Kerro pahin mokasi töissä
blurris
BANNATTU
BANNED
Itsehän en ole koskaan mokannut. Töissä ainakaan. Olenko ollut oikein töissäkään, niin tiedä sitäkään.
Mutta lainaan stooria Amerikasta ja koska ollaan ATK-foorumilla, niin laitan developperistoorin. Juuri Uliopistosta valmistunut nuori koodari tekaisee Elämänsä Kämmit™ heti ekana työpäivänään.
Firman tuotantotietokanta sileeksi ekana työpäivänä kun skriptaa itelleen ympäristöä pystyyn. (joo, tiedetään, onhan se vähän outo firma jos ei varmistuksia ja suoranaisia estojakin ole tuollaiselle operaatiolle, mutta jätetään se nyt sivuseikaksi)
Today was my first day on the job as a Junior Software Developer and was my first non-internship position after university. Unfortunately i screwed up badly.
I was basically given a document detailing how to setup my local development environment. Which involves run a small script to create my own personal DB instance from some test data. After running the command i was supposed to copy the database url/password/username outputted by the command and configure my dev environment to point to that database. Unfortunately instead of copying the values outputted by the tool, i instead for whatever reason used the values the document had.
Unfortunately apparently those values were actually for the production database (why they are documented in the dev setup guide i have no idea). Then from my understanding that the tests add fake data, and clear existing data between test runs which basically cleared all the data from the production database. Honestly i had no idea what i did and it wasn't about 30 or so minutes after did someone actually figure out/realize what i did.
While what i had done was sinking in. The CTO told me to leave and never come back. He also informed me that apparently legal would need to get involved due to severity of the data loss. I basically offered and pleaded to let me help in someway to redeem my self and i was told that i "completely fucked everything up".
So i left. I kept an eye on slack, and from what i can tell the backups were not restoring and it seemed like the entire dev team was on full on panic mode. I sent a slack message to our CTO explaining my screw up. Only to have my slack account immediately disabled not long after sending the message.
I haven't heard from HR, or anything and i am panicking to high heavens. I just moved across the country for this job, is there anything i can even remotely do to redeem my self in this situation? Can i possibly be sued for this? Should i contact HR directly? I am really confused, and terrified.
EDIT Just to make it even more embarrassing, i just realized that i took the laptop i was issued home with me (i have no idea why i did this at all).
EDIT 2 I just woke up, after deciding to drown my sorrows and i am shocked by the number of responses, well wishes and other things. Will do my best to sort through everything.
Työharjoittelussa joskus kymmenen vuotta sitten ymmärsin hieman väärin ohjeistusta, ja aiheutin kiinteistöalan firmalle viidentonnin vahingot. Ei sitä tyhmänä 9 e/pv harjoittelijana ihan kaikkea sentään osaa :))
Jos tuo tapaus ei ole keksitty, niin kyllähän tuossa on ollut katastrofi odottamassa tapahtumista. Harmi, että sattui aloittavan työntekijän kohdalle.
Joskus pudotin vainajan keskellä sairaalan pihaa paareilta :rolleyes:
Muuten varmaan pahimmat ollu mallia kunnon "vittusaatanan" karjuminen ilman että tajuaa potilaan/omaisen/pomon olevan seläntakana.
Joskus unohdin yhen mummon myös tunniksi vessaan istumaa yksikseen (ei päässy ite liikkeelle).
Rakennusmittaushommissa Vuosaaren satamassa. Vesisade alkaa samaan aikaan kuin ruokatauko, joten heitän sadetakin mittauslaitteen päälle kun lähdetään. Oikeasti olisi pitänyt käyttää erityistä suojahuppua, mutta en tiennyt tätä, koska olin harjoittelijana ja kokenut työparini hyväksyi sadetakin.
Kun tultiin ruokatunnilta takaisin, kone oli tuhannen paskana betonin päällä. Tuuli oli ilmeisesti tarttunut sadetakkiin ja nykäissyt koneen nurin.
Kymmenien tuhansien markkojen arvoinen vahinko.
Reilu työparini tottakai syytti minua täysin vahingosta ja uhkaili että koko vahinko maksetaan minun palkastani. Hänen esimiehensä puolestaan ehdotti että tehdään vakuutuspetos, ei puhuta vahingosta mitään, vaan väitetään että mittalaitteen jalkojen lukitus oli pettänyt sateen takia.
Asia hoidettiin väärin, mutta koska olin harjoittelija, enkä vielä tiennyt yksityisten firmojen juonista mitään, olin vain iloinen että en joutunut itse maksamaan vahinkoa.
Vainajan pudotus. Lähes.
Vittusaatana huonossa paikassa. Done.
Mummo unohtunu vessaan. Done.
Lääkemokia jokunen, ne kaikki onneksi merkityksettömiä.
Rahallisesti? Tuli alkuaikoina työnnettyä liikkeelle 43kg paketti joka kerkes vantaan terminaaliin asti ennen ulkomaille lähtöä noin viikko pari sen jälkeen kun olin kysellyt voisko meille hommata vaa'an jotta sais tehtyä mahd. painavat paketit ja säästettyä toimituskuluissa. Pistivät paketin takaisin meille, pilkottiin puoliksi ja uudestaan reissuun, tuskin montaa hunttia kustansi.
