Aborted by host               00%      9107         -
# 5  Short offline       Completed without error       00%      9083         -
# 6  Short offline       Completed without error       00%      9059         -
# 7  Extended offline    Completed without error       00%      9035         -
# 8  Short offline       Completed without error       00%      9011         -
# 9  Short offline       Completed without error       00%      8987         -
#10  Short offline       Completed without error       00%      8963         -
#11  Short offline       Completed without error       00%      8939         -
#12  Short offline       Completed without error       00%      8914         -
#13  Short offline       Completed without error       00%      8890         -
#14  Extended offline    Completed without error       00%      8866         -
#15  Short offline       Completed without error       00%      8842         -
#16  Short offline       Completed without error       00%      8818         -
#17  Short offline       Completed without error       00%      8794         -
#18  Short offline       Completed without error       00%      8770         -
#19  Short offline       Completed without error       00%      8746         -
#20  Short offline       Completed without error       00%      8722         -
#21  Extended offline    Completed without error       00%      8697         -
Selective Self-tests/Logging not supported
SCT Commands not supported
Device Statistics (SMART Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 3) ==
0x01  0x008  4              34  ---  Lifetime Power-On Resets
0x01  0x010  4            9109  ---  Power-on Hours
0x01  0x018  6     19424269568  ---  Logical Sectors Written
0x01  0x028  6     14081150483  ---  Logical Sectors Read
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              53  ---  Current Temperature
0x05  0x020  1              62  ---  Highest Temperature
0x05  0x028  1              42  ---  Lowest Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x018  4               5  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               8  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
ATA_READ_LOG_EXT (addr=0x11:0x00, page=0, n=1) failed: 48-bit ATA commands require SAT ATA PASS-THROUGH (16)
Read SATA Phy Event Counters failed
AllanT