Vieläkään ei ole sitä vitun vaakaa.
Firman maineellisesti? Huusin työkaverille vitun kovaa "Hei Erkki (nimi muutettu), ookko ikinä ostanu semmosia kortsuja mikkä luistaa iha vitusti?" samalla ku vilkaisen kameraan ja huomaan naisasiakkaan aulassa linnuntietä noin 2 metrin päässä minusta. Välissä oli särmi/hylly mutta eipä se mitään estä.
Ilme kertoi aikalailla kaiken.
Ei nyt sinällään mikään moka, vaan nolo tilanne.
Aikoinaan olin ruokakaupassa kesätöissä ja itse kauppias antoi tehtäväksi vaatehyllyjen purkamisen, kun vaateosasto oli menossa remonttiin. Olivat sellaisia metalliputkista väsättyjä, aivan helvetin tiukassa jumissa eikä niitä saanut käsivoimin mitenkään eroteltua. No, kauppias käski käydä varaston jäbältä kysymässä jotain ainetta helpottamaan tilannetta.
Tajusin, että jotain pitäisi saada, millä putket rupeaa luistamaan taasen, mutta en vain millään saanut päähäni sitä sanaa, mitä minun pitäisi pyytää varastolta. Aika kerkesi tulla vastaan ja kun varastopäällikön toimistoon kävelin, niin pyysin tältä liukuvoidetta -- abstraktilla tasollahan tuo nyt aika läheltä liippaa, muttei se ihan nappiin mennyt kuitenkaan. Voiteluöljy olisi siis ollut se oikea termi. Kyllähän se naureskeli ja kuittaili asiasta useampaan otteeseen.
Amiksen työharjoittelussa 90-luvulla tankkasin asiakaskäynnin yhteydessä ATK-firman pakuun dieselin sijasta bensaa. Toinen työntekijä pääsi synkälle metsätaipaleelle asti sillä ennenkuin moottori kosahti, ei ollut tyytyväinen. Meni amiksen vakuutuksen piikkiin. Oli kyllä vanha ja huonokuntoinen paku jo valmiiksi, seliseli.
Jonku 10-20k€ arvoisen piirilevyn käräytin ekassa alan kesätyöpaikassa. Sittemmin ala on vaihtunut softan puolelle. :)
Joskus nuorena kossina parikymmentä vuotta takaperin, tuli melkein poltettua koko vitun työpaikka.
Etanolipesukone jolla pestiin painokoneen painosylintereitä. Ei mikään ihan pieni laite ja täynnä etanolia.
Minä siitä sitten täyttämään Zippoa etanolilla täydennysletkusta ja tottahan se piti sitten testata että sytkä toimii. No se perkeleen etanoli, helposti höyrystyvänä aineena lemahti ihan kunnolla aina pesukoneen letkua pitkin koneen nurkille asti.
Sammutin vitun äkkiä kouraan ja suihk suihk.
Eipä siinä, pomon kysellessä tilanteesta saattoi olla että pesukone sai "kipinän jostain". :rolleyes:
En saanu edes varoitusta vaikka paskapuheeni loisti naapurikuntaan saakka.
Muutamia vuosia sitten kun vielä ajoin kuorma-autoa työkseni kävi seuraavanlainen tapahtuma..
Olin viemässä eräälle asiakkaalle kotitoimituksena erään Ison ketjun keittiökaluste lähetystä. Oli siis sovittu asiakkaan kanssa ajankohta koska vien tavaran perille. Mentiin apupoika-anteron kanssa pelipaikoille odottelemaan ja aateltiin siinä että "revitään" lavat jo valmiiks lähelle auton perälautaa ja tietysti pieneen mäkeen kun se auto jäi niin joutui kaksinverroin repimään niitä lavoja kahteen mieheenkin. Siinä hikipisaroiden lentäessä tuli sitten letkautettua apupojalle että "kukahan p**keleen köyhä tämmöstä *askaa ostaa kun pienellä lisäsijoituksella sais huomattavasti laadukkaampia kalusteita".. No siinä kun pienet naurunhörähdykset töräytettiin ja satuin katsomaan perälaudan suuntaan niin tavaran vastaanottaja seiso perälaudan vieressä ja ihmetteli meidän puuhastelua.
2 sekunttia oli silleen "kuuliko se???" :vihellys: Siinä revittiin sit sen kummempia ihmettelemättä kamat ulos autosta ja sovittuun paikkaan jättö, nimet rahtikirjaan ja pois. Joutu muutamat naurut ottaa ku lähdettiin pihasta :rofl::rofl:. Ei tuosta mitään perästä päin koskaan kuulunut... :nb:
..erään Ison ketjun keittiökaluste lähetystä...
Itseasiassa nuo ikean kaapit ei ole ollenkaan niin paskoja, kuin saattaisi olettaa.
Lisäksi niitä pystyy muuttamaan/laajentamaan jne. myös jälkikäteen helposti, kun käy vain marketista kipasemassa tarvittavat lisäkalusteet/sisusteet.
Edit: eli kun vaimo 2 vuoden välein haluaa eriväriset kaapit, niin käy hakemassa uudet ovet ja tunnin-parin homma ja keittiö taas "uusi".
Noo mielipiteitä ja asentajia on monia. :tup:
Joskus annoin väärää raportointidataa (tai sinänsä oikeaa, mutta väärä tunnusluku siihen tarpeeseen), jonka seurauksena sitten firma laskutti noin miljoona eur liian vähän. No, ei siitä mitään traagista tullut kun asia huomattiin talousosastolla ja hoidettiin hyvityksillä/uusilla laskuilla kuntoon, mutta saattoi siinä ehkä jonkin aikaa naama punottaa :think:
Joskus kesäduunissa myös sain jotain hommia joista olin aivan totaalisen pihalla enkä uskaltanut kysyä, tein varmaan (jälkeenpäin ajatellen) jotain muutoksia tuotannon erppiin ja jännitin sitten seuraavat viikot että tuleeko huutoa jostain. (ei tullut)
Joku 15 vuotta sitten vedin tasaiseksi tuotantokannan. Onneksi oli pikku firmamme oma jossa oli vain intran dataa, mutta kyllä vitutti.
Edit: phrasing
Kesätöissä sain firman palvelimen nurin, kun vahingossa rinnakkaistin omat simulaatiot vaikka piti laskea peräkkäin. En ollut siis Linuxia käyttänyt hirveästi ja tein niin kuin ohjeistettiin kyseenalaistamatta ohjeita. Kirjauduin vielä ulos enkä päässyt kirjautumaan takaisin. Joku kävi sitten sammuttamassa palvelimen manuaalisesti. Kai siellä meni jotkut pari viikkoa pyörineet simuloinnit.
Ei jumalauta:rofl::rofl::rofl:
Olin tiskin takana ja lähdössä jonnekin siitä, sanoin työkaverille että noi on yhen neekerin kamat tossa tiskillä... sitä ennen se neeperi lähti hakemaan vielä jotain, ja selän kun käänsi niin toinen, tällä kertaa kaapuakka olikin ilmestynyt siihen kuin tyhjästä. Sen ilme oli: :jd:... siitä sitten poistuin paikalta:vihellys:
Oli toinenkin hieman rasistinen juttu, joka päätyi suoli24/kaupunki saakka, siitä tuli jo sanomista muttei sen kummempaa.
Firman vanhaan hiaceen lisäisin öljyä. Unohtui laittaa se korkki kiinni, jossain kohtaa alkoi ihmetyttää kun öljy haisee aika vahvasti. Öljyt pitkin konehuonetta ja mittatikku ei näyttänyt mitään. Ihme ettei hajonnut.
Ei tuon pahempia, varmaan on muutakin jos alkaa muistelemaan.
Tästä on jo kymmenisen vuotta aikaa, mutta olin kerrankin eka työpaikalla ja aattelin että keitämpä koko porukalle kahvit.
No keittimenä mikäs muu kuin kuningas moccamaster. Kun sain homman tulille lähin tekee töitä ja kun tulin takas oli kaikki kahvit pitkin pöytiä ja lattiaa failanneen tippalukon takia.
En tiedä mikä pahin mutta 20 tuhannen litran pesualtaan täyttöhana unohtui vuorokaudeksi päälle, tuloksena hallin lattia lainehti vedellä.
Raksalla katkaistiin maakaasuputki kaivinkoneella tuloksena työmaa suljettiin , kaupungin kaasumiehet/palokunta jouduttiin tilaamaan hätiin.
Joskus suviuunona olin pyörittämässä lämminvesivaraajien hitsausrobottia. Robotin edessä oli pyörivä pöytä johon laitettiin hitsattavat osat ja sen jälkeen pyöräytettiin pöytää 180 astetta niin että jo hitsattu osa tuli ulkopuolelle ja hitsattavaksi menevä osa meni robotin koppiin. No kerran sitten ajatuksissani laitoin vain osan osista paikalleen ja käänsin pöydän. Robotti tietty tyytyväisenä hitsas osat kiinni pöytään. Pari ukkoa siinä joutu tekemään puoli päivää hommia että saatiin kone toimimaan.
Toinen mieleen muistuva tapahtui nykyisellä työnantajalla. Olin noin 6 henkilön kouluttajana ja koulutusviikon aikana päätimme lähteä korjaamaan yhtä vikaa jossain noin sadan kilometrin päässä. Paikalle kun päästiin niin vika löytyi ja ryhdyttiin hommiin. Joku 5 h siinä varmaan laitettiin hommaa kasaan kunnes huomasin että otin sitten pussillisen vääriä kaapeleita mukaan. "onneksi" vanha järjestelmä oli jo särki niin ei ainakaan huononnettu tilannetta mutta aavistuksen nolotti. Seuraavalla viikolla sitten yksin laittamaan homma kuntoon.
Oikeissa töissähän en ole vielä ollu mutta on tuolla "työharjoittelussa" joskus tapahtunu. Ekassa hommassa eli elektroniikan purkajana purettii kaiken maailman paskaa ja meikälle yks päivä sattu painepesuri eteen. Noh siinä sitten vähän ajan päästä lainelehti pöytä öljystä tai jostakin nesteestä :D Onneksi ei ollu kuitenkaan iso homma saada pöytää puhtaaksi, omatuntoa lieventämään jollakin toisellakin tapahtui sama homma.
Oli ihan repäisevää porata (ihan keskelle) 6 mm kivirterällä laattaseinään (ulkoseinä, mulkkailtu joskaan ei tarkastettu materiaalitutkalla tjsp) 28 mm kupariputkeen reikä. Oli uima-altaan täyttöputki. Vettä tuli ihan mukavasti, lensi tosin suoraan sinne altaaseen ettei lattiaa päästy uusimaan.
Lusmuilevan firman vuoksi vakuutusyhtiö soitteli pitkään ja hartaasti. Firman herrat olivat kertoneet minun hoitavan asian kuntoon. Kerroin tarinan useampaan kertaan, aina kysymyksellä mikä se sinun asemasi nyt yrityksessä oikein olikaan...
Taloon saatiin vesi päälle tuhoamalla pari kaakelia ja juottamalla paikka kupariputkeen. Seinästä ne tappelivat pitkään ja hartaasti. Huhu kertoi isännän suostuneen eri laatoista (kasaria isoa Italialaista, huonekalukeisarin vanha torppa) tehtyyn korjaukseen joka jäikin IV-koneen ja kaapiston taakse. Emäntä oli sisustussuunnittelijan kanssa ideoinut koko allas/sauna/peseytymistilan (n. 20 neliötä) uusiksi.
Lopputulema jäi kuulematta. Samassa firmassa työkaveri sai ok-talossa eristehötön palamaan kahden betoniseinän välissä. Jäi se ilppi asentamatta kun palokunta repäisi seinän alas...
Turisen aamulle työpaikalla pomon kanssa niitä näitä.
Kanssaduunari huomauttaa jotain roikkuvan housujeni lahkeissa.
Vedä lahkeesta pitkät kalsarit, jotka olivat jääneet housunlahkeisiin edellisenä päivänä kun olin kotiinlähtiessä ilmeisesti riisunut kaikki housut kerralla. En ollut aamulla tätä sitten tajunnut. Lisätään vielä, että kyseessä oli elintarvikkeita valmistava yritys.
Pomon alkuun hämmentynyt ilme ja sitä seurannut räkänauru ovat jääneet elävästi mieleen.
Ei nyt ihan varsinainen moka, mutta kuitenkin mieleenpainunut tilanne. Olin kuitenkin kunnostautunut työpaikan pellenä jo usean vuoden ajan joten en edes osannut nolostua.
Salaatinkastikepurkki tipahti, kun olin kaupassa hyllyjä täyttämässä työharjoittelussa. :sori:
Savage, mutta pistän paremmaksi:
Kaupan hyllyttäjänä viilsin vahingossa talkkunajauhopussin rikki, enkä kertonut kellekään, vaan pistin sen muiden pussien taakse.:smoke:
Ite oon kaupassa duunissa (ollu jo pitkään). Kelle tahansa sattuu joskus vahinkoja kun kuormia pitää kuitenkin purkaa monta kertaa viikossa ja sitä tavaraa on paljon. Mutta pahin mitä oon nähny oli kun meillä oli joskus pari just amiksessa alottanutta poikaa harjottelussa parin kuukauden ajan ja niiden jäljiltä löyty varmaan vielä kuukauden päästäkin halki viillettyjä kahvipaketteja. Eipä ne muutenkaan paljoa välittäny tavaroista kun mentaliteetti oli että "ei nää meidän oo niin ei haittaa". En ymmärrä miks kauppias anto niiden olla niinkin kauan tekemässä tuhojaan.
Vedytin jotain biohajoavan polymeerin esiastetta palladium hiilellä. Vittumainen aine joka osaa hehkua itsekseen kerran käynnistyttyään, ja se sytyttää aivan kaiken mikä yleensä voi syttyä. Talsin illalla reaktorille, ja sattumoisin siinä ei tapahtunut juuri sillä hetkellä mitään, ei ollut lämmitys päällä ja varoitusvalot eivät palaneet sillä hetkellä. Aloitin purkamisen ottamalla irti lämpötilaa mittaavan vastuksen ja pistin sen kylmälle kivilattialle. Vähän sellaisen paistilämpömittarin kaltaisen esineen. - Jotain siinä vielä öhräsin muuta ja purin sitten paineastian kannen pultit auki... minä selvisin ulos huoneesta, mutta se huone ei selvinnyt. Reaktorissa oli pari kolme litraa etyyliasetaattia, palladiumhiiltä ja se pahuksen polymeeri, ja sen astian koko sisältö kirjaimellisesti kiehui kun kansi aukesi. Seuraavana yönä tyttökaverin kanssa sitä huonetta sitten siivottiin ja maalattiin ne kaikki seinät uusiksi. Onneksi se paikka muistutti kerrostalon pyöräkellaria jo ihan lähtökohtaisesti. Syksyllä tulee 25 vuotta täyteen hänen kanssaan, ja naimisiinkin ollaan menty. 60 tunnin työviikot muuttuivat vähäksi aikaa 100 tunnin työviikoiksi... se isolla vaivalla tehty polymeeri kun sattumoisin katosi siinä rytäkässä. Professorin kuivakka kommentti oli, ettei näissä hommissa pidä tappaa itseään.
Nuorena opiskelijana Tornion terästehtaalla unohdin laajentaa tuurnan, ja kelasin supussa olevan tuurnan päälle 25 tonnia terästä. Trukilla se piti irrottaa. Tuotantokatko oli noin 20 minuuttia. Laskun määrää ei viitsi edes laskea... parin henkilöauton hinnan verran ehkä meni... tunnollisena sitten kirjoitin tuotantopapereihin oikean syyn ja nimeni siihen perään. Pari isompaa pomoa tuli ihan katsomaan, "kuka täällä on näin yltiörehellinen..." Eivätkä edes moittineet. Taisin olla jo valmiiksi aika nöyrän näköinen. - Syystäkin.
(Polymeerin hukkaamisesta on siis aikaa yli 20 vuotta, ja tuosta tehdas kämmistä noin 30 vuotta.)
90-luvun puolen välin jälkeen olin useamman vuoden elintarvikealan firmassa, missä tuotannossa oli extruden (suulakepuristin) käytössä.
Tuotantotapaa oli muutettu siten, että tuotetta voitiin vaihtaa lennossa ilman koko tuotantolinjan pysäyttämistä ja uudelleen käynnistämistä kuten aiemmin oli tapana. Tuota miten vaihto oikeasti tapahtuisi ei oltu kirjoittaneelle avattu kunnolla. Perimmäisenä ajatuksena oli, että tuotetta ajettaisiin "hukkaan" kyseisen laitteen jälkeen muutama kymmen kiloa ennenkuin uusi tuote lähtisi linjassa eteenpäin. Ensimmäisessä vaihdossa en ajatellut asiaa sen enempää, vaan laitoin tuotteen katkolle ennen kyseistä puristinta ja muutaman kymmenen kilon jälkeen takaisin puristimelle.
Lopputuloksena oli parin vuoron ylimääräinen seisakki, kun puristin oli tukossa. Kyseinen laite jouduttiin purkamaan käytännössä kokonaan, kun tuote oli jämähtänyt kokonaan sisälle. Seuraavana päivänä pomo selitti sitten miten se tuotevaihto oli ajateltu tapahtuvan.
Suulakepuristimen jälkeen oli sykloni-eroitin, jolla tuote siirrettiin alipaineen avulla puristimelta tuotelinjalle. Syklonin alla oli lokeroeroitin, jolla tuote siirrettiin tuotelinjalle eteenpäin vietäväksi. Oli häiriötilanne, jonka takia osa linjasta oli sammutettava, mutta puristin oli toiminnassa koko ajan. Muutaman minuutin jälkeen oli linjasto jälleen käytössä, ja oletin tapahtuman olevan ohitse.
Puolisen tuntia myöhemmin tuli sattumoisin ulkona raaka-ainetta tuonut rekkakuski sisälle ja sanoi, että ulkona satoi "papanaa" eli siis tuotetta jota oli juuri sillä hetkellä tuotannossa. Kävi ilmi, että jostakin syystä syklonin pohjassa ollut lokeroeroitin ei ollutkaan lähtenyt häiriön jälkeen käyntiin kuten muu laitteisto häiriön jälkeen. Sykloni-erotin oli pikku hiljaa täyttynyt ja loppujen lopuksi tuote meni ilman mukana suoraan pihalle huono-onnisen kuskin päälle.
Jälleen oli parin vuoron ylimääräinen seisakki edessä, kun syklonia tyhjennettiin. Vaikeusastetta toi sellainen pikku seikka, että märästä papanasta tuli aikamoista taikinaa ja pikku hiljaa kuivuessaan teki kaikkensa ettei tulisi sieltä syklonista ulos. Pomolle vain:"kuinkas se nyt näin".
Kyseinen firma laittoi tuossa vuosituhannen vaihteessa lapun luukulle, kun tuotanto siirrettiin ulkomaille. Seuraava työpaikka oli suuren kuljetusfirman ulkomaan terminaali, jossa trukilla sompailin autoja tyhjäksi ja täyttelin. ABB:ltä tuli lasti uusia sähkömoottoreita asiakkaalle menossa. Noiden moottoreiden lisäksi sinne piti saada jotakin muutakin, ja se tarkoitti osan lastin purkua. Kuski totesi, että lastatessa oli piikeillä ollut kolme moottoria. Ja pienen yrittämisen jälkeen niille piikeille todellakin mahtui kolme isoa sähkömoottoria. Tosin nipin napia ja sai ajaa kieli keskellä suuta. Kaikki meni siihen saakka hyin, ennenkuin oli aika pysähtyä. Vaikka nopeutta ei ollut juuri lainkaan sai varovasti jarruttaessa huomata, että se kolmas moottori oli liikaa. Pikku hiljaa otti ja kallistui vain tippuakseen piikeiltä betonilattiaan. En tiedä mitä tuollainen moottori painoi, mutta teki lattiaan kunnon jäljet. Kyseinen moottori lähti sitten paluukuormassa takaisin tehtaalle.
Pomo ei kommentoinut asiaa lainkaan.
Tekevälle sattuu. Onha noita töppäilyitä ihan liikaa, mutta ei onneksi vakavia (eli ei musta olisi esim terveydenhoitoon tappamaan potilaita). Olen yksi hajamielinen sählä.
Kaikkea perus sähläystä, eli väärä virtalähteen polariteetti ja savu nousee, tai staattinen sähkö tuhoaa kalliin piirin, kun maadoitusranneke nyt sattui unohtumaan.
Kesätöissä kun aikanaan olin, niin jouduttiin (oman) toimiston muuttohommiin. Muutto tapahtui kerrosta ylemmäs ja välissä oli tasan 0 turvallisuusmääräystä täyttävä ikivanha tavarahissi. Just sain talon ainoan ja edelleen toimivan nauhavetoisen tarratulostimen mahtumaan hissiin, oven kiinni ja painoin nappia ylöspäin. Sitä piti pitää koko ajan pohjassa, että hissi liikkuu. No, kuinka ollakkaan kerrosten välissä oli yläkerran betoninen kannattajapalkki, joka ulottui osin siihen hissin oven päälle. Tätä ei kuitenkaan näkynyt alakerrassa seisoessa. Tulostin katosi näkyvistä ja sitten kuului helvetillinen rusahdus. Napista irti ja alaspäin. Tuurilla tulostimen metallirunko oli kestänyt siinä määrin, että koko etupaneeli oli taittunut reilusti kaarelle, mutta itse tulostinrata oli ehjä. Laite toimi käytössä vielä muutaman vuoden käyttöpaneelin ollessa kovasti "ergonomisesti" muotoiltu. Oliskohan ollut tuolloin joku 30-40 kilomarkan arvoinen tekele. Lähinnä siksi, että uusien valmistajia oli hyvin vähän / ei ollenkaan. Pomo nauroi vedet silmissä mun ilmeelle kun menin kertomaan tapahtuneesta. Tällöin en vielä tiennyt laitteen jääneen ehjäksi.
Ei itselleni tapahtunut, mutta nykyisessä työpaikassa. Työkaveri oli aikoinaan aidon hämmästynyt, kun 1000kg:n tavarahissi ei jaksanut nostaa 1.kerroksesta 4. kerrokseen kahta 1000kg:n konttia. Olisihan sen pitänyt jaksaa, koska sinne hissiin mahtui kaksi konttia ja mies. Palokunta kävi päästämässä miehen pois hissistä. Oli hieman hieman nolona, varsinkin kun oli vielä etukäteen naureskeltu, että näin tulee käymään...
Yli vuosikymmen sitten ajoin trukilla varaston seinästä läpi laboratorioon kotimaisessa lääkealan yrityksessä. Vahingot olivat mittavat, mutta tätähän varten on sitten vakuutukset... kaikki labran vehkeet meni uusiksi - koska kontaminaatio. Trukille ei käynyt mitenkään.
Lasitavaraa on ikävä kanniskella käsin. Isolla rullakolla saa huomattavasti nopeammin kiireessä hoidettua hommat. Paitsi kun kiire kostautuu ja nakkaat rullakon kynnyksen yli huomaten että oviaukko olikin väärällä puolella ja kitka ei auta pitämään tavaraa paikallaan. Lopputuloksena liiketila juuri täyttymässä asiakkaista ja lattialla tasaisesti viiden sentin kerros lasimurskaa.
No lasi on halpaa, mutta eräällä työmaalla tavaroiden varastointiin on tuet pihamaalla. Tosin epähuomiossa kun tuet laittaa väärinpäin se prässätty pellinkulma uppoaa kesäkuumalla mustaan muoviputkeen kuin kuuma veitsi voihin.
No eihän siinä halpaahan muoviputki on. Paitsi kun halkaisija metrin ja paksuus kymmeniäsenttejä paino tonneja.
No katkaisu ja paikkaus niinhän se hoituu.
No ei hoidu kun putket menossa ydinvoimalatyömaalle ja hyväksynnät/laskelmien tarkkuus sen mukaisia.
Takkiin tuli kymmenistätuhansista satoihintuhansiin.
On sitä sitten onnistuttu työntämään trukin piikit kaukokiidon lämpöeristetystä peräkärristä lävitse ja muuta kivaa. Rapatessa roiskuu.
Nuorempana kun olin työharjoittelussa ammattikoulun aikoihin eräällä kodinkonefirmalla ruttasin asiakastoimituksen yhteydessä pakettiauton näppärästi asiakkaan autotallin kulmaan. Talliin taisi tulla pieni kolhu ja pakusta lasi paskaksi. Ei kuitenkaan kovin suuri mälli mut hävetti niin pirusti. Muistelisin että ajokortti taisi olla ollut taskussa reilu kuukauden verran silloin, että pystyi vähän kokemattomuuden piikkiin laskemaan tuon.
Sellainen pieni moka, kuin väärä konffi sähkömittariin jolloin isosta kiinteistöstä mitattiin sähköä 500MWh/a ja todellinen kulutus oli 1GWh/a. Ei siinä mitään, tuollainen kulutus näkyy jo häviöissäkin, joten vika löytyi. Laskuttaahan tuossa piti 1.5v taaksepäin, mutta rahallista tappiota tuossa ei tullut.
Ihan ekassa palkkaduunissa jakeluautolla lähdin aamulla tallista ulos, käänsin hiukan liian aikaisin ja liian paljon rattia joten kopin takareuna vetäsi pomon talvisäilössä olleen 635CSI:n etulokarin kasaan. Pikanttina yksityiskohtana edeltäjäni oli tehnyt saman muutamaa kuukautta aikaisemmin. Vakuutusyhtiössä tykättiin. Sen jälkeen auton talvisäilytyspaikka vaihtui.
Tämä taas sattui työkaverille: tietsikkaliikkeessä huollon puolella vaihteeksi työkaverilla (~35v) työkalut häviksissä, joten kaikki paikat käännettyään kaveri avasi oven ja huikkasi kassalla istuville myyjille (~20v) "ootteko tytöt nähny mun meisseliä?"... sillä meni muutama tupakka ennenkuin pokka kesti palata liikkeen puolelle.
2000-luvun alussa isossa vielä silloin kotimaisessa IT-firmassa päivitettiin tiketöintijärjestelmä. No, päivityksessä oli bugi joka aiheutti sen että poistamalla vastaanottajan s-postiosoitteen ja tallentamalla tiketin, tiketti lähtikin kaikille tietokannassa oleville s-postiosoitteille. Joku parisenkymmentätuhatta viestiä se ehti puskea ulos ennenkuin napattiin linjoilta. Ei rahallista haittaa eikä periaatteessa mun moka, mutta...
Leipäkuskina kesätöissä ollessa yhdellä lastauslaiturilla tuli vähän kiire kun kadulle alkoi kertyä kuorma-autojen jono. Lastauslaiturilla hommissa olleet varastomiehet stressasi ja hoputti, että äkkiä kamat ulos autosta ja pois laiturilta, että muut pääsee purkamaan.
Kuorma tyhjeni sen paikan osalta mukavasti ja kaasutin kiireesti pois paikalta. Seuraavasta risteyksestä kun lähti kiihdyttämään, niin puolikas lava leipää ja se lavanosturi (en muista sanaa) tippui ryminällä tielle. Oli jäänyt nosturi laskematta ala-asentoon ja nostolava oli jäänyt auki. Onneksi oli suht hiljainen paikka, mutta kyllä hävetti.
EDIT: Pari virhettä korjattu.
Yksi loppusyksy/alkutalvi työpaikan varastohalliin oli asennettu uusi nosto-ovi. Talven ja kovien pakkasten tullen koitti sitten huoltopäivä (n. 3kk välein isompi huolto) ja minä lähdin hakemaan trukilla huoltotarvikkeita varastosta, mutta en ajatellut että hallin edusta oli erittäin liukas, niin kappas, trukki ei edes yrittänyt pysähtyä ennen varastonovea, joten trukin piikit painui oven läpi ja painoi oven osittain sisään. Hieman nolotti, kun ovi oli about 3kk vanha.:facepalm: Onneksi selvittiin muutaman elementin ja kiskojen vaihdolla, laskusta ei tietoa. Onhan sitä muutakin pientä sattunut, mutta tuo oli ehkä se noloin.:tdown:
Melkein sama kävi itelle, kun olin autokaupassa juoksupoikana nuorempana. Siinä oli semmonen vastaanotto/kassatiski, jossa oli samat nuori(25) ja vanha(55) nainen aina koko päivän istumassa. Tiskin takana oli kaikenlaista roinaa ja tarvikkeita, niin menin sitten ajattelematta sanomaan 'Ootteko nähnyt meisseliä?' niin se vanhempi nainen siihen jotain sanoi, että 'En ihan hetkeen, mutta nuorempana niitä tuli nähtyä kyllä paljonkin'. Minä ja tämä nuorempi nainen sitten aika punasena siinä. Tuli kyllä myöhemmin itse näytettyä tälle nuoremmalle.
Pahimmat mokatkin tuli kyllä tehtyä tuolla autoalalla. Peruutin semmoseen esittelyhallin kylttiin, joka kaatui toisen auton päälle ja molempiin tuli jäljet. Kerran käänsin kuormalavan yli ja rengas puhki. Peruutin jonkun lojuvan pakoputken päälle ja puskuriin jäljet. Joskus myös ajoin sladissa liikenneympyrän ympäri liikkeelle tulleessa ja sitten perässä tullut auto parkkeerasi viereen ja oli joku esimiehen esimiehen esimies.
Särmääjänä tuli joskus isojakin sarjoja taiteltua vituilleen ja ehtivät asiakkaille astikkin, no uutta vaan tilalle :vihellys: Muutamia tuhansia hukkaan ja metallia kierrätykseen :tup:
Sähkärin hommia tehdes vedin ristikytkimelle 4x1,5 kaapelin vaikka piti laittaa 5x1.5, pomon luvalla kevistä tehtii virtajohto. Edelleen käytössä eräässä liiketilassa nimeltämainitsemattomassa paikassa :think:
Kauan kauan sitten asiakas tohkeissaan esitteli heidän sähkärinsä jo valmiiksi johdottamaa automaatiopakettia.
Kaikki oli vedetty samalla ruskealla 1,5mm2 sähköjohdolla - 12v, data, anturit, ohjaukset... Ei tuo mitään, toimisihan tuo niillä kuitenkin.
Silmä heitti kuitenkin sen verran, etten huomannut että käyttövirtajohdot oli vedetty 230V/12V muuntajan ohitse suoraan paketille.
Asiakkaan sähkäri painaa silmät loistaen päävirtakytkimen päälle...
Automaatiopaketista kuuluu mukava poksahdus kun komponentit siirtyvät kiertoradalle. Sitten odotetaan vajaa viikko kun DHL toimittaa uuden keskusyksikön mantereen toiselle puolelle. Itse yksikkö oli vain tonni ja risat, mutta odottelu ja uudelleenasennus (ja johdotuksen vaihtaminen nomakiksi ihan vain koska sillä se olisi pitänyt alunperin mennä) oli muutama tonni kuluja lisää.
Ja tottakai syy oli sen, joka k.o. virityksen jetlagisena oli mennyt hyväksymään...
Onneksi on isommilta/kalliilta mokilta säästynyt mutta pari juttua tuli mieleen
Kerran noin 10 vuotta sitten olimme työkaverin kanssa purkamassa radiolinkkijännettä. Oli talvi ja viikko alkoi olla lopuilla joten mieli teki jo kotia niin päätimme hoitaa homman nopeasti. Koska kyseessä oli 0,6m halkaisiajaltaan oleva pieni peili joka menisi romuksu emme alkanee kasailemaan vinssiä vaan kipusin maston nokkaan (oli jossain 70m korkeudessa, yllättävän korkealla linkiksi) ja suunnitelma oli ottaa radio "perseeseen" ja tuoda mukanaan alas kun se meni kiertoon ja viskata itse peili hallitusti maahan (ja ei, tämä ei ole se suositeltu tapa toimia), Noh siinä jään ja lumen keskellä hanskat kädessä sährätessä kävi niin että kun jouduin avaamaan peilin asennusraudan pultit kokonaan kun rauta oli nipin napin mastoon käyvä niin yksi isoista pulteista pääsi tipahtamaan. EI siinä mitään, ei ollut ensimmäinen kerta kun jotain pientä tippuu vahingossa mutta eiköhän se tällä kertaa löytänyt itsensä 50m alempana olevan 1,2m linkkipeilin kaulukseen ja rutisti kauluksen peilin sisään. Siinä sitten alas tullessa paukutin tuota kaulusta takaisin entiseen muotoonsa ja kaivoin pultin peilin sisältä. jätimme asian "kyllä se varmaan vielä toimii" "jäät särkeneet" mielellä noin emmekä maininneet asiasta kellekkään.
Toinen oli kerran kun asensimme työkaverin kanssa 48v DC voimalaitetta ja akustoa räkkikaappiin. Kyseessä siis 19" teline avonaisilla sivuilla. Akusto (n. 4X100Ah)tuli kaapin alaosaan. Kun tuo oli saatu asennettua huomasimme että voimalaitteeseen kytkettävä kaapeli joka oli jo aikaisemmin vedetty tilaan oli jäänyt räkin alle liskuun. Kehitettiin sunnitelma että minä kallistan kaappia varovasti eteenpäin niin kaveri vetää kaapelin pois alta. Noh, kallistaessa akusto liukui sen verran eteenpäin että molemmin puolin akustoa olevien akustokaapelien eristämättömät kengät sattuivat juuri kohdilleen osuakseen räkkikiskoihin aiheuttaen oikosulun. Kipinöinnin ja savun keskellä melkein tuli löysät housuun ja savun hälvettyä reunimmaisten akkujen navat olivat piloilla. Ei muuta kuin akut vaihtoon.
Viking Linellä tai jollain muulla rahtiakin kuljettavalla laivafirmalla on trukkikuskeilla miljoonakerho, johon pääsee sisään kun aiheuttaa vähintään miljoonalla eurolla vahinkoa. Kallein moka on paperikoneen telan tiputtaneella kuskilla. Vahingon seurauksena paperikone Saksassa joutui seisomaan tyhjänpanttina jonkin aikaa ja vastuuvakuutuksesta kuulemma korvattiin yli 24 miljoonaa euroa.
Larnuji
